HTTP POST with NCS v1.0.0-rc4
Dear
I just tried to run LTE-M/HTTP POST with NCS v1.0.0-rc4 (with nrf git fetch origin pull/943/head:branch1)
but, I COULD NOT POST any more:
**** Booting Zephyr OS build v1.14.99-ncs2-rc4-495-ga8933a2ead01 *****
LTETESTING is starting
 LTE is connecting...........
Checking LTE_M signal.............
+COPS: 0,2,"24201",7
OK
OK
+CEREG: 2,1,"765D","0110C303",7
OK
Original String is: +CEREG: 2,1,"765D","0110C303",7
OK
Found the LTE_M signal
Closing socket
  find LTE_M signal...........
***** USAGE FAULT *****
  Illegal load of EXC_RETURN into PC
***** Hardware exception *****
Current thread ID = 0x200203a8
Faulting instruction address = 0x0
Fatal fault in thread 0x200203a8! Aborting.
Exception occurred in Secure State
***** HARD FAULT *****
  Fault escalation (see below)
***** BUS FAULT *****
  Precise data bus error
  BFAR Address: 0x50008120
Current thread ID = 0x20021ae4
Faulting instruction address = 0x21992
Fatal fault in ISR! Spinning...
It worked normal with the old version v0.4.0
1. when i used the same setup, i got error:
1> zephyr/subsys/net/ip/libsubsys__net__ip.a(net_if.c.obj): In function `net_if_ipv6_calc_reachable_time':
1> D:/hng/projects/CyCollector/ncs_v1.0.0_rc4/zephyr/subsys/net/ip/net_if.c:2067: undefined reference to `sys_rand32_get'
1> collect2.exe: error: ld returned 1 exit status
2. I added the option:
# Disable native network stack to save some memory
CONFIG_NET_IPV4=n
CONFIG_NET_IPV6=n
then, Build Solution: Build completed
but, I got the error
My code:
LTE_M_NB-IoT.7z
Thanks so much
hng
  • Try using snprintk() instead, that worked for me.
    Simon
  • Hi Simon,
    I tried to use snprintk(), but it did NOT work, the same error came with me
    ***** Booting Zephyr OS v1.14.99-ncs2 *****
    tmp_string is: $GPGGA,2019072***** HARD FAULT *****
      BFAR Address: 0x61000064
    Current thread ID = 0x61000000
    Faulting instruction address = 0xd998
    can you send me the full setup. thanks
    Mvh
    Hoang Nguyen
  • I am sorry, I was too quick to answer and gave you wrong information. The change that made it work was to set CONFIG_NO_OPTIMIZATION=y in prj.conf. I am attaching main.c and prj.conf down below.
    prj.conf
    CONFIG_BSD_LIBRARY=y
    CONFIG_TEST_RANDOM_GENERATOR=y
    CONFIG_NETWORKING=y
    CONFIG_NET_BUF_USER_DATA_SIZE=1
    CONFIG_NET_SOCKETS_OFFLOAD=y
    CONFIG_NET_SOCKETS=y
    CONFIG_NET_SOCKETS_POSIX_NAMES=y
    CONFIG_NET_RAW_MODE=y
    CONFIG_HEAP_MEM_POOL_SIZE=1024
    # LTE link control
    CONFIG_LTE_LINK_CONTROL=y
    CONFIG_MAIN_STACK_SIZE=4096
    CONFIG_NO_OPTIMIZATIONS=y
    main.c
    #include <zephyr.h>
    #include <net/socket.h>
    #include <stdio.h>
    #include <uart.h>
    #include <string.h>
    #define MAXLINE 4096
    #define HTTP_HOST "142.93.37.192"
    #define HTTP_PATH "/"
    #define TEST_STRING  "Hello from nRF9160 DK"
    #define POST_TEMPLATE "POST %s? HTTP/1.1\r\n"\
    		"Host: %s\r\n"\
    		"Connection: keep-alive\r\n"\
    	        "Content-type: application/x-www-form-urlencoded\r\n"\
    		"Content-length: %d\r\n\r\n"\
    		"%s"
         printk("Hello from start of main");
         char tmp_str[MAXLINE + 1];
         snprintf(tmp_str,500,
    		"$GPGGA,%02d%02d%02d.200,%8.3f,N,%09.3f,W,1,"
    		"12,1.0,0.0,M,0.0,M,,*", 2019, 07, 23, 59.3033, 10.454);
         //printf("tmp_string is: %s \n",tmp_str);
         char send_buf[MAXLINE + 1];
         int send_data_len_post = snprintk(send_buf,
                                             500,
    				         POST_TEMPLATE, HTTP_PATH,
    				         HTTP_HOST, strlen(TEST_STRING),
    				         TEST_STRING);
         printf("send_buf is: %s \n",send_buf);
         printk("send err: %d\n\r", send_data_len_post);
         while (1) {
              //5 seconds delay
              k_sleep(5000);
    Simon
  • Hi Simon
    Ja, thats what i am looking for.
    Thanks so much
    Mvh
    Hoang Nguyen
  • Dear Simon,
    Ja, it works, but I got another "funny" error ( because I dont know why!!!)
    I removed:
    and just ran:
    int main(void){
         printk("Hello from start of main \n");
                                             500,
    				         TEST_STRING);
         //snprintk_post("OMG whyyyyyyyyyyyy \n");
         while (1) {
              //5 seconds delay
              k_sleep(5000);
    it didnt work:
    SPM: NS image at 0xc000
    SPM: NS MSP at 0x20024cf8
    SPM: NS reset vector at 0xec1d
    SPM: prepare to jump to Non-Secure image.
    Hello from start of main %
      Illegal use of the EPSR
    Current thread ID = 0x20021e9c
    Faulting instruction address = 0xec1c
    Fatal fault in essential thread! Spinning...
    then, I tried to add an extra variable (but i will not use it !!!!)
    char tmp[MAXLINE + 1];
    and, it works:
    send_buf is: POST /? HTTP/1.1
    Host: 142.93.37.192
    Content-length: 19
    111 from nRF9160 DK
    send err: 153
    I dont know why!!!????
    mvh
    Hoang
