nRF9160 DK Connecting problems with nRF Cloud
Hello, I tried to set up my nRF9160 with this tutorial and there is a problem:
https://www.youtube.com/watch?v=jZQcmU3KIMY&t=216s
According to the tutorial, LED 3 and the LED 4 should be blinking after 3 minutes, what means that the board is connected to the nRF Cloud.
However on my nRF9160, the LED 4  never starts blinking, even if I wait 10 minutes longer than required.
I tried to push the reset button a few times, I turned the nRF9160 on and off a few times and I also started the "Add LTE Device" on nRF Cloud a few times.
But LED 4 still remains dark.
There were 2 things different compared to the tutorial video:
1) The Sim Card Registration worked fine, but when I came to the window in the picture below, I had an IMEI, but I found no PIN. So, I tried the option without a pin (Red mark in the picture).
Maybe I need a PIN, but where do I get it? I tried to insert every possible number I found on my nRF9160, but none of them worked.
I have already installed the latest firmware update for the nRF9160 successfully. So what did I do wrong? Or how can I finally connect the nRF9160 to the nRF Cloud?
- Thanks for your answers
- Bergmann
  • New thread created: https://devzone.nordicsemi.com/f/nordic-q-a/53152/cloud_connect-failed--111
    There you can also read that I've re-tested without static IP, and then DNS lookup fails.
  • Hi, I updated the certificate successfully:
    On the last step, where you must delete the device from the nrf cloud, it said:
    But my nrf never got connected to the cloud anyway, so I might ignore this error message.
    Then I flashed the nrf with the asset_tracker again and I updated the host IP address to the prj.conf, but there is error -111 again:
    2019-10-13T07:19:15.953Z INFO Application data folder: C:\Users\Benjamin Bergmann\AppData\Roaming\nrfconnect\pc-nrfconnect-linkmonitor
    2019-10-13T07:19:16.026Z DEBUG App pc-nrfconnect-linkmonitor v1.1.1 official
    2019-10-13T07:19:16.026Z DEBUG App path: C:\Users\Benjamin Bergmann\.nrfconnect-apps\node_modules\pc-nrfconnect-linkmonitor
    2019-10-13T07:19:16.026Z DEBUG nRFConnect 3.2.0 is supported by the app (^3.2.0)
    2019-10-13T07:19:16.026Z DEBUG nRFConnect path: C:\Users\Benjamin Bergmann\AppData\Local\Programs\nrfconnect\resources\app.asar
    2019-10-13T07:19:16.026Z DEBUG HomeDir: C:\Users\Benjamin Bergmann
    2019-10-13T07:19:16.026Z DEBUG TmpDir: C:\Users\BENJAM~1\AppData\Local\Temp
    2019-10-13T07:19:18.909Z INFO Modem port is opened
    2019-10-13T07:19:18.915Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2019-10-13T07:19:18.933Z DEBUG modem << +CFUN: 1\x0D\x0A
    2019-10-13T07:19:18.936Z DEBUG modem << OK\x0D
    2019-10-13T07:19:18.950Z DEBUG modem >> AT+CGSN=1\x0D\x0A
    2019-10-13T07:19:18.964Z DEBUG modem << +CGSN: "352656100037459"\x0D\x0A
    2019-10-13T07:19:18.965Z DEBUG modem << OK\x0D\x0A
    2019-10-13T07:19:18.971Z DEBUG modem >> AT+CGMI\x0D\x0A
    2019-10-13T07:19:18.987Z DEBUG modem << Nordic Semiconductor ASA\x0D\x0A
    2019-10-13T07:19:18.988Z DEBUG modem << OK\x0D\x0A
    2019-10-13T07:19:18.991Z DEBUG modem >> AT+CGMM\x0D\x0A
    2019-10-13T07:19:19.007Z DEBUG modem << nRF9160-SICA\x0D\x0A
    2019-10-13T07:19:19.008Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:19.011Z DEBUG modem >> AT+CGMR\x0D\x0A
    2019-10-13T07:19:19.025Z DEBUG modem << mfw_nrf9160_1.0.1\x0D\x0A
    2019-10-13T07:19:19.026Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:19.027Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.0.1] SerNr: 352656100037459
    2019-10-13T07:19:19.028Z DEBUG modem >> AT+CEMODE?\x0D\x0A
    2019-10-13T07:19:19.041Z DEBUG modem << +CEMODE: 0\x0D\x0A
    2019-10-13T07:19:19.043Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:19.050Z DEBUG modem >> AT%XCBAND=?\x0D\x0A
    2019-10-13T07:19:19.064Z DEBUG modem << %XCBAND: (1,3,5,8)\x0D\x0A
    2019-10-13T07:19:19.066Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:19.074Z DEBUG modem >> AT+CMEE?\x0D\x0A
    2019-10-13T07:19:19.087Z DEBUG modem << +CMEE: 0\x0D\x0A
    2019-10-13T07:19:19.088Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:19.091Z DEBUG modem >> AT+CMEE=1\x0D\x0A
    2019-10-13T07:19:19.104Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:19.107Z DEBUG modem >> AT+CNEC?\x0D\x0A
    2019-10-13T07:19:19.121Z DEBUG modem << +CNEC: 0\x0D\x0A
    2019-10-13T07:19:19.123Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:19.126Z DEBUG modem >> AT+CNEC=24\x0D\x0A
    2019-10-13T07:19:19.138Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:19.141Z DEBUG modem >> AT+CGEREP?\x0D\x0A
    2019-10-13T07:19:19.154Z DEBUG modem << +CGEREP: 0,0\x0D\x0A
    2019-10-13T07:19:19.155Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:19.158Z DEBUG modem >> AT+CGDCONT?\x0D\x0A
    2019-10-13T07:19:19.170Z DEBUG modem << OK\x0D
    2019-10-13T07:19:19.173Z DEBUG modem >> AT+CGACT?\x0D\x0A
    2019-10-13T07:19:19.187Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:19.190Z DEBUG modem >> AT+CGEREP=1\x0D\x0A
    2019-10-13T07:19:19.203Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:19.207Z DEBUG modem >> AT+CIND=1,1,1\x0D\x0A
    2019-10-13T07:19:19.221Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:19.224Z DEBUG modem >> AT+CEREG=2\x0D\x0A
    2019-10-13T07:19:19.237Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:19.240Z DEBUG modem >> AT+CEREG?\x0D\x0A
    2019-10-13T07:19:19.256Z DEBUG modem << +CEREG: 2,4,"FFFE","FFFFFFFF",9\x0D\x0A
    2019-10-13T07:19:19.257Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:19.261Z DEBUG modem >> AT%CESQ=1\x0D\x0A
    2019-10-13T07:19:19.273Z DEBUG modem << OK\x0D
    2019-10-13T07:19:19.277Z DEBUG modem >> AT+CESQ\x0D\x0A
    2019-10-13T07:19:19.291Z DEBUG modem << +CESQ: 99,99,255,255,255,255\x0D
    2019-10-13T07:19:19.292Z DEBUG modem << \x0A
    2019-10-13T07:19:19.293Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:19.296Z DEBUG modem >> AT%XSIM=1\x0D\x0A
    2019-10-13T07:19:19.308Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:19.311Z DEBUG modem >> AT%XSIM?\x0D\x0A
    2019-10-13T07:19:19.323Z DEBUG modem << %XSIM: 1\x0D\x0A
    2019-10-13T07:19:19.325Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:19.330Z DEBUG modem >> AT+CPIN?\x0D\x0A
    2019-10-13T07:19:19.343Z DEBUG modem << +CPIN: READY\x0D\x0A
    2019-10-13T07:19:19.344Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:19.347Z DEBUG modem >> AT+CPINR="SIM PIN"\x0D\x0A
    2019-10-13T07:19:19.369Z DEBUG modem << +CPINR: "SIM PIN",3\x0D\x0A
    2019-10-13T07:19:19.371Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:19.374Z DEBUG modem >> AT+CIMI\x0D\x0A
    2019-10-13T07:19:19.388Z DEBUG modem << 901405710000106\x0D\x0A
    2019-10-13T07:19:19.389Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:19.390Z INFO IMSIdentity: 901405710000106
    2019-10-13T07:19:21.047Z DEBUG modem << [00:00:17.667,510] \x1B[0m<dbg> lte_lc.at_handler: recv: %CESQ: 54,2\x0D\x0A
    2019-10-13T07:19:21.051Z DEBUG modem << \x1B[0m\x0D
    2019-10-13T07:19:21.062Z DEBUG modem << [00:00:17.674,285] \x1B[0m<dbg> lte_lc.at_handler: recv: +CEREG: 2,"3AAC","01375F66",9\x0D\x0A
    2019-10-13T07:19:21.064Z DEBUG modem << \x1B[0m\x0D\x0A
    2019-10-13T07:19:23.738Z DEBUG modem << [00:00:20.357,879] \x1B[0m<dbg> lte_lc.at_handler: recv: +CGEV: ME PDN ACT 0,0\x0D\x0A
    2019-10-13T07:19:23.741Z DEBUG modem << \x1B[0m\x0D\x0A
    2019-10-13T07:19:23.745Z DEBUG modem << [00:00:20.365,570] \x1B[0m<dbg> lte_lc.at_handler: recv: +CNEC_ESM: 50,0\x0D\x0A
    2019-10-13T07:19:23.747Z DEBUG modem << \x1B[0m\x0D\x0A
    2019-10-13T07:19:23.758Z DEBUG modem << [00:00:20.372,589] \x1B[0m<dbg> lte_lc.at_handler: recv: +CEREG: 5,"3AAC","01375F66",9\x0D\x0A
    2019-10-13T07:19:23.760Z DEBUG modem << \x1B[0m\x0D\x0A
    2019-10-13T07:19:23.761Z DEBUG modem << Connected to LTE network\x0D\x0A
    2019-10-13T07:19:23.764Z DEBUG modem << [00:00:20.383,300] \x1B[0m<dbg> nrf_cloud_transport.nct_connect: IPv4 Address 3.83.211.27\x1B[0m\x0D\x0A
    2019-10-13T07:19:27.121Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2019-10-13T07:19:27.126Z DEBUG modem << +CFUN: 1\x0D\x0A
    2019-10-13T07:19:27.131Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:27.132Z DEBUG modem >> AT+CGSN=1\x0D\x0A
    2019-10-13T07:19:27.139Z DEBUG modem << +CGSN: "352656100037459"\x0D\x0A
    2019-10-13T07:19:27.140Z DEBUG modem << OK\x0D
    2019-10-13T07:19:27.144Z DEBUG modem >> AT+CGMI\x0D\x0A
    2019-10-13T07:19:27.151Z DEBUG modem << Nordic Semiconductor ASA\x0D\x0A
    2019-10-13T07:19:27.152Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:27.156Z DEBUG modem >> AT+CGMM\x0D\x0A
    2019-10-13T07:19:27.161Z DEBUG modem << nRF9160-SICA\x0D\x0A
    2019-10-13T07:19:27.162Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:27.164Z DEBUG modem >> AT+CGMR\x0D\x0A
    2019-10-13T07:19:27.168Z DEBUG modem << mfw_nrf9160_1.0.1\x0D\x0A
    2019-10-13T07:19:27.173Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:27.173Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.0.1] SerNr: 352656100037459
    2019-10-13T07:19:27.176Z DEBUG modem >> AT+CEMODE?\x0D\x0A
    2019-10-13T07:19:27.180Z DEBUG modem << +CEMODE: 0\x0D\x0A
    2019-10-13T07:19:27.181Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:27.188Z DEBUG modem >> AT%XCBAND=?\x0D\x0A
    2019-10-13T07:19:27.193Z DEBUG modem << %XCBAND: (1,3,5,8)\x0D\x0A
    2019-10-13T07:19:27.194Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:27.198Z DEBUG modem >> AT+CMEE?\x0D\x0A
    2019-10-13T07:19:27.205Z DEBUG modem << +CMEE: 1\x0D\x0A
    2019-10-13T07:19:27.206Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:27.209Z DEBUG modem >> AT+CNEC?\x0D\x0A
    2019-10-13T07:19:27.214Z DEBUG modem << +CNEC: 24\x0D\x0A
    2019-10-13T07:19:27.215Z DEBUG modem << OK\x0D
    2019-10-13T07:19:27.218Z DEBUG modem >> AT+CGEREP?\x0D\x0A
    2019-10-13T07:19:27.223Z DEBUG modem << +CGEREP: 1,0\x0D\x0A
    2019-10-13T07:19:27.224Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:27.226Z DEBUG modem >> AT+CIND=1,1,1\x0D\x0A
    2019-10-13T07:19:27.230Z DEBUG modem << OK\x0D\x0A
    2019-10-13T07:19:27.232Z DEBUG modem >> AT+CEREG=2\x0D\x0A
    2019-10-13T07:19:27.235Z DEBUG modem << OK\x0D\x0A
    2019-10-13T07:19:27.239Z DEBUG modem >> AT+CEREG?\x0D\x0A
    2019-10-13T07:19:27.246Z DEBUG modem << +CEREG: 2,5,"3AAC","01375F66",9\x0D\x0A
    2019-10-13T07:19:27.247Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:27.250Z DEBUG modem >> AT+COPS=3,2\x0D\x0A
    2019-10-13T07:19:27.256Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:27.260Z DEBUG modem >> AT+COPS?\x0D\x0A
    2019-10-13T07:19:27.265Z DEBUG modem << +COPS: 0,2,"23203",9\x0D\x0A
    2019-10-13T07:19:27.266Z DEBUG modem << OK\x0D
    2019-10-13T07:19:27.274Z DEBUG modem >> AT%XCBAND\x0D\x0A
    2019-10-13T07:19:27.278Z DEBUG modem << %XCBAND: 8\x0D
    2019-10-13T07:19:27.280Z DEBUG modem << \x0A
    2019-10-13T07:19:27.280Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:27.284Z DEBUG modem >> AT+CGDCONT?\x0D\x0A
    2019-10-13T07:19:27.292Z DEBUG modem << +CGDCONT: 0,"IP","alliot.nbiot.at","10.8.0.78",0,0\x0D\x0A
    2019-10-13T07:19:27.293Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:27.297Z DEBUG modem >> AT+CGACT?\x0D\x0A
    2019-10-13T07:19:27.302Z DEBUG modem << +CGACT: 0,1\x0D
    2019-10-13T07:19:27.308Z DEBUG modem << \x0A
    2019-10-13T07:19:27.309Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:27.313Z DEBUG modem >> AT%CESQ=1\x0D\x0A
    2019-10-13T07:19:27.317Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:27.319Z DEBUG modem >> AT+CESQ\x0D\x0A
    2019-10-13T07:19:27.325Z DEBUG modem << +CESQ: 99,99,255,255,255,54\x0D\x0A
    2019-10-13T07:19:27.326Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:27.330Z DEBUG modem >> AT%XSIM=1\x0D\x0A
    2019-10-13T07:19:27.334Z DEBUG modem << OK\x0D\x0A
    2019-10-13T07:19:27.339Z DEBUG modem >> AT%XSIM?\x0D\x0A
    2019-10-13T07:19:27.343Z DEBUG modem << %XSIM: 1\x0D\x0A
    2019-10-13T07:19:27.344Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:27.348Z DEBUG modem >> AT+CPIN?\x0D\x0A
    2019-10-13T07:19:27.353Z DEBUG modem << +CPIN: READY\x0D\x0A
    2019-10-13T07:19:27.353Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:27.359Z DEBUG modem >> AT+CPINR="SIM PIN"\x0D\x0A
    2019-10-13T07:19:27.372Z DEBUG modem << +CPINR: "SIM PIN",3\x0D\x0A
    2019-10-13T07:19:27.373Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:27.378Z DEBUG modem >> AT+CIMI\x0D\x0A
    2019-10-13T07:19:27.383Z DEBUG modem << 901405710000106\x0D\x0A
    2019-10-13T07:19:27.383Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-13T07:19:27.383Z INFO IMSIdentity: 901405710000106
    2019-10-13T07:19:41.021Z DEBUG modem << cloud_connect failed: -111\x0D\x0A
    2019-10-13T07:19:41.029Z DEBUG modem << LTE link disconnect\x0D\x0A
    2019-10-13T07:19:42.953Z DEBUG modem << Shutdown modem\x0D\x0A
    2019-10-13T07:19:42.965Z DEBUG modem << ***** Booting Zephyr OS build v1.14.99-ncs3-snapshot2-2647-gd6e67554cfeb *****\x0D\x0A
    2019-10-13T07:19:42.968Z DEBUG modem << Flash region\x09\x09Domain\x09\x09Permissions\x0D\x0A
    2019-10-13T07:19:42.976Z DEBUG modem << 00 0x00000 0x08000 \x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-13T07:19:42.977Z DEBUG modem << 01 0x08000 0x10000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:42.979Z DEBUG modem << 02 0x10000 0x18000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:42.981Z DEBUG modem << 03 0x18000 0x20000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:42.984Z DEBUG modem << 04 0x20000 0x28000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:42.991Z DEBUG modem << 05 0x28000 0x30000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:42.992Z DEBUG modem << 06 0x30000 0x38000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:42.995Z DEBUG modem << 07 0x38000 0x40000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:42.998Z DEBUG modem << 08 0x40000 0x48000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.002Z DEBUG modem << 09 0x48000 0x50000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.008Z DEBUG modem << 10 0x50000 0x58000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.009Z DEBUG modem << 11 0x58000 0x60000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.012Z DEBUG modem << 12 0x60000 0x68000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.014Z DEBUG modem << 13 0x68000 0x70000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.017Z DEBUG modem << 14 0x70000 0x78000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.026Z DEBUG modem << 15 0x78000 0x80000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.027Z DEBUG modem << 16 0x80000 0x88000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.029Z DEBUG modem << 17 0x88000 0x90000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.030Z DEBUG modem << 18 0x90000 0x98000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.033Z DEBUG modem << 19 0x98000 0xa0000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.041Z DEBUG modem << 20 0xa0000 0xa8000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.043Z DEBUG modem << 21 0xa8000 0xb0000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.044Z DEBUG modem << 22 0xb0000 0xb8000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.046Z DEBUG modem << 23 0xb8000 0xc0000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.050Z DEBUG modem << 24 0xc0000 0xc8000 \x09Non-Secure\x09rwxl\x0D
    2019-10-13T07:19:43.058Z DEBUG modem << 25 0xc8000 0xd0000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.060Z DEBUG modem << 26 0xd0000 0xd8000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.061Z DEBUG modem << 27 0xd8000 0xe0000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.063Z DEBUG modem << 28 0xe0000 0xe8000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.066Z DEBUG modem << 29 0xe8000 0xf0000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.069Z DEBUG modem << 30 0xf0000 0xf8000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.076Z DEBUG modem << 31 0xf8000 0x100000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.079Z DEBUG modem << Non-secure callable region 0 placed in flash region 0 with size 32.\x0D
    2019-10-13T07:19:43.252Z DEBUG modem << SRAM region\x09\x09Domain\x09\x09Permissions\x0D\x0A
    2019-10-13T07:19:43.271Z DEBUG modem << 00 0x00000 0x02000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.274Z DEBUG modem << 01 0x02000 0x04000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.277Z DEBUG modem << 02 0x04000 0x06000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.279Z DEBUG modem << 03 0x06000 0x08000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.280Z DEBUG modem << 04 0x08000 0x0a000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.281Z DEBUG modem << 05 0x0a000 0x0c000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.282Z DEBUG modem << 06 0x0c000 0x0e000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.283Z DEBUG modem << 07 0x0e000 0x10000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.284Z DEBUG modem << 08 0x10000 0x12000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.285Z DEBUG modem << 09 0x12000 0x14000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.286Z DEBUG modem << 10 0x14000 0x16000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.295Z DEBUG modem << 11 0x16000 0x18000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.296Z DEBUG modem << 12 0x18000 0x1a000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.297Z DEBUG modem << 13 0x1a000 0x1c000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.298Z DEBUG modem << 14 0x1c000 0x1e000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.299Z DEBUG modem << 15 0x1e000 0x20000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.302Z DEBUG modem << 16 0x20000 0x22000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.309Z DEBUG modem << 17 0x22000 0x24000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.310Z DEBUG modem << 18 0x24000 0x26000\x09Non-Secure\x09rwxl\x0D
    2019-10-13T07:19:43.312Z DEBUG modem << 19 0x26000 0x28000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.315Z DEBUG modem << 20 0x28000 0x2a000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.318Z DEBUG modem << 21 0x2a000 0x2c000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.326Z DEBUG modem << 22 0x2c000 0x2e000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.327Z DEBUG modem << 23 0x2e000 0x30000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.329Z DEBUG modem << 24 0x30000 0x32000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.331Z DEBUG modem << 25 0x32000 0x34000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.334Z DEBUG modem << 26 0x34000 0x36000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.342Z DEBUG modem << 27 0x36000 0x38000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.343Z DEBUG modem << 28 0x38000 0x3a000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.344Z DEBUG modem << 29 0x3a000 0x3c000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.347Z DEBUG modem << 30 0x3c000 0x3e000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:19:43.350Z DEBUG modem << 31 0x3e000 0x40000\x09Non-Secure\x09rwxl\x0D\x0A\x0D\x0A
    2019-10-13T07:19:43.352Z DEBUG modem << Peripheral\x09\x09Domain\x09\x09Status\x0D
    2019-10-13T07:19:43.360Z DEBUG modem << 00 NRF_P0               Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:19:43.360Z DEBUG modem << 01 NRF_CLOCK            Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:19:43.363Z DEBUG modem << 02 NRF_RTC1             Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:19:43.366Z DEBUG modem << 03 NRF_NVMC             Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:19:43.369Z DEBUG modem << 04 NRF_UARTE1           Non-Secure\x09OK\x0D
    2019-10-13T07:19:43.376Z DEBUG modem << 05 NRF_UARTE2           Secure\x09\x09SKIP\x0D\x0A
    2019-10-13T07:19:43.377Z DEBUG modem << 06 NRF_TWIM2            Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:19:43.380Z DEBUG modem << 07 NRF_SPIM3            Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:19:43.383Z DEBUG modem << 08 NRF_TIMER0           Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:19:43.392Z DEBUG modem << 09 NRF_TIMER1           Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:19:43.394Z DEBUG modem << 10 NRF_TIMER2           Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:19:43.396Z DEBUG modem << 11 NRF_SAADC            Non-Secure\x09OK\x0D
    2019-10-13T07:19:43.397Z DEBUG modem << 12 NRF_PWM0             Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:19:43.400Z DEBUG modem << 13 NRF_PWM1             Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:19:43.404Z DEBUG modem << 14 NRF_PWM2             Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:19:43.413Z DEBUG modem << 15 NRF_PWM3             Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:19:43.414Z DEBUG modem << 16 NRF_WDT              Secure\x09\x09SKIP\x0D\x0A
    2019-10-13T07:19:43.415Z DEBUG modem << 17 NRF_IPC              Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:19:43.417Z DEBUG modem << 18 NRF_VMC              Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:19:43.426Z DEBUG modem << 19 NRF_FPU              Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:19:43.427Z DEBUG modem << 20 NRF_EGU1             Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:19:43.428Z DEBUG modem << 21 NRF_EGU2             Non-Secure\x09OK\x0D
    2019-10-13T07:19:43.431Z DEBUG modem << 22 NRF_GPIOTE1          Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:19:43.434Z DEBUG modem << 23 NRF_REGULATORS       Secure\x09\x09SKIP\x0D
    2019-10-13T07:19:43.443Z DEBUG modem << SPM: NS image at 0xc000\x0D\x0A
    2019-10-13T07:19:43.444Z DEBUG modem << SPM: NS MSP at 0x2002c568\x0D\x0A
    2019-10-13T07:19:43.445Z DEBUG modem << SPM: NS reset vector at 0x14771\x0D\x0A
    2019-10-13T07:19:43.446Z DEBUG modem << SPM: prepare to jump to Non-Secure image.\x0D\x0A
    2019-10-13T07:19:43.825Z DEBUG modem << ***** Booting Zephyr OS build v1.14.99-ncs3-snapshot2-2647-gd6e67554cfeb *****\x0D\x0A
    2019-10-13T07:19:43.834Z DEBUG modem << [00:00:00.378,631] \x1B[0m<dbg> nrf9160_gps.init: MAGPIO set: AT%XMAGPIO=1,0,0,1,1,1574,1577\x1B[0m\x0D\x0A
    2019-10-13T07:19:43.852Z DEBUG modem << Asset tracker started\x0D\x0A
    2019-10-13T07:19:43.854Z DEBUG modem << [00:00:00.389,739] \x1B[0m<dbg> nrf_cloud_transport.nct_client_id_get: client_id = nrf-352656100037459\x1B[0m\x0D\x0A
    2019-10-13T07:19:43.857Z DEBUG modem << [00:00:00.398,986] \x1B[0m<dbg> nrf_cloud_transport.nct_topics_populate: shadow_base_topic: $aws/things/nrf-352656100037459/shadow\x1B[0m\x0D\x0A
    2019-10-13T07:19:43.869Z DEBUG modem << [00:00:00.410,705] \x1B[0m<dbg> nrf_cloud_transport.nct_topics_populate: accepted_topic: $aws/things/nrf-352656100037459/shadow/get/accepted\x1B[0m\x0D\x0A
    2019-10-13T07:19:43.882Z DEBUG modem << [00:00:00.423,278] \x1B[0m<dbg> nrf_cloud_transport.nct_topics_populate: rejected_topic: $aws/things/nrf-352656100037459/shadow/get/rejected\x1B[0m\x0D\x0A
    2019-10-13T07:19:43.895Z DEBUG modem << [00:00:00.435,852] \x1B[0m<dbg> nrf_cloud_transport.nct_topics_populate: update_delta_topic: $aws/things/nrf-352656100037459/shadow/update/delta\x1B[0m\x0D\x0A
    2019-10-13T07:19:43.910Z DEBUG modem << [00:00:00.448,791] \x1B[0m<dbg> nrf_cloud_transport.nct_topics_populate: update_topic: $aws/things/nrf-352656100037459/shadow/update\x1B[0m\x0D\x0A
    2019-10-13T07:19:43.918Z DEBUG modem << [00:00:00.460,693] \x1B[0m<dbg> nrf_cloud_transport.nct_topics_populate: shadow_get_topic: $aws/things/nrf-352656100037459/shadow/get\x1B[0m\x0D\x0A
    2019-10-13T07:19:43.926Z DEBUG modem << Connecting to LTE network. This may take several minutes.\x0D\x0A
    2019-10-13T07:19:43.931Z DEBUG modem << [00:00:00.478,942] \x1B[0m<inf> lte_lc: Using legacy LTE PCO mode...\x1B[0m\x0D\x0A
    2019-10-13T07:19:43.943Z DEBUG modem << [00:00:00.485,382] \x1B[0m<dbg> lte_lc.w_lte_lc_connect: Network mode: AT%XSYSTEMMODE=0,1,1,0\x1B[0m\x0D\x0A
    2019-10-13T07:20:02.012Z DEBUG modem << [00:00:18.554,779] \x1B[0m<dbg> lte_lc.at_handler: recv: +CEREG: 2,"3AAC","01375F66",9,0,0,"11100000","11100000"\x0D\x0A
    2019-10-13T07:20:02.014Z DEBUG modem << \x1B[0m\x0D\x0A
    2019-10-13T07:20:03.981Z DEBUG modem << [00:00:20.525,207] \x1B[0m<dbg> lte_lc.at_handler: recv: +CEREG: 5,"3AAC","01375F66",9,,,"11100000","01011111"\x0D\x0A
    2019-10-13T07:20:03.994Z DEBUG modem << \x1B[0m\x0D\x0A
    2019-10-13T07:20:03.995Z DEBUG modem << Connected to LTE network\x0D\x0A
    2019-10-13T07:20:03.996Z DEBUG modem << [00:00:20.538,085] \x1B[0m<dbg> nrf_cloud_transport.nct_connect: IPv4 Address 3.83.211.27\x1B[0m\x0D\x0A
    2019-10-13T07:20:21.250Z DEBUG modem << cloud_connect failed: -111\x0D
    2019-10-13T07:20:21.260Z DEBUG modem << LTE link disconnect\x0D\x0A
    2019-10-13T07:20:21.840Z DEBUG modem << Shutdown modem\x0D\x0A
    2019-10-13T07:20:21.852Z DEBUG modem << ***** Booting Zephyr OS build v1.14.99-ncs3-snapshot2-2647-gd6e67554cfeb *****\x0D\x0A
    2019-10-13T07:20:21.855Z DEBUG modem << Flash region\x09\x09Domain\x09\x09Permissions\x0D\x0A
    2019-10-13T07:20:21.863Z DEBUG modem << 00 0x00000 0x08000 \x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-13T07:20:21.864Z DEBUG modem << 01 0x08000 0x10000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:21.866Z DEBUG modem << 02 0x10000 0x18000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:21.868Z DEBUG modem << 03 0x18000 0x20000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:21.871Z DEBUG modem << 04 0x20000 0x28000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:21.874Z DEBUG modem << 05 0x28000 0x30000 \x09Non-Secure\x09rwxl\x0D
    2019-10-13T07:20:21.881Z DEBUG modem << 06 0x30000 0x38000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:21.883Z DEBUG modem << 07 0x38000 0x40000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:21.884Z DEBUG modem << 08 0x40000 0x48000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:21.887Z DEBUG modem << 09 0x48000 0x50000 \x09Non-Secure\x09rwxl\x0D
    2019-10-13T07:20:21.896Z DEBUG modem << 10 0x50000 0x58000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:21.897Z DEBUG modem << 11 0x58000 0x60000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:21.898Z DEBUG modem << 12 0x60000 0x68000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:21.901Z DEBUG modem << 13 0x68000 0x70000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:21.904Z DEBUG modem << 14 0x70000 0x78000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:21.912Z DEBUG modem << 15 0x78000 0x80000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:21.914Z DEBUG modem << 16 0x80000 0x88000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:21.915Z DEBUG modem << 17 0x88000 0x90000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:21.917Z DEBUG modem << 18 0x90000 0x98000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:21.920Z DEBUG modem << 19 0x98000 0xa0000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:21.923Z DEBUG modem << 20 0xa0000 0xa8000 \x09Non-Secure\x09rwxl\x0D
    2019-10-13T07:20:21.931Z DEBUG modem << 21 0xa8000 0xb0000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:21.932Z DEBUG modem << 22 0xb0000 0xb8000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:21.933Z DEBUG modem << 23 0xb8000 0xc0000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:21.936Z DEBUG modem << 24 0xc0000 0xc8000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:21.946Z DEBUG modem << 25 0xc8000 0xd0000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:21.947Z DEBUG modem << 26 0xd0000 0xd8000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:21.948Z DEBUG modem << 27 0xd8000 0xe0000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:21.950Z DEBUG modem << 28 0xe0000 0xe8000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:21.953Z DEBUG modem << 29 0xe8000 0xf0000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:21.956Z DEBUG modem << 30 0xf0000 0xf8000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:21.964Z DEBUG modem << 31 0xf8000 0x100000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:21.966Z DEBUG modem << Non-secure callable region 0 placed in flash region 0 with size 32.\x0D\x0A\x0D\x0A
    2019-10-13T07:20:22.137Z DEBUG modem << SRAM region\x09\x09Domain\x09\x09Permissions\x0D\x0A
    2019-10-13T07:20:22.147Z DEBUG modem << 00 0x00000 0x02000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-13T07:20:22.149Z DEBUG modem << 01 0x02000 0x04000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-13T07:20:22.150Z DEBUG modem << 02 0x04000 0x06000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-13T07:20:22.151Z DEBUG modem << 03 0x06000 0x08000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-13T07:20:22.152Z DEBUG modem << 04 0x08000 0x0a000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-13T07:20:22.154Z DEBUG modem << 05 0x0a000 0x0c000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-13T07:20:22.167Z DEBUG modem << 06 0x0c000 0x0e000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-13T07:20:22.168Z DEBUG modem << 07 0x0e000 0x10000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-13T07:20:22.168Z DEBUG modem << 08 0x10000 0x12000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:22.169Z DEBUG modem << 09 0x12000 0x14000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:22.171Z DEBUG modem << 10 0x14000 0x16000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:22.172Z DEBUG modem << 11 0x16000 0x18000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:22.184Z DEBUG modem << 12 0x18000 0x1a000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:22.185Z DEBUG modem << 13 0x1a000 0x1c000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:22.186Z DEBUG modem << 14 0x1c000 0x1e000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:22.187Z DEBUG modem << 15 0x1e000 0x20000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:22.189Z DEBUG modem << 16 0x20000 0x22000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:22.198Z DEBUG modem << 17 0x22000 0x24000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:22.199Z DEBUG modem << 18 0x24000 0x26000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:22.201Z DEBUG modem << 19 0x26000 0x28000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:22.202Z DEBUG modem << 20 0x28000 0x2a000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:22.204Z DEBUG modem << 21 0x2a000 0x2c000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:22.214Z DEBUG modem << 22 0x2c000 0x2e000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:22.215Z DEBUG modem << 23 0x2e000 0x30000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:22.216Z DEBUG modem << 24 0x30000 0x32000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:22.218Z DEBUG modem << 25 0x32000 0x34000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:22.220Z DEBUG modem << 26 0x34000 0x36000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:22.230Z DEBUG modem << 27 0x36000 0x38000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:22.231Z DEBUG modem << 28 0x38000 0x3a000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:22.232Z DEBUG modem << 29 0x3a000 0x3c000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:22.233Z DEBUG modem << 30 0x3c000 0x3e000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-13T07:20:22.236Z DEBUG modem << 31 0x3e000 0x40000\x09Non-Secure\x09rwxl\x0D\x0A\x0D\x0A
    2019-10-13T07:20:22.238Z DEBUG modem << Peripheral\x09\x09Domain\x09\x09Status\x0D
    2019-10-13T07:20:22.247Z DEBUG modem << 00 NRF_P0               Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:20:22.248Z DEBUG modem << 01 NRF_CLOCK            Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:20:22.249Z DEBUG modem << 02 NRF_RTC1             Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:20:22.252Z DEBUG modem << 03 NRF_NVMC             Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:20:22.256Z DEBUG modem << 04 NRF_UARTE1           Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:20:22.264Z DEBUG modem << 05 NRF_UARTE2           Secure\x09\x09SKIP\x0D\x0A
    2019-10-13T07:20:22.265Z DEBUG modem << 06 NRF_TWIM2            Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:20:22.266Z DEBUG modem << 07 NRF_SPIM3            Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:20:22.269Z DEBUG modem << 08 NRF_TIMER0           Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:20:22.280Z DEBUG modem << 09 NRF_TIMER1           Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:20:22.281Z DEBUG modem << 10 NRF_TIMER2           Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:20:22.282Z DEBUG modem << 11 NRF_SAADC            Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:20:22.283Z DEBUG modem << 12 NRF_PWM0             Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:20:22.287Z DEBUG modem << 13 NRF_PWM1             Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:20:22.297Z DEBUG modem << 14 NRF_PWM2             Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:20:22.299Z DEBUG modem << 15 NRF_PWM3             Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:20:22.300Z DEBUG modem << 16 NRF_WDT              Secure\x09\x09SKIP\x0D\x0A
    2019-10-13T07:20:22.301Z DEBUG modem << 17 NRF_IPC              Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:20:22.303Z DEBUG modem << 18 NRF_VMC              Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:20:22.314Z DEBUG modem << 19 NRF_FPU              Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:20:22.315Z DEBUG modem << 20 NRF_EGU1             Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:20:22.316Z DEBUG modem << 21 NRF_EGU2             Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:20:22.317Z DEBUG modem << 22 NRF_GPIOTE1          Non-Secure\x09OK\x0D\x0A
    2019-10-13T07:20:22.320Z DEBUG modem << 23 NRF_REGULATORS       Secure\x09\x09SKIP\x0D\x0A
    2019-10-13T07:20:22.323Z DEBUG modem << SPM: NS image at 0xc000\x0D\x0A
    2019-10-13T07:20:22.333Z DEBUG modem << SPM: NS MSP at 0x2002c568\x0D\x0A
    2019-10-13T07:20:22.334Z DEBUG modem << SPM: NS reset vector at 0x14771\x0D\x0A
    2019-10-13T07:20:22.334Z DEBUG modem << SPM: prepare to jump to Non-Secure image.\x0D\x0A
    2019-10-13T07:20:24.156Z DEBUG modem << ***** Booting Zephyr OS build v1.14.99-ncs3-snapshot2-2647-gd6e67554cfeb *****\x0D\x0A
    2019-10-13T07:20:24.172Z DEBUG modem << [00:00:01.823,425] \x1B[0m<dbg> nrf9160_gps.init: MAGPIO set: AT%XMAGPIO=1,0,0,1,1,1574,1577\x1B[0m\x0D\x0A
    2019-10-13T07:20:24.173Z DEBUG modem << Asset tracker started\x0D\x0A
    2019-10-13T07:20:24.176Z DEBUG modem << [00:00:01.834,594] \x1B[0m<dbg> nrf_cloud_transport.nct_client_id_get: client_id = nrf-352656100037459\x1B[0m\x0D\x0A
    2019-10-13T07:20:24.188Z DEBUG modem << [00:00:01.843,872] \x1B[0m<dbg> nrf_cloud_transport.nct_topics_populate: shadow_base_topic: $aws/things/nrf-352656100037459/shadow\x1B[0m\x0D\x0A
    2019-10-13T07:20:24.201Z DEBUG modem << [00:00:01.855,590] \x1B[0m<dbg> nrf_cloud_transport.nct_topics_populate: accepted_topic: $aws/things/nrf-352656100037459/shadow/get/accepted\x1B[0m\x0D\x0A
    2019-10-13T07:20:24.214Z DEBUG modem << [00:00:01.868,164] \x1B[0m<dbg> nrf_cloud_transport.nct_topics_populate: rejected_topic: $aws/things/nrf-352656100037459/shadow/get/rejected\x1B[0m\x0D\x0A
    2019-10-13T07:20:24.231Z DEBUG modem << [00:00:01.880,767] \x1B[0m<dbg> nrf_cloud_transport.nct_topics_populate: update_delta_topic: $aws/things/nrf-352656100037459/shadow/update/delta\x1B[0m\x0D\x0A
    2019-10-13T07:20:24.238Z DEBUG modem << [00:00:01.893,707] \x1B[0m<dbg> nrf_cloud_transport.nct_topics_populate: update_topic: $aws/things/nrf-352656100037459/shadow/update\x1B[0m\x0D\x0A
    2019-10-13T07:20:24.250Z DEBUG modem << [00:00:01.905,609] \x1B[0m<dbg> nrf_cloud_transport.nct_topics_populate: shadow_get_topic: $aws/things/nrf-352656100037459/shadow/get\x1B[0m\x0D\x0A
    2019-10-13T07:20:24.256Z DEBUG modem << Connecting to LTE network. This may take several minutes.\x0D\x0A
    2019-10-13T07:20:24.265Z DEBUG modem << [00:00:01.923,889] \x1B[0m<inf> lte_lc: Using legacy LTE PCO mode...\x1B[0m\x0D\x0A
    2019-10-13T07:20:24.271Z DEBUG modem << [00:00:01.930,358] \x1B[0m<dbg> lte_lc.w_lte_lc_connect: Network mode: AT%XSYSTEMMODE=0,1,1,0\x1B[0m\x0D\x0A
    2019-10-13T07:20:27.069Z INFO Modem port is closed
    Do you have any ideas?
    Another question: The goal of my project with the nrf is to send some data from the nrf to a server. Should this be already be possible in this state? So, I could skip the step of getting into the nrf cloud and focus on sending the data to a server.
    Thanks for your help and answers!
  • Hi, did you remember to re-add the device to nRF Cloud before connecting?
    You don't have to be able to connect to nRF Cloud to send data to an external server. But I recommend it, so you are sure there is nothing wrong with your device or the connection.
  • Hi, do you mean like this:
    Now I have to insert the HWID and then it says the device has to be connected to nrf Cloud. I tried this step a couple of times, but every time I get the error message.
    Or do I have to re-add the device somewhere else?
  • You are getting this error because the device isn't connected to nRF Cloud. It has to be connected before you can re-add the device.
    I see from your log you are only waiting three minutes for a connection. On average, this takes much longer. Please wait at least 60 minutes before closing the modem. If it still hasn't connected, please attach the output log again.
