HTTP POST with NCS v1.0.0-rc4
Dear ,
I just tried to run LTE-M/HTTP POST with NCS v1.0.0-rc4 (with nrf git fetch origin pull/943/head:branch1)
but, I COULD NOT POST any more:
**** Booting Zephyr OS build v1.14.99-ncs2-rc4-495-ga8933a2ead01 *****
LTETESTING is starting
 LTE is connecting...........
Checking LTE_M signal.............
+COPS: 0,2,"24201",7
OK
OK
+CEREG: 2,1,"765D","0110C303",7
OK
Original String is: +CEREG: 2,1,"765D","0110C303",7
OK
Found the LTE_M signal
Closing socket
  find LTE_M signal...........
***** USAGE FAULT *****
  Illegal load of EXC_RETURN into PC
***** Hardware exception *****
Current thread ID = 0x200203a8
Faulting instruction address = 0x0
Fatal fault in thread 0x200203a8! Aborting.
Exception occurred in Secure State
***** HARD FAULT *****
  Fault escalation (see below)
***** BUS FAULT *****
  Precise data bus error
  BFAR Address: 0x50008120
Current thread ID = 0x20021ae4
Faulting instruction address = 0x21992
Fatal fault in ISR! Spinning...
It worked normal with the old version v0.4.0
1. when i used the same setup, i got error:
1> zephyr/subsys/net/ip/libsubsys__net__ip.a(net_if.c.obj): In function `net_if_ipv6_calc_reachable_time':
1> D:/hng/projects/CyCollector/ncs_v1.0.0_rc4/zephyr/subsys/net/ip/net_if.c:2067: undefined reference to `sys_rand32_get'
1> collect2.exe: error: ld returned 1 exit status
2. I added the option:
# Disable native network stack to save some memory
CONFIG_NET_IPV4=n
CONFIG_NET_IPV6=n
then, Build Solution: Build completed
but, I got the error
My code:
LTE_M_NB-IoT.7z
Thanks so much
hng
  • I am sorry for the long delay. I am currently looking into your issue and will try to provide you with an answer as soon as possible.
    Simon
  • I was able to post to a webserver, with ncs v1.0.0 and modem v1.0.0. Could you test my attached example?
    http_post.zip
    Simon
  • Hi @Simon
    Thanks so much, I just backed from vocation, I will try your suggestion and contact with you soon
    Mvh,
    Hoang Nguyen
  • Dear Simon
    I tried with your suggestion: ncs v1.0.0
    and your example: ( change to my webserver address)
     char send_buf[] = "POST /? HTTP/1.1\r\n"\
    		"Host: 142.93.37.192\r\n"\
    		"Connection: keep-alive\r\n"\
    	    "Content-type: application/x-www-form-urlencoded\r\n"\
    		"Content-length: 50\r\n\r\n"\
    		"hng12 34 566 678899 01233 345678 99876543 2765432654";
    and it works,
    your code, you did NOT use function snprintf()
    char send_buf[MAXLINE + 1];
    int send_data_len_post = snprintf(send_buf,
    				         500,
    				         POST_TEMPLATE, HTTP_PATH,
    				         HTTP_HOST, strlen(PostString),
    				         PostString);
    snprintf() does NOT work !!
    I want to use snprintf() because I want to assign my "PostString" to send_buf()
    I am confusing: why snprintf() does NOT work? if i use your suggestion, how can i assign my data to send_buf()
    Thanks so much,
    Yeah, 1 more thing, about NCS v1.0.0-rc4, I will tell you why I used this version: We ( my company) got the support from Nordicsemi and  came to help us. and we tried ncs v1.0.0, asset_tracker DIDNT work, it didnt show the real data of GPS, so Bjørn suggested use ncs v.1.0.0-rc4, then asset_tracker WORKs.
    Thanks again
    Hoang  Nguyen
  • Hi Simon,
    I tried with a simple example to test snprintf() function. 1 with LTE and without LTE
    1. Without LTE:
    # LTE link control
    #CONFIG_LTE_LINK_CONTROL=y
    #include <zephyr.h>
    #include <net/socket.h>
    #include <stdio.h>
    #include <uart.h>
    #include <string.h>
    #define MAXLINE 4096
    #define HTTP_HOST "142.93.37.192"
    #define HTTP_PATH "/"
    #define TEST_STRING  "Hello from nRF9160 DK"
    #define POST_TEMPLATE "POST %s? HTTP/1.1\r\n"\
    		"Host: %s\r\n"\
    		"Content-length: %d\r\n\r\n"\
    		"%s"
         char tmp_str[MAXLINE + 1];
         snprintf(tmp_str,500,
    		"$GPGGA,%02d%02d%02d.200,%8.3f,N,%09.3f,W,1,"
    		"12,1.0,0.0,M,0.0,M,,*", 2019, 07, 23, 59.3033, 10.454);
         printf("tmp_string is: %s \n",tmp_str);
    				         500,
    				         HTTP_HOST, strlen(TEST_STRING),
    				         TEST_STRING);
         printf("send_buf is: %s \n",send_buf);
         printk("send err: %d\n\r", send_data_len_post);
         while (1) {
              //5 seconds delay
              k_sleep(5000);
    it works,
    ***** Booting Zephyr OS v1.14.99-ncs2 *****
    tmp_string is: $GPGGA,20190723.200,  59.303,N,00010.454,W,1,12,1.0,0.0,M,0.0,M,,*
    send_buf is: POST /? HTTP/1.1
    Host: 142.93.37.192
    Content-length: 21
    send err: 155
    and Now, without LTE:
    # LTE link control
    and error:
    tmp_string is: $GPGGA,201907***** HARD FAULT *****
      BFAR Address: 0x61000064
    Current thread ID = 0x61000000
    Faulting instruction address = 0xd998
    snprintf() and LTE_LINK_CONTROL conflict !?
    Mvh
    Hoang Nguyen
