Not connecting to nRFCloud
Hi, we have an nRF9160DK (0.8.3) and it does not connect to the nrfcloud.
We have updated to the latest firmware 1.0.0
We only have nb-iot here so we  didn't use the iBasis sim, instead using a vodafone V-Sim (which is active).
Are we missing a step here?
Thanks
  • Hi.
    Is it only when you have CONFIG_AT_CMD_RESPONSE_MAX_LEN =2560 in your prj.conf you have problems connecting to the device?
    If so, I would not worry too much about it or try a lower number.
    It looks like you are missing your nRF Cloud certificates. If you have previously registered the device to your nRF Cloud user, you can use the steps explained here to recover them.
    Didrik
  • HI Didrik,
    No putting back the setting has no affect.
    Any ideas how I can get it to connect (we've tried re-starting the machine etc).
    I can't find any documentation on this error.
    Thanks
  • Hi Didrik,
    I have no idea why it stopped working but we re-installed Segger and the project, this worked and it can connect / build+run etc again :)
    We use Kiel here and are not familiar with Segger, it seems complex and buggy or maybe we just are not used to it.
    We have never registered the device on the cloud so how would we have certificates?
    Also how exactly do we get the certificates?
    Using the URLs with our API Key in the Chrome window doesn't seem to work (we just get search results).
    Here are the actual commands we are putting into URL text box:
    http api.nrfcloud.com/.../devices Authorization:"Bearer b8c3ad8b60e4abb110bb67421346f274586306e2"
    POST api.nrfcloud.com/.../<device ID>/certificates Authorization:"Bearer b8c3ad8b60e4abb110bb67421346f274586306e2"
    Are they formatted OK?
    If we remove the http and POST we get this for both.
        "message": "Missing Authentication Token",
        "type":  "MISSING_AUTHENTICATION_TOKEN",
        "resourcePath":  "",
        "statusCode": "'404'"
    Any ideas?
    Ian
  • Hi.
    The "http" commands should be run in the command line after installing httpie. <device ID> should be replaced with the device ID you get from the first command.
    However, if your device is not registered to your account in nRF Cloud you will not get any devices. I am working on what to do in that case and will come back to you as soon as I have an answer.
    Didrik
  • Thanks Didrik,
    Just to explain what we did, since we have rev 0.8.3 there doesn't seem to be a way to register.
    First it asks you for the SIM details which I assume is only for iBasis and since we have a Vodafone SIM we clicked the "already have an active SIM link" (Vodafone SIM is active and working). Since we have an old DK we press that link too.
    Also below is the CMD line output for the commands.
    Ian
    Ian
