Even if "ble_app_multirole_lesc" that does not change the BLE processing is used, a DHKEY error occurred.
Is there a problem with the development environment and tool settings?
【Development environment】
Compiler: Segger Embedded studio v3.34a
* KEIL project has been changed.
The project file could not be uploaded
ecc was compiled with cygwin's gcc.
/** * Copyright (c) 2016 - 2017, Nordic Semiconductor ASA * * All rights reserved. * * Redistribution and use in source and binary forms, with or without modification, * are permitted provided that the following conditions are met: * * 1. Redistributions of source code must retain the above copyright notice, this * list of conditions and the following disclaimer. * * 2. Redistributions in binary form, except as embedded into a Nordic * Semiconductor ASA integrated circuit in a product or a software update for * such product, must reproduce the above copyright notice, this list of * conditions and the following disclaimer in the documentation and/or other * materials provided with the distribution. * * 3. Neither the name of Nordic Semiconductor ASA nor the names of its * contributors may be used to endorse or promote products derived from this * software without specific prior written permission. * * 4. This software, with or without modification, must only be used with a * Nordic Semiconductor ASA integrated circuit. * * 5. Any software provided in binary form under this license must not be reverse * engineered, decompiled, modified and/or disassembled. * * THIS SOFTWARE IS PROVIDED BY NORDIC SEMICONDUCTOR ASA "AS IS" AND ANY EXPRESS * OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES * OF MERCHANTABILITY, NONINFRINGEMENT, AND FITNESS FOR A PARTICULAR PURPOSE ARE * DISCLAIMED. IN NO EVENT SHALL NORDIC SEMICONDUCTOR ASA OR CONTRIBUTORS BE * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE * GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * */ /** * @brief BLE multirole LESC example application main file. * * @detail This application demonstrates bonding with LE Secure Connections both as a peripheral and as a central. * * Led layout: * LED 1: Central side is scanning LED 2: Central side is connected to a peripheral * LED 3: Peripheral side is advertising LED 4: Peripheral side is connected to a central * * @note: This application requires the use of an external ECC library for public key and shared secret calculation. * Refer to the application's documentation for more details. * */ #include <stdint.h> #include <stdio.h> #include <string.h> #include "nordic_common.h" #include "softdevice_handler.h" #include "peer_manager.h" #include "app_timer.h" #include "boards.h" #include "bsp.h" #include "bsp_btn_ble.h" #include "ble.h" #include "app_uart.h" #include "app_util.h" #include "ble_advdata.h" #include "ble_advertising.h" #include "ble_conn_params.h" #include "ble_db_discovery.h" #include "ble_hrs.h" #include "ble_hrs_c.h" #include "ble_conn_state.h" #include "fstorage.h" #include "fds.h" #include "nrf_crypto.h" #define NRF_LOG_MODULE_NAME "APP" #include "nrf_log.h" #include "nrf_log_ctrl.h" #define LESC_DEBUG_MODE 0 /**< Set to 1 to use LESC debug keys, allows you to use a sniffer to inspect traffic. */ #define LESC_MITM_NC 1 /**< Use MITM (Numeric Comparison). */ #define APP_FEATURE_NOT_SUPPORTED BLE_GATT_STATUS_ATTERR_APP_BEGIN + 2 /**< Reply when unsupported features are requested. */ #if (NRF_SD_BLE_API_VERSION == 3) #define NRF_BLE_MAX_MTU_SIZE GATT_MTU_SIZE_DEFAULT /**< MTU size used in the softdevice enabling and to reply to a BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST event. */ #endif #define CENTRAL_LINK_COUNT 1 /**< Number of central links used by the application. When changing this number remember to adjust the RAM settings*/ #define PERIPHERAL_LINK_COUNT 1 /**< Number of peripheral links used by the application. When changing this number remember to adjust the RAM settings*/ /* Central related. */ #define CENTRAL_SCANNING_LED BSP_BOARD_LED_0 #define CENTRAL_CONNECTED_LED BSP_BOARD_LED_1 #define APP_TIMER_PRESCALER 0 /**< Value of the RTC1 PRESCALER register. */ #define APP_TIMER_MAX_TIMERS (2 + BSP_APP_TIMERS_NUMBER) /**< Maximum number of timers used by the application. */ #define APP_TIMER_OP_QUEUE_SIZE 2 /**< Size of timer operation queues. */ #define SEC_PARAMS_BOND 1 /**< Perform bonding. */ #if LESC_MITM_NC #define SEC_PARAMS_MITM 1 /**< Man In The Middle protection required. */ #define SEC_PARAMS_IO_CAPABILITIES BLE_GAP_IO_CAPS_DISPLAY_ONLY /**< Display Yes/No to force Numeric Comparison. */ #else #define SEC_PARAMS_MITM 0 /**< Man In The Middle protection required. */ #define SEC_PARAMS_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE /**< No I/O caps. */ #endif #define SEC_PARAMS_LESC 1 /**< LE Secure Connections pairing required. */ #define SEC_PARAMS_KEYPRESS 0 /**< Keypress notifications not required. */ #define SEC_PARAMS_OOB 0 /**< Out Of Band data not available. */ #define SEC_PARAMS_MIN_KEY_SIZE 7 /**< Minimum encryption key size in octets. */ #define SEC_PARAMS_MAX_KEY_SIZE 16 /**< Maximum encryption key size in octets. */ #define SCAN_INTERVAL 0x00A0 /**< Determines scan interval in units of 0.625 millisecond. */ #define SCAN_WINDOW 0x0050 /**< Determines scan window in units of 0.625 millisecond. */ #define SCAN_TIMEOUT 0 #define MIN_CONNECTION_INTERVAL (uint16_t) MSEC_TO_UNITS(7.5, UNIT_1_25_MS) /**< Determines minimum connection interval in milliseconds. */ #define MAX_CONNECTION_INTERVAL (uint16_t) MSEC_TO_UNITS(30, UNIT_1_25_MS) /**< Determines maximum connection interval in milliseconds. */ #define SLAVE_LATENCY 0 /**< Determines slave latency in terms of connection events. */ #define SUPERVISION_TIMEOUT (uint16_t) MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Determines supervision time-out in units of 10 milliseconds. */ /**@brief Variable length data encapsulation in terms of length and pointer to data. */ typedef struct { uint8_t * p_data; /**< Pointer to data. */ uint16_t data_len; /**< Length of data. */ } data_t; /** * @brief Parameters used when scanning. */ static const ble_gap_scan_params_t m_scan_params = { .active = 1, .interval = SCAN_INTERVAL, .window = SCAN_WINDOW, .timeout = SCAN_TIMEOUT, #if (NRF_SD_BLE_API_VERSION == 2) .selective = 0, .p_whitelist = NULL, #endif #if (NRF_SD_BLE_API_VERSION == 3) .use_whitelist = 0, #endif }; /**@brief Connection parameters requested for connection. */ static const ble_gap_conn_params_t m_connection_param = { (uint16_t)MIN_CONNECTION_INTERVAL, (uint16_t)MAX_CONNECTION_INTERVAL, 0, (uint16_t)SUPERVISION_TIMEOUT }; static ble_hrs_c_t m_ble_hrs_c; /**< Main structure used by the Heart rate client module. */ static uint16_t m_conn_handle_hrs_c = BLE_CONN_HANDLE_INVALID; /**< Connection handle for the HRS central application */ static ble_db_discovery_t m_ble_db_discovery[CENTRAL_LINK_COUNT + PERIPHERAL_LINK_COUNT]; /**< list of DB structures used by the database discovery module. */ /* Peripheral related. */ #define PERIPHERAL_ADVERTISING_LED BSP_BOARD_LED_2 #define PERIPHERAL_CONNECTED_LED BSP_BOARD_LED_3 #define DEVICE_NAME "NordicLESCApp" /**< Name of device used for advertising. */ #define MANUFACTURER_NAME "NordicSemiconductor" /**< Manufacturer. Will be passed to Device Information Service. */ #define APP_ADV_INTERVAL 300 /**< The advertising interval (in units of 0.625 ms). This value corresponds to 187.5 ms. */ #define APP_ADV_TIMEOUT_IN_SECONDS 180 /**< The advertising timeout in units of seconds. */ #define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000, APP_TIMER_PRESCALER) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */ #define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000, APP_TIMER_PRESCALER)/**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */ #define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */ static ble_hrs_t m_hrs; /**< Main structure for the Heart rate server module. */ #define BLE_GAP_LESC_P256_SK_LEN 32 /**@brief GAP LE Secure Connections P-256 Private Key. */ typedef struct { uint8_t sk[BLE_GAP_LESC_P256_SK_LEN]; /**< LE Secure Connections Elliptic Curve Diffie-Hellman P-256 Private Key in little-endian. */ } ble_gap_lesc_p256_sk_t; static bool m_numneric_match_requested = false; static uint16_t m_num_comp_conn_handle; static char invalid_role_str[] = "INVALID_ROLE"; static char central_str[] = "CENTRAL"; static char periph_str[] = "PERIPHERAL"; static char *roles_str[BLE_GAP_ROLE_CENTRAL+1]; #if LESC_DEBUG_MODE /**@brief Bluetooth SIG debug mode Private Key */ __ALIGN(4) static const ble_gap_lesc_p256_sk_t m_debug_lesc_sk = {{0xbd,0x1a,0x3c,0xcd,0xa6,0xb8,0x99,0x58,0x99,0xb7,0x40,0xeb,0x7b,0x60,0xff,0x4a, \ 0x50,0x3f,0x10,0xd2,0xe3,0xb3,0xc9,0x74,0x38,0x5f,0xc5,0xa3,0xd4,0xf6,0x49,0x3f}}; #else /**@brief Private Key: Replace with your own one, can be a random number or generated using a tool like OpenSSL */ __ALIGN(4) static const ble_gap_lesc_p256_sk_t m_lesc_sk = {{0x4a,0xa3,0x74,0x4b,0xa9,0xfc,0x2a,0x3a,0x8e,0x5a,0xd5,0x15,0xf8,0xe3,0x3f,0xb0, \ 0x82,0x6c,0x98,0xf0,0x32,0x2a,0x51,0xee,0xb5,0x35,0x57,0x12,0xac,0x73,0x25,0x04}}; #endif __ALIGN(4) static ble_gap_lesc_p256_pk_t m_lesc_pk; /**< LESC ECC Public Key */ __ALIGN(4) static ble_gap_lesc_dhkey_t m_lesc_dhkey; /**< LESC ECC DH Key*/ static nrf_crypto_key_t m_crypto_key_sk = { #if LESC_DEBUG_MODE .p_le_data = (uint8_t *) m_debug_lesc_sk.sk, #else .p_le_data = (uint8_t *) m_lesc_sk.sk, #endif .len = sizeof(m_lesc_sk.sk) }; static nrf_crypto_key_t m_crypto_key_pk = { .p_le_data = (uint8_t *) m_lesc_pk.pk, .len = sizeof(m_lesc_pk.pk) }; static nrf_crypto_key_t m_crypto_key_dhkey = { .p_le_data = (uint8_t *) m_lesc_dhkey.key, .len = sizeof(m_lesc_dhkey.key) }; /* IAR has no support for the __ALIGN macro */ #if defined(__ICCARM__) #pragma data_alignment = 1 #endif /**@brief names which the central applications will scan for, and which will be advertised by the peripherals. * if these are set to empty strings, the UUIDs defined below will be used */ static const char m_target_periph_name[] = ""; /**@brief UUIDs which the central applications will scan for if the name above is set to an empty string, * and which will be advertised by the peripherals. */ static ble_uuid_t m_adv_uuids[] = {{BLE_UUID_HEART_RATE_SERVICE, BLE_UUID_TYPE_BLE}, {BLE_UUID_RUNNING_SPEED_AND_CADENCE, BLE_UUID_TYPE_BLE}}; char passkey[BLE_GAP_PASSKEY_LEN + 1]; /**@brief Function to handle asserts in the SoftDevice. * * @details This function will be called in case of an assert in the SoftDevice. * * @warning This handler is an example only and does not fit a final product. You need to analyze * how your product is supposed to react in case of Assert. * @warning On assert from the SoftDevice, the system can only recover on reset. * * @param[in] line_num Line number of the failing ASSERT call. * @param[in] p_file_name File name of the failing ASSERT call. */ void assert_nrf_callback(uint16_t line_num, const uint8_t * p_file_name) { app_error_handler(0xDEADBEEF, line_num, p_file_name); } void uart_error_handle(app_uart_evt_t * p_event) { if (p_event->evt_type == APP_UART_COMMUNICATION_ERROR) { APP_ERROR_HANDLER(p_event->data.error_communication); } else if (p_event->evt_type == APP_UART_FIFO_ERROR) { APP_ERROR_HANDLER(p_event->data.error_code); } } /**@brief Function for handling errors from the Connection Parameters module. * * @param[in] nrf_error Error code containing information about what went wrong. */ static void conn_params_error_handler(uint32_t nrf_error) { APP_ERROR_HANDLER(nrf_error); } /** * @brief Parses advertisement data, providing length and location of the field in case * matching data is found. * * @param[in] Type of data to be looked for in advertisement data. * @param[in] Advertisement report length and pointer to report. * @param[out] If data type requested is found in the data report, type data length and * pointer to data will be populated here. * * @retval NRF_SUCCESS if the data type is found in the report. * @retval NRF_ERROR_NOT_FOUND if the data type could not be found. */ static uint32_t adv_report_parse(uint8_t type, data_t * p_advdata, data_t * p_typedata) { uint32_t index = 0; uint8_t * p_data; p_data = p_advdata->p_data; while (index < p_advdata->data_len) { uint8_t field_length = p_data[index]; uint8_t field_type = p_data[index + 1]; if (field_type == type) { p_typedata->p_data = &p_data[index + 2]; p_typedata->data_len = field_length - 1; return NRF_SUCCESS; } index += field_length + 1; } return NRF_ERROR_NOT_FOUND; } /**@brief Function for initiating scanning. */ static void scan_start(void) { ret_code_t err_code; (void) sd_ble_gap_scan_stop(); err_code = sd_ble_gap_scan_start(&m_scan_params); // It is okay to ignore this error since we are stopping the scan anyway. if (err_code != NRF_ERROR_INVALID_STATE) { APP_ERROR_CHECK(err_code); } NRF_LOG_INFO("Scanning\r\n"); } /**@brief Function for initiating advertising and scanning. */ static void adv_scan_start(void) { ret_code_t err_code; uint32_t count; //check if there are no flash operations in progress err_code = fs_queued_op_count_get(&count); APP_ERROR_CHECK(err_code); if (count == 0) { // Start scanning for peripherals and initiate connection to devices which // advertise Heart Rate or Running speed and cadence UUIDs. // scan_start(); // Turn on the LED to signal scanning. // bsp_board_led_on(CENTRAL_SCANNING_LED); } // Start advertising. err_code = ble_advertising_start(BLE_ADV_MODE_FAST); APP_ERROR_CHECK(err_code); NRF_LOG_INFO("Advertising\r\n"); } /**@brief Function for handling File Data Storage events. * * @param[in] p_evt Peer Manager event. * @param[in] cmd */ static void fds_evt_handler(fds_evt_t const * const p_fds_evt) { if (p_fds_evt->id == FDS_EVT_GC) { NRF_LOG_DEBUG("GC completed\r\n"); } } /**@brief Function for handling Peer Manager events. * * @param[in] p_evt Peer Manager event. */ static void pm_evt_handler(pm_evt_t const * p_evt) { ret_code_t err_code; uint16_t role = ble_conn_state_role(p_evt->conn_handle); switch (p_evt->evt_id) { case PM_EVT_BONDED_PEER_CONNECTED: { NRF_LOG_DEBUG("%s : PM_EVT_BONDED_PEER_CONNECTED: peer_id=%d\r\n", nrf_log_push(roles_str[role]), p_evt->peer_id); } break; case PM_EVT_CONN_SEC_START: { NRF_LOG_DEBUG("%s : PM_EVT_CONN_SEC_START: peer_id=%d\r\n", nrf_log_push(roles_str[role]), p_evt->peer_id); } break; case PM_EVT_CONN_SEC_SUCCEEDED: { NRF_LOG_INFO("%s : PM_EVT_CONN_SEC_SUCCEEDED conn_handle: %d, Procedure: %d\r\n", nrf_log_push(roles_str[role]), p_evt->conn_handle, p_evt->params.conn_sec_succeeded.procedure); } break; case PM_EVT_CONN_SEC_FAILED: { NRF_LOG_DEBUG("%s: PM_EVT_CONN_SEC_FAILED: peer_id=%d, error=%d\r\n", nrf_log_push(roles_str[role]), p_evt->peer_id, p_evt->params.conn_sec_failed.error); } break; case PM_EVT_CONN_SEC_CONFIG_REQ: { // Reject pairing request from an already bonded peer. pm_conn_sec_config_t conn_sec_config = {.allow_repairing = false}; pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config); } break; case PM_EVT_STORAGE_FULL: { // Run garbage collection on the flash. err_code = fds_gc(); if (err_code == FDS_ERR_BUSY || err_code == FDS_ERR_NO_SPACE_IN_QUEUES) { // Retry. } } break; case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED: { NRF_LOG_DEBUG("%s: PM_EVT_PEER_DATA_UPDATE_SUCCEEDED: peer_id=%d data_id=0x%x action=0x%x\r\n", nrf_log_push(roles_str[role]), p_evt->peer_id, p_evt->params.peer_data_update_succeeded.data_id, p_evt->params.peer_data_update_succeeded.action); } break; case PM_EVT_PEERS_DELETE_SUCCEEDED: { adv_scan_start(); } break; case PM_EVT_LOCAL_DB_CACHE_APPLY_FAILED: { // The local database has likely changed, send service changed indications. pm_local_database_has_changed(); } break; case PM_EVT_PEER_DATA_UPDATE_FAILED: { // Assert. APP_ERROR_CHECK(p_evt->params.peer_data_update_failed.error); } break; case PM_EVT_PEER_DELETE_FAILED: { // Assert. APP_ERROR_CHECK(p_evt->params.peer_delete_failed.error); } break; case PM_EVT_PEERS_DELETE_FAILED: { // Assert. APP_ERROR_CHECK(p_evt->params.peers_delete_failed_evt.error); } break; case PM_EVT_ERROR_UNEXPECTED: { // Assert. APP_ERROR_CHECK(p_evt->params.error_unexpected.error); } break; case PM_EVT_PEER_DELETE_SUCCEEDED: case PM_EVT_LOCAL_DB_CACHE_APPLIED: case PM_EVT_SERVICE_CHANGED_IND_SENT: case PM_EVT_SERVICE_CHANGED_IND_CONFIRMED: default: break; } } /**@brief Handles events coming from the Heart Rate central module. */ static void hrs_c_evt_handler(ble_hrs_c_t * p_hrs_c, ble_hrs_c_evt_t * p_hrs_c_evt) { switch (p_hrs_c_evt->evt_type) { case BLE_HRS_C_EVT_DISCOVERY_COMPLETE: { if (m_conn_handle_hrs_c == BLE_CONN_HANDLE_INVALID) { ret_code_t err_code; m_conn_handle_hrs_c = p_hrs_c_evt->conn_handle; NRF_LOG_INFO("CENTRAL: HRS discovered on conn_handle 0x%x\r\n", m_conn_handle_hrs_c); err_code = ble_hrs_c_handles_assign(p_hrs_c, m_conn_handle_hrs_c, &p_hrs_c_evt->params.peer_db); APP_ERROR_CHECK(err_code); // Initiate bonding. NRF_LOG_INFO("CENTRAL: initiate security"); err_code = pm_conn_secure(m_conn_handle_hrs_c, false); if (err_code != NRF_ERROR_INVALID_STATE) { APP_ERROR_CHECK(err_code); } // Heart rate service discovered. Enable notification of Heart Rate Measurement. err_code = ble_hrs_c_hrm_notif_enable(p_hrs_c); APP_ERROR_CHECK(err_code); } } break; // BLE_HRS_C_EVT_DISCOVERY_COMPLETE case BLE_HRS_C_EVT_HRM_NOTIFICATION: { NRF_LOG_INFO("CENTRAL: Heart Rate = %d\r\n", p_hrs_c_evt->params.hrm.hr_value); } break; // BLE_HRS_C_EVT_HRM_NOTIFICATION default: // No implementation needed. break; } } /**@brief Function for searching a given name in the advertisement packets. * * @details Use this function to parse received advertising data and to find a given * name in them either as 'complete_local_name' or as 'short_local_name'. * * @param[in] p_adv_report advertising data to parse. * @param[in] name_to_find name to search. * @return true if the given name was found, false otherwise. */ static bool find_adv_name(const ble_gap_evt_adv_report_t *p_adv_report, const char * name_to_find) { uint32_t err_code; data_t adv_data; data_t dev_name; // Initialize advertisement report for parsing adv_data.p_data = (uint8_t *)p_adv_report->data; adv_data.data_len = p_adv_report->dlen; //search for advertising names err_code = adv_report_parse(BLE_GAP_AD_TYPE_COMPLETE_LOCAL_NAME, &adv_data, &dev_name); if (err_code == NRF_SUCCESS) { if (memcmp(name_to_find, dev_name.p_data, dev_name.data_len )== 0) { return true; } } else { // Look for the short local name if it was not found as complete err_code = adv_report_parse(BLE_GAP_AD_TYPE_SHORT_LOCAL_NAME, &adv_data, &dev_name); if (err_code != NRF_SUCCESS) { return false; } if (memcmp(m_target_periph_name, dev_name.p_data, dev_name.data_len )== 0) { return true; } } return false; } /**@brief Function for searching a UUID in the advertisement packets. * * @details Use this function to parse received advertising data and to find a given * UUID in them. * * @param[in] p_adv_report advertising data to parse. * @param[in] uuid_to_find UUIID to search. * @return true if the given UUID was found, false otherwise. */ static bool find_adv_uuid(const ble_gap_evt_adv_report_t *p_adv_report, const uint16_t uuid_to_find) { uint32_t err_code; data_t adv_data; data_t type_data; // Initialize advertisement report for parsing. adv_data.p_data = (uint8_t *)p_adv_report->data; adv_data.data_len = p_adv_report->dlen; err_code = adv_report_parse(BLE_GAP_AD_TYPE_16BIT_SERVICE_UUID_MORE_AVAILABLE, &adv_data, &type_data); if (err_code != NRF_SUCCESS) { // Look for the services in 'complete' if it was not found in 'more available'. err_code = adv_report_parse(BLE_GAP_AD_TYPE_16BIT_SERVICE_UUID_COMPLETE, &adv_data, &type_data); if (err_code != NRF_SUCCESS) { // If we can't parse the data, then exit. return false; } } // Verify if any UUID match the given UUID. for (uint32_t u_index = 0; u_index < (type_data.data_len / sizeof(uint16_t)); u_index++) { uint16_t extracted_uuid; extracted_uuid = uint16_decode(&type_data.p_data[u_index * sizeof(uint16_t)]); if (extracted_uuid == uuid_to_find) { return true; } } return false; } /**@brief Function for handling BLE Stack events common to both the central and peripheral roles. * @param[in] conn_handle Connection Handle. * @param[in] p_ble_evt Bluetooth stack event. */ static void on_ble_evt(uint16_t conn_handle, ble_evt_t * p_ble_evt) { ret_code_t err_code; // char passkey[BLE_GAP_PASSKEY_LEN + 1]; uint16_t role = ble_conn_state_role(conn_handle); static nrf_crypto_key_t peer_pk; switch (p_ble_evt->header.evt_id) { case BLE_GAP_EVT_SEC_PARAMS_REQUEST: NRF_LOG_INFO("%s: BLE_GAP_EVT_SEC_PARAMS_REQUEST\r\n", nrf_log_push(roles_str[role])); break; case BLE_GAP_EVT_PASSKEY_DISPLAY: memcpy(passkey, p_ble_evt->evt.gap_evt.params.passkey_display.passkey, BLE_GAP_PASSKEY_LEN); passkey[BLE_GAP_PASSKEY_LEN] = 0x00; NRF_LOG_INFO("%s: BLE_GAP_EVT_PASSKEY_DISPLAY: passkey=%s match_req=%d\r\n", nrf_log_push(roles_str[role]), nrf_log_push(passkey), p_ble_evt->evt.gap_evt.params.passkey_display.match_request); if (p_ble_evt->evt.gap_evt.params.passkey_display.match_request) { NRF_LOG_INFO("Press Button 1 to confirm, Button 2 to reject\r\n"); m_num_comp_conn_handle = conn_handle; m_numneric_match_requested = true; } break; case BLE_GAP_EVT_AUTH_KEY_REQUEST: NRF_LOG_INFO("%s: BLE_GAP_EVT_AUTH_KEY_REQUEST\r\n", nrf_log_push(roles_str[role])); break; case BLE_GAP_EVT_LESC_DHKEY_REQUEST: NRF_LOG_INFO("%s: BLE_GAP_EVT_LESC_DHKEY_REQUEST\r\n", nrf_log_push(roles_str[role])); peer_pk.p_le_data = &p_ble_evt->evt.gap_evt.params.lesc_dhkey_request.p_pk_peer->pk[0]; peer_pk.len = BLE_GAP_LESC_P256_PK_LEN; err_code = nrf_crypto_shared_secret_compute(NRF_CRYPTO_CURVE_SECP256R1, &m_crypto_key_sk, &peer_pk, &m_crypto_key_dhkey); APP_ERROR_CHECK(err_code); err_code = sd_ble_gap_lesc_dhkey_reply(conn_handle, &m_lesc_dhkey); APP_ERROR_CHECK(err_code); break; case BLE_GAP_EVT_AUTH_STATUS: NRF_LOG_INFO("%s: BLE_GAP_EVT_AUTH_STATUS: status=0x%x bond=0x%x lv4: %d kdist_own:0x%x kdist_peer:0x%x\r\n", nrf_log_push(roles_str[role]), p_ble_evt->evt.gap_evt.params.auth_status.auth_status, p_ble_evt->evt.gap_evt.params.auth_status.bonded, p_ble_evt->evt.gap_evt.params.auth_status.sm1_levels.lv4, *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_own), *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_peer)); break; default: // No implementation needed. break; } } /**@brief Function for handling BLE Stack events concerning central applications. * * @details This function keeps the connection handles of central applications up-to-date. It * parses scanning reports, initiating a connection attempt to peripherals when a target UUID * is found, and manages connection parameter update requests. Additionally, it updates the status * of LEDs used to report central applications activity. * * @note Since this function updates connection handles, @ref BLE_GAP_EVT_DISCONNECTED events * should be dispatched to the target application before invoking this function. * * @param[in] p_ble_evt Bluetooth stack event. */ static void on_ble_central_evt(const ble_evt_t * const p_ble_evt) { const ble_gap_evt_t * const p_gap_evt = &p_ble_evt->evt.gap_evt; ret_code_t err_code; switch (p_ble_evt->header.evt_id) { /** Upon connection, check which peripheral has connected (HR or RSC), initiate DB * discovery, update LEDs status and resume scanning if necessary. */ case BLE_GAP_EVT_CONNECTED: { NRF_LOG_INFO("CENTRAL: connected\r\n"); /** If no Heart Rate sensor is currently connected, try to find them on this peripheral*/ if (m_conn_handle_hrs_c == BLE_CONN_HANDLE_INVALID) { NRF_LOG_INFO("CENTRAL: try to find HRS on conn_handle 0x%x\r\n", p_gap_evt->conn_handle); APP_ERROR_CHECK_BOOL(p_gap_evt->conn_handle < CENTRAL_LINK_COUNT + PERIPHERAL_LINK_COUNT); err_code = ble_db_discovery_start(&m_ble_db_discovery[p_gap_evt->conn_handle], p_gap_evt->conn_handle); APP_ERROR_CHECK(err_code); } /** Update LEDs status, and check if we should be looking for more * peripherals to connect to. */ bsp_board_led_on(CENTRAL_CONNECTED_LED); if (ble_conn_state_n_centrals() == CENTRAL_LINK_COUNT) { bsp_board_led_off(CENTRAL_SCANNING_LED); } else { // Resume scanning. bsp_board_led_on(CENTRAL_SCANNING_LED); scan_start(); } } break; // BLE_GAP_EVT_CONNECTED /** Upon disconnection, reset the connection handle of the peer which disconnected, update * the LEDs status and start scanning again. */ case BLE_GAP_EVT_DISCONNECTED: { uint8_t n_centrals; NRF_LOG_INFO("CENTRAL: disconnected (reason: %d)\r\n", p_gap_evt->params.disconnected.reason); if (p_gap_evt->conn_handle == m_conn_handle_hrs_c) { m_conn_handle_hrs_c = BLE_CONN_HANDLE_INVALID; } if (m_conn_handle_hrs_c == BLE_CONN_HANDLE_INVALID) { // Start scanning scan_start(); // Update LEDs status. bsp_board_led_on(CENTRAL_SCANNING_LED); } n_centrals = ble_conn_state_n_centrals(); if (n_centrals == 0) { bsp_board_led_off(CENTRAL_CONNECTED_LED); } } break; // BLE_GAP_EVT_DISCONNECTED case BLE_GAP_EVT_ADV_REPORT: { if (strlen(m_target_periph_name) != 0) { if (find_adv_name(&p_gap_evt->params.adv_report, m_target_periph_name)) { // Initiate connection. NRF_LOG_INFO("central connecting ...\r\n"); err_code = sd_ble_gap_connect(&p_gap_evt->params.adv_report.peer_addr, &m_scan_params, &m_connection_param); if (err_code != NRF_SUCCESS) { NRF_LOG_DEBUG("Connection Request Failed, reason %d\r\n", err_code); } } } else { /** We do not want to connect to two peripherals offering the same service, so when * a UUID is matched, we check that we are not already connected to a peer which * offers the same service. */ if (find_adv_uuid(&p_gap_evt->params.adv_report, BLE_UUID_HEART_RATE_SERVICE)&& (m_conn_handle_hrs_c == BLE_CONN_HANDLE_INVALID)) { // Initiate connection. NRF_LOG_INFO("CENTRAL: connecting ...\r\n"); err_code = sd_ble_gap_connect(&p_gap_evt->params.adv_report.peer_addr, &m_scan_params, &m_connection_param); if (err_code != NRF_SUCCESS) { NRF_LOG_DEBUG("CENTRAL: Connection Request Failed, reason %d\r\n", err_code); } } } } break; // BLE_GAP_ADV_REPORT case BLE_GAP_EVT_TIMEOUT: { // We have not specified a timeout for scanning, so only connection attemps can timeout. if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN) { NRF_LOG_DEBUG("CENTRAL: Connection Request timed out.\r\n"); } } break; // BLE_GAP_EVT_TIMEOUT case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST: { // Accept parameters requested by peer. err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle, &p_gap_evt->params.conn_param_update_request.conn_params); APP_ERROR_CHECK(err_code); } break; // BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST case BLE_GATTC_EVT_TIMEOUT: // Disconnect on GATT Client timeout event. NRF_LOG_DEBUG("CENTRAL: GATT Client Timeout.\r\n"); err_code = sd_ble_gap_disconnect(p_ble_evt->evt.gattc_evt.conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION); APP_ERROR_CHECK(err_code); break; // BLE_GATTC_EVT_TIMEOUT case BLE_GATTS_EVT_TIMEOUT: // Disconnect on GATT Server timeout event. NRF_LOG_DEBUG("CENTRAL: GATT Server Timeout.\r\n"); err_code = sd_ble_gap_disconnect(p_ble_evt->evt.gatts_evt.conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION); APP_ERROR_CHECK(err_code); break; // BLE_GATTS_EVT_TIMEOUT #if (NRF_SD_BLE_API_VERSION == 3) case BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST: err_code = sd_ble_gatts_exchange_mtu_reply(p_ble_evt->evt.gatts_evt.conn_handle, NRF_BLE_MAX_MTU_SIZE); APP_ERROR_CHECK(err_code); break; // BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST #endif default: // No implementation needed. break; } } /**@brief Function for handling BLE Stack events involving peripheral applications. Manages the * LEDs used to report the status of the peripheral applications. * * @param[in] p_ble_evt Bluetooth stack event. */ static void on_ble_peripheral_evt(ble_evt_t * p_ble_evt) { ret_code_t err_code; switch (p_ble_evt->header.evt_id) { case BLE_GAP_EVT_CONNECTED: NRF_LOG_INFO("PERIPHERAL: connected\r\n"); bsp_board_led_off(PERIPHERAL_ADVERTISING_LED); bsp_board_led_on(PERIPHERAL_CONNECTED_LED); break; // BLE_GAP_EVT_CONNECTED case BLE_GAP_EVT_DISCONNECTED: NRF_LOG_INFO("PERIPHERAL: disconnected, reason %d\r\n", p_ble_evt->evt.gap_evt.params.disconnected.reason); bsp_board_led_off(PERIPHERAL_CONNECTED_LED); break; // BLE_GAP_EVT_DISCONNECTED case BLE_GATTC_EVT_TIMEOUT: // Disconnect on GATT Client timeout event. NRF_LOG_DEBUG("PERIPHERAL: GATT Client Timeout.\r\n"); err_code = sd_ble_gap_disconnect(p_ble_evt->evt.gattc_evt.conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION); APP_ERROR_CHECK(err_code); break; // BLE_GATTC_EVT_TIMEOUT case BLE_GATTS_EVT_TIMEOUT: // Disconnect on GATT Server timeout event. NRF_LOG_DEBUG("PERIPHERAL: GATT Server Timeout.\r\n"); err_code = sd_ble_gap_disconnect(p_ble_evt->evt.gatts_evt.conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION); APP_ERROR_CHECK(err_code); break; // BLE_GATTS_EVT_TIMEOUT case BLE_EVT_USER_MEM_REQUEST: err_code = sd_ble_user_mem_reply(p_ble_evt->evt.gap_evt.conn_handle, NULL); APP_ERROR_CHECK(err_code); break; // BLE_EVT_USER_MEM_REQUEST case BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST: { ble_gatts_evt_rw_authorize_request_t req; ble_gatts_rw_authorize_reply_params_t auth_reply; req = p_ble_evt->evt.gatts_evt.params.authorize_request; if (req.type != BLE_GATTS_AUTHORIZE_TYPE_INVALID) { if ((req.request.write.op == BLE_GATTS_OP_PREP_WRITE_REQ) || (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_NOW) || (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_CANCEL)) { if (req.type == BLE_GATTS_AUTHORIZE_TYPE_WRITE) { auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_WRITE; } else { auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_READ; } auth_reply.params.write.gatt_status = APP_FEATURE_NOT_SUPPORTED; err_code = sd_ble_gatts_rw_authorize_reply(p_ble_evt->evt.gatts_evt.conn_handle, &auth_reply); APP_ERROR_CHECK(err_code); } } } break; // BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST #if (NRF_SD_BLE_API_VERSION == 3) case BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST: err_code = sd_ble_gatts_exchange_mtu_reply(p_ble_evt->evt.gatts_evt.conn_handle, NRF_BLE_MAX_MTU_SIZE); APP_ERROR_CHECK(err_code); break; // BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST #endif default: // No implementation needed. break; } } /**@brief Function for handling advertising events. * * @param[in] ble_adv_evt Advertising event. */ static void on_adv_evt(ble_adv_evt_t ble_adv_evt) { switch (ble_adv_evt) { case BLE_ADV_EVT_FAST: bsp_board_led_on(PERIPHERAL_ADVERTISING_LED); break; case BLE_ADV_EVT_IDLE: { ret_code_t err_code; err_code = ble_advertising_start(BLE_ADV_MODE_FAST); APP_ERROR_CHECK(err_code); } break; default: // No implementation needed. break; } } /**@brief Function for dispatching a BLE stack event to all modules with a BLE stack event handler. * * @details This function is called from the scheduler in the main loop after a BLE stack event has * been received. * * @param[in] p_ble_evt Bluetooth stack event. */ static void ble_evt_dispatch(ble_evt_t * p_ble_evt) { uint16_t conn_handle; uint16_t role; /** The Connection state module has to be fed BLE events in order to function correctly * Remember to call ble_conn_state_on_ble_evt before calling any ble_conns_state_* functions. */ ble_conn_state_on_ble_evt(p_ble_evt); pm_on_ble_evt(p_ble_evt); // The connection handle should really be retrievable for any event type. conn_handle = p_ble_evt->evt.gap_evt.conn_handle; role = ble_conn_state_role(conn_handle); on_ble_evt(conn_handle, p_ble_evt); // Based on the role this device plays in the connection, dispatch to the right applications. if (role == BLE_GAP_ROLE_PERIPH) { // Manages peripheral LEDs. on_ble_peripheral_evt(p_ble_evt); ble_advertising_on_ble_evt(p_ble_evt); ble_conn_params_on_ble_evt(p_ble_evt); // Dispatch to peripheral applications. ble_hrs_on_ble_evt (&m_hrs, p_ble_evt); } else if ((role == BLE_GAP_ROLE_CENTRAL) || (p_ble_evt->header.evt_id == BLE_GAP_EVT_ADV_REPORT)) { /** on_ble_central_evt will update the connection handles, so we want to execute it * after dispatching to the central applications upon disconnection. */ if (p_ble_evt->header.evt_id != BLE_GAP_EVT_DISCONNECTED) { on_ble_central_evt(p_ble_evt); } if (conn_handle < CENTRAL_LINK_COUNT + PERIPHERAL_LINK_COUNT) { ble_db_discovery_on_ble_evt(&m_ble_db_discovery[conn_handle], p_ble_evt); } ble_hrs_c_on_ble_evt(&m_ble_hrs_c, p_ble_evt); // If the peer disconnected, we update the connection handles last. if (p_ble_evt->header.evt_id == BLE_GAP_EVT_DISCONNECTED) { on_ble_central_evt(p_ble_evt); } } } /**@brief Function for dispatching a system event to interested modules. * * @details This function is called from the System event interrupt handler after a system * event has been received. * * @param[in] sys_evt System stack event. */ static void sys_evt_dispatch(uint32_t sys_evt) { ble_advertising_on_sys_evt(sys_evt); /** Dispatch the system event to the Flash Storage module, where it will be * dispatched to the Flash Data Storage module and from there to the Peer Manager. */ fs_sys_event_handler(sys_evt); } /**@brief Heart rate collector initialization. */ static void hrs_c_init(void) { uint32_t err_code; ble_hrs_c_init_t hrs_c_init_obj; hrs_c_init_obj.evt_handler = hrs_c_evt_handler; err_code = ble_hrs_c_init(&m_ble_hrs_c, &hrs_c_init_obj); APP_ERROR_CHECK(err_code); } /**@brief Function for initializing the BLE stack. * * @details Initializes the SoftDevice and the BLE event interrupts. */ static void ble_stack_init(void) { ret_code_t err_code; // Initialize the SoftDevice handler module. nrf_clock_lf_cfg_t clock_lf_cfg = {.source = NRF_CLOCK_LF_SRC_RC, \ .rc_ctiv = 16, \ .rc_temp_ctiv = 2, \ .xtal_accuracy = NRF_CLOCK_LF_XTAL_ACCURACY_250_PPM}; SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL); ble_enable_params_t ble_enable_params; err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT, PERIPHERAL_LINK_COUNT, &ble_enable_params); APP_ERROR_CHECK(err_code); //Check the ram settings against the used number of links CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT,PERIPHERAL_LINK_COUNT); // Enable BLE stack. #if (NRF_SD_BLE_API_VERSION == 3) ble_enable_params.gatt_enable_params.att_mtu = NRF_BLE_MAX_MTU_SIZE; #endif err_code = softdevice_enable(&ble_enable_params); APP_ERROR_CHECK(err_code); // Register with the SoftDevice handler module for BLE events. err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch); APP_ERROR_CHECK(err_code); // Register with the SoftDevice handler module for System events. err_code = softdevice_sys_evt_handler_set(sys_evt_dispatch); APP_ERROR_CHECK(err_code); } /**@brief Function for the Peer Manager initialization. * * @param[in] erase_bonds Indicates whether bonding information should be cleared from * persistent storage during initialization of the Peer Manager. */ static void peer_manager_init(bool erase_bonds) { ble_gap_sec_params_t sec_params; ret_code_t err_code; err_code = pm_init(); APP_ERROR_CHECK(err_code); if (erase_bonds) { (void) pm_peers_delete(); } memset(&sec_params, 0, sizeof(ble_gap_sec_params_t)); // Security parameters to be used for all security procedures. sec_params.bond = SEC_PARAMS_BOND; sec_params.mitm = SEC_PARAMS_MITM; sec_params.lesc = SEC_PARAMS_LESC; sec_params.keypress = SEC_PARAMS_KEYPRESS; sec_params.io_caps = SEC_PARAMS_IO_CAPABILITIES; sec_params.oob = SEC_PARAMS_OOB; sec_params.min_key_size = SEC_PARAMS_MIN_KEY_SIZE; sec_params.max_key_size = SEC_PARAMS_MAX_KEY_SIZE; sec_params.kdist_own.enc = 1; sec_params.kdist_own.id = 1; sec_params.kdist_peer.enc = 1; sec_params.kdist_peer.id = 1; err_code = pm_sec_params_set(&sec_params); APP_ERROR_CHECK(err_code); err_code = pm_register(pm_evt_handler); APP_ERROR_CHECK(err_code); err_code = fds_register(fds_evt_handler); APP_ERROR_CHECK(err_code); nrf_crypto_init(); err_code = nrf_crypto_public_key_compute(NRF_CRYPTO_CURVE_SECP256R1, &m_crypto_key_sk, &m_crypto_key_pk); APP_ERROR_CHECK(err_code); /* Set the public key */ err_code = pm_lesc_public_key_set(&m_lesc_pk); APP_ERROR_CHECK(err_code); } /**@brief Function for handling events from the BSP module. * * @param[in] event Event generated by button press. */ static void bsp_event_handler(bsp_event_t event) { ret_code_t err_code; switch (event) { case BSP_EVENT_KEY_0: NRF_LOG_DEBUG("BSP_EVENT_KEY_0\r\n"); err_code = ble_hrs_heart_rate_measurement_send(&m_hrs, 87); if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_INVALID_STATE) && (err_code != BLE_ERROR_NO_TX_PACKETS) && (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING) ) { APP_ERROR_HANDLER(err_code); } if (m_numneric_match_requested) { NRF_LOG_INFO("Numeric Match\r\n"); err_code = sd_ble_gap_auth_key_reply(m_num_comp_conn_handle, BLE_GAP_AUTH_KEY_TYPE_PASSKEY, NULL); APP_ERROR_CHECK(err_code); m_numneric_match_requested = false; } break; case BSP_EVENT_KEY_1: NRF_LOG_DEBUG("BSP_EVENT_KEY_1\r\n"); if (m_numneric_match_requested) { NRF_LOG_INFO("Numeric REJECT\r\n"); err_code = sd_ble_gap_auth_key_reply(m_num_comp_conn_handle, BLE_GAP_AUTH_KEY_TYPE_NONE, NULL);//Reject APP_ERROR_CHECK(err_code); m_numneric_match_requested = false; } break; default: break; } } /**@brief Function for initializing buttons and leds. * * @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to * wake the application up. */ static void buttons_leds_init(bool * p_erase_bonds) { bsp_event_t startup_event; ret_code_t err_code = bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS, APP_TIMER_TICKS(100, APP_TIMER_PRESCALER), bsp_event_handler); APP_ERROR_CHECK(err_code); err_code = bsp_btn_ble_init(NULL, &startup_event); APP_ERROR_CHECK(err_code); *p_erase_bonds = (startup_event == BSP_EVENT_CLEAR_BONDING_DATA); } /**@brief Function for the GAP initialization. * * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the * device including the device name, appearance, and the preferred connection parameters. */ static void gap_params_init(void) { uint32_t err_code; ble_gap_conn_params_t gap_conn_params; ble_gap_conn_sec_mode_t sec_mode; BLE_GAP_CONN_SEC_MODE_SET_OPEN(&sec_mode); err_code = sd_ble_gap_device_name_set(&sec_mode, (const uint8_t *)DEVICE_NAME, strlen(DEVICE_NAME)); APP_ERROR_CHECK(err_code); memset(&gap_conn_params, 0, sizeof(gap_conn_params)); gap_conn_params.min_conn_interval = MIN_CONNECTION_INTERVAL; gap_conn_params.max_conn_interval = MAX_CONNECTION_INTERVAL; gap_conn_params.slave_latency = SLAVE_LATENCY; gap_conn_params.conn_sup_timeout = SUPERVISION_TIMEOUT; err_code = sd_ble_gap_ppcp_set(&gap_conn_params); APP_ERROR_CHECK(err_code); } /**@brief Function for initializing the Connection Parameters module. */ static void conn_params_init(void) { uint32_t err_code; ble_conn_params_init_t cp_init; memset(&cp_init, 0, sizeof(cp_init)); cp_init.p_conn_params = NULL; cp_init.first_conn_params_update_delay = FIRST_CONN_PARAMS_UPDATE_DELAY; cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY; cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT; cp_init.start_on_notify_cccd_handle = BLE_CONN_HANDLE_INVALID; // Start upon connection. cp_init.disconnect_on_fail = true; cp_init.evt_handler = NULL; // Ignore events. cp_init.error_handler = conn_params_error_handler; err_code = ble_conn_params_init(&cp_init); APP_ERROR_CHECK(err_code); } /**@brief Function for handling database discovery events. * * @details This function is callback function to handle events from the database discovery module. * Depending on the UUIDs that are discovered, this function should forward the events * to their respective services. * * @param[in] p_event Pointer to the database discovery event. */ static void db_disc_handler(ble_db_discovery_evt_t * p_evt) { ble_hrs_on_db_disc_evt(&m_ble_hrs_c, p_evt); } /** * @brief Database discovery initialization. */ static void db_discovery_init(void) { ret_code_t err_code = ble_db_discovery_init(db_disc_handler); APP_ERROR_CHECK(err_code); } /**@brief Function for initializing services that will be used by the application. * * @details Initialize the Heart Rate, Battery and Device Information services. */ static void services_init(void) { uint32_t err_code; ble_hrs_init_t hrs_init; uint8_t body_sensor_location; // Initialize the Heart Rate Service. body_sensor_location = BLE_HRS_BODY_SENSOR_LOCATION_FINGER; memset(&hrs_init, 0, sizeof(hrs_init)); hrs_init.evt_handler = NULL; hrs_init.is_sensor_contact_supported = true; hrs_init.p_body_sensor_location = &body_sensor_location; // Require LESC with MITM (Numeric Comparison) BLE_GAP_CONN_SEC_MODE_SET_LESC_ENC_WITH_MITM(&hrs_init.hrs_hrm_attr_md.cccd_write_perm); BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hrs_init.hrs_hrm_attr_md.read_perm); BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hrs_init.hrs_hrm_attr_md.write_perm); // Require LESC with MITM (Numeric Comparison) BLE_GAP_CONN_SEC_MODE_SET_LESC_ENC_WITH_MITM(&hrs_init.hrs_bsl_attr_md.read_perm); BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hrs_init.hrs_bsl_attr_md.write_perm); err_code = ble_hrs_init(&m_hrs, &hrs_init); APP_ERROR_CHECK(err_code); } /**@brief Function for initializing the Advertising functionality. */ static void advertising_init(void) { uint32_t err_code; ble_advdata_t advdata; ble_adv_modes_config_t options; // Build advertising data struct to pass into @ref ble_advertising_init. memset(&advdata, 0, sizeof(advdata)); advdata.name_type = BLE_ADVDATA_FULL_NAME; advdata.include_appearance = true; advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE; advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]); advdata.uuids_complete.p_uuids = m_adv_uuids; memset(&options, 0, sizeof(options)); options.ble_adv_fast_enabled = true; options.ble_adv_fast_interval = APP_ADV_INTERVAL; options.ble_adv_fast_timeout = APP_ADV_TIMEOUT_IN_SECONDS; err_code = ble_advertising_init(&advdata, NULL, &options, on_adv_evt, NULL); APP_ERROR_CHECK(err_code); } /** @brief Function to sleep until a BLE event is received by the application. */ static void power_manage(void) { ret_code_t err_code = sd_app_evt_wait(); APP_ERROR_CHECK(err_code); } int main(void) { ret_code_t err_code; bool erase_bonds; err_code = NRF_LOG_INIT(NULL); APP_ERROR_CHECK(err_code); roles_str[BLE_GAP_ROLE_INVALID] = invalid_role_str; roles_str[BLE_GAP_ROLE_PERIPH] = periph_str; roles_str[BLE_GAP_ROLE_CENTRAL] = central_str; APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, NULL); buttons_leds_init(&erase_bonds); if (erase_bonds) { NRF_LOG_INFO("Bonds erased!\r\n"); } ble_stack_init(); peer_manager_init(erase_bonds); db_discovery_init(); hrs_c_init(); NRF_LOG_INFO("LE Secure Connections Example\r\n"); gap_params_init(); conn_params_init(); services_init(); advertising_init(); adv_scan_start(); for (;;) { if (NRF_LOG_PROCESS() == false) { // Wait for BLE events. power_manage(); } } }
