Not connecting to nRFCloud
Hi, we have an nRF9160DK (0.8.3) and it does not connect to the nrfcloud.
We have updated to the latest firmware 1.0.0
We only have nb-iot here so we  didn't use the iBasis sim, instead using a vodafone V-Sim (which is active).
Are we missing a step here?
Thanks
  • Hi Ian,
    The "Mobile Country Code" (MCC) and the "Mobile Network Codes" (MNC) can be found at https://www.mcc-mnc.com/ or directly from your operator.
    example:
    Ireland + Vodafone
    (AT+COPS=1,2,"27201")
    I would recommend testing with the at_client first since it's faster to do some quick changes in the settings to the modem while you try to connect to the network.
    In that way, you can confirm that you can get an attachment with the base station and a connection with the network.
    so when you get a connection with at_client you know what is needed to get a connection with the network and can then implement this in the other applications as "asset_tracker".
    AT+COPS? will search through all the bands and that will take some time, so it is expected to get a timeout when trying to send AT-commands while the modem is in this searching mode.
    So you should not need to press that button.
    Please try with the MCC/MNC codes and share the LTE Link Monitor log.
    Best Regards,
    Martin L.
  • Morning Martin,
    No luck, below is the list.
    BTW should is it OK to have the asset_tracker running in the background while I'm using the at_client (i.e. should I erase everything and load inn your hex file)?
    Also could it be an issue with our V-Sim? As far as I know its OK (account etc.) but we have never tested it with any other hardware.
    Thanks
    Ian
    2019-07-12T07:30:19.917Z INFO Application data folder: C:\Users\Ian\AppData\Roaming\nrfconnect\pc-nrfconnect-linkmonitor
    2019-07-12T07:30:19.997Z DEBUG App pc-nrfconnect-linkmonitor v1.0.0 official
    2019-07-12T07:30:19.997Z DEBUG App path: C:\Users\Ian\.nrfconnect-apps\node_modules\pc-nrfconnect-linkmonitor
    2019-07-12T07:30:19.997Z DEBUG nRFConnect 3.0.0 is supported by the app (^3.0.0)
    2019-07-12T07:30:19.997Z DEBUG nRFConnect path: C:\Users\Ian\AppData\Local\Programs\nrfconnect\resources\app.asar
    2019-07-12T07:30:19.997Z DEBUG HomeDir: C:\Users\Ian
    2019-07-12T07:30:19.997Z DEBUG TmpDir: C:\Users\Ian\AppData\Local\Temp
    2019-07-12T07:30:49.592Z INFO Modem port is opened
    2019-07-12T07:30:49.600Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2019-07-12T07:30:49.607Z DEBUG modem << +CFUN: 1\x0D\x0A
    2019-07-12T07:30:49.609Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:30:49.649Z DEBUG modem >> AT+CGSN=1\x0D\x0A
    2019-07-12T07:30:49.656Z DEBUG modem << +CGSN: "352656100110413"\x0D\x0A
    2019-07-12T07:30:49.657Z DEBUG modem << OK\x0D\x0A
    2019-07-12T07:30:49.661Z DEBUG modem >> AT+CGMI\x0D\x0A
    2019-07-12T07:30:49.669Z DEBUG modem << Nordic Semiconductor ASA\x0D\x0A
    2019-07-12T07:30:49.670Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:30:49.676Z DEBUG modem >> AT+CGMM\x0D\x0A
    2019-07-12T07:30:49.681Z DEBUG modem << nRF9160-SICA\x0D
    2019-07-12T07:30:49.686Z DEBUG modem << \x0A
    2019-07-12T07:30:49.688Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:30:49.692Z DEBUG modem >> AT+CGMR\x0D\x0A
    2019-07-12T07:30:49.699Z DEBUG modem << mfw_nrf9160_1.0.0\x0D
    2019-07-12T07:30:49.703Z DEBUG modem << \x0A
    2019-07-12T07:30:49.705Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:30:49.706Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.0.0] SerNr: 352656100110413
    2019-07-12T07:30:49.708Z DEBUG modem >> AT+CEMODE?\x0D\x0A
    2019-07-12T07:30:49.717Z DEBUG modem << +CEMODE: 0\x0D\x0A
    2019-07-12T07:30:49.718Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:30:49.727Z DEBUG modem >> AT%XCBAND=?\x0D\x0A
    2019-07-12T07:30:49.735Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,17,19,20,25,26,28,66)\x0D\x0A
    2019-07-12T07:30:49.737Z DEBUG modem << OK\x0D
    2019-07-12T07:30:49.746Z DEBUG modem >> AT+CMEE?\x0D\x0A
    2019-07-12T07:30:49.752Z DEBUG modem << +CMEE: 0\x0D\x0A
    2019-07-12T07:30:49.754Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:30:49.757Z DEBUG modem >> AT+CMEE=1\x0D\x0A
    2019-07-12T07:30:49.760Z DEBUG modem << OK\x0D
    2019-07-12T07:30:49.765Z DEBUG modem >> AT+CNEC?\x0D\x0A
    2019-07-12T07:30:49.770Z DEBUG modem << +CNEC: 0\x0D\x0A
    2019-07-12T07:30:49.772Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:30:49.775Z DEBUG modem >> AT+CNEC=24\x0D\x0A
    2019-07-12T07:30:49.779Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:30:49.784Z DEBUG modem >> AT+CGEREP?\x0D\x0A
    2019-07-12T07:30:49.789Z DEBUG modem << +CGEREP: 0,0\x0D\x0A
    2019-07-12T07:30:49.790Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:30:49.795Z DEBUG modem >> AT+CGDCONT?\x0D\x0A
    2019-07-12T07:30:49.801Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:30:49.805Z DEBUG modem >> AT+CGACT?\x0D\x0A
    2019-07-12T07:30:49.811Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:30:49.818Z DEBUG modem >> AT+CGEREP=1\x0D\x0A
    2019-07-12T07:30:49.822Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:30:49.826Z DEBUG modem >> AT+CIND=1,1,1\x0D\x0A
    2019-07-12T07:30:49.832Z DEBUG modem << OK\x0D
    2019-07-12T07:30:49.837Z DEBUG modem >> AT+CEREG=2\x0D\x0A
    2019-07-12T07:30:49.841Z DEBUG modem << OK\x0D\x0A
    2019-07-12T07:30:49.845Z DEBUG modem >> AT+CEREG?\x0D\x0A
    2019-07-12T07:30:49.852Z DEBUG modem << +CEREG: 2,4,"FFFE","FFFFFFFF",9\x0D\x0A
    2019-07-12T07:30:49.854Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:30:49.861Z DEBUG modem >> AT%CESQ=1\x0D\x0A
    2019-07-12T07:30:49.870Z DEBUG modem << OK\x0D
    2019-07-12T07:30:49.874Z DEBUG modem >> AT+CESQ\x0D\x0A
    2019-07-12T07:30:49.881Z DEBUG modem << +CESQ: 99,99,255,255,255,255\x0D\x0A
    2019-07-12T07:30:49.888Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:30:49.893Z DEBUG modem >> AT%XSIM=1\x0D\x0A
    2019-07-12T07:30:49.902Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:30:49.905Z DEBUG modem >> AT%XSIM?\x0D\x0A
    2019-07-12T07:30:49.913Z DEBUG modem << %XSIM: 1\x0D\x0A
    2019-07-12T07:30:49.914Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:30:49.929Z DEBUG modem >> AT+CPIN?\x0D\x0A
    2019-07-12T07:30:49.939Z DEBUG modem << +CPIN: READY\x0D\x0A
    2019-07-12T07:30:49.940Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:30:49.945Z DEBUG modem >> AT+CPINR="SIM PIN"\x0D\x0A
    2019-07-12T07:30:49.959Z DEBUG modem << +CPINR: "SIM PIN",3\x0D\x0A
    2019-07-12T07:30:49.961Z DEBUG modem << OK\x0D
    2019-07-12T07:30:49.971Z DEBUG modem >> AT+CIMI\x0D\x0A
    2019-07-12T07:30:49.977Z DEBUG modem << 901280990314292\x0D\x0A
    2019-07-12T07:30:49.978Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:30:49.979Z INFO IMSIdentity: 901280990314292
    2019-07-12T07:31:53.264Z DEBUG modem >> AT+CFUN=4\x0D\x0A
    2019-07-12T07:31:53.314Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:32:12.661Z DEBUG modem >> AT%XSYSTEMMODE=0,1,0,0\x0D\x0A
    2019-07-12T07:32:12.675Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:32:18.368Z DEBUG modem >> AT%XEPCO=0\x0D\x0A
    2019-07-12T07:32:18.380Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:32:24.199Z DEBUG modem >> AT+CGDCONT=0,"IP","ciot.vodafone.com"\x0D\x0A
    2019-07-12T07:32:24.212Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:32:28.405Z DEBUG modem >> AT+CGAUTH=0,"PAP","vodafone","vodafone"\x0D\x0A
    2019-07-12T07:32:28.423Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:32:46.911Z DEBUG modem >> AT+COPS=1,2,"27201"\x0D\x0A
    2019-07-12T07:32:46.925Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:32:53.219Z DEBUG modem >> AT+CFUN=1\x0D\x0A
    2019-07-12T07:32:53.262Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:33:11.103Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2019-07-12T07:33:11.115Z DEBUG modem << +CFUN: 1\x0D
    2019-07-12T07:33:11.119Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:33:11.120Z DEBUG modem >> AT+CGSN=1\x0D\x0A
    2019-07-12T07:33:11.134Z DEBUG modem << +CGSN: "352656100110413"\x0D\x0A
    2019-07-12T07:33:11.136Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:33:11.139Z DEBUG modem >> AT+CGMI\x0D\x0A
    2019-07-12T07:33:11.152Z DEBUG modem << Nordic Semiconductor ASA\x0D
    2019-07-12T07:33:11.153Z DEBUG modem << \x0A
    2019-07-12T07:33:11.154Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:33:11.157Z DEBUG modem >> AT+CGMM\x0D\x0A
    2019-07-12T07:33:11.169Z DEBUG modem << nRF9160-SICA\x0D\x0A
    2019-07-12T07:33:11.170Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:33:11.173Z DEBUG modem >> AT+CGMR\x0D\x0A
    2019-07-12T07:33:11.183Z DEBUG modem << mfw_nrf9160_1.0.0\x0D\x0A
    2019-07-12T07:33:11.184Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:33:11.185Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.0.0] SerNr: 352656100110413
    2019-07-12T07:33:11.187Z DEBUG modem >> AT+CEMODE?\x0D\x0A
    2019-07-12T07:33:11.199Z DEBUG modem << +CEMODE: 0\x0D\x0A
    2019-07-12T07:33:11.200Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:33:11.203Z DEBUG modem >> AT%XCBAND=?\x0D\x0A
    2019-07-12T07:33:11.219Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,17,19,20,25,26,28,66)\x0D
    2019-07-12T07:33:11.219Z DEBUG modem << \x0A
    2019-07-12T07:33:11.220Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:33:11.223Z DEBUG modem >> AT+CMEE?\x0D\x0A
    2019-07-12T07:33:11.235Z DEBUG modem << +CMEE: 1\x0D\x0A
    2019-07-12T07:33:11.236Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:33:11.239Z DEBUG modem >> AT+CNEC?\x0D\x0A
    2019-07-12T07:33:11.250Z DEBUG modem << +CNEC: 24\x0D\x0A
    2019-07-12T07:33:11.252Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:33:11.254Z DEBUG modem >> AT+CGEREP?\x0D\x0A
    2019-07-12T07:33:11.265Z DEBUG modem << +CGEREP: 1,0\x0D
    2019-07-12T07:33:11.266Z DEBUG modem << \x0A
    2019-07-12T07:33:11.266Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:33:11.269Z DEBUG modem >> AT+CIND=1,1,1\x0D\x0A
    2019-07-12T07:33:11.281Z DEBUG modem << OK\x0D\x0A
    2019-07-12T07:33:11.284Z DEBUG modem >> AT+CEREG=2\x0D\x0A
    2019-07-12T07:33:11.296Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:33:11.299Z DEBUG modem >> AT+CEREG?\x0D\x0A
    2019-07-12T07:33:11.313Z DEBUG modem << +CEREG: 2,2,"2332","02574A20",9\x0D\x0A
    2019-07-12T07:33:11.314Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:33:11.317Z DEBUG modem >> AT%CESQ=1\x0D\x0A
    2019-07-12T07:33:11.329Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:33:11.332Z DEBUG modem >> AT+CESQ\x0D\x0A
    2019-07-12T07:33:11.345Z DEBUG modem << +CESQ: 99,99,255,255,255,69\x0D
    2019-07-12T07:33:11.347Z DEBUG modem << \x0A
    2019-07-12T07:33:11.348Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:33:11.353Z DEBUG modem >> AT%XSIM=1\x0D\x0A
    2019-07-12T07:33:11.365Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:33:11.368Z DEBUG modem >> AT%XSIM?\x0D\x0A
    2019-07-12T07:33:11.380Z DEBUG modem << %XSIM: 1\x0D\x0A
    2019-07-12T07:33:11.381Z DEBUG modem << OK\x0D\x0A
    2019-07-12T07:33:11.384Z DEBUG modem >> AT+CPIN?\x0D\x0A
    2019-07-12T07:33:11.395Z DEBUG modem << +CPIN: READY\x0D\x0A
    2019-07-12T07:33:11.398Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:33:11.402Z DEBUG modem >> AT+CPINR="SIM PIN"\x0D\x0A
    2019-07-12T07:33:11.423Z DEBUG modem << +CPINR: "SIM PIN",3\x0D
    2019-07-12T07:33:11.428Z DEBUG modem << \x0A
    2019-07-12T07:33:11.429Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:33:11.432Z DEBUG modem >> AT+CIMI\x0D\x0A
    2019-07-12T07:33:11.445Z DEBUG modem << 901280990314292\x0D\x0A
    2019-07-12T07:33:11.446Z DEBUG modem << OK\x0D\x0A
    2019-07-12T07:33:11.447Z INFO IMSIdentity: 901280990314292
    2019-07-12T07:33:36.222Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2019-07-12T07:33:36.234Z DEBUG modem << +CFUN: 1\x0D
    2019-07-12T07:33:36.238Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:33:36.239Z DEBUG modem >> AT+CGSN=1\x0D\x0A
    2019-07-12T07:33:36.254Z DEBUG modem << +CGSN: "352656100110413"\x0D\x0A
    2019-07-12T07:33:36.255Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:33:36.259Z DEBUG modem >> AT+CGMI\x0D\x0A
    2019-07-12T07:33:36.273Z DEBUG modem << Nordic Semiconductor ASA\x0D\x0A
    2019-07-12T07:33:36.273Z DEBUG modem << OK\x0D
    2019-07-12T07:33:36.276Z DEBUG modem >> AT+CGMM\x0D\x0A
    2019-07-12T07:33:36.288Z DEBUG modem << nRF9160-SICA\x0D\x0A
    2019-07-12T07:33:36.289Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:33:36.292Z DEBUG modem >> AT+CGMR\x0D\x0A
    2019-07-12T07:33:36.302Z DEBUG modem << mfw_nrf9160_1.0.0\x0D\x0A
    2019-07-12T07:33:36.303Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:33:36.304Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.0.0] SerNr: 352656100110413
    2019-07-12T07:33:36.306Z DEBUG modem >> AT+CEMODE?\x0D\x0A
    2019-07-12T07:33:36.318Z DEBUG modem << +CEMODE: 0\x0D\x0A
    2019-07-12T07:33:36.319Z DEBUG modem << OK\x0D
    2019-07-12T07:33:36.322Z DEBUG modem >> AT%XCBAND=?\x0D\x0A
    2019-07-12T07:33:36.337Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,17,19,20,25,26,28,66)\x0D\x0A
    2019-07-12T07:33:36.338Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:33:36.342Z DEBUG modem >> AT+CMEE?\x0D\x0A
    2019-07-12T07:33:36.354Z DEBUG modem << +CMEE: 1\x0D\x0A
    2019-07-12T07:33:36.355Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:33:36.358Z DEBUG modem >> AT+CNEC?\x0D\x0A
    2019-07-12T07:33:36.369Z DEBUG modem << +CNEC: 24\x0D\x0A
    2019-07-12T07:33:36.371Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:33:36.374Z DEBUG modem >> AT+CGEREP?\x0D\x0A
    2019-07-12T07:33:36.386Z DEBUG modem << +CGEREP: 1,0\x0D\x0A
    2019-07-12T07:33:36.387Z DEBUG modem << OK\x0D
    2019-07-12T07:33:36.390Z DEBUG modem >> AT+CIND=1,1,1\x0D\x0A
    2019-07-12T07:33:36.401Z DEBUG modem << OK\x0D
    2019-07-12T07:33:36.404Z DEBUG modem >> AT+CEREG=2\x0D\x0A
    2019-07-12T07:33:36.415Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:33:36.420Z DEBUG modem >> AT+CEREG?\x0D\x0A
    2019-07-12T07:33:36.434Z DEBUG modem << +CEREG: 2,2,"2332","02574A20",9\x0D\x0A
    2019-07-12T07:33:36.435Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:33:36.438Z DEBUG modem >> AT%CESQ=1\x0D\x0A
    2019-07-12T07:33:36.450Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:33:36.453Z DEBUG modem >> AT+CESQ\x0D\x0A
    2019-07-12T07:33:36.467Z DEBUG modem << +CESQ: 99,99,255,255,255,69\x0D\x0A
    2019-07-12T07:33:36.468Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:33:36.470Z DEBUG modem >> AT%XSIM=1\x0D\x0A
    2019-07-12T07:33:36.482Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:33:36.485Z DEBUG modem >> AT%XSIM?\x0D\x0A
    2019-07-12T07:33:36.499Z DEBUG modem << %XSIM: 1\x0D\x0A
    2019-07-12T07:33:36.500Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:33:36.503Z DEBUG modem >> AT+CPIN?\x0D\x0A
    2019-07-12T07:33:36.516Z DEBUG modem << +CPIN: READY\x0D\x0A
    2019-07-12T07:33:36.517Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:33:36.522Z DEBUG modem >> AT+CPINR="SIM PIN"\x0D\x0A
    2019-07-12T07:33:36.544Z DEBUG modem << +CPINR: "SIM PIN",3\x0D\x0A
    2019-07-12T07:33:36.545Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:33:36.550Z DEBUG modem >> AT+CIMI\x0D\x0A
    2019-07-12T07:33:36.567Z DEBUG modem << 901280990314292\x0D\x0A
    2019-07-12T07:33:36.568Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:33:36.568Z INFO IMSIdentity: 901280990314292
    2019-07-12T07:34:03.356Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2019-07-12T07:34:03.359Z DEBUG modem << +CFUN: 1\x0D
    2019-07-12T07:34:03.370Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:34:03.374Z DEBUG modem >> AT+CGSN=1\x0D\x0A
    2019-07-12T07:34:03.385Z DEBUG modem << +CGSN: "352656100110413"\x0D\x0A
    2019-07-12T07:34:03.386Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:34:03.392Z DEBUG modem >> AT+CGMI\x0D\x0A
    2019-07-12T07:34:03.401Z DEBUG modem << Nordic Semiconductor ASA\x0D\x0A
    2019-07-12T07:34:03.402Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:34:03.405Z DEBUG modem >> AT+CGMM\x0D\x0A
    2019-07-12T07:34:03.408Z DEBUG modem << nRF9160-SICA\x0D\x0A
    2019-07-12T07:34:03.409Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:34:03.412Z DEBUG modem >> AT+CGMR\x0D\x0A
    2019-07-12T07:34:03.420Z DEBUG modem << mfw_nrf9160_1.0.0\x0D\x0A
    2019-07-12T07:34:03.421Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:34:03.422Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.0.0] SerNr: 352656100110413
    2019-07-12T07:34:03.425Z DEBUG modem >> AT+CEMODE?\x0D\x0A
    2019-07-12T07:34:03.435Z DEBUG modem << +CEMODE: 0\x0D\x0A
    2019-07-12T07:34:03.436Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:34:03.441Z DEBUG modem >> AT%XCBAND=?\x0D\x0A
    2019-07-12T07:34:03.453Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,17,19,20,25,26,28,66)\x0D\x0A
    2019-07-12T07:34:03.454Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:34:03.458Z DEBUG modem >> AT+CMEE?\x0D\x0A
    2019-07-12T07:34:03.469Z DEBUG modem << +CMEE: 1\x0D\x0A
    2019-07-12T07:34:03.470Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:34:03.473Z DEBUG modem >> AT+CNEC?\x0D\x0A
    2019-07-12T07:34:03.477Z DEBUG modem << +CNEC: 24\x0D
    2019-07-12T07:34:03.478Z DEBUG modem << \x0A
    2019-07-12T07:34:03.479Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:34:03.487Z DEBUG modem >> AT+CGEREP?\x0D\x0A
    2019-07-12T07:34:03.493Z DEBUG modem << +CGEREP: 1,0\x0D\x0A
    2019-07-12T07:34:03.494Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:34:03.501Z DEBUG modem >> AT+CIND=1,1,1\x0D\x0A
    2019-07-12T07:34:03.505Z DEBUG modem << OK\x0D\x0A
    2019-07-12T07:34:03.508Z DEBUG modem >> AT+CEREG=2\x0D\x0A
    2019-07-12T07:34:03.520Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:34:03.523Z DEBUG modem >> AT+CEREG?\x0D\x0A
    2019-07-12T07:34:03.538Z DEBUG modem << +CEREG: 2,2,"2332","02574A20",9\x0D\x0A
    2019-07-12T07:34:03.539Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:34:03.544Z DEBUG modem >> AT%CESQ=1\x0D\x0A
    2019-07-12T07:34:03.556Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:34:03.559Z DEBUG modem >> AT+CESQ\x0D\x0A
    2019-07-12T07:34:03.572Z DEBUG modem << +CESQ: 99,99,255,255,255,69\x0D\x0A
    2019-07-12T07:34:03.573Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:34:03.577Z DEBUG modem >> AT%XSIM=1\x0D\x0A
    2019-07-12T07:34:03.589Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:34:03.592Z DEBUG modem >> AT%XSIM?\x0D\x0A
    2019-07-12T07:34:03.603Z DEBUG modem << %XSIM: 1\x0D
    2019-07-12T07:34:03.604Z DEBUG modem << \x0A
    2019-07-12T07:34:03.605Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:34:03.609Z DEBUG modem >> AT+CPIN?\x0D\x0A
    2019-07-12T07:34:03.622Z DEBUG modem << +CPIN: READY\x0D\x0A
    2019-07-12T07:34:03.623Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:34:03.627Z DEBUG modem >> AT+CPINR="SIM PIN"\x0D\x0A
    2019-07-12T07:34:03.647Z DEBUG modem << +CPINR: "SIM PIN",3\x0D\x0A
    2019-07-12T07:34:03.648Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:34:03.653Z DEBUG modem >> AT+CIMI\x0D\x0A
    2019-07-12T07:34:03.665Z DEBUG modem << 901280990314292\x0D\x0A
    2019-07-12T07:34:03.666Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T07:34:03.668Z INFO IMSIdentity: 901280990314292
  • Hi Ian,
    • I think it could be okay, but I would recommend just to run the at_client sample to avoid any interference from the asset_tracker sample.
    • It would be nice to have it confirmed that the V-SIM is working as it should.
    • It would be a good idea to contact your carrier and confirm if there is something special that needs to be done to be able to connect to their network.
    Best Regards,
    Martin L.
  • Hi Ian,
    That's strange.
    Could you confirm that you wait at least ~5mins after turning ON the modem and then send the AT+CFUN? command?
    The first time connecting to an nb-IoT network can take some time.
  • No I left it for an hour with no success!
    What about roaming?
    Do you have any other UK or Irish clients who have manged to get it going?
    Here is the log....
    2019-07-12T13:13:24.915Z INFO Application data folder: C:\Users\Ian\AppData\Roaming\nrfconnect\pc-nrfconnect-linkmonitor
    2019-07-12T13:13:24.994Z DEBUG App pc-nrfconnect-linkmonitor v1.0.0 official
    2019-07-12T13:13:24.994Z DEBUG App path: C:\Users\Ian\.nrfconnect-apps\node_modules\pc-nrfconnect-linkmonitor
    2019-07-12T13:13:24.994Z DEBUG nRFConnect 3.0.0 is supported by the app (^3.0.0)
    2019-07-12T13:13:24.994Z DEBUG nRFConnect path: C:\Users\Ian\AppData\Local\Programs\nrfconnect\resources\app.asar
    2019-07-12T13:13:24.994Z DEBUG HomeDir: C:\Users\Ian
    2019-07-12T13:13:24.994Z DEBUG TmpDir: C:\Users\Ian\AppData\Local\Temp
    2019-07-12T13:13:30.145Z INFO Modem port is opened
    2019-07-12T13:13:30.150Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2019-07-12T13:13:34.899Z INFO Modem port is closed
    2019-07-12T13:13:34.905Z INFO Modem port is opened
    2019-07-12T13:13:34.912Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2019-07-12T13:13:45.043Z INFO Modem port is opened
    2019-07-12T13:13:45.046Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2019-07-12T13:13:45.059Z DEBUG modem << +CFUN: 4\x0D\x0A
    2019-07-12T13:13:45.060Z DEBUG modem << OK\x0D
    2019-07-12T13:13:45.072Z DEBUG modem >> AT+CFUN=1\x0D\x0A
    2019-07-12T13:13:45.114Z DEBUG modem << OK\x0D
    2019-07-12T13:13:50.318Z DEBUG modem >> AT+CFUN=4\x0D\x0A
    2019-07-12T13:13:50.349Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T13:14:09.993Z DEBUG modem >> AT%XSYSTEMMODE=0,1,0,0\x0D\x0A
    2019-07-12T13:14:10.007Z DEBUG modem << OK\x0D\x0A
    2019-07-12T13:14:14.247Z DEBUG modem >> AT%XEPCO=0\x0D\x0A
    2019-07-12T13:14:14.259Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T13:14:15.599Z DEBUG modem >> AT+CGDCONT=0,"IP","ciot.vodafone.com"\x0D\x0A
    2019-07-12T13:14:15.613Z DEBUG modem << OK\x0D
    2019-07-12T13:14:17.549Z DEBUG modem >> AT+CGAUTH=0,"PAP","vodafone","vodafone"\x0D\x0A
    2019-07-12T13:14:17.564Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T13:14:22.542Z DEBUG modem >> AT+COPS=1,2,"90128"\x0D\x0A
    2019-07-12T13:14:22.557Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T13:14:28.288Z DEBUG modem >> AT+CFUN=1\x0D\x0A
    2019-07-12T13:14:28.329Z DEBUG modem << OK\x0D\x0A
    2019-07-12T14:17:31.667Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2019-07-12T14:17:31.671Z DEBUG modem << +CFUN: 1\x0D\x0A
    2019-07-12T14:17:31.677Z DEBUG modem << OK\x0D\x0A
    2019-07-12T14:17:31.681Z DEBUG modem >> AT+CGSN=1\x0D\x0A
    2019-07-12T14:17:31.686Z DEBUG modem << +CGSN: "352656100110413"\x0D\x0A
    2019-07-12T14:17:31.687Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T14:17:31.690Z DEBUG modem >> AT+CGMI\x0D\x0A
    2019-07-12T14:17:31.698Z DEBUG modem << Nordic Semiconductor ASA\x0D\x0A
    2019-07-12T14:17:31.701Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T14:17:31.704Z DEBUG modem >> AT+CGMM\x0D\x0A
    2019-07-12T14:17:31.708Z DEBUG modem << nRF9160-SICA\x0D\x0A
    2019-07-12T14:17:31.709Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T14:17:31.714Z DEBUG modem >> AT+CGMR\x0D\x0A
    2019-07-12T14:17:31.719Z DEBUG modem << mfw_nrf9160_1.0.0\x0D\x0A
    2019-07-12T14:17:31.720Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T14:17:31.721Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.0.0] SerNr: 352656100110413
    2019-07-12T14:17:31.723Z DEBUG modem >> AT+CEMODE?\x0D\x0A
    2019-07-12T14:17:31.726Z DEBUG modem << +CEMODE: 0\x0D\x0A
    2019-07-12T14:17:31.730Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T14:17:31.735Z DEBUG modem >> AT%XCBAND=?\x0D\x0A
    2019-07-12T14:17:31.747Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,17,19,20,25,26,28,66)\x0D\x0A
    2019-07-12T14:17:31.749Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T14:17:31.754Z DEBUG modem >> AT+CMEE?\x0D\x0A
    2019-07-12T14:17:31.758Z DEBUG modem << +CMEE: 0\x0D
    2019-07-12T14:17:31.759Z DEBUG modem << \x0A
    2019-07-12T14:17:31.760Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T14:17:31.767Z DEBUG modem >> AT+CMEE=1\x0D\x0A
    2019-07-12T14:17:31.770Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T14:17:31.773Z DEBUG modem >> AT+CNEC?\x0D\x0A
    2019-07-12T14:17:31.777Z DEBUG modem << +CNEC: 0\x0D\x0A
    2019-07-12T14:17:31.777Z DEBUG modem << OK\x0D\x0A
    2019-07-12T14:17:31.781Z DEBUG modem >> AT+CNEC=24\x0D\x0A
    2019-07-12T14:17:31.785Z DEBUG modem << OK\x0D
    2019-07-12T14:17:31.788Z DEBUG modem >> AT+CGEREP?\x0D\x0A
    2019-07-12T14:17:31.792Z DEBUG modem << +CGEREP: 0,0\x0D\x0A
    2019-07-12T14:17:31.793Z DEBUG modem << OK\x0D\x0A
    2019-07-12T14:17:31.798Z DEBUG modem >> AT+CGDCONT?\x0D\x0A
    2019-07-12T14:17:31.805Z DEBUG modem << +CGDCONT: 0,"IP","ciot.vodafone.com","",0,0\x0D
    2019-07-12T14:17:31.806Z DEBUG modem << \x0A
    2019-07-12T14:17:31.806Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T14:17:31.815Z DEBUG modem >> AT+CGACT?\x0D\x0A
    2019-07-12T14:17:31.819Z DEBUG modem << +CGACT: 0,0\x0D\x0A
    2019-07-12T14:17:31.820Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T14:17:31.824Z DEBUG modem >> AT+CGEREP=1\x0D\x0A
    2019-07-12T14:17:31.827Z DEBUG modem << OK\x0D
    2019-07-12T14:17:31.830Z DEBUG modem >> AT+CIND=1,1,1\x0D\x0A
    2019-07-12T14:17:31.834Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T14:17:31.837Z DEBUG modem >> AT+CEREG=2\x0D\x0A
    2019-07-12T14:17:31.841Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T14:17:31.844Z DEBUG modem >> AT+CEREG?\x0D\x0A
    2019-07-12T14:17:31.851Z DEBUG modem << +CEREG: 2,2,"FFFE","FFFFFFFF",9\x0D\x0A
    2019-07-12T14:17:31.852Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T14:17:31.856Z DEBUG modem >> AT%CESQ=1\x0D\x0A
    2019-07-12T14:17:31.859Z DEBUG modem << OK\x0D\x0A
    2019-07-12T14:17:31.865Z DEBUG modem >> AT+CESQ\x0D\x0A
    2019-07-12T14:17:31.871Z DEBUG modem << +CESQ: 99,99,255,255,255,255\x0D\x0A
    2019-07-12T14:17:31.872Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T14:17:31.876Z DEBUG modem >> AT%XSIM=1\x0D\x0A
    2019-07-12T14:17:31.882Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T14:17:31.887Z DEBUG modem >> AT%XSIM?\x0D\x0A
    2019-07-12T14:17:31.890Z DEBUG modem << %XSIM: 1\x0D\x0A
    2019-07-12T14:17:31.891Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T14:17:31.896Z DEBUG modem >> AT+CPIN?\x0D\x0A
    2019-07-12T14:17:31.902Z DEBUG modem << +CPIN: READY\x0D\x0A
    2019-07-12T14:17:31.904Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T14:17:31.907Z DEBUG modem >> AT+CPINR="SIM PIN"\x0D\x0A
    2019-07-12T14:17:31.920Z DEBUG modem << +CPINR: "SIM PIN",3\x0D\x0A
    2019-07-12T14:17:31.921Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T14:17:31.926Z DEBUG modem >> AT+CIMI\x0D\x0A
    2019-07-12T14:17:31.932Z DEBUG modem << 901280990314292\x0D\x0A
    2019-07-12T14:17:31.933Z DEBUG modem << OK\x0D\x0A\x00
    2019-07-12T14:17:31.934Z INFO IMSIdentity: 901280990314292
