what settings are require for it?
devzone.nordicsemi.com/.../184681
Keil manuals: http://www.keil.com/support/man_arm.htm
Specifically, include paths: http://www.keil.com/support/man/docs/uv4/uv4_dg_adscc.htm
Also, regarding ANT, see:
Thanks Awneil for your response,It's working.
After copy of header files ,I have compile code .There is one error given which is
"..\..\..\main.c(70): error: #5: cannot open source input file "app_uart.h": No such file or directory"
How can I get this header file?
It should be included in the SDK download.
You should start by just building some of the provided example projects - they should "just work".
From them, you can find where all these things are, and adjust to suit your application ...
Please verify the answer(s) when your issue is resolved:
Yes,I download it nrf SDK 15.3.0 and unzipped.In component folder no UART driver is given in this SDK.
only this drivers are included,then how to find for above error?
The app_uart.h file is in components\libraries\uart
Again, start with an SDK example which uses this - it will be correctly configured to find what it needs.
