I tried to set up the programming Environment for Windows 10 by following the "Getting Started Assistant" from the "nRF Connect SDK" program. When I finally came to the point, where I should open a project, an error message occurs :
Loading solution blinkled.emProject Executing load commands cmake -GNinja -DBOARD=nrf9160_pca10090 -DBOARD_DIR=C:/Users/Benjamin Bergmann/AppData/Roaming/nrfconnect/pc-nrfconnect-linkmonitor/logs/ncs/zephyr/boards/arm/nrf9160_pca10090 -DZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb -DGNUARMEMB_TOOLCHAIN_PATH=C:/gnuarmemb -BC:/Users/Benjamin Bergmann/Music/blinkled/build_nrf9160_pca10090ns -HC:/Users/Benjamin Bergmann/Music/blinkled -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=C:/Nordic/arm_segger_embedded_studio_v416_win_x86_nordic/html/configure_nordic_project_menuconfig.py -- Using application from 'C:/Users/Benjamin Bergmann/Music/blinkled' Zephyr version: 1.14.99 -- Found PythonInterp: C:/Python37/python.exe (found suitable version "3.7.3", minimum required is "3.4") -- Selected BOARD nrf9160_pca10090 -- Found west: C:/Python37/Scripts/west.exe (found suitable version "0.5.8", minimum required is "0.5.6") -- Cache files will be written to: C:\Users\Benjamin Bergmann\AppData\Local/.cache/zephyr CMake Error at C:/Users/Benjamin Bergmann/AppData/Roaming/nrfconnect/pc-nrfconnect-linkmonitor/logs/ncs/zephyr/cmake/kconfig.cmake:135 (message): File not found: C:/Users/Benjamin/nrf9160_pca10090_defconfig Call Stack (most recent call first): C:/Users/Benjamin Bergmann/AppData/Roaming/nrfconnect/pc-nrfconnect-linkmonitor/logs/ncs/zephyr/cmake/app/boilerplate.cmake:500 (include) CMakeLists.txt:3 (include) -- Configuring incomplete, errors occurred! Project load failed Reported error: solution load command failed (1)
I don't know how to get rid of it.
However, during the installation process of the "Getting Started Assistant", I wasn't always sure, if I entered the right file directory. For example:
Where is the sourcecode_root folder?
I chose
C:\Users\Benjamin Bergmann\AppData\Roaming\nrfconnect\pc-nrfconnect-linkmonitor\logs
for the sourcecode_root folder, but I am not sure if that is the right one. Which folder would be the right one?
Then in the SES, I inserted:
and then I wanted to make a new project, but you can only open an existing project for nRF9160DK.
I don't know where I get an existing project, so I followed this tutorial to build one from scratch:
I made the project with the blinking LEDs.
I have no idea what could cause the error. Thanks for all answers.
- Bergmann
