HTTP POST with NCS v1.0.0-rc4
Dear
I just tried to run LTE-M/HTTP POST with NCS v1.0.0-rc4 (with nrf git fetch origin pull/943/head:branch1)
but, I COULD NOT POST any more:
**** Booting Zephyr OS build v1.14.99-ncs2-rc4-495-ga8933a2ead01 *****
LTETESTING is starting
 LTE is connecting...........
Checking LTE_M signal.............
+COPS: 0,2,"24201",7
OK
OK
+CEREG: 2,1,"765D","0110C303",7
OK
Original String is: +CEREG: 2,1,"765D","0110C303",7
OK
Found the LTE_M signal
Closing socket
  find LTE_M signal...........
***** USAGE FAULT *****
  Illegal load of EXC_RETURN into PC
***** Hardware exception *****
Current thread ID = 0x200203a8
Faulting instruction address = 0x0
Fatal fault in thread 0x200203a8! Aborting.
Exception occurred in Secure State
***** HARD FAULT *****
  Fault escalation (see below)
***** BUS FAULT *****
  Precise data bus error
  BFAR Address: 0x50008120
Current thread ID = 0x20021ae4
Faulting instruction address = 0x21992
Fatal fault in ISR! Spinning...
It worked normal with the old version v0.4.0
1. when i used the same setup, i got error:
1> zephyr/subsys/net/ip/libsubsys__net__ip.a(net_if.c.obj): In function `net_if_ipv6_calc_reachable_time':
1> D:/hng/projects/CyCollector/ncs_v1.0.0_rc4/zephyr/subsys/net/ip/net_if.c:2067: undefined reference to `sys_rand32_get'
1> collect2.exe: error: ld returned 1 exit status
2. I added the option:
# Disable native network stack to save some memory
CONFIG_NET_IPV4=n
CONFIG_NET_IPV6=n
then, Build Solution: Build completed
but, I got the error
My code:
LTE_M_NB-IoT.7z
Thanks so much
hng
