Enter in SYSTEM ON doest not work
Hello everyone,
I'm using the nrf52840 Dev Kit (PCA10056 1.1.0 2019.19 683465548)
SDK version: 15.3
OS: Fedora
I work on a custom board and try to put it in SYSTEM ON mode like so:
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
log_init();
NRF_LOG_INFO("App start\n");
NRF_LOG_FLUSH();
power_management_init();
for (;;) {
nrf_pwr_mgmt_run();
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
When I measure my consommation with OTII I get 4 mA instead of 1.5 uA according to this link (Debugging: Section 4).
Any ideas?
Louis
  • Hi Louis
    As stated in the link you provided, this means the CPU is still running for some reason. Seeing as you're using a logger, I assume your application doesn't handle pending log operations before it goes to sleep, which causes the CPU to keep running.
    Could you try adding the idle_state_handle(); in your for loop instead of the nrf_pwr_mgmt_run(); as idle_state_handle(); handles pending log operations, then sleeps until the next event occurs.
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    10
    11
    * @details Handle any pending log operation(s), then sleep until the next event occurs.
    nrf_pwr_mgmt_run();
    Due to the summer holidays in Norway, our support team is understaffed this week, and delayed replies must be expected. Sorry for the inconvenience!
    Simon
  • Hi Simonr
    I tried with idle_state_handle function and now I have 2.6 mA instead of 1.5 uA.
    I compiled and run the pwr_mgmt example with no modification except commenting some lines like so:
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    // APP_ERROR_CHECK(NRF_LOG_INIT(NULL));
    // NRF_LOG_DEFAULT_BACKENDS_INIT();
    // NRF_LOG_INFO("Power Management example");
    lfclk_config();
    uint32_t err_code = app_timer_init();
    // #if NRF_PWR_MGMT_CONFIG_USE_SCHEDULER
    // APP_SCHED_INIT(APP_SCHED_MAX_EVENT_SIZE, APP_SCHED_QUEUE_SIZE);
    // #endif // NRF_PWR_MGMT_CONFIG_USE_SCHEDULER
    // bsp_configuration();
    ret_code_t ret_code = nrf_pwr_mgmt_init();
    APP_ERROR_CHECK(ret_code);
    while (true)
    and my consommation is 4 mA..
    I don't know how to get 1.5 uA.
    Any ideas?
  • If I unplug my JLink from my custom board I get 2.6 mA on pwr_mgmt example too.
  • Hi Louis
    How are you measuring your current consumption? I just tested the pwr_mgmt example myself and were able to measure ~570uA when the application was running, and ~0.3uA when I pressed button 1 to go to sleep mode using the PPK and an nRF52840DK. Additionally, when commenting out the same lines as you, I get a constant 2.3uA current using the same measurement setup.
    Simon
  • Hi Simonr
    I returned into my application project code and:
    1. Set DCDC mode in my main
    2. Enable NRF_PWR_MGMT_CONFIG_USE_SCHEDULER in my SDK config
    3. Fix an external peripheral problem ( which was drawning the 2 mA .... )
    Now I measure ~580µA when I'm in SYSTEM ON just like you in your pwr_mgmt project.
    I would like to go below 10µA, but i don't understand how the lines i have commented out in the pwr_mgmt project brought you from 570µA to 2.3µA.
    From my understanding, i have only commented Logs and AppScheduler which are not supposed to consume extra power.
    Why do you get 2.3µA instead of 570µA when commenting lines I commented in pwr_mgmt example ?
    Thanks
1 2
