Can not Load nRF Connect project into Segger Studio getting Did not finish "cmake"
I am trying to install the nRF9160 development environment on an additional computer.  We have the system running on 3 computers now but are in the process of setting one up for testing documentation purposes.
I installed following the Getting Stated assistant v1.0.1 directions for installing the tool chain.
We are working on a windows 10 systems.
I have tried matching the versions of the utilities to one of our working systems without success.
This is a list of the Tool chain versions.
amir
Non Working
Karma
Working
cmake
cmake version 3.13.4
cmake version 3.14.5
git
git version 2.22.0.windows.1
git version 2.21.0.windows.1
python
Python 3.7.1
Python 3.7.3
ninja
1.8.2
1.9.0
gperf
GNU gperf 3.1
GNU gperf 3.1
west
West bootstrapper version: v0.5.8 (c:\python37\lib\site-packages\west\_bootstrap)
Segger Studio
ARM(Nordic Edition)V4.18
  • Hi.
    Is cmake in your path?
    Could you paste the output text from Segger Embedded Studio?
    Like this:
    Andreas
  • just to make sure yes cmake is in the path from a command prompt
    Microsoft Windows [Version 10.0.18362.239]
    (c) 2019 Microsoft Corporation. All rights reserved.
    C:\Users\apasdar>cmake -version
    cmake version 3.14.6
    CMake suite maintained and supported by Kitware (kitware.com/cmake).
    C:\Users\apasdar>
    There is nothing in the Segger Studio screen.I am attaching the log files from the build directory
    The target system is: Generic - 1.14.99 - arm
    The host system is: Windows - 10.0.18362 - AMD64
    Compiling the C compiler identification source file "CMakeCCompilerId.c" succeeded.
    Compiler: C:/gnuarmemb/bin/arm-none-eabi-gcc.exe
    Build flags:
    Id flags: -c
    The output was:
    0
    Compilation of the C compiler identification source "CMakeCCompilerId.c" produced "CMakeCCompilerId.o"
    The C compiler identification is GNU, found in "C:/ncs/nrf/samples/nrf9160/mqtt_simple/build_nrf9160_pca10090ns/CMakeFiles/3.14.6/CompilerIdC/CMakeCCompilerId.o"
    Compiling the CXX compiler identification source file "CMakeCXXCompilerId.cpp" succeeded.
    Build flags:
    Id flags: -c
    The output was:
    0
    Compilation of the CXX compiler identification source "CMakeCXXCompilerId.cpp" produced "CMakeCXXCompilerId.o"
    The CXX compiler identification is GNU, found in "C:/ncs/nrf/samples/nrf9160/mqtt_simple/build_nrf9160_pca10090ns/CMakeFiles/3.14.6/CompilerIdCXX/CMakeCXXCompilerId.o"
    Checking whether the ASM compiler is GNU using "--version" matched "(GNU assembler)|(GCC)|(Free Software Foundation)":
    arm-none-eabi-gcc.exe (GNU Tools for Arm Embedded Processors 7-2018-q2-update) 7.3.1 20180622 (release) [ARM/embedded-7-branch revision 261907]
    Copyright (C) 2017 Free Software Foundation, Inc.
    This is free software; see the source for copying conditions.  There is NO
    warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
    Performing C SOURCE FILE Test toolchain_is_ok succeeded with the following output:
    Change Dir: C:/ncs/nrf/samples/nrf9160/mqtt_simple/build_nrf9160_pca10090ns/CMakeFiles/CMakeTmp
    Run Build Command(s):C:/ProgramData/chocolatey/bin/ninja.exe cmTC_2cb7b
    [1/2] Building C object CMakeFiles/cmTC_2cb7b.dir/src.c.obj
    [2/2] Linking C executable cmTC_2cb7b
    c:/gnuarmemb/bin/../lib/gcc/arm-none-eabi/7.3.1/../../../../arm-none-eabi/bin/ld.exe: warning: cannot find entry symbol _start; defaulting to 00008000
    Source file was:
    int main(void) { return 0; }
    Compiling the C compiler identification source file "CMakeCCompilerId.c" failed.
    Build flags:
    Id flags:
    The output was:
    1
    c:/gnuarmemb/bin/../lib/gcc/arm-none-eabi/7.3.1/../../../../arm-none-eabi/lib\libc.a(lib_a-exit.o): In function `exit':
    exit.c:(.text.exit+0x2c): undefined reference to `_exit'
    collect2.exe: error: ld returned 1 exit status
    Compiling the CXX compiler identification source file "CMakeCXXCompilerId.cpp" failed.
    Build flags:
    Id flags:
    The output was:
    1
  • As a Follow up  I replaced the version of cmake with 3.13.4 like on my working system, and copied the gcc compiler from the working system with no difference.
  • Hi.
    You mean you replaced cmake version 3.13.4 with 3.13.5, correct?
    Coul you also try to have the same version of python and ninja as well?
    From the output below it seems like there is an issue with the linker script when you try to build, do you use a new build folder?
    Andreas
  • Hi AndreasF,
    I have exactly the same problem. Did you solve it already?
    schnuckelg
