nRF9160 DK Connecting problems with nRF Cloud
Hello, I tried to set up my nRF9160 with this tutorial and there is a problem:
https://www.youtube.com/watch?v=jZQcmU3KIMY&t=216s
According to the tutorial, LED 3 and the LED 4 should be blinking after 3 minutes, what means that the board is connected to the nRF Cloud.
However on my nRF9160, the LED 4  never starts blinking, even if I wait 10 minutes longer than required.
I tried to push the reset button a few times, I turned the nRF9160 on and off a few times and I also started the "Add LTE Device" on nRF Cloud a few times.
But LED 4 still remains dark.
There were 2 things different compared to the tutorial video:
1) The Sim Card Registration worked fine, but when I came to the window in the picture below, I had an IMEI, but I found no PIN. So, I tried the option without a pin (Red mark in the picture).
Maybe I need a PIN, but where do I get it? I tried to insert every possible number I found on my nRF9160, but none of them worked.
I have already installed the latest firmware update for the nRF9160 successfully. So what did I do wrong? Or how can I finally connect the nRF9160 to the nRF Cloud?
- Thanks for your answers
- Bergmann
  • On the website( https://developer.nordicsemi.com/nRF_Connect_SDK/doc/0.3.0/nrf/samples/nrf9160/asset_tracker/README.html#building-and-running) it says, that the asset tracker example would be in
    However, there was no CmakeLists.txt File to Load the project.
    There also are 2 other folders with the name asset_tracker:
    I tried to open the other to projects, but there were error messages:
    2nd Projekt:
    Error: Aborting due to non-whitelisted Kconfig warning 'C:/Nordic/fw-nrfconnect-nrf-
    master/applications/asset_tracker/prj.conf:34: warning: attempt to assign the value 'y' to the
    undefined symbol CLOUD_API'. Note: If this warning doesn't point to an actual problem, you can add
    it to the whitelist at the top of C:/Nordic/ncs/zephyr/scripts/kconfig/kconfig.py.
    CMake Error at C:/Nordic/ncs/zephyr/cmake/kconfig.cmake:194 (message):
    command failed with return code: 1
    C:/Nordic/ncs/zephyr/cmake/app/boilerplate.cmake:500 (include)
    CMakeLists.txt:11 (include)
    Project load failed
    Reported error: solution load command failed (1)
    3rd project:
    Error: Aborting due to non-whitelisted Kconfig warning 'warning: the value '' is invalid for
    FLIP_INPUT (defined at C:/Nordic/ncs/nrf/applications/asset_tracker/Kconfig:116), which has type int
    -- assignment ignored'. Note: If this warning doesn't point to an actual problem, you can add it to
    See also "C:/Nordic/ncs/nrf/applications/asset_tracker/build_nrf9160_pca10090/CMakeFiles/CMakeOutput.log".
    See also "C:/Nordic/ncs/nrf/applications/asset_tracker/build_nrf9160_pca10090/CMakeFiles/CMakeError.log".
    Project load failed
    What should I do?
  • Seems like you have several different branches of the ncs repo locally. In the latest v1.0.0 branch the asset tracker example is located in ncs\nrf\applications\asset_tracker.
    I would recommend to follow step 2 in the Getting Started Assistant again to make sure that you have the correct branch checked out.
    Best regards
    Bjørn
  • Yes, you were right. I reinstalled everything with the correct branches and all worked fine. Thanks for that!
    However, LED 4 still remains dark. I am located in Austria and now I have a SIM Chard from my local provider (Magenta T-Mobile Austria). The code on the SIM Card is to long for the ICCID for the textbox and there is no PUK, so I chose "Already have an active SIM? Skip this step". Is this the right way to do it or do I have enter the SIM Card in another way in the nRF Connect for Cloud?
    I also didn't find a PIN, so I clicked on the "Have an old devkit without a PIN?"
    Can I connect to nRF Cloud with a SIM Card that is not from iBasis?
  • Hi!
    You can connect to nRF Cloud with a SIM Card not from iBasis, on the condition that the SIM card has support for either NB-IoT or LTE-M.
    And you are correct in skipping the first step, and selecting the option without a PIN as the nRF9160 does not have a PIN.
    Heidi
  • Hello I couldn't set up the connection yet (so that LED 4 blinks), but I noticed something:
    In the meantime I got access to a Nordic Thingy91 and I inserted the Sim Card there and the Thingy91 couldn't connect either. So probably the problem has to do with the Sim Card itself. There is another local provider for NB-IoT or LTE-M and I might try it with a SIM Card from them.
    One question more:
    I opened the Thingy91 in the LTE Monitor and I saw that the LTE Panel in the top right was blinking yellow:
    That means, that the Thingy91 is searching an LTE Tower.
    However when I open the nRF9160 in the LTE Monitor, the Searching LTE Panel remains grey, what means that the device is closed:
    Should that be grey or does this mean, that the nRF9160 isn't even trying to search a LTE Tower?
    Thanks for your answers.
