peer_manager pairing problem
Here's I want to do:
Use static passkey to connect with central and peripheral.
I'm useing peer_manager to doing this.
1. I've setup passkey in peripheral with function sd_ble_opt_set
2. on central,ble_evt_handler, when I got event BLE_GAP_EVT_CONNECTED, I use sd_ble_gap_authenticate
to start auth.
3. then I will get event BLE_GAP_EVT_AUTH_KEY_REQUEST in ble_evt_handler
so I use sd_ble_gap_auth_key_reply to reply the static passkey.
I don't know what's next step. after this it seems linked but not use passkey!
because on central I send passkey as "123456",in peripheral I set passkey as "125534"
it's not a matched key, it should be not connect.
I want to know is there any step wrong? or something I have not done?
Here's my setup in peer_manager_init
central:
sec_param.bond = 0
sec_param.mitm = 1
sec_param.lesc = 0
sec_param.keypress = 0
sec_param.io_caps = BLE_GAP_IO_CAPS_KEYBOARD_ONLY
sec_param.oob = 0
sec_param.min_key_size = 7
sec_param.max_key_size = 16
peripheral:
sec_param.bond = 1
sec_param.mitm = 1
sec_param.lesc = 0
sec_param.io_caps = BLE_GAP_IO_CAPS_DISPLAY_ONLY
sec_param.oob = 0
If there's any peremiter need please tell me.
Thanks.
  • Hi
    Take a look at this case, as it goes very thoroughly the passkey functionality.
    Simon
  • Hi Simonr
    Thanks for reply!
    I've read the case you've post
    I'm using the nRF5_SDK_15.3.0 in central and peripheral
    the post still using nRF5_SDK_11.0.0 in central
    and they are using device_manager for connect
    I'm using peer_manager for connect
    seems there's some different in there SDK.
    I'm trying to learn something form the post, but seems all the step I've done
    I still don't know how to solve my problem, please help. Tnanks!
  • After I reload softdevice via nRFgo studio with right version(SDK 15.0.0) to central and peripheral
    the connection become normal, and the passkey work well !
