How to receive SMS message in standby mode in nRF9160?
I want to wake up nRF9160 by SMS.
What I want to do:
The nRF9160 usually sleeps to reduce power consumption, and only when it receives SMS it wakes up and send some data by UDP or so.
I succeeded in implementing MQTT(+TLS), but have no experience to implement SMS function.
Any advice?
  • I've already checked the link below, but I don't really get what each line means.
    devzone.nordicsemi.com/.../sending-sms-using-at_client-example
    This is my understanding.
    AT+CFUN=1
    => Turn on the modem. The modem can receive SMS at any time.
    AT+CPIN="1234"
    => Set Pin number, which is a password of SIM.
    AT+CNMI=3,2,0,1
    => Configure the process of receving SMS.
    After this setting, MCU can go to sleep to wait until SMS is received. When SMS is received, MCU wakes up.
    Is this correct? I'm not familiar with SMS function. Sorry for poor skill.
  • This is draft code of what I want to do.
     * Copyright (c) 2018 Nordic Semiconductor ASA
     * SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
    #include <zephyr.h>
    #include <net/socket.h>
    #include <stdio.h>
    #include <uart.h>
    #include <string.h>
    /**@brief Recoverable BSD library error. */
    void bsd_recoverable_error_handler(uint32_t err)
    	printk("bsdlib recoverable error: %u\n", err);
    /**@brief Irrecoverable BSD library error. */
    void bsd_irrecoverable_error_handler(uint32_t err)
    	printk("bsdlib irrecoverable error: %u\n", err);
    	__ASSERT_NO_MSG(false);
    int blocking_recv(int fd, u8_t *buf, u32_t size, u32_t flags)
    	int err;
    	do {
    		err = recv(fd, buf, size, flags);
    	} while (err < 0 && errno == EAGAIN);
    	return err;
    int blocking_send(int fd, u8_t *buf, u32_t size, u32_t flags)
    	int err;
    	do {
    		err = send(fd, buf, size, flags);
    	return err;
    int blocking_connect(int fd, struct sockaddr *local_addr, socklen_t len)
    	int err;
    	do {
    		err = connect(fd, local_addr, len);
    	return err;
    void setup_sms()
        char recv_buf[256 + 1];
        const char *at_commands[] = {<AT Commands that enables modem and SMS notification>};
    	int at_socket_fd = socket(AF_LTE, 0, NPROTO_AT);
    	printk("Starting simple AT socket application\n\r");
    	if (at_socket_fd < 0) {
    		printk("Socket err: %d, errno: %d\r\n", at_socket_fd, errno);
    	for (int i = 0; i < ARRAY_SIZE(at_commands); i++) {
            printk("%s\n", at_commands[i]);
    		int bytes_written = send(at_socket_fd, at_commands[i], strlen(at_commands[i]), 0);
    		if (bytes_written > 0) {
    			int r_bytes = blocking_recv(at_socket_fd, recv_buf, sizeof(recv_buf), MSG_DONTWAIT);
    			if (r_bytes > 0) {
    				printk("%s\n", recv_buf);
    	printk("Closing socket\n\r");
    	(void)close(at_socket_fd);
    void main(void)
    	printk("The SMS receiving sample started\n");
    	char sms_messsage[30];
        setup_sms();
        while(1){
            while(<no SMS message? = true>){
                <check if modem is on and SMS notification is on in some interval>;
                if(<modem is off of SMS notification is off>){
                    setup_sms();
            // if SMS received
            <store sms message to sms_messsage>;
            printk("SMS message is %s\n", sms_message);
  • The sample you link to is for sending sms. For receiving sms, you need to poll the AT socket. Try to use at_client, and see if you are able to get a sms successfully received. Note that you need a SIM card which has a phone number in order to send/receive sms.
    Håkon
  • Hi Yusuke, sounds like your development would be similar to ours. I am wondering that when you succeeded in implementing MQTT(+TLS) to wake up the device and send some data by UDP, is the LTE module in PSM? Did you successfully implement SMS function? I have been trying to implement the method to wake up the LTE by sending SMS and send some data to the server by UDP. If you don't mind, please exchange the information. Thanks
