Dear Team,
what is the way to do it in Zephyr?
I have a signal up-to 10kHz, what is the best way to keep the counter in the background?
Thank you and best
Oleh
Dear Team,
Thank you and best
Oleh
thank you, now I am trying to make it working on the latest ncs git... but getting errors...
is there anything I have to change?
***** Booting Zephyr OS build v1.14.99-ncs3-snapshot2-2647-gd6e67554cfeb *****
starting application...
starting init gpiote...
prepare time 1 cfg...
uninit time 1...
init time 1...
prepare time 2 cfg...
uninit time 2...
init time 2...
nrfx_timer_ms_to_ticks...
nrfx_timer_extended_compare...
gpiote_setup...
gpiote_setup...
gpiote_evt_addr: 0x5000d100
NRF_GPIOTE_EVENTS_IN_0: 0x00000100
NRF_GPIOTE1_NS: 0x40031000
gpiote_evt_addr - NRF_GPIOTE0_S: 0x0ffdc100
[00:00:00.069,274] <err> os: ***** BUS FAULT *****
[00:00:00.069,274] <err> os: Precise data bus error
[00:00:00.069,274] <err> os: BFAR Address: 0x40010088
[00:00:00.069,305] <err> os: r0/a1: 0x00000000 r1/a2: 0x00000001 r2/a3: 0x80000000
[00:00:00.069,305] <err> os: r3/a4: 0x40010088 r12/ip: 0x00000030 r14/lr: 0x0000061f
[00:00:00.069,305] <err> os: xpsr: 0x29000000
[00:00:00.069,305] <err> os: Faulting instruction address (r15/pc): 0x00000632
[00:00:00.069,335] <err> os: >>> ZEPHYR FATAL ERROR 0: CPU exception
[00:00:00.069,335] <err> os: Current thread: 0x20000274 (unknown)
[00:00:00.140,075] <err> os: Halting system
Hi.
A pull request for a sample demonstrating how to use the nrfx drivers in Zephyr was just opened.
Hopefully, it is able to help you.
https://github.com/zephyrproject-rtos/zephyr/pull/20089/files
Didrik
Hello and thank you!
short question: what is the best way to suspend / resume the ppi in this sample?
and how to safely reset counters?
Hi, and sorry for the late reply.
For resetting counters, I would use the nrfx_timer_clear function.
For suspending/resuming DPPI, you would have to either stop the events from being generated, not publish the events, or subscribe to them (or all at once).
Hi and thank you for your input.
I managed to update and make the code working! great! thank you!
Regarding the Suspend/Resume, just for info: I need it in order to save power, as the sensor is external and connected to a stepup convertor, so when not in use -- I would like to power it off. Thus also disable DPPI.
Best regards
Oleh
