[nRF52840 + zigbee] About install codes
I will add feature "installation codes".
I guess that security API do work.
At coordinator side, zb_secur_ic_add, zb_set_installcode_policy functions
At end device side, zb_secur_ic_set and zb_set_installcode_policy functions
Questions
1. My understanding is correct ?
2. At zigbee router, how can activate installation codes ?
(Router shall call zb_secur_ic_add or not ?)
3. zb_secur_ic_add and zb_secur_ic_set function save installation infromation into flash ??
4. Where can i find examples using security features?
Thanks.
  • Hi.
    You can take a look at how installation codes are used in the CLI, you can find the code in the SDK under components\zigbee\cli\zigbee_cli_cmd_bdb.c.
    /** @brief Set install code on the device, add information about the install code
     *  on the trust center, set the trust center install code policy.
     * @code
     * bdb ic add <h:install code> <h:eui64>
     * bdb ic set <h:install code>
     * bdb ic policy <enable|disable>
     * @endcode
     * @pre Setting and defining policy only before @ref start "bdb start".
     * Adding only after @ref start "bdb start".
     * <tt>bdb ic set</tt> must only be used on a joining device.
     * <tt>bdb ic add</tt> must only be used on a coordinator.
     * <tt>bdb ic policy</tt> must only be used on a coordinator.
     * Provide the install code as an ASCII-encoded hex including CRC16.
     * For production devices, an install code must be installed by the production
     * configuration present in flash.
     * Example:
     * @code
     * > bdb ic add 83FED3407A939723A5C639B26916D505C3B5 0B010E2F79E9DBFA
     * Done
     * @endcode
    static void cmd_zb_install_code(nrf_cli_t const * p_cli, size_t argc, char **argv)
        const char *   p_err_msg = NULL;
        zb_ieee_addr_t addr;
        zb_uint8_t     ic[ZB_CCM_KEY_SIZE + 2]; // +2 for CRC16
        if (nrf_cli_help_requested(p_cli) || (argc == 1))
            print_usage(p_cli, argv[0],
                        "ic - set or add install code. Enable IC policy.\r\n"
                        "ic set <h:install code> - set the ic code to <install_code>\r\n"
                        "ic add <h:install code> <h:eui64> - add ic for device with given eui43\r\n"
                        "ic policy - set Trust Center install code policy");
            return;
        if ((argc == 2) && (strcmp(argv[0], "set") == 0))
            if (!parse_hex_str(argv[1], ic, 2*sizeof(ic), false))
                p_err_msg = "Failed to parse IC";
                goto exit;
            if (zb_secur_ic_set(ic) != RET_OK)
                p_err_msg = "Failed to set IC";
                goto exit;
        else if ((argc == 3) && (strcmp(argv[0], "add") == 0))
                goto exit;
            if (!parse_long_address(argv[2], addr))
                p_err_msg = "Failed to parse eui64";
                goto exit;
            if (zb_secur_ic_add(addr, ic) != RET_OK)
                p_err_msg = "Failed to add IC";
                goto exit;
        else if ((argc == 2) && (strcmp(argv[0], "policy") == 0))
            if (strcmp(argv[1], "enable") == 0)
                zb_set_installcode_policy(ZB_TRUE);
            else if (strcmp(argv[1], "disable") == 0)
                zb_set_installcode_policy(ZB_FALSE);
                p_err_msg = "Syntax error";
                goto exit;
            p_err_msg ="Syntax error";
    exit:
        if (p_err_msg)
            print_error(p_cli, p_err_msg);
            print_done(p_cli, ZB_FALSE);
    You have to run zb_secur_ic_set at the client side (the side without TC) and you have to run zb_secur_ic_add at the ZC (the side with TC).
    Andreas
  • Thanks for reply.
    I have  more questionㄴ.
    1. At ZR(router) side, what to do for security ?
    2. using
    "zb_secur_ic_set" and
    "zb_secur_ic_add"
    Information is saved in flash ? or volatile ?
    Best reguards.
  • Hi.
    1.
    The router is a joining device before it becomes a router, so you should use zb_secur_ic_set.
    2.
    The information is stored in NVRAM.
    Andreas
  • Thanks.
    Sorry for more questions.
    1. Is there any API to retrieve registered Install Codes with mac at coordinator side ?
      (same question for end device)
    2. How can erase registered(in NVRAM) specific MAC-IC  pair ?
    If there is no way to erase specific tuple, then how to erase all the secure IC ?
    zigbee_erase_persistent_storage(ZB_TRUE) does that ?
    3. I found that PAN_ID setting function in cli souces(in zigbee cli cmd_bdb.c).
    but Changing pan id with "ZB_PIBCACHE_PAN_ID() = pan_id" only update
    cached structure.
    In comment in zboss_api_nwk.h,  "must sync it with MLME-SET".
    What api correspoding "MLME-SET" ?
    Sincerely yours.
  • Hi.
    Can we please clarify what you need help with at this moment? I find it a bit confusing when you have created 4 different tickets in a short time span.
    (devzone.nordicsemi.com/.../233623)
    (devzone.nordicsemi.com/.../233787)
    (devzone.nordicsemi.com/.../233781)
    (devzone.nordicsemi.com/.../233766)
    Can we please keep the discussion in one ticket?
    I would like to keep the discussion in this ticket.
    I will have to talk with out developers about your question, please be patient Blush
    Andreas
