Not connecting to nRFCloud
Hi, we have an nRF9160DK (0.8.3) and it does not connect to the nrfcloud.
We have updated to the latest firmware 1.0.0
We only have nb-iot here so we  didn't use the iBasis sim, instead using a vodafone V-Sim (which is active).
Are we missing a step here?
Thanks
  • Hello Ian,
    Can you confirm that you get a connection with the network running at_client sample together with LTE Link Monitor?
    (please share the log if you can)
    For the asset_tracker sample have you configured the application to choose the NB-IoT network?
    Please share log output when running the samples.
    Best Regards,
    Martin L.
  • Hi Martin,
    Where do I get the AT_client sample hex file? Can you send me a link?
    Do we need to run this, change settings to NB-iot using AT commands (close down gracefully) and then re-load the nRFCloud example?
    Thanks Ian
  • Hi Ian,
    You should be able to build and flash the at_client sample following this tutorial.
    For your convinience, I can attach the precompiled .hex here as well.at_clientDefault.hex
    Use the command: nrfjprog --program at_clientDefault.hex -f nrf91 --sectorerase -r --verify
    to flash the application, or just use the Programmer app in "nRF Connect for Desktop".
    You should switch the modem to NB-IoT mode before you turn the modem ON.
    Send the AT-Command:
    AT%XSYSTEMMODE=0,1,0,0
    before you turn ON the modem (AT+CFUN=1) to set the mode.
    If you are going to set the network mode in the asset_tracker sample just add this in the prj.conf:
    CONFIG_LTE_NETWORK_MODE_NBIOT=y
    or do it directly in SES --> Project --> Configure nRF Connect SDK project
    Click configure, then build and flash.
    Best Regards,
    Martin L.
  • Hi Martin,
    We get an error when we use the command.
    Do we need to do something else?
    I tried to use AT+CFUN=0 and then it takes the command?
    See log below.
    Thanks
    Ian
    2019-07-10T08:31:29.359Z INFO Application data folder: C:\Users\Ian\AppData\Roaming\nrfconnect\pc-nrfconnect-linkmonitor
    2019-07-10T08:31:29.433Z DEBUG App pc-nrfconnect-linkmonitor v1.0.0 official
    2019-07-10T08:31:29.433Z DEBUG App path: C:\Users\Ian\.nrfconnect-apps\node_modules\pc-nrfconnect-linkmonitor
    2019-07-10T08:31:29.433Z DEBUG nRFConnect 3.0.0 is supported by the app (^3.0.0)
    2019-07-10T08:31:29.433Z DEBUG nRFConnect path: C:\Users\Ian\AppData\Local\Programs\nrfconnect\resources\app.asar
    2019-07-10T08:31:29.433Z DEBUG HomeDir: C:\Users\Ian
    2019-07-10T08:31:29.433Z DEBUG TmpDir: C:\Users\Ian\AppData\Local\Temp
    2019-07-10T08:31:42.196Z INFO Modem port is opened
    2019-07-10T08:31:42.200Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2019-07-10T08:31:42.246Z DEBUG modem << +CFUN: 4\x0D\x0A
    2019-07-10T08:31:42.248Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:31:42.268Z DEBUG modem >> AT+CFUN=1\x0D\x0A
    2019-07-10T08:31:42.311Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:33:10.885Z DEBUG modem >> AT+CFUN=1\x0D\x0A
    2019-07-10T08:33:10.888Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:33:32.389Z DEBUG modem >> AT%XSYSTEMMODE=0,1,0,0\x0D\x0A
    2019-07-10T08:33:32.394Z DEBUG modem << ERROR\x0D
    2019-07-10T08:33:32.396Z ERROR Error: AT%XSYSTEMMODE=0,1,0,0
    failed
    2019-07-10T08:39:07.834Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2019-07-10T08:39:07.838Z DEBUG modem << +CFUN: 1\x0D\x0A
    2019-07-10T08:39:07.846Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:39:07.847Z DEBUG modem >> AT+CGSN=1\x0D\x0A
    2019-07-10T08:39:07.855Z DEBUG modem << +CGSN: "352656100110413"\x0D\x0A
    2019-07-10T08:39:07.856Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:39:07.859Z DEBUG modem >> AT+CGMI\x0D\x0A
    2019-07-10T08:39:07.864Z DEBUG modem << Nordic Semiconductor ASA\x0D\x0A
    2019-07-10T08:39:07.865Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:39:07.868Z DEBUG modem >> AT+CGMM\x0D\x0A
    2019-07-10T08:39:07.872Z DEBUG modem << nRF9160-SICA\x0D\x0A
    2019-07-10T08:39:07.873Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:39:07.876Z DEBUG modem >> AT+CGMR\x0D\x0A
    2019-07-10T08:39:07.880Z DEBUG modem << mfw_nrf9160_1.0.0\x0D\x0A
    2019-07-10T08:39:07.881Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:39:07.882Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.0.0] SerNr: 352656100110413
    2019-07-10T08:39:07.884Z DEBUG modem >> AT+CEMODE?\x0D\x0A
    2019-07-10T08:39:07.888Z DEBUG modem << +CEMODE: 2\x0D\x0A
    2019-07-10T08:39:07.889Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:39:07.894Z DEBUG modem >> AT%XCBAND=?\x0D\x0A
    2019-07-10T08:39:07.903Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,14,17,18,19,20,25,26,28,66)\x0D\x0A
    2019-07-10T08:39:07.905Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:39:07.909Z DEBUG modem >> AT+CMEE?\x0D\x0A
    2019-07-10T08:39:07.912Z DEBUG modem << +CMEE: 0\x0D\x0A
    2019-07-10T08:39:07.913Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:39:07.917Z DEBUG modem >> AT+CMEE=1\x0D\x0A
    2019-07-10T08:39:07.923Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:39:07.926Z DEBUG modem >> AT+CNEC?\x0D\x0A
    2019-07-10T08:39:07.929Z DEBUG modem << +CNEC: 0\x0D\x0A
    2019-07-10T08:39:07.930Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:39:07.933Z DEBUG modem >> AT+CNEC=24\x0D\x0A
    2019-07-10T08:39:07.938Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:39:07.942Z DEBUG modem >> AT+CGEREP?\x0D\x0A
    2019-07-10T08:39:07.946Z DEBUG modem << +CGEREP: 0,0\x0D\x0A
    2019-07-10T08:39:07.947Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:39:07.950Z DEBUG modem >> AT+CGDCONT?\x0D\x0A
    2019-07-10T08:39:07.956Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:39:07.958Z DEBUG modem >> AT+CGACT?\x0D\x0A
    2019-07-10T08:39:07.961Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:39:07.964Z DEBUG modem >> AT+CGEREP=1\x0D\x0A
    2019-07-10T08:39:07.967Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:39:07.972Z DEBUG modem >> AT+CIND=1,1,1\x0D\x0A
    2019-07-10T08:39:07.976Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:39:07.982Z DEBUG modem >> AT+CEREG=2\x0D\x0A
    2019-07-10T08:39:07.986Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:39:07.990Z DEBUG modem >> AT+CEREG?\x0D\x0A
    2019-07-10T08:39:07.996Z DEBUG modem << +CEREG: 2,2,"FFFE","FFFFFFFF",7\x0D\x0A
    2019-07-10T08:39:07.997Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:39:08.001Z DEBUG modem >> AT%CESQ=1\x0D\x0A
    2019-07-10T08:39:08.006Z DEBUG modem << OK\x0D\x0A
    2019-07-10T08:39:08.010Z DEBUG modem >> AT+CESQ\x0D\x0A
    2019-07-10T08:39:08.016Z DEBUG modem << +CESQ: 99,99,255,255,255,255\x0D\x0A
    2019-07-10T08:39:08.017Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:39:08.026Z DEBUG modem >> AT%XSIM=1\x0D\x0A
    2019-07-10T08:39:08.032Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:39:08.035Z DEBUG modem >> AT%XSIM?\x0D\x0A
    2019-07-10T08:39:08.040Z DEBUG modem << %XSIM: 1\x0D\x0A
    2019-07-10T08:39:08.042Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:39:08.046Z DEBUG modem >> AT+CPIN?\x0D\x0A
    2019-07-10T08:39:08.051Z DEBUG modem << +CPIN: READY\x0D\x0A
    2019-07-10T08:39:08.052Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:39:08.060Z DEBUG modem >> AT+CPINR="SIM PIN"\x0D\x0A
    2019-07-10T08:39:08.073Z DEBUG modem << +CPINR: "SIM PIN",3\x0D\x0A
    2019-07-10T08:39:08.074Z DEBUG modem << OK\x0D\x0A
    2019-07-10T08:39:08.077Z DEBUG modem >> AT+CIMI\x0D\x0A
    2019-07-10T08:39:08.081Z DEBUG modem << 901280990314292\x0D
    2019-07-10T08:39:08.082Z DEBUG modem << \x0A
    2019-07-10T08:39:08.082Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:39:08.083Z INFO IMSIdentity: 901280990314292
    2019-07-10T08:39:26.046Z DEBUG modem >> AT+CFUN=0\x0D\x0A
    2019-07-10T08:39:26.073Z DEBUG modem << ERROR\x0D\x0A\x00
    2019-07-10T08:39:26.074Z ERROR Error: AT+CFUN=0
    failed
    2019-07-10T08:39:26.074Z DEBUG modem << %CESQ: 255,0\x0D\x0A
    2019-07-10T08:39:26.080Z DEBUG modem << %XSIM: 1\x0D\x0A\x00
    2019-07-10T08:39:26.086Z DEBUG modem << %XSIM: 0\x0D\x0A\x00
    2019-07-10T08:39:26.095Z DEBUG modem >> AT+CPIN?\x0D\x0A
    2019-07-10T08:39:26.107Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:39:26.110Z DEBUG modem >> AT+CIMI\x0D\x0A
    2019-07-10T08:39:46.122Z ERROR getInternationalMobileSubscriber() failed: Error: 'AT+CIMI
    ' timed out
    2019-07-10T08:39:46.123Z DEBUG modem >> AT%XSYSTEMMODE=0,1,0,0\x0D\x0A
    2019-07-10T08:39:47.126Z ERROR Error: 'AT%XSYSTEMMODE=0,1,0,0
    ' timed out
    2019-07-10T08:39:47.130Z DEBUG modem >> AT%XSYSTEMMODE=0,1,0,0\x0D\x0A
    2019-07-10T08:39:48.131Z ERROR Error: 'AT%XSYSTEMMODE=0,1,0,0
    ' timed out
    2019-07-10T08:39:48.136Z DEBUG modem >> AT+CFUN=1\x0D\x0A
    2019-07-10T08:39:49.137Z ERROR Error: 'AT+CFUN=1
    ' timed out
    2019-07-10T08:41:03.353Z INFO Modem port is opened
    2019-07-10T08:41:03.356Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2019-07-10T08:41:03.368Z DEBUG modem << +CFUN: 4\x0D\x0A
    2019-07-10T08:41:03.369Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:41:03.373Z DEBUG modem >> AT+CFUN=1\x0D\x0A
    2019-07-10T08:41:03.415Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:41:20.758Z DEBUG modem >> AT%XSYSTEMMODE=0,1,0,0\x0D\x0A
    2019-07-10T08:41:20.766Z DEBUG modem << ERROR\x0D\x0A\x00
    2019-07-10T08:41:20.768Z ERROR Error: AT%XSYSTEMMODE=0,1,0,0
    failed
    2019-07-10T08:41:28.314Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2019-07-10T08:41:28.319Z DEBUG modem << +CFUN: 1\x0D\x0A
    2019-07-10T08:41:28.323Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:41:28.325Z DEBUG modem >> AT+CGSN=1\x0D\x0A
    2019-07-10T08:41:28.334Z DEBUG modem << +CGSN: "352656100110413"\x0D\x0A
    2019-07-10T08:41:28.335Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:41:28.339Z DEBUG modem >> AT+CGMI\x0D\x0A
    2019-07-10T08:41:28.345Z DEBUG modem << Nordic Semiconductor ASA\x0D\x0A
    2019-07-10T08:41:28.346Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:41:28.353Z DEBUG modem >> AT+CGMM\x0D\x0A
    2019-07-10T08:41:28.357Z DEBUG modem << nRF9160-SICA\x0D\x0A
    2019-07-10T08:41:28.358Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:41:28.360Z DEBUG modem >> AT+CGMR\x0D\x0A
    2019-07-10T08:41:28.368Z DEBUG modem << mfw_nrf9160_1.0.0\x0D\x0A
    2019-07-10T08:41:28.369Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:41:28.370Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.0.0] SerNr: 352656100110413
    2019-07-10T08:41:28.372Z DEBUG modem >> AT+CEMODE?\x0D\x0A
    2019-07-10T08:41:28.376Z DEBUG modem << +CEMODE: 2\x0D\x0A
    2019-07-10T08:41:28.376Z DEBUG modem << OK\x0D
    2019-07-10T08:41:28.384Z DEBUG modem >> AT%XCBAND=?\x0D\x0A
    2019-07-10T08:41:28.393Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,14,17,18,19,20,25,26,28,66)\x0D\x0A
    2019-07-10T08:41:28.394Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:41:28.402Z DEBUG modem >> AT+CMEE?\x0D\x0A
    2019-07-10T08:41:28.406Z DEBUG modem << +CMEE: 0\x0D\x0A
    2019-07-10T08:41:28.407Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:41:28.410Z DEBUG modem >> AT+CMEE=1\x0D\x0A
    2019-07-10T08:41:28.418Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:41:28.423Z DEBUG modem >> AT+CNEC?\x0D\x0A
    2019-07-10T08:41:28.427Z DEBUG modem << +CNEC: 0\x0D\x0A
    2019-07-10T08:41:28.428Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:41:28.434Z DEBUG modem >> AT+CNEC=24\x0D\x0A
    2019-07-10T08:41:28.438Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:41:28.441Z DEBUG modem >> AT+CGEREP?\x0D\x0A
    2019-07-10T08:41:28.450Z DEBUG modem << +CGEREP: 0,0\x0D\x0A
    2019-07-10T08:41:28.451Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:41:28.454Z DEBUG modem >> AT+CGDCONT?\x0D\x0A
    2019-07-10T08:41:28.457Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:41:28.460Z DEBUG modem >> AT+CGACT?\x0D\x0A
    2019-07-10T08:41:28.468Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:41:28.471Z DEBUG modem >> AT+CGEREP=1\x0D\x0A
    2019-07-10T08:41:28.474Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:41:28.484Z DEBUG modem >> AT+CIND=1,1,1\x0D\x0A
    2019-07-10T08:41:28.488Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:41:28.491Z DEBUG modem >> AT+CEREG=2\x0D\x0A
    2019-07-10T08:41:28.494Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:41:28.502Z DEBUG modem >> AT+CEREG?\x0D\x0A
    2019-07-10T08:41:28.507Z DEBUG modem << +CEREG: 2,4,"FFFE","FFFFFFFF",7\x0D\x0A
    2019-07-10T08:41:28.509Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:41:28.521Z DEBUG modem >> AT%CESQ=1\x0D\x0A
    2019-07-10T08:41:28.524Z DEBUG modem << OK\x0D\x0A
    2019-07-10T08:41:28.532Z DEBUG modem >> AT+CESQ\x0D\x0A
    2019-07-10T08:41:28.537Z DEBUG modem << +CESQ: 99,99,255,255,255,255\x0D\x0A
    2019-07-10T08:41:28.538Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:41:28.542Z DEBUG modem >> AT%XSIM=1\x0D\x0A
    2019-07-10T08:41:28.545Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:41:28.553Z DEBUG modem >> AT%XSIM?\x0D\x0A
    2019-07-10T08:41:28.557Z DEBUG modem << %XSIM: 1\x0D\x0A
    2019-07-10T08:41:28.558Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:41:28.561Z DEBUG modem >> AT+CPIN?\x0D\x0A
    2019-07-10T08:41:28.568Z DEBUG modem << +CPIN: READY\x0D\x0A
    2019-07-10T08:41:28.569Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:41:28.573Z DEBUG modem >> AT+CPINR="SIM PIN"\x0D\x0A
    2019-07-10T08:41:28.585Z DEBUG modem << +CPINR: "SIM PIN",3\x0D\x0A
    2019-07-10T08:41:28.586Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:41:28.590Z DEBUG modem >> AT+CIMI\x0D\x0A
    2019-07-10T08:41:28.594Z DEBUG modem << 901280990314292\x0D
    2019-07-10T08:41:28.594Z DEBUG modem << \x0A
    2019-07-10T08:41:28.595Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:41:28.596Z INFO IMSIdentity: 901280990314292
    2019-07-10T08:41:57.546Z DEBUG modem >> AT%XSYSTEMMODE=0,1,0,0\x0D\x0A
    2019-07-10T08:41:57.555Z DEBUG modem << ERROR\x0D\x0A\x00
    2019-07-10T08:41:57.556Z ERROR Error: AT%XSYSTEMMODE=0,1,0,0
    failed
    2019-07-10T08:42:12.339Z DEBUG modem >> AT+CFUN=0\x0D\x0A
    2019-07-10T08:42:12.381Z DEBUG modem << ERROR\x0D\x0A\x00
    2019-07-10T08:42:12.382Z ERROR Error: AT+CFUN=0
    failed
    2019-07-10T08:42:12.382Z DEBUG modem << %CESQ: 255,0\x0D
    2019-07-10T08:42:12.402Z DEBUG modem << %XSIM: 1\x0D\x0A\x00
    2019-07-10T08:42:12.405Z DEBUG modem << %XSIM: 0\x0D\x0A\x00
    2019-07-10T08:42:12.408Z DEBUG modem >> AT+CPIN?\x0D\x0A
    2019-07-10T08:42:13.732Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:42:22.116Z DEBUG modem >> AT%XSYSTEMMODE=0,1,0,0\x0D\x0A
    2019-07-10T08:42:22.129Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-10T08:42:26.365Z DEBUG modem >> AT+CFUN=1\x0D\x0A
    2019-07-10T08:42:26.376Z DEBUG modem << OK\x0D
    2019-07-10T08:42:31.132Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2019-07-10T08:42:31.140Z DEBUG modem << OK\x0D\x0A\x00
  • Hi Ian,
    You have to send the command before the modem turns ON.
    You can turn the modem to offline mode and then change it, like described in the documentation.
    AT+CFUN=4
    AT+CFUN=1
    If you turn the modem OFF (at+cfun=0) then you cannot turn the modem on. You then need to power cycle the board.
    Best Regards,
    Martin L.
