Hi
AfterI updated the nrf_Connect v2.02 IOS version. I found that disconnect will happen when key in the bonding code "123456".
And my code never has this issus with previous app version ( I forgot which version number, but the APP interface is totall difference with this v2.02)
I also tried my code with Android nrf_Conect v4.23, it works fine when bonding, no disconnect happend.
I would like to know is't a APP issue or my code's problem. Thanks.
my cellphone is iPhone 6S, ios version is 12.4.1
attaced is my main.c file. it;s modified from ble_uart sample code.
* Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup ble_sdk_uart_over_ble_main main.c
* @ingroup ble_sdk_app_nus_eval
* @brief UART over BLE application main file.
* This file contains the source code for a sample application that uses the Nordic UART service.
* This application uses the @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "app_timer.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp_btn_ble.h"
#include "nrf_pwr_mgmt.h"
#include "bsp.h" //BRN
#include <nrf_delay.h>
#include "app_pwm.h"
#include <nrfx_timer.h>
#include "nrf_drv_pwm.h"
#include "ble_srv_common.h"
#include "nrf_dfu_ble_svci_bond_sharing.h"
#include "nrf_svci_async_function.h"
#include "nrf_svci_async_handler.h"
#include "ble_dfu.h"
#include "peer_manager.h"
#include "fds.h"
#include "ble_conn_state.h"
#include "ble.h"
#include "nrf_bootloader_info.h"
#include "nrf_drv_clock.h"
#include "nrf_power.h"
#include "nrf_fstorage_sd.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_drv_saadc.h"
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define DEVICE_NAME "V015" /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL 64 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION 6000//18000 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(20, UNIT_1_25_MS) /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(75, UNIT_1_25_MS) /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */
#define TX_POWER_LEVEL (0)
//BRN
#define STATIC_PASSKEY "123456"
static ble_opt_t m_static_pin_option;
//BRN
#define SEC_PARAM_BOND 1
/**< Perform bonding. */
#define SEC_PARAM_MITM 1
/**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC 0
/**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS 0
/**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_DISPLAY_ONLY //BLE_GAP_IO_CAPS_NONE
/**< No I/O capabilities. */
#define SEC_PARAM_OOB 0
/**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE 7
/**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE 16
/**< Maximum encryption key size. */
#define BEEP_PIN 14
#define MOTOR_PIN 7
#define LED_PIN 12
#define KEY_PIN 11
#define YP_PIN 29
#define USB_DET_PIN 8
#define HALL_PWR_PIN 31
#define HALL_OUT_PIN 6
#define BAT_VOL_PIN 30
#define LED_ST_OFF 0
#define LED_ST_SLOW_BLINK 1
#define LED_ST_ON 2
#define LED_ST_FAST_BLINK 3
#define INIT_BAT_PWM 200
#define INIT_USB_PWM 200
#define AUTO_OFF_TIME 900
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT); /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
//APP_TIMER_DEF(m_app_10ms_tmr); //BRN
APP_TIMER_DEF(m_app_1ms_tmr); //BRN
static volatile bool ready_flag; // A flag indicating PWM status.
void pwm_ready_callback(uint32_t pwm_id) // PWM callback function
ready_flag = true;
static nrf_drv_pwm_t m_pwm0 = NRF_DRV_PWM_INSTANCE(0);
APP_PWM_INSTANCE(PWM1,1); // Create the instance "PWM1" using TIMER1.
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifier. */
uint8_t rcvData[8]; //BRN
uint8_t sendData[8];//BRN
uint16_t DataLength; //BRN
uint8_t testData = 0;//BRN
uint32_t brnEc;
bool writeFlashCmd = 0;
bool readFlashCmd = 0;
bool advStartedFlag = 0;
bool connectedFlag = 0;
bool newBleDataFlag = 0;
uint16_t updateDevStateCnt;
const uint8_t firmwareVer[2] = {0x01,0x03};
bool decanterStateFlag = 0;
bool beepOnFlag = 0;
bool systemOnFlag = 0;
bool preKeyState = 1;
bool ypSwitchState = 0;
bool aerateStartFlag = 0;
bool aerateDoneFlag = 0;
bool motorOnFlag = 0;
bool uploadYpState = 0;
uint8_t keyDebounceCnt = 0;
uint16_t ledBlinkingCnt = 0;
uint16_t beepTimeCnt = 0;
uint8_t beepTimes = 0;
uint16_t ypSwitchDetCnt = 0;
uint32_t brnEc = 0;
uint16_t enterSleepDelay = 0;
uint16_t sysAutoOffCnt = 0;
uint16_t msCnt = 0;
uint16_t aerateTimer = 0;
uint8_t ledState = 0;
uint16_t beepIntervalCnt = 0;
uint8_t aerateDoneBeepCnt = 0;
uint8_t uploadYpStateDelay = 0;
nrf_saadc_value_t saadc_val;
uint16_t adcReadDelay = 0;
uint8_t batLowCnt = 0;
bool batLowFlag = 0;
bool preHallSnrLvl = 0;
bool hallStUpdateFlag = 0;
uint8_t hallSnrDebounceCnt = 0;
uint16_t rotateSpeedTimeCnt = 0;
uint16_t rotateSpeedTime = 0;
uint16_t stuckCnt = 0;
bool stuckedFlag = 0;
uint8_t pwmSetting = 0;
uint8_t pwmSettingBackup = 0;
bool usbConnectedFlag = 0;
uint8_t usbConnectCnt = 0;
uint16_t motorOffDelayCnt = 0;
bool motorDelayStopFlag = 0;
bool motorDelayOffTimeSetFlag = 0;
bool backToFixedPosFlag;
uint8_t hallBlockCnt = 0;
uint16_t motorDelayOffTimeSet;
static nrf_pwm_values_individual_t m_demo1_seq_values;
static nrf_pwm_sequence_t const m_demo1_seq =
.values.p_individual = &m_demo1_seq_values,
.length = NRF_PWM_VALUES_LENGTH(m_demo1_seq_values),
.repeats = 0,
.end_delay = 0
static void demo1_handler(nrf_drv_pwm_evt_type_t event_type)
static void pwm_drv_init(void)
nrf_drv_pwm_config_t const config0 =
.output_pins =
MOTOR_PIN,
NRF_DRV_PWM_PIN_NOT_USED,
.irq_priority = APP_IRQ_PRIORITY_LOWEST,
.base_clock = NRF_PWM_CLK_4MHz,
.count_mode = NRF_PWM_MODE_UP,
.top_value = 255,
.load_mode = NRF_PWM_LOAD_INDIVIDUAL,
.step_mode = NRF_PWM_STEP_AUTO
APP_ERROR_CHECK(nrf_drv_pwm_init(&m_pwm0, &config0, NULL/*demo1_handler*/));
m_demo1_seq_values.channel_0 = 255;
(void)nrf_drv_pwm_simple_playback(&m_pwm0, &m_demo1_seq, 1,
NRF_DRV_PWM_FLAG_LOOP);
static void advertising_init(void);
static void advertising_start(bool erase_bonds);
static void fstorage_evt_handler(nrf_fstorage_evt_t * p_evt);
NRF_FSTORAGE_DEF(nrf_fstorage_t fstorage) =
/* Set a handler for fstorage events. */
.evt_handler = fstorage_evt_handler,
/* These below are the boundaries of the flash space assigned to this instance of fstorage.
* You must set these manually, even at runtime, before nrf_fstorage_init() is called.
* The function nrf5_flash_end_addr_get() can be used to retrieve the last address on the
* last page of flash available to write data. */
.start_addr = 0x77000,
.end_addr = 0x77FFF,
/* Dummy data to write to flash. */
//static uint32_t pairKey;
if (p_evt->result != NRF_SUCCESS)
NRF_LOG_INFO("--> Event received: ERROR while executing an fstorage operation.");
return;
switch (p_evt->id)
case NRF_FSTORAGE_EVT_WRITE_RESULT:
NRF_LOG_INFO("--> Event received: wrote %d bytes at address 0x%x.",
p_evt->len, p_evt->addr);
} break;
case NRF_FSTORAGE_EVT_ERASE_RESULT:
NRF_LOG_INFO("--> Event received: erased %d page from address 0x%x.",
} break;
//static uint32_t nrf5_flash_end_addr_get()
// uint32_t const bootloader_addr = NRF_UICR->NRFFW[0];
// uint32_t const page_sz = NRF_FICR->CODEPAGESIZE;
// uint32_t const code_sz = NRF_FICR->CODESIZE;
// return (bootloader_addr != 0xFFFFFFFF ?
// bootloader_addr : (code_sz * page_sz));
void wait_for_flash_ready(nrf_fstorage_t const * p_fstorage)
/* While fstorage is busy, sleep and wait for an event. */
while (nrf_fstorage_is_busy(p_fstorage))
sd_app_evt_wait();
/**@brief Handler for shutdown preparation.
* @details During shutdown procedures, this function will be called at a 1 second interval
* untill the function returns true. When the function returns true, it means that the
* app is ready to reset to DFU mode.
* @param[in] event Power manager event.
* @retval True if shutdown is allowed by this power manager handler, otherwise false.
static bool app_shutdown_handler(nrf_pwr_mgmt_evt_t event)
switch (event)
case NRF_PWR_MGMT_EVT_PREPARE_DFU:
NRF_LOG_INFO("Power management wants to reset to DFU mode.");
// YOUR_JOB: Get ready to reset into DFU mode
// If you aren't finished with any ongoing tasks, return "false" to
// signal to the system that reset is impossible at this stage.
// Here is an example using a variable to delay resetting the device.
// if (!m_ready_for_reset)
// return false;
// else
// // Device ready to enter
// uint32_t err_code;
// err_code = sd_softdevice_disable();
// APP_ERROR_CHECK(err_code);
// err_code = app_timer_stop_all();
// YOUR_JOB: Implement any of the other events available from the power management module:
// -NRF_PWR_MGMT_EVT_PREPARE_SYSOFF
// -NRF_PWR_MGMT_EVT_PREPARE_WAKEUP
// -NRF_PWR_MGMT_EVT_PREPARE_RESET
return true;
NRF_LOG_INFO("Power management allowed to reset to DFU mode.");
return true;
//lint -esym(528, m_app_shutdown_handler)
/**@brief Register application shutdown handler with priority 0.
NRF_PWR_MGMT_HANDLER_REGISTER(app_shutdown_handler, 0);
static void buttonless_dfu_sdh_state_observer(nrf_sdh_state_evt_t state, void * p_context)
if (state == NRF_SDH_EVT_STATE_DISABLED)
// Softdevice was disabled before going into reset. Inform bootloader to skip CRC on next boot.
nrf_power_gpregret2_set(BOOTLOADER_DFU_SKIP_CRC);
//Go to system off.
nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
/* nrf_sdh state observer. */
NRF_SDH_STATE_OBSERVER(m_buttonless_dfu_state_obs, 0) =
.handler = buttonless_dfu_sdh_state_observer,
// YOUR_JOB: Update this code if you want to do anything given a DFU event (optional).
/**@brief Function for handling dfu events from the Buttonless Secure DFU service
* @param[in] event Event from the Buttonless Secure DFU service.
static void ble_dfu_evt_handler(ble_dfu_buttonless_evt_type_t event)
switch (event)
case BLE_DFU_EVT_BOOTLOADER_ENTER_PREPARE:
NRF_LOG_INFO("Device is preparing to enter bootloader mode.");
// YOUR_JOB: Disconnect all bonded devices that currently are connected.
// This is required to receive a service changed indication
// on bootup after a successful (or aborted) Device Firmware Update.
case BLE_DFU_EVT_BOOTLOADER_ENTER:
// YOUR_JOB: Write app-specific unwritten data to FLASH, control finalization of this
// by delaying reset by reporting false in app_shutdown_handler
NRF_LOG_INFO("Device will enter bootloader mode.");
case BLE_DFU_EVT_BOOTLOADER_ENTER_FAILED:
NRF_LOG_ERROR("Request to enter bootloader mode failed asynchroneously.");
// YOUR_JOB: Take corrective measures to resolve the issue
// like calling APP_ERROR_CHECK to reset the device.
case BLE_DFU_EVT_RESPONSE_SEND_ERROR:
NRF_LOG_ERROR("Request to send a response to client failed.");
APP_ERROR_CHECK(false);
NRF_LOG_ERROR("Unknown event from ble_dfu_buttonless.");
/**@brief Function for handling Peer Manager events.
* @param[in] p_evt Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
ret_code_t err_code;
switch (p_evt->evt_id)
case PM_EVT_BONDED_PEER_CONNECTED:
NRF_LOG_INFO("Connected to a previously bonded device.");
} break;
case PM_EVT_CONN_SEC_SUCCEEDED:
NRF_LOG_INFO("Connection secured: role: %d, conn_handle: 0x%x, procedure: %d.",
ble_conn_state_role(p_evt->conn_handle),
p_evt->conn_handle,
p_evt->params.conn_sec_succeeded.procedure);
} break;
case PM_EVT_CONN_SEC_FAILED:
/* Often, when securing fails, it shouldn't be restarted, for security reasons.
* Other times, it can be restarted directly.
* Sometimes it can be restarted, but only after changing some Security Parameters.
* Sometimes, it cannot be restarted until the link is disconnected and reconnected.
* Sometimes it is impossible, to secure the link, or the peer device does not support it.
* How to handle this error is highly application dependent. */
} break;
case PM_EVT_CONN_SEC_CONFIG_REQ:
// Reject pairing request from an already bonded peer.
pm_conn_sec_config_t conn_sec_config = {.allow_repairing = 1};
pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config);
} break;
case PM_EVT_STORAGE_FULL:
// Run garbage collection on the flash.
err_code = fds_gc();
if (err_code == FDS_ERR_NO_SPACE_IN_QUEUES)
// Retry.
} break;
advertising_start(false);
//advStartedFlag = 1;
} break;
case PM_EVT_PEER_DATA_UPDATE_FAILED:
// Assert.
APP_ERROR_CHECK(p_evt->params.peer_data_update_failed.error);
} break;
case PM_EVT_PEER_DELETE_FAILED:
// Assert.
APP_ERROR_CHECK(p_evt->params.peer_delete_failed.error);
} break;
case PM_EVT_PEERS_DELETE_FAILED:
// Assert.
APP_ERROR_CHECK(p_evt->params.peers_delete_failed_evt.error);
} break;
case PM_EVT_ERROR_UNEXPECTED:
// Assert.
APP_ERROR_CHECK(p_evt->params.error_unexpected.error);
} break;
case PM_EVT_CONN_SEC_START:
case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
case PM_EVT_PEER_DELETE_SUCCEEDED:
case PM_EVT_LOCAL_DB_CACHE_APPLIED:
case PM_EVT_LOCAL_DB_CACHE_APPLY_FAILED:
// This can happen when the local DB has changed.
case PM_EVT_SERVICE_CHANGED_IND_SENT:
case PM_EVT_SERVICE_CHANGED_IND_CONFIRMED:
/**@brief Function for assert macro callback.
* @warning This handler is an example only and does not fit a final product. You need to analyse
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] p_file_name File name of the failing ASSERT call.
/**@brief Function for initializing the timer module.
static void timers_init(void)
* the device. It also sets the permissions and appearance.
uint32_t err_code;
ble_gap_conn_params_t gap_conn_params;
strlen(DEVICE_NAME));
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
//BRN
uint8_t passkey[] = STATIC_PASSKEY;
m_static_pin_option.gap_opt.passkey.p_passkey = passkey;
err_code = sd_ble_opt_set(BLE_GAP_OPT_PASSKEY, &m_static_pin_option);
//BRN
* application about an error.
* @param[in] nrf_error Error code containing information about what went wrong.
APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the data from the Nordic UART Service.
* @details This function will process the data received from the Nordic UART BLE Service and send
* it to the UART module.
* @param[in] p_evt Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
//uint32_t err_code;
//bsp_board_led_invert(BSP_BOARD_LED_3); //BRN
if(p_evt->params.rx_data.length == 4)
for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
rcvData[i] = p_evt->params.rx_data.p_data[i];//BRN
newBleDataFlag = 1;
uint32_t err_code;
ble_nus_init_t nus_init;
ble_dfu_buttonless_init_t dfus_init = {0};
// Initialize NUS.
// Initialize the async SVCI interface to bootloader.
err_code = ble_dfu_buttonless_async_svci_init();
dfus_init.evt_handler = ble_dfu_evt_handler;
err_code = ble_dfu_buttonless_init(&dfus_init);
/**@brief Function for handling an event from the Connection Parameters Module.
* @details This function will be called for all events in the Connection Parameters Module
* which are passed to the application.
* @note All this function does is to disconnect. This could have been done by simply setting
* the disconnect_on_fail config parameter, but instead we use the event handler
* mechanism to demonstrate its use.
* @param[in] p_evt Event received from the Connection Parameters Module.
uint32_t err_code;
ledState = LED_ST_SLOW_BLINK;
connectedFlag = 0; //BRN
sysAutoOffCnt = AUTO_OFF_TIME;
/**@brief Function for handling errors from the Connection Parameters module.
uint32_t err_code;
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
uint32_t err_code;
nrf_gpio_pin_clear(LED_PIN);
nrf_gpio_pin_clear(HALL_PWR_PIN);
APP_ERROR_CHECK(app_pwm_channel_duty_set(&PWM1, 0, 0));
app_pwm_disable(&PWM1);
app_timer_stop(m_app_1ms_tmr);
nrf_drv_pwm_stop(&m_pwm0, true);
// Prepare wakeup buttons.
* @param[in] ble_adv_evt Advertising event.
uint32_t err_code;
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
//err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING);
//APP_ERROR_CHECK(err_code);
case BLE_ADV_EVT_IDLE:
//sleep_mode_enter();
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
uint32_t err_code;
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected");
//err_code = bsp_indication_set(BSP_INDICATE_CONNECTED);
connectedFlag = 1;
beepTimes = 1;
uploadYpState = 1;
uploadYpStateDelay = 100;
//advStartedFlag = 0;
ledState = LED_ST_ON;
//BRN
ble_gap_sec_params_t params;
params.bond = 1;
params.mitm = 1;
sd_ble_gap_authenticate(m_conn_handle,¶ms);
NRF_LOG_INFO("authenticated");
NRF_LOG_FLUSH();
//BRN
NRF_LOG_INFO("Disconnected");
connectedFlag = 0x00;//BRN
beepTimes = 2;
//advertising_init(); //BRN
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
// case BLE_GAP_EVT_SEC_PARAMS_REQUEST:
// //BRN
// // Pairing not supported
// //err_code = sd_ble_gap_sec_params_reply(m_conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
// //APP_ERROR_CHECK(err_code);
// //resp_pair_request();
// //BRN
// break;
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
//BRN
case BLE_GAP_EVT_AUTH_STATUS:
if(p_ble_evt->evt.gap_evt.params.auth_status.auth_status == BLE_GAP_SEC_STATUS_SUCCESS){
NRF_LOG_INFO("SEC_SUCCESS");
NRF_LOG_FLUSH();
//beepTimes = 3;
}else{
sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
//BRN
// No implementation needed.
/**@brief Function for the SoftDevice initialization.
* @details This function initializes the SoftDevice and the BLE event interrupt.
uint32_t ram_start = 0;
// Enable BLE stack.
static void peer_manager_init()
err_code = pm_init();
sec_param.bond = SEC_PARAM_BOND;
sec_param.mitm = SEC_PARAM_MITM;
sec_param.lesc = SEC_PARAM_LESC;
sec_param.keypress = SEC_PARAM_KEYPRESS;
sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
sec_param.oob = SEC_PARAM_OOB;
sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
sec_param.kdist_own.enc = 1;
sec_param.kdist_own.id = 1;
sec_param.kdist_peer.enc = 1;
sec_param.kdist_peer.id = 1;
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
p_gatt->att_mtu_desired_central,
p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
* @param[in] event Event generated by button press.
uint32_t err_code;
switch (event)
case BSP_EVENT_SLEEP:
sleep_mode_enter();
case BSP_EVENT_DISCONNECT:
err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
//beepTimes = 2;
case BSP_EVENT_WHITELIST_OFF:
case BSP_EVENT_KEY_3: //BRN
NRF_LOG_INFO("KEY3 EVENT HAPPENED");
//bsp_board_led_invert(BSP_BOARD_LED_1); //BRN
DataLength = 4;
sendData[0] = 0xA1;
sendData[1] = 0xB2;
sendData[3] = 0xC3;
sendData[4] = testData++;
err_code = ble_nus_data_send(&m_nus, sendData, &DataLength, m_conn_handle, m_nus.tx_handles.value_handle );
uint32_t err_code;
ble_advertising_init_t init;
int8_t tx_power_level = TX_POWER_LEVEL;//BRN
//--------------brn----------------------
//�Զ�����û����ݣ�������������
uint8_t my_adv_manuf_data[3];
// my_adv_manuf_data[0] = (uint8_t)(NRF_FICR->DEVICEID[0]&0x000000FF);
// my_adv_manuf_data[1] = (uint8_t)((NRF_FICR->DEVICEID[0] >> 8)&0x000000FF);
// my_adv_manuf_data[2] = (uint8_t)((NRF_FICR->DEVICEID[0] >> 16)&0x000000FF);
// my_adv_manuf_data[3] = (uint8_t)((NRF_FICR->DEVICEID[0] >> 24)&0x000000FF);
// my_adv_manuf_data[4] = (uint8_t)(NRF_FICR->DEVICEID[1]&0x000000FF);
// my_adv_manuf_data[5] = (uint8_t)((NRF_FICR->DEVICEID[1] >> 8)&0x000000FF);
// my_adv_manuf_data[6] = (uint8_t)((NRF_FICR->DEVICEID[1] >> 16)&0x000000FF);
// my_adv_manuf_data[7] = (uint8_t)((NRF_FICR->DEVICEID[1] >> 24)&0x000000FF);
my_adv_manuf_data[0] = 0;
my_adv_manuf_data[1] = firmwareVer[0];
my_adv_manuf_data[2] = firmwareVer[1];
//�����һ���������Զ������ݵĽṹ����������ù㲥����ʱ���ñ����ĵ�ַ��ֵ��
//�㲥���ݰ���
ble_advdata_manuf_data_t manuf_specific_data;
//0x0059��Nordic��������IDID
manuf_specific_data.company_identifier = 0x0059;
//ָ���������Զ��������
manuf_specific_data.data.p_data = my_adv_manuf_data;
//�������Զ�������ݴ�С
manuf_specific_data.data.size = sizeof(my_adv_manuf_data);
init.advdata.p_manuf_specific_data = &manuf_specific_data;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
init.advdata.p_tx_power_level = &tx_power_level; //BRN
init.srdata.uuids_complete.p_uuids = m_adv_uuids;
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
* @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up.
bsp_event_t startup_event;
uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
nrf_pwr_mgmt_run();
/** @brief Clear bonding information from persistent storage.
static void delete_bonds(void)
NRF_LOG_INFO("Erase bonds!");
err_code = pm_peers_delete();
if (erase_bonds == true)
delete_bonds();
// Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
NRF_LOG_DEBUG("advertising is started");
// uint32_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
static void tx_power_set(void)
ret_code_t err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_advertising.adv_handle, TX_POWER_LEVEL);
static void app_1ms_timer_handler(void * p_context) //BRN
UNUSED_PARAMETER(p_context);
if(ledBlinkingCnt) ledBlinkingCnt--;
if(beepTimeCnt) beepTimeCnt--;
if(enterSleepDelay) enterSleepDelay--;
keyDebounceCnt++;
ypSwitchDetCnt++;
if(beepIntervalCnt) beepIntervalCnt--;
if(uploadYpStateDelay) uploadYpStateDelay--;
if(adcReadDelay) adcReadDelay--;
hallSnrDebounceCnt++;
rotateSpeedTimeCnt++;
stuckCnt++;
usbConnectCnt++;
if(motorOffDelayCnt) motorOffDelayCnt--;
if(hallBlockCnt) hallBlockCnt--;
msCnt++;
if(msCnt >= 1000)
msCnt = 0;
if(sysAutoOffCnt) sysAutoOffCnt--;
if((ypSwitchState == 0) && motorOnFlag)
if(aerateTimer) aerateTimer--;
updateDevStateCnt++;
if(updateDevStateCnt >= 800)
updateDevStateCnt = 0;
DataLength = 4;
sendData[0] = (uint8_t)(rotateSpeedTime >> 8);
sendData[1] = (uint8_t)(rotateSpeedTime & 0x00FF);
sendData[2] = m_demo1_seq_values.channel_0;
sendData[3] = testData++;
sendData[3] &= 0x7F;
if(backToFixedPosFlag) sendData[3] |= 0x80;
static void GPIO_Init(void)
nrf_gpio_cfg_output(LED_PIN);
nrf_gpio_cfg_output(HALL_PWR_PIN);
nrf_gpio_cfg_input(KEY_PIN, NRF_GPIO_PIN_PULLUP );
nrf_gpio_cfg_input(YP_PIN, NRF_GPIO_PIN_PULLUP );
nrf_gpio_cfg_input(USB_DET_PIN, NRF_GPIO_PIN_PULLDOWN );
nrf_gpio_cfg_input(HALL_OUT_PIN, NRF_GPIO_PIN_PULLUP );
nrf_gpio_cfg_input(BAT_VOL_PIN, NRF_GPIO_PIN_NOPULL );
static void Button_Process(void)
if((nrf_gpio_pin_read(KEY_PIN)) != preKeyState)
if(keyDebounceCnt >= 15)
preKeyState = nrf_gpio_pin_read(KEY_PIN);
keyDebounceCnt = 0;
if(preKeyState == 0) //KEY_DOWN
beepTimes = 1;
if(systemOnFlag == 0)
systemOnFlag = 1;
ypSwitchState = 1;
ypSwitchDetCnt = 0;
aerateTimer = 300;
enterSleepDelay = 300;
motorOnFlag = 0;
backToFixedPosFlag = 0;
systemOnFlag = 0;
if(motorOnFlag)
motorDelayStopFlag = 1;
motorOffDelayCnt = 2000;
keyDebounceCnt = 0;
static void LED_Process(void)
if(systemOnFlag)
if(batLowFlag)
if(ledBlinkingCnt == 0)
if(nrf_gpio_pin_out_read(LED_PIN) == 1)
ledBlinkingCnt = 3000;
ledBlinkingCnt = 300;
beepTimes = 1;
nrf_gpio_pin_toggle(LED_PIN);
else if(ledState == 0)
else if(ledState == 1) //SLOW BLINKING
ledBlinkingCnt = 1000;
else if(ledState == 2) //constantly on
nrf_gpio_pin_set(LED_PIN);
else if(ledState == 3) //FAST BLINKING
ledBlinkingCnt = 100;
static void Motro_Ctrl(void)
if(stuckedFlag)
if(motorOnFlag)
motorOnFlag = 0;
if((ypSwitchState == 1) && backToFixedPosFlag)
if(motorDelayStopFlag == 0)
pwmSetting = INIT_BAT_PWM;
pwmSettingBackup = pwmSetting;
m_demo1_seq_values.channel_0 = 255 - pwmSetting;
motorOnFlag = 1;
stuckCnt = 0;
hallBlockCnt = 30;
if(motorDelayStopFlag && motorOnFlag)
if(motorOffDelayCnt == 0)
motorOnFlag = 0;
if(systemOnFlag && aerateTimer && (ypSwitchState == 0) && aerateStartFlag && (stuckedFlag == 0))
if(motorOnFlag == 0)
motorOnFlag = 1;
stuckCnt = 0;
backToFixedPosFlag = 1;
else if(aerateDoneFlag)
motorOnFlag = 1;
else if(motorOnFlag && (motorDelayStopFlag == 0))
motorOnFlag = 0;
}else if(motorDelayStopFlag == 0)
if(motorOnFlag)
motorOnFlag = 0;
static void Beep_Ctrl(void)
if(aerateDoneBeepCnt)
if(beepIntervalCnt == 0)
beepTimes = 3;
beepIntervalCnt = 3000;
aerateDoneBeepCnt--;
if(stuckedFlag)
beepTimes = 1;
beepIntervalCnt = 500;
if(beepTimeCnt == 0)
if(beepTimes)
if(beepOnFlag)
beepOnFlag = 0;
beepTimeCnt = 200;
beepTimes--;
beepOnFlag = 1;
APP_ERROR_CHECK(app_pwm_channel_duty_set(&PWM1, 0, 50));
beepTimeCnt = 100;
void YP_Swtich_Detection(void)
if(uploadYpState && (uploadYpStateDelay == 0))
uploadYpState = 0;
DataLength = 1;
if(ypSwitchState == 0)
sendData[0] = 0x01;
sendData[0] = 0x00;
ble_nus_data_send(&m_nus, sendData, &DataLength, m_conn_handle, m_nus.pot_handles.value_handle );
if(nrf_gpio_pin_read(YP_PIN) != ypSwitchState)
if(ypSwitchDetCnt >= 300)
ypSwitchState = nrf_gpio_pin_read(YP_PIN);
ypSwitchDetCnt = 0;
if(ypSwitchState == 1) //YP SWITCH is up
stuckedFlag = 0;
if(aerateDoneFlag == 0)
DataLength = 1;
sendData[0] = 0x00;
//aerateTimer = 300;
//ledState = LED_ST_ON;
DataLength = 1;
sendData[0] = 0x01;
if(connectedFlag == 0)
if((aerateStartFlag == 0) && (ledState != LED_ST_FAST_BLINK))
//aerateStartFlag = 1;
ypSwitchDetCnt = 0;
static void Timer_Process(void)
if(aerateDoneFlag)
if(sysAutoOffCnt == 0)
systemOnFlag = 0;
beepTimes = 1;
aerateDoneFlag = 0;
if(stuckedFlag || batLowFlag)
if(systemOnFlag && (sysAutoOffCnt == 0))
systemOnFlag = 0;
enterSleepDelay = 500;
beepTimes = 1;
if((ypSwitchState == 1) || (aerateStartFlag == 0))
if(systemOnFlag && (sysAutoOffCnt == 0) && (connectedFlag == 0)){
systemOnFlag = 0;
beepTimes = 1;
else if( (aerateStartFlag) && (aerateTimer == 0))
ledState = LED_ST_FAST_BLINK;
sysAutoOffCnt = 10;
aerateDoneBeepCnt = 3;
aerateDoneFlag = 1;
void saadc_init(void)
nrf_saadc_channel_config_t channel_config =
NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN6);
err_code = nrf_drv_saadc_init(NULL, saadc_callback);
err_code = nrf_drv_saadc_channel_init(0, &channel_config);
void Adc_Read(void)
if(adcReadDelay == 0)
adcReadDelay = 500;
nrf_drv_saadc_sample_convert(0,&saadc_val);
if((batLowFlag == 0) && (usbConnectedFlag == 0))
if(saadc_val <= 0x02C8)
batLowCnt++;
if(batLowCnt >= 3)
batLowFlag = 1;
if(connectedFlag)
}else
batLowCnt = 0;
// DataLength = 4;
// sendData[0] = (uint8_t)(saadc_val >> 8);
// sendData[1] = (uint8_t)(saadc_val & 0x00FF);
// sendData[2] = 0xC3;
// sendData[3] = testData++;
// ble_nus_data_send(&m_nus, sendData, &DataLength, m_conn_handle, m_nus.tx_handles.value_handle );
void Usb_Detect(void)
if(nrf_gpio_pin_read(USB_DET_PIN) != usbConnectedFlag)
if(usbConnectCnt > 100)
usbConnectedFlag = nrf_gpio_pin_read(USB_DET_PIN);
if(usbConnectedFlag)
beepTimes = 1;
batLowFlag = 0;
beepTimes = 2;
usbConnectCnt = 0;
void Stuck_Detect(void)
if(motorOnFlag && (ypSwitchState == 0))
if(stuckCnt > 2500)
stuckedFlag = 1;
stuckCnt = 0;
void Hall_Sensor_Detect(void)
if(nrf_gpio_pin_read(HALL_OUT_PIN) != preHallSnrLvl)
if(hallSnrDebounceCnt >= 3)
preHallSnrLvl = nrf_gpio_pin_read(HALL_OUT_PIN);
stuckCnt = 0;
hallStUpdateFlag = 1;
if(preHallSnrLvl == 0)
rotateSpeedTime = rotateSpeedTimeCnt;
// DataLength = 4;
// sendData[0] = (uint8_t)(rotateSpeedTime >> 8);
// sendData[1] = (uint8_t)(rotateSpeedTime & 0x00FF);
// sendData[2] = pwmSetting;
if(motorDelayStopFlag && (motorDelayOffTimeSetFlag == 0) && (hallBlockCnt == 0))
motorOffDelayCnt = motorDelayOffTimeSet;
motorDelayOffTimeSetFlag = 1;
void Rotate_Speed_Adjust(void)
if(aerateStartFlag && motorOnFlag && hallStUpdateFlag)
if(rotateSpeedTime >= 933)
if(pwmSetting < 255)
pwmSetting++;
else if(rotateSpeedTime <= 913)
if(pwmSetting)
pwmSetting--;
void variable_init(void)
preKeyState = 1;
ypSwitchState = 1;
uploadYpState = 0;
adcReadDelay = 100;
batLowFlag = 0;
/**@brief Application main function.
bool erase_bonds;
uint32_t err_code;
GPIO_Init();
//beepTimes = 2; //test
if(nrf_gpio_pin_read(KEY_PIN) == 0)
beepTimes = 1;
systemOnFlag = 1;
sysAutoOffCnt = AUTO_OFF_TIME;//60;
ypSwitchState = 1;
ypSwitchDetCnt = 0;
aerateTimer = 0;
motorOnFlag = 0;
aerateDoneFlag = 0;
batLowFlag = 0;
nrf_gpio_pin_set(HALL_PWR_PIN);
if(nrf_gpio_pin_read(USB_DET_PIN))
usbConnectedFlag = 1;
motorDelayOffTimeSet = 500;
pwm_drv_init();
/* Initialize and enable PWM. */
app_pwm_config_t pwm1_cfg = APP_PWM_DEFAULT_CONFIG_1CH(250, BEEP_PIN); //BEEP /MOTOR
pwm1_cfg.pin_polarity[0] = APP_PWM_POLARITY_ACTIVE_HIGH;
brnEc = app_pwm_init(&PWM1,&pwm1_cfg,NULL/*pwm_ready_callback*/);
APP_ERROR_CHECK(brnEc);
app_pwm_enable(&PWM1);
while(beepTimes)
nrf_delay_ms(50);
nrf_delay_ms(100);
beepTimes--;
// Initialize.
log_init();
timers_init();
//buttons_leds_init(&erase_bonds);
//bsp_board_init(BSP_INIT_LEDS); //BRN
power_management_init();
ble_stack_init();
peer_manager_init();
gap_params_init();
gatt_init();
services_init();
advertising_init();
conn_params_init();
variable_init();
// Start execution.
//advertising_start(erase_bonds);
app_timer_create(&m_app_1ms_tmr,APP_TIMER_MODE_REPEATED,app_1ms_timer_handler); //BRN
app_timer_start(m_app_1ms_tmr, APP_TIMER_TICKS(1), NULL);
saadc_init();
// Enter main loop.
for (;;)
Button_Process();
LED_Process();
Beep_Ctrl();
YP_Swtich_Detection();
Motro_Ctrl();
Timer_Process();
Adc_Read();
Hall_Sensor_Detect();
Rotate_Speed_Adjust();
Usb_Detect();
Stuck_Detect();
if(newBleDataFlag)
newBleDataFlag = 0;
beepTimes = 1;
APP_ERROR_CHECK(app_pwm_channel_duty_set(&PWM1, 0, rcvData[3]));
//m_demo1_seq_values.channel_0 = rcvData[3];
//beepTimes = 2;
else if(aerateDoneFlag == 0)
beepTimes = 1;
//motorDelayOffTimeSet = (rcvData[2] * 256) + rcvData[3]; //test
if(rcvData[0] == 0x01)
aerateTimer = rcvData[1]*60 + rcvData[2];
aerateDoneFlag = 0;
aerateDoneFlag = 0;
if(motorOnFlag)
if((enterSleepDelay == 0) &&(systemOnFlag == 0) && (nrf_gpio_pin_read(KEY_PIN) == 1))
if((advStartedFlag) && (connectedFlag == 0))
advStartedFlag = 0;
// err_code = sd_ble_gap_adv_stop(m_advertising.adv_handle);
sleep_mode_enter();
if(systemOnFlag && (advStartedFlag == 0))
advStartedFlag = 1;
idle_state_handle();
