nRF9160 DK Connecting problems with nRF Cloud
Hello, I tried to set up my nRF9160 with this tutorial and there is a problem:
https://www.youtube.com/watch?v=jZQcmU3KIMY&t=216s
According to the tutorial, LED 3 and the LED 4 should be blinking after 3 minutes, what means that the board is connected to the nRF Cloud.
However on my nRF9160, the LED 4  never starts blinking, even if I wait 10 minutes longer than required.
I tried to push the reset button a few times, I turned the nRF9160 on and off a few times and I also started the "Add LTE Device" on nRF Cloud a few times.
But LED 4 still remains dark.
There were 2 things different compared to the tutorial video:
1) The Sim Card Registration worked fine, but when I came to the window in the picture below, I had an IMEI, but I found no PIN. So, I tried the option without a pin (Red mark in the picture).
Maybe I need a PIN, but where do I get it? I tried to insert every possible number I found on my nRF9160, but none of them worked.
I have already installed the latest firmware update for the nRF9160 successfully. So what did I do wrong? Or how can I finally connect the nRF9160 to the nRF Cloud?
- Thanks for your answers
- Bergmann
  • Hi!
    The grey means the nRF9160 can't find a signal. You can also see this from the response to +CEREG and +CESQ.
    +CEREG: 2,4, "FFFE", "FFFFFFFF", 7
    The status value 4 means "Unknown", most likely because the device is out of a coverage area (e.g can't find a signal).
    +CESQ: 99,99,255,255,255,255
    The rsrp value 255 (the last number) indicates the RSRP is either not known or not detectable.
    Try letting it run for up to an hour (sometimes it takes that long) and see if it finds a signal. You can also turn on a periodic signal quality request in LTE Link Monitor to follow the progress, see image below. If the last value changes from 255, you know it has found a signal.
    Let me know if this works!
    Heidi
  • I let the periodic signal run for 2 hours on the nRF9160 and then on the Thingy91 twice, but the CESQ stayed at
    So it has to be the Sim Card that is not working or that is the cause of the problem.
    I have the SIM Card form T-Mobile Austria (Deutsche Telekom) . Maybe I should contact them again about the problem or I should try it with a SIM Card from A1. What do you think? According to the
    https://www.gsma.com/iot/deployment-map/#AT
    map, it would be the second local provider for NB-IoT SIM Cards.
    Thanks for your answers. Slight smile
  • Hi again. Does the SIM card support NB-IoT or LTE-M. Both the Thingy and the DK can only connect to LTE-M out-of-box. For NB-IoT you need to flash a different example.
    Could you try flashing this example, and running
    AT+CFUN=4
    AT%XSYSTEMMODE=0,1,0,0
    AT+CFUN=1
    to enable NB-IoT and see if it finds a signal now?
     nrf91dk_at_client.hex
    Heidi
  • I flashed the nRF9160 with the at_client application with the Segger Embedded Studio Software and then I entered the 3 Command-Lines in the LTE Monitor and after a short amount of time it seems like there is finally a signal (At least there are 2 columns in the signal strength):
    However, it says that on the beginning of the blue text:
    nrf_cloud_connect failed: 22
    Does this mean, that it found an NB-Iot Tower?
    Or does this mean something else?
  • Error 22 means invalid argument but I'm not sure why you're getting it. Could you try running
    AT%XEPCO=0
    Thanks!
