I2C clock frequency problem
I am using NRF52832 development board , to which i have interfaced LIS3DSH accelerometer sensor(3.3V i2c)
when i  configure it for 1600 sampling rate and all the axis enabled , i am not able to get any data .
could anyone help with this problem.
also the I2c clock frequency, as shown in below image, while i am capturing data when i observe in oscilloscope or logic analyzer , clock frequency is showing 200 all the setting is for 400KHz.
what could be the problem for this or is there any other way i need to follow to set the clock to 400KHz.
help me ASAP...
Thank you
  • "without any devices" means exactly that - nothing connected to the I2C lines!
    Nothing except the pullups, of course!
    In that situation, you should see the Master sending the Slave Address.
    Because there is no Slave attached, the Master will see that as a NAK - but it will be enough to see the Clock ...
  • Without any TWI slaves attached to the bus.
    I want to see the scope of the clock signal.
    : So, in this situation, you should see the Master sending the Slave Address.
    Because there is no Slave, the Master will see this as a NACK. This does not matter - it will be enough for you to capture a scope trace with the clock in it.
    Capturing a trace of the clock is the object of this exercise.
     * Copyright (c) 2016 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup tw_scanner main.c
     * @ingroup nrf_twi_example
     * @brief TWI Sensor Example main file.
     * This file contains the source code for a sample application using TWI.
    #include <stdio.h>
    #include "boards.h"
    #include "app_error.h"
    #include "nrf_drv_twi.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    /* TWI instance ID. */
    #if TWI0_ENABLED
    #define TWI_INSTANCE_ID     0
    #elif TWI1_ENABLED
    #define TWI_INSTANCE_ID     1
     /* Number of possible TWI addresses. */
     #define TWI_ADDRESSES      127
    /* TWI instance. */
    static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
     * @brief TWI initialization.
    void twi_init (void)
        ret_code_t err_code;
        const nrf_drv_twi_config_t twi_config = {
           .scl                = ARDUINO_SCL_PIN,
           .sda                = ARDUINO_SDA_PIN,
           .frequency          = NRF_DRV_TWI_FREQ_400K,
           .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
           .clear_bus_init     = false
        err_code = nrf_drv_twi_init(&m_twi, &twi_config, NULL, NULL);
        nrf_drv_twi_enable(&m_twi);
        uint8_t address;
        uint8_t sample_data;
        bool detected_device = false;
        NRF_LOG_INFO("TWI scanner started.");
        NRF_LOG_FLUSH();
        twi_init();
        while(1)
        for (address = 1; address <= TWI_ADDRESSES; address++)
            err_code = nrf_drv_twi_rx(&m_twi, address, &sample_data, sizeof(sample_data));
            if (err_code == NRF_SUCCESS)
                detected_device = true;
                NRF_LOG_INFO("TWI device detected at address 0x%x.", address);
            NRF_LOG_FLUSH();
        if (!detected_device)
            NRF_LOG_INFO("No device was found.");
            NRF_LOG_FLUSH();
        while (true)
            /* Empty loop. */
    NAK
    Thank You
    attached is the code snippet and logic analyzer scope as u have requested, by not connecting to any devices to development kit.
    As u can see still the clock is 200K.
    Thank you
  • sorry i couldn't take the frequency info while taking snapshot , clock was still 200, if u want i can retake and send
