SPI Two Reads in a Row, First Works, Second is Cut Off
SDK v15.2.0 using peripheral spi example. Windows 8.1, uploading to nRF52 DK.
 * Copyright (c) 2015 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
#include "bma2x2.h"
#include "nrf_drv_spi.h"
#include "nrf_delay.h"
#include "boards.h"
#include "app_error.h"
#include <string.h>
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define SPI_INSTANCE  0 /**< SPI instance index. */
static const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE);  /**< SPI instance. */
static volatile bool spi_xfer_done;  /**< Flag used to indicate that SPI instance completed the transfer. */
#define BMA2x2_SPI_BUS_WRITE_CONTROL_BYTE	0x7F
#define BMA2x2_SPI_BUS_READ_CONTROL_BYTE	0x80
#define SPI_BUFFER_LEN                      5
static uint8_t       m_rx_buf[SPI_BUFFER_LEN];        /**< RX buffer. */
#define BMA_ERROR_CHECK(ERR_CODE) { APP_ERROR_CHECK((ret_code_t) ERR_CODE); }
 * @brief SPI user event handler.
 * @param event
void spi_event_handler(nrf_drv_spi_evt_t const * p_event,
                       void *                    p_context)
    spi_xfer_done = true;
    NRF_LOG_INFO("Transfer completed.");
    if (m_rx_buf[0] != 0)
        NRF_LOG_INFO(" Received: %x", m_rx_buf[0]);
s8 bma_spi_write(u8 dev_addr, u8 reg_addr, u8 *reg_data, u8 cnt)
    s8 error = NO_ERROR;
    uint8_t tx_buf[cnt+1];
    // place write bit + address in first byte
    tx_buf[0] = (reg_addr++) & ~BMA2x2_SPI_BUS_WRITE_CONTROL_BYTE;
    for (uint8_t string_pos = 1; string_pos < cnt+1; string_pos++)
        // place data in second byte
        tx_buf[string_pos] = *(reg_data + string_pos - 1);
    spi_xfer_done = false;
    error = (s8) nrf_drv_spi_transfer(&spi, tx_buf, cnt+1, NULL, 0);
    BMA_ERROR_CHECK(error);
    return error;
s8 bma_spi_read(u8 dev_addr, u8 reg_addr, u8 *reg_data, u8 cnt)
    uint8_t tx_buf[1] = {reg_addr|BMA2x2_SPI_BUS_READ_CONTROL_BYTE};
    error = (s8) nrf_drv_spi_transfer(&spi, tx_buf, 1, reg_data, cnt);
    return error;
void spi_delay(u32 millis_time)
    nrf_delay_ms(millis_time);
    nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
    spi_config.ss_pin   = SPI_SS_PIN; //29 -> 17
    spi_config.miso_pin = SPI_MISO_PIN; //28 -> 8
    spi_config.mosi_pin = SPI_MOSI_PIN; //4 -> 6
    spi_config.sck_pin  = SPI_SCK_PIN; //3 -> 15
    spi_config.mode = NRF_DRV_SPI_MODE_3;
    spi_config.bit_order = NRF_SPI_BIT_ORDER_MSB_FIRST;
    APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL));
    NRF_LOG_INFO("SPI hardware initialised.");
    struct bma2x2_t bma2x2;
    bma2x2.chip_id = BMA2x2_INIT_VALUE;
    bma2x2.bus_write = &bma_spi_write;
    bma2x2.bus_read = &bma_spi_read;
    bma2x2.dev_addr = 102; // Random value. No chip select mechanism in place
    bma2x2.delay_msec = &spi_delay;
    BMA_ERROR_CHECK(bma2x2_init(&bma2x2));
    if (bma2x2.chip_id == 0xFD)
        NRF_LOG_INFO("BMA API initialised.");
        NRF_LOG_INFO("BMA chip id: %x", bma2x2.chip_id);
    while (1)
        u8 m_rx[1] = {0xFF};
        bma_spi_read(0, 0, m_rx, sizeof(m_rx));
        NRF_LOG_INFO("m_rx: %x", m_rx[0]);
        nrf_delay_us(2);
        NRF_LOG_INFO("m_rx_2: %x", m_rx[0]);
        while (!spi_xfer_done)
            __WFE();
        NRF_LOG_FLUSH();
        nrf_delay_ms(1000);
In my while loop I use bma_spi_read() twice with a small delay in between. The first call includes 16 clock pulses as expected but the second only includes 8. I do not know why.
spi waveform
