I see from the event log that you have replied, edited something and deleted a reply. Also I noticed that the original ticket text is gone. I am not sure whether this was on purpose or not, but just as you know, I can't see anything more in this ticket now, and consider it closed until you update it or reply.
NB: We can only see that something is edited, and not what the edit actually was, so the best is to reply instead of editing existing replies.
Edvin
Hi. Long time no see.
Thanks to you,
we have confirmed the connection between the < ble_app_lbs_nus_its_multi_role> example and
<ble_app_lbs_nus> examples.
I would like to ask another issue.
I connect the < ble_app_lbs_nus_its_multi_role> example to a mobile phone (nrf toolbox / ios) and the data entered in the uart terminal does not reach the mobile phone (nrf toolbox / ios).
Connecting the example to a mobile phone (nrf toolbox / ios) and entering data into the uart terminal is successfully sent.
A. Example <ble_app_lbs_nus_its_multi_role> and the Mobile Connection Screen
<UART>
(Tx "DATA SEND")
<NRF TOOLBOX(ios)>
not reveive
B. Example <ble_app_lbs_nus> and the Mobile Connection Screen
(Tx "DATA SEND")
<NRF TOOLBOX(ios)>
reveived "data send"
as above I wonder why the ble_app_lbs_nus_its_multi_role example doesn't work.
Below is the project file I used.
I used sdk 15.3
nrf5-ble-multiple-role-example-master.zip
Thank you. Please.
In the case where it doesn't work, what does ble_nus_data_send() return?
Hi
A. <ble_app_lbs_nus_its_multi_role> example
Returns 5
B. <ble_app_lbs_nus> example > [Normal operation example]
Returns 0
As long as it doesn't return 0, the message is not sent.
Can you check where in ble_nus_data_send it returns 5? 5 = NRF_ERROR_NOT_FOUND. It should be in ble_nus.c. Either it is
if ((conn_handle == BLE_CONN_HANDLE_INVALID) || (p_client == NULL))
return NRF_ERROR_NOT_FOUND;
or the softdevice call:
return sd_ble_gatts_hvx(conn_handle, &hvx_params);
It may be easiest to debug and set breakpoints to figure out which one it is, since NRF_LOG is not enabled by default. Alternatively you can enable it by setting BLE_NUS_CONFIG_LOG_ENABLED to 1 in sdk_config.h to be able to use NRF_LOG_INFO in ble_nus.c.
It is a bit tricky to port the ble_app_uart example to support multiple connections. You have to handle all your connection handles correctly. I suggest you take a look in the ble_app_multiperipheral example in SDK\examples\ble_peripheral\experimental\ble_app_multiperipheral.
Especially in the on_connected() funtion in main, where nrf_ble_qwr_conn_handle_assign() is called in this example. The conn handles is an array. It should be the same in your example. You can also see how it uses the connection handle in led_status_send_to_all().
Edvin
