Please kindly help to push this emergent issue!!!
We detected CLK signal using oscilloscope as picture below:
We can see that clock frequency is set to 32MHz,but we detected the rise time is nearly 4.2ns, from the AMOLED specification, rise/fall time has to be limited under 2ns, otherwise, it will leads to unpredictable read or write faulty issue 。
Feedback from AMOLED vendor shows that clock rise time and fall time must be within the specification(less than 2ns),
Moreover,we probed the setup/hold timing for CLK and MOSI, as below.
It is not equal for setup time and hold time,setup time is much less than hold time
My question as below:
1. Please help to confirm if there is a solution for this issue to reduce the rise/fall time,which means a big issue for our product design
2. Is there some solution to change the timing charcteristic for CLK and MOSI from MCU firmware,?It will be much better if setup time can match with hold time,which is highly recommended by AMOLED vendor.
Looking forward to your reply A.S.A.P.
