Help Importing Existing IAR Project to SES / GCC
I am attempting to import an existing IAR project to SES / GCC and am having some trouble. I recently joined the project team and we are making an effort to switch from the paid IAR license that our contracting firmware group has used to a free IDE/toolchain in order to take over development.
It began as a ble_app_hrs example and dfu secure_bootloader example was later incorporated, but it has come a long way.
I am not yet familiar with IAR so I am having some trouble translating the IAR .icf linker files, macros, and preprocessor definitions to work with the Segger internal GCC toolchain. I have been looking for any guides or assistance that I can find, but there doesn't seem to be much on the subject.
I followed the Segger guide for porting projects from IAR (link) but it is not specific to Nordic or comprehensive, and I have had difficulty at the troubleshooting memory linker script section. I also referenced the Nordic guide for Importing from Keil but it seems a bit out of date. After creating a flash_placement.xml file based off the original SES examples' flash_placement.xml files, and then changing the FLASH and RAM section placement macros and Heap/Stack size in runtime memory area settings I am still unable to compile and am seeing the following errors:
Building ‘neop_hat_main_s132_with_dfu_pca10040’ from solution ‘project’ in configuration ‘nrf52832_xxaa_s132 Internal’
Output/nrf52832_xxaa_s132 Internal/Exe/neop_hat_main_s132_with_dfu_pca10040.elf does not exist.
Generating linker script ‘neop_hat_main_s132_with_dfu_pca10040.ld’
Linking neop_hat_main_s132_with_dfu_pca10040.elf
Output/nrf52832_xxaa_s132 Internal/Exe/neop_hat_main_s132_with_dfu_pca10040.elf section `.init' will not fit in region `UNPLACED_SECTIONS'
region `UNPLACED_SECTIONS' overflowed by 16688 bytes
cannot find entry symbol reset_handler; not setting start address
Output/neop_hat_main_s132_with_dfu_pca10040 nrf52832_xxaa_s132 Internal/Obj/ses_startup_nrf52.o: in function `_vectors':
(.vectors+0x0): undefined reference to `__stack_end__'
(.vectors+0x4): undefined reference to `Reset_Handler'
Output/neop_hat_main_s132_with_dfu_pca10040 nrf52832_xxaa_s132 Internal/Obj/nrf_sdh.o:(.rodata.sdh_stack_observers+0x0): undefined reference to `__start_sdh_stack_observers'
Output/neop_hat_main_s132_with_dfu_pca10040 nrf52832_xxaa_s132 Internal/Obj/nrf_sdh.o:(.rodata.sdh_stack_observers+0x4): undefined reference to `__stop_sdh_stack_observers'
Post-build command
\GIT\Neopenda\Firmware\neop_hat_main\pca10040\s132_with_dfu\iar>echo Creating folder for DFU packages if not exist... 1>.\..\..\..\tools\"\postBuildLog.txt
\GIT\Neopenda\Firmware\neop_hat_main\pca10040\s132_with_dfu\iar>if not exist ".\..\..\..\tools\"\DFU_Packages" mkdir .\..\..\..\tools\"\DFU_Packages
Build failed
So my questions are:
  1. Is there anything obvious I am doing wrong based on error output?
  2. Which startup files should I be including? I added thumb_crt0.s as the Keil importing guide instructed - is this correct? Should I also add ses_startup_nrf_common.s (it is in the ble_app_hrs example but causes more errors when I include it). Anything else?
  3. Is there any more comprehensive guide or any other useful information available on converting the IAR linker scripts correctly to corresponding GCC linker scripts and allocating memory correctly in the flash_placement.xml format?
  4. Am I going about this the right way or is there anything else I should be considering or referencing at this point in order to successfully migrate the project?
I am aware that importing existing IAR projects can be challenging. If there is anything else that can help us do so I would like to pursue it. If however, the recommendation is that this is a mess and to stay with IAR at all costs we would consider that as well.
Thanks!
