nRF9160 DK Connecting problems with nRF Cloud
Hello, I tried to set up my nRF9160 with this tutorial and there is a problem:
https://www.youtube.com/watch?v=jZQcmU3KIMY&t=216s
According to the tutorial, LED 3 and the LED 4 should be blinking after 3 minutes, what means that the board is connected to the nRF Cloud.
However on my nRF9160, the LED 4  never starts blinking, even if I wait 10 minutes longer than required.
I tried to push the reset button a few times, I turned the nRF9160 on and off a few times and I also started the "Add LTE Device" on nRF Cloud a few times.
But LED 4 still remains dark.
There were 2 things different compared to the tutorial video:
1) The Sim Card Registration worked fine, but when I came to the window in the picture below, I had an IMEI, but I found no PIN. So, I tried the option without a pin (Red mark in the picture).
Maybe I need a PIN, but where do I get it? I tried to insert every possible number I found on my nRF9160, but none of them worked.
I have already installed the latest firmware update for the nRF9160 successfully. So what did I do wrong? Or how can I finally connect the nRF9160 to the nRF Cloud?
- Thanks for your answers
- Bergmann
  • Hi, you need " " around the IP address, so
    CONFIG_NRF_CLOUD_STATIC_IPV4_ADDR="52.87.36.155"
  • Thanks! Now I flashed the program on the nrf and I got
    cloud_connect failed: -111
    2019-10-10T17:09:30.343Z INFO Application data folder: C:\Users\Benjamin Bergmann\AppData\Roaming\nrfconnect\pc-nrfconnect-linkmonitor
    2019-10-10T17:09:30.417Z DEBUG App pc-nrfconnect-linkmonitor v1.1.1 official
    2019-10-10T17:09:30.417Z DEBUG App path: C:\Users\Benjamin Bergmann\.nrfconnect-apps\node_modules\pc-nrfconnect-linkmonitor
    2019-10-10T17:09:30.417Z DEBUG nRFConnect 3.2.0 is supported by the app (^3.2.0)
    2019-10-10T17:09:30.417Z DEBUG nRFConnect path: C:\Users\Benjamin Bergmann\AppData\Local\Programs\nrfconnect\resources\app.asar
    2019-10-10T17:09:30.417Z DEBUG HomeDir: C:\Users\Benjamin Bergmann
    2019-10-10T17:09:30.417Z DEBUG TmpDir: C:\Users\BENJAM~1\AppData\Local\Temp
    2019-10-10T17:09:38.996Z INFO Modem port is opened
    2019-10-10T17:09:39.003Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2019-10-10T17:09:39.009Z DEBUG modem << +CFUN: 1\x0D\x0A
    2019-10-10T17:09:39.011Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:09:39.037Z DEBUG modem >> AT+CGSN=1\x0D\x0A
    2019-10-10T17:09:39.043Z DEBUG modem << +CGSN: "352656100037459"\x0D\x0A
    2019-10-10T17:09:39.044Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:09:39.049Z DEBUG modem >> AT+CGMI\x0D\x0A
    2019-10-10T17:09:39.056Z DEBUG modem << Nordic Semiconductor ASA\x0D\x0A
    2019-10-10T17:09:39.057Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:09:39.060Z DEBUG modem >> AT+CGMM\x0D\x0A
    2019-10-10T17:09:39.070Z DEBUG modem << nRF9160-SICA\x0D\x0A
    2019-10-10T17:09:39.072Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:09:39.075Z DEBUG modem >> AT+CGMR\x0D\x0A
    2019-10-10T17:09:39.083Z DEBUG modem << mfw_nrf9160_1.0.1\x0D\x0A
    2019-10-10T17:09:39.084Z DEBUG modem << OK\x0D
    2019-10-10T17:09:39.086Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.0.1] SerNr: 352656100037459
    2019-10-10T17:09:39.088Z DEBUG modem >> AT+CEMODE?\x0D\x0A
    2019-10-10T17:09:39.093Z DEBUG modem << +CEMODE: 0\x0D\x0A
    2019-10-10T17:09:39.094Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:09:39.104Z DEBUG modem >> AT%XCBAND=?\x0D\x0A
    2019-10-10T17:09:39.113Z DEBUG modem << %XCBAND: (1,3,5,8)\x0D\x0A
    2019-10-10T17:09:39.115Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:09:39.125Z DEBUG modem >> AT+CMEE?\x0D\x0A
    2019-10-10T17:09:39.131Z DEBUG modem << +CMEE: 0\x0D\x0A
    2019-10-10T17:09:39.132Z DEBUG modem << OK\x0D
    2019-10-10T17:09:39.135Z DEBUG modem >> AT+CMEE=1\x0D\x0A
    2019-10-10T17:09:39.139Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:09:39.141Z DEBUG modem >> AT+CNEC?\x0D\x0A
    2019-10-10T17:09:39.149Z DEBUG modem << +CNEC: 0\x0D\x0A
    2019-10-10T17:09:39.151Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:09:39.154Z DEBUG modem >> AT+CNEC=24\x0D\x0A
    2019-10-10T17:09:39.158Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:09:39.161Z DEBUG modem >> AT+CGEREP?\x0D\x0A
    2019-10-10T17:09:39.168Z DEBUG modem << +CGEREP: 0,0\x0D\x0A
    2019-10-10T17:09:39.169Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:09:39.172Z DEBUG modem >> AT+CGDCONT?\x0D\x0A
    2019-10-10T17:09:39.185Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:09:39.189Z DEBUG modem >> AT+CGACT?\x0D\x0A
    2019-10-10T17:09:39.209Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:09:39.213Z DEBUG modem >> AT+CGEREP=1\x0D\x0A
    2019-10-10T17:09:39.225Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:09:39.229Z DEBUG modem >> AT+CIND=1,1,1\x0D\x0A
    2019-10-10T17:09:39.241Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:09:39.244Z DEBUG modem >> AT+CEREG=2\x0D\x0A
    2019-10-10T17:09:39.257Z DEBUG modem << OK\x0D
    2019-10-10T17:09:39.259Z DEBUG modem >> AT+CEREG?\x0D\x0A
    2019-10-10T17:09:39.275Z DEBUG modem << +CEREG: 2,4,"FFFE","FFFFFFFF",9\x0D\x0A
    2019-10-10T17:09:39.276Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:09:39.284Z DEBUG modem >> AT%CESQ=1\x0D\x0A
    2019-10-10T17:09:39.296Z DEBUG modem << OK\x0D
    2019-10-10T17:09:39.301Z DEBUG modem >> AT+CESQ\x0D\x0A
    2019-10-10T17:09:39.317Z DEBUG modem << +CESQ: 99,99,255,255,255,255\x0D\x0A
    2019-10-10T17:09:39.318Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:09:39.323Z DEBUG modem >> AT%XSIM=1\x0D\x0A
    2019-10-10T17:09:39.334Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:09:39.337Z DEBUG modem >> AT%XSIM?\x0D\x0A
    2019-10-10T17:09:39.350Z DEBUG modem << %XSIM: 1\x0D\x0A
    2019-10-10T17:09:39.351Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:09:39.357Z DEBUG modem >> AT+CPIN?\x0D\x0A
    2019-10-10T17:09:39.370Z DEBUG modem << +CPIN: READY\x0D
    2019-10-10T17:09:39.371Z DEBUG modem << \x0A
    2019-10-10T17:09:39.372Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:09:39.377Z DEBUG modem >> AT+CPINR="SIM PIN"\x0D\x0A
    2019-10-10T17:09:39.398Z DEBUG modem << +CPINR: "SIM PIN",3\x0D\x0A
    2019-10-10T17:09:39.399Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:09:39.403Z DEBUG modem >> AT+CIMI\x0D\x0A
    2019-10-10T17:09:39.416Z DEBUG modem << 901405710000106\x0D\x0A
    2019-10-10T17:09:39.417Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:09:39.418Z INFO IMSIdentity: 901405710000106
    2019-10-10T17:09:55.910Z DEBUG modem >> AT+CESQ\x0D\x0A
    2019-10-10T17:09:55.924Z DEBUG modem << +CESQ: 99,99,255,255,255,255\x0D
    2019-10-10T17:09:55.926Z DEBUG modem << \x0A
    2019-10-10T17:09:55.927Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:09:56.911Z DEBUG modem >> AT+CESQ\x0D\x0A
    2019-10-10T17:09:56.927Z DEBUG modem << +CESQ: 99,99,255,255,255,255\x0D\x0A
    2019-10-10T17:09:56.937Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:09:57.262Z DEBUG modem << [00:00:20.707,275] \x1B[0m<dbg> lte_lc.at_handler: recv: %CESQ: 57,2\x0D\x0A
    2019-10-10T17:09:57.272Z DEBUG modem << \x1B[0m\x0D\x0A
    2019-10-10T17:09:57.274Z DEBUG modem << [00:00:20.714,050] \x1B[0m<dbg> lte_lc.at_handler: recv: +CEREG: 2,"3AAC","01375F66",9\x0D\x0A
    2019-10-10T17:09:57.275Z DEBUG modem << \x1B[0m\x0D\x0A
    2019-10-10T17:09:57.909Z DEBUG modem >> AT+CESQ\x0D\x0A
    2019-10-10T17:09:57.919Z DEBUG modem << +CESQ: 99,99,255,255,255,57\x0D\x0A
    2019-10-10T17:09:57.920Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:09:58.909Z DEBUG modem >> AT+CESQ\x0D\x0A
    2019-10-10T17:09:58.918Z DEBUG modem << +CESQ: 99,99,255,255,255,57\x0D\x0A
    2019-10-10T17:09:58.919Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:09:59.248Z DEBUG modem << [00:00:22.692,626] \x1B[0m<dbg> lte_lc.at_handler: recv: +CGEV: ME PDN ACT 0,0\x0D\x0A
    2019-10-10T17:09:59.250Z DEBUG modem << \x1B[0m\x0D\x0A
    2019-10-10T17:09:59.255Z DEBUG modem << [00:00:22.700,286] \x1B[0m<dbg> lte_lc.at_handler: recv: +CNEC_ESM: 50,0\x0D\x0A
    2019-10-10T17:09:59.257Z DEBUG modem << \x1B[0m\x0D\x0A
    2019-10-10T17:09:59.264Z DEBUG modem << [00:00:22.707,305] \x1B[0m<dbg> lte_lc.at_handler: recv: +CEREG: 5,"3AAC","01375F66",9\x0D\x0A
    2019-10-10T17:09:59.265Z DEBUG modem << \x1B[0m\x0D\x0A
    2019-10-10T17:09:59.271Z DEBUG modem << Connected to LTE network\x0D\x0A
    2019-10-10T17:09:59.275Z DEBUG modem << [00:00:22.717,987] \x1B[0m<dbg> nrf_cloud_transport.nct_connect: IPv4 Address 52.206.68.39\x1B[0m\x0D\x0A
    2019-10-10T17:10:10.552Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2019-10-10T17:10:10.556Z DEBUG modem << +CFUN: 1\x0D\x0A
    2019-10-10T17:10:10.560Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:10:10.562Z DEBUG modem >> AT+CGSN=1\x0D\x0A
    2019-10-10T17:10:10.569Z DEBUG modem << +CGSN: "352656100037459"\x0D\x0A
    2019-10-10T17:10:10.570Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:10:10.573Z DEBUG modem >> AT+CGMI\x0D\x0A
    2019-10-10T17:10:10.578Z DEBUG modem << Nordic Semiconductor ASA\x0D\x0A
    2019-10-10T17:10:10.580Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:10:10.582Z DEBUG modem >> AT+CGMM\x0D\x0A
    2019-10-10T17:10:10.590Z DEBUG modem << nRF9160-SICA\x0D\x0A
    2019-10-10T17:10:10.591Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:10:10.593Z DEBUG modem >> AT+CGMR\x0D\x0A
    2019-10-10T17:10:10.598Z DEBUG modem << mfw_nrf9160_1.0.1\x0D\x0A
    2019-10-10T17:10:10.600Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:10:10.601Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.0.1] SerNr: 352656100037459
    2019-10-10T17:10:10.606Z DEBUG modem >> AT+CEMODE?\x0D\x0A
    2019-10-10T17:10:10.610Z DEBUG modem << +CEMODE: 0\x0D\x0A
    2019-10-10T17:10:10.611Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:10:10.614Z DEBUG modem >> AT%XCBAND=?\x0D\x0A
    2019-10-10T17:10:10.621Z DEBUG modem << %XCBAND: (1,3,5,8)\x0D\x0A
    2019-10-10T17:10:10.621Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:10:10.625Z DEBUG modem >> AT+CMEE?\x0D\x0A
    2019-10-10T17:10:10.629Z DEBUG modem << +CMEE: 1\x0D\x0A
    2019-10-10T17:10:10.630Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:10:10.632Z DEBUG modem >> AT+CNEC?\x0D\x0A
    2019-10-10T17:10:10.638Z DEBUG modem << +CNEC: 24\x0D\x0A
    2019-10-10T17:10:10.639Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:10:10.641Z DEBUG modem >> AT+CGEREP?\x0D\x0A
    2019-10-10T17:10:10.646Z DEBUG modem << +CGEREP: 1,0\x0D\x0A
    2019-10-10T17:10:10.647Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:10:10.652Z DEBUG modem >> AT+CIND=1,1,1\x0D\x0A
    2019-10-10T17:10:10.657Z DEBUG modem << OK\x0D
    2019-10-10T17:10:10.660Z DEBUG modem >> AT+CEREG=2\x0D\x0A
    2019-10-10T17:10:10.664Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:10:10.670Z DEBUG modem >> AT+CEREG?\x0D\x0A
    2019-10-10T17:10:10.676Z DEBUG modem << +CEREG: 2,5,"3AAC","01375F66",9\x0D\x0A
    2019-10-10T17:10:10.677Z DEBUG modem << OK\x0D\x0A
    2019-10-10T17:10:10.682Z DEBUG modem >> AT+COPS=3,2\x0D\x0A
    2019-10-10T17:10:10.690Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:10:10.693Z DEBUG modem >> AT+COPS?\x0D\x0A
    2019-10-10T17:10:10.698Z DEBUG modem << +COPS: 0,2,"23203",9\x0D\x0A
    2019-10-10T17:10:10.705Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:10:10.710Z DEBUG modem >> AT%XCBAND\x0D\x0A
    2019-10-10T17:10:10.715Z DEBUG modem << %XCBAND: 8\x0D\x0A
    2019-10-10T17:10:10.716Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:10:10.725Z DEBUG modem >> AT+CGDCONT?\x0D\x0A
    2019-10-10T17:10:10.739Z DEBUG modem << +CGDCONT: 0,"IP","alliot.nbiot.at","10.16.0.226",0,0\x0D\x0A
    2019-10-10T17:10:10.740Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:10:10.746Z DEBUG modem >> AT+CGACT?\x0D\x0A
    2019-10-10T17:10:10.755Z DEBUG modem << +CGACT: 0,1\x0D\x0A
    2019-10-10T17:10:10.756Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:10:10.760Z DEBUG modem >> AT%CESQ=1\x0D\x0A
    2019-10-10T17:10:10.764Z DEBUG modem << OK\x0D\x0A
    2019-10-10T17:10:10.770Z DEBUG modem >> AT+CESQ\x0D\x0A
    2019-10-10T17:10:10.775Z DEBUG modem << +CESQ: 99,99,255,255,255,57\x0D
    2019-10-10T17:10:10.776Z DEBUG modem << \x0A
    2019-10-10T17:10:10.777Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:10:10.781Z DEBUG modem >> AT%XSIM=1\x0D\x0A
    2019-10-10T17:10:10.791Z DEBUG modem << OK\x0D\x0A
    2019-10-10T17:10:10.794Z DEBUG modem >> AT%XSIM?\x0D\x0A
    2019-10-10T17:10:10.798Z DEBUG modem << %XSIM: 1\x0D\x0A
    2019-10-10T17:10:10.799Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:10:10.807Z DEBUG modem >> AT+CPIN?\x0D\x0A
    2019-10-10T17:10:10.812Z DEBUG modem << +CPIN: READY\x0D\x0A
    2019-10-10T17:10:10.814Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:10:10.825Z DEBUG modem >> AT+CPINR="SIM PIN"\x0D\x0A
    2019-10-10T17:10:10.839Z DEBUG modem << +CPINR: "SIM PIN",3\x0D\x0A
    2019-10-10T17:10:10.840Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:10:10.844Z DEBUG modem >> AT+CIMI\x0D\x0A
    2019-10-10T17:10:10.848Z DEBUG modem << 901405710000106\x0D\x0A
    2019-10-10T17:10:10.854Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-10T17:10:10.855Z INFO IMSIdentity: 901405710000106
    2019-10-10T17:10:16.533Z DEBUG modem << cloud_connect failed: -111\x0D\x0A
    2019-10-10T17:10:16.542Z DEBUG modem << LTE link disconnect\x0D\x0A
    2019-10-10T17:10:17.089Z DEBUG modem << Shutdown modem\x0D\x0A
    2019-10-10T17:10:17.103Z DEBUG modem << ***** Booting Zephyr OS build v1.14.99-ncs3-snapshot2-2647-gd6e67554cfeb *****\x0D\x0A
    2019-10-10T17:10:17.106Z DEBUG modem << Flash region\x09\x09Domain\x09\x09Permissions\x0D\x0A
    2019-10-10T17:10:17.108Z DEBUG modem << 00 0x00000 0x08000 \x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.111Z DEBUG modem << 01 0x08000 0x10000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.114Z DEBUG modem << 02 0x10000 0x18000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.122Z DEBUG modem << 03 0x18000 0x20000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.123Z DEBUG modem << 04 0x20000 0x28000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.125Z DEBUG modem << 05 0x28000 0x30000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.127Z DEBUG modem << 06 0x30000 0x38000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.130Z DEBUG modem << 07 0x38000 0x40000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.138Z DEBUG modem << 08 0x40000 0x48000 \x09Non-Secure\x09rwxl\x0D
    2019-10-10T17:10:17.139Z DEBUG modem << 09 0x48000 0x50000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.141Z DEBUG modem << 10 0x50000 0x58000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.142Z DEBUG modem << 11 0x58000 0x60000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.146Z DEBUG modem << 12 0x60000 0x68000 \x09Non-Secure\x09rwxl\x0D
    2019-10-10T17:10:17.154Z DEBUG modem << 13 0x68000 0x70000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.156Z DEBUG modem << 14 0x70000 0x78000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.157Z DEBUG modem << 15 0x78000 0x80000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.159Z DEBUG modem << 16 0x80000 0x88000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.163Z DEBUG modem << 17 0x88000 0x90000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.166Z DEBUG modem << 18 0x90000 0x98000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.173Z DEBUG modem << 19 0x98000 0xa0000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.174Z DEBUG modem << 20 0xa0000 0xa8000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.176Z DEBUG modem << 21 0xa8000 0xb0000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.178Z DEBUG modem << 22 0xb0000 0xb8000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.181Z DEBUG modem << 23 0xb8000 0xc0000 \x09Non-Secure\x09rwxl\x0D
    2019-10-10T17:10:17.190Z DEBUG modem << 24 0xc0000 0xc8000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.192Z DEBUG modem << 25 0xc8000 0xd0000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.193Z DEBUG modem << 26 0xd0000 0xd8000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.195Z DEBUG modem << 27 0xd8000 0xe0000 \x09Non-Secure\x09rwxl\x0D
    2019-10-10T17:10:17.199Z DEBUG modem << 28 0xe0000 0xe8000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.205Z DEBUG modem << 29 0xe8000 0xf0000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.206Z DEBUG modem << 30 0xf0000 0xf8000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.209Z DEBUG modem << 31 0xf8000 0x100000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.214Z DEBUG modem << Non-secure callable region 0 placed in flash region 0 with size 32.\x0D\x0A\x0D\x0A
    2019-10-10T17:10:17.386Z DEBUG modem << SRAM region\x09\x09Domain\x09\x09Permissions\x0D\x0A
    2019-10-10T17:10:17.398Z DEBUG modem << 00 0x00000 0x02000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.399Z DEBUG modem << 01 0x02000 0x04000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.401Z DEBUG modem << 02 0x04000 0x06000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.403Z DEBUG modem << 03 0x06000 0x08000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.404Z DEBUG modem << 04 0x08000 0x0a000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.405Z DEBUG modem << 05 0x0a000 0x0c000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.406Z DEBUG modem << 06 0x0c000 0x0e000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.408Z DEBUG modem << 07 0x0e000 0x10000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.411Z DEBUG modem << 08 0x10000 0x12000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.415Z DEBUG modem << 09 0x12000 0x14000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.424Z DEBUG modem << 10 0x14000 0x16000\x09Non-Secure\x09rwxl\x0D
    2019-10-10T17:10:17.425Z DEBUG modem << 11 0x16000 0x18000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.426Z DEBUG modem << 12 0x18000 0x1a000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.428Z DEBUG modem << 13 0x1a000 0x1c000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.430Z DEBUG modem << 14 0x1c000 0x1e000\x09Non-Secure\x09rwxl\x0D
    2019-10-10T17:10:17.439Z DEBUG modem << 15 0x1e000 0x20000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.441Z DEBUG modem << 16 0x20000 0x22000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.442Z DEBUG modem << 17 0x22000 0x24000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.444Z DEBUG modem << 18 0x24000 0x26000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.446Z DEBUG modem << 19 0x26000 0x28000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.449Z DEBUG modem << 20 0x28000 0x2a000\x09Non-Secure\x09rwxl\x0D
    2019-10-10T17:10:17.457Z DEBUG modem << 21 0x2a000 0x2c000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.458Z DEBUG modem << 22 0x2c000 0x2e000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.459Z DEBUG modem << 23 0x2e000 0x30000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.462Z DEBUG modem << 24 0x30000 0x32000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.465Z DEBUG modem << 25 0x32000 0x34000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.475Z DEBUG modem << 26 0x34000 0x36000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.476Z DEBUG modem << 27 0x36000 0x38000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.477Z DEBUG modem << 28 0x38000 0x3a000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.479Z DEBUG modem << 29 0x3a000 0x3c000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.481Z DEBUG modem << 30 0x3c000 0x3e000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-10T17:10:17.491Z DEBUG modem << 31 0x3e000 0x40000\x09Non-Secure\x09rwxl\x0D\x0A\x0D\x0A
    2019-10-10T17:10:17.492Z DEBUG modem << Peripheral\x09\x09Domain\x09\x09Status\x0D\x0A
    2019-10-10T17:10:17.493Z DEBUG modem << 00 NRF_P0               Non-Secure\x09OK\x0D
    2019-10-10T17:10:17.494Z DEBUG modem << 01 NRF_CLOCK            Non-Secure\x09OK\x0D\x0A
    2019-10-10T17:10:17.497Z DEBUG modem << 02 NRF_RTC1             Non-Secure\x09OK\x0D\x0A
    2019-10-10T17:10:17.507Z DEBUG modem << 03 NRF_NVMC             Non-Secure\x09OK\x0D\x0A
    2019-10-10T17:10:17.508Z DEBUG modem << 04 NRF_UARTE1           Non-Secure\x09OK\x0D\x0A
    2019-10-10T17:10:17.509Z DEBUG modem << 05 NRF_UARTE2           Secure\x09\x09SKIP\x0D
    2019-10-10T17:10:17.511Z DEBUG modem << 06 NRF_TWIM2            Non-Secure\x09OK\x0D\x0A
    2019-10-10T17:10:17.514Z DEBUG modem << 07 NRF_SPIM3            Non-Secure\x09OK\x0D\x0A
    2019-10-10T17:10:17.524Z DEBUG modem << 08 NRF_TIMER0           Non-Secure\x09OK\x0D\x0A
    2019-10-10T17:10:17.525Z DEBUG modem << 09 NRF_TIMER1           Non-Secure\x09OK\x0D\x0A
    2019-10-10T17:10:17.526Z DEBUG modem << 10 NRF_TIMER2           Non-Secure\x09OK\x0D\x0A
    2019-10-10T17:10:17.528Z DEBUG modem << 11 NRF_SAADC            Non-Secure\x09OK\x0D\x0A
    2019-10-10T17:10:17.531Z DEBUG modem << 12 NRF_PWM0             Non-Secure\x09OK\x0D
    2019-10-10T17:10:17.540Z DEBUG modem << 13 NRF_PWM1             Non-Secure\x09OK\x0D\x0A
    2019-10-10T17:10:17.541Z DEBUG modem << 14 NRF_PWM2             Non-Secure\x09OK\x0D\x0A
    2019-10-10T17:10:17.542Z DEBUG modem << 15 NRF_PWM3             Non-Secure\x09OK\x0D\x0A
    2019-10-10T17:10:17.545Z DEBUG modem << 16 NRF_WDT              Secure\x09\x09SKIP\x0D\x0A
    2019-10-10T17:10:17.548Z DEBUG modem << 17 NRF_IPC              Non-Secure\x09OK\x0D
    2019-10-10T17:10:17.556Z DEBUG modem << 18 NRF_VMC              Non-Secure\x09OK\x0D\x0A
    2019-10-10T17:10:17.557Z DEBUG modem << 19 NRF_FPU              Non-Secure\x09OK\x0D\x0A
    2019-10-10T17:10:17.559Z DEBUG modem << 20 NRF_EGU1             Non-Secure\x09OK\x0D
    2019-10-10T17:10:17.562Z DEBUG modem << 21 NRF_EGU2             Non-Secure\x09OK\x0D\x0A
    2019-10-10T17:10:17.565Z DEBUG modem << 22 NRF_GPIOTE1          Non-Secure\x09OK\x0D
    2019-10-10T17:10:17.572Z DEBUG modem << 23 NRF_REGULATORS       Secure\x09\x09SKIP\x0D\x0A\x0D\x0A
    2019-10-10T17:10:17.573Z DEBUG modem << SPM: NS image at 0xc000\x0D\x0A
    2019-10-10T17:10:17.574Z DEBUG modem << SPM: NS MSP at 0x2002c568\x0D\x0A
    2019-10-10T17:10:17.576Z DEBUG modem << SPM: NS reset vector at 0x14771\x0D\x0A
    2019-10-10T17:10:17.580Z DEBUG modem << SPM: prepare to jump to Non-Secure image.\x0D\x0A
    2019-10-10T17:10:19.302Z DEBUG modem << ***** Booting Zephyr OS build v1.14.99-ncs3-snapshot2-2647-gd6e67554cfeb *****\x0D\x0A
    2019-10-10T17:10:19.317Z DEBUG modem << [00:00:01.721,862] \x1B[0m<dbg> nrf9160_gps.init: MAGPIO set: AT%XMAGPIO=1,0,0,1,1,1574,1577\x1B[0m\x0D\x0A
    2019-10-10T17:10:19.318Z DEBUG modem << Asset tracker started\x0D\x0A
    2019-10-10T17:10:19.323Z DEBUG modem << [00:00:01.732,971] \x1B[0m<dbg> nrf_cloud_transport.nct_client_id_get: client_id = nrf-352656100037459\x1B[0m\x0D\x0A
    2019-10-10T17:10:19.340Z DEBUG modem << [00:00:01.742,218] \x1B[0m<dbg> nrf_cloud_transport.nct_topics_populate: shadow_base_topic: $aws/things/nrf-352656100037459/shadow\x1B[0m\x0D\x0A
    2019-10-10T17:10:19.347Z DEBUG modem << [00:00:01.753,936] \x1B[0m<dbg> nrf_cloud_transport.nct_topics_populate: accepted_topic: $aws/things/nrf-352656100037459/shadow/get/accepted\x1B[0m\x0D\x0A
    2019-10-10T17:10:19.359Z DEBUG modem << [00:00:01.766,479] \x1B[0m<dbg> nrf_cloud_transport.nct_topics_populate: rejected_topic: $aws/things/nrf-352656100037459/shadow/get/rejected\x1B[0m\x0D
    2019-10-10T17:10:19.373Z DEBUG modem << [00:00:01.779,052] \x1B[0m<dbg> nrf_cloud_transport.nct_topics_populate: update_delta_topic: $aws/things/nrf-352656100037459/shadow/update/delta\x1B[0m\x0D\x0A
    2019-10-10T17:10:19.390Z DEBUG modem << [00:00:01.791,992] \x1B[0m<dbg> nrf_cloud_transport.nct_topics_populate: update_topic: $aws/things/nrf-352656100037459/shadow/update\x1B[0m\x0D\x0A
    2019-10-10T17:10:19.396Z DEBUG modem << [00:00:01.803,863] \x1B[0m<dbg> nrf_cloud_transport.nct_topics_populate: shadow_get_topic: $aws/things/nrf-352656100037459/shadow/get\x1B[0m\x0D\x0A
    2019-10-10T17:10:19.407Z DEBUG modem << Connecting to LTE network. This may take several minutes.\x0D\x0A
    2019-10-10T17:10:19.409Z DEBUG modem << [00:00:01.822,082] \x1B[0m<inf> lte_lc: Using legacy LTE PCO mode...\x1B[0m\x0D\x0A
    2019-10-10T17:10:19.423Z DEBUG modem << [00:00:01.828,521] \x1B[0m<dbg> lte_lc.w_lte_lc_connect: Network mode: AT%XSYSTEMMODE=0,1,1,0\x1B[0m\x0D\x0A
    2019-10-10T17:10:38.228Z DEBUG modem << [00:00:20.636,810] \x1B[0m<dbg> lte_lc.at_handler: recv: +CEREG: 2,"3AAC","01375F66",9,0,0,"11100000","11100000"\x0D\x0A
    2019-10-10T17:10:38.238Z DEBUG modem << \x1B[0m\x0D\x0A
    2019-10-10T17:10:41.493Z DEBUG modem << [00:00:23.902,160] \x1B[0m<dbg> lte_lc.at_handler: recv: +CEREG: 5,"3AAC","01375F66",9,,,"11100000","01011111"\x0D\x0A
    2019-10-10T17:10:41.500Z DEBUG modem << \x1B[0m\x0D\x0A
    2019-10-10T17:10:41.501Z DEBUG modem << Connected to LTE network\x0D\x0A
    2019-10-10T17:10:41.505Z DEBUG modem << [00:00:23.915,008] \x1B[0m<dbg> nrf_cloud_transport.nct_connect: IPv4 Address 52.206.68.39\x1B[0m\x0D\x0A
    Everytime, when I search a ip adress with your link (https://whatismyipaddress.com/hostname-ip)
    the IP address of the a2n7tk1kp18wix-ats.iot.us-east-1.amazonaws.com changes. Is this normal?
    And do you have an idea what the problem could be?
    Thanks for your answers!
  • Hi, if you get -111 there is an issue with the certificates. Try running through this tutorial and trying again.
    Yes, the IP address will change constantly, which is why this is just a workaround to see if the DNS lookup was the actual problem.
    For developing and testing, you should be on a network that supports this.
  • Hi, this thread has been very useful for me to get past several problems getting the asset tracker example to work. I connect successfully to a NB-IoT network here in Norway now, thanks to (as explained in other posts here) setting modem mode to NB-IoT, using legacy PCO mode and using a static IP address since DNS is not supported.
    Finally, the problem I am left with is "cloud_connect failed: -111". I had high hopes that a certificate update would solve this, but after successfully updating my certificates the same problem still persists.
    Here is my output from the terminal:
    [00:00:00.378,173]
    [00:00:00.389,282]
    [0m<dbg> nrf_cloud_transport.nct_client_id_get: client_id = nrf-352656100223414
    [00:00:00.398,498]
    [0m<dbg> nrf_cloud_transport.nct_topics_populate: shadow_base_topic: $aws/things/nrf-352656100223414/shadow
    [00:00:00.410,156]
    [0m<dbg> nrf_cloud_transport.nct_topics_populate: accepted_topic: nrf-352656100223414/shadow/get/accepted
    [00:00:00.421,661]
    [0m<dbg> nrf_cloud_transport.nct_topics_populate: rejected_topic: $aws/things/nrf-352656100223414/shadow/get/rejected
    [00:00:00.434,204]
    [0m<dbg> nrf_cloud_transport.nct_topics_populate: update_delta_topic: $aws/things/nrf-352656100223414/shadow/update/delta
    [00:00:00.447,082]
    [0m<dbg> nrf_cloud_transport.nct_topics_populate: update_topic: $aws/things/nrf-352656100223414/shadow/update
    [00:00:00.458,923]
    [0m<dbg> nrf_cloud_transport.nct_topics_populate: shadow_get_topic: $aws/things/nrf-352656100223414/shadow/get
    [00:00:00.477,172]
    [00:00:00.483,428]
    [00:00:04.653,717]
    [0m<dbg> lte_lc.at_handler: recv: +CEREG: 2,"0CEB","0202791C",9,0,0,"11100000","11100000"
    [00:00:04.664,123]
    [0m<dbg> lte_lc.parse_nw_reg_status: Network registration status: 2
    [00:00:05.574,218]
    [0m<dbg> lte_lc.at_handler: recv: +CEREG: 1,"0CEB","0202791C",9,,,"11100000","11100000
    [00:00:05.584,472]
    [0m<dbg> lte_lc.parse_nw_reg_status: Network registration status: 1
    [00:00:05.595,123]
    [0m<dbg> nrf_cloud_transport.nct_connect: IPv4 Address 52.54.149.10
    LTE link disconnect
    Shutdown modem
    Terje
  • Hi Terje!
    Could you please make a new ticket with your issue? This makes the site much more searchable for our users.
    Side note: all networks in Norway support DNS lookup, so I don't think that is your issue.
    Heidi
