Delay in connecting and disconnecting BLE
For my application using softdevice I need ADC update every 400ms and Battery level update every 2sec and  string update for HT1632 led driver every 2sec.So I have created three timers with corresponding time interval.When I included ADC timer it worked well.But when I included battery level and ht1632 driver timer and tried connecting to device from nRF Connect for Mobile I found that connection to softdevice is delayed more than 5sec same thing observed on disconnect.
As a part of clearing this issue on browsing i read a post on devzone https://devzone.nordicsemi.com/f/nordic-q-a/4147/ble-connect-events-cause-delays-in-app_timer-and-ppi,here it is mentioned that scheduler could solve the issue.If it helps please let me know  how implementation can be done.And also I am unable to understand on including ADC timer it is working fine without improper delay,but why not on including other two timers?
Thank you.
    From your description, it sounds like you get delays in the connect and disconnect process, is this correct? The thread you linked is about delays in the timer events.
    Can you post your code? Preferably the entire project, which will allow us to reproduce the issue and debug it.
    Jørgen
     * Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_app_template_main main.c
     * @ingroup ble_sdk_app_template
     * @brief Template project main file.
     * This file contains a template for creating a new application. It has the code necessary to wakeup
     * from button, advertise, get a connection restart advertising on disconnect and if no new
     * connection created go back to system-off mode.
     * It can easily be used as a starting point for creating a new application, the comments identified
     * with 'YOUR_JOB' indicates where and how you can customize.
    #include "HT1632_INIT.h"
    #include "app_error.h"
    #include "app_timer.h"
    #include "ble.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_bas.h"
    #include "ble_conn_params.h"
    #include "ble_conn_state.h"
    #include "ble_hci.h"
    #include "ble_srv_common.h"
    #include "bsp_btn_ble.h"
    #include "characterarray_5x21.h"
    #include "fds.h"
    #include "nordic_common.h"
    #include "nrf.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "nrf_delay.h"
    #include "nrf_drv_rtc.h"                            //**RTC driver legacy layer**//
    #include "nrf_drv_saadc.h"
    #include "nrf_gpio.h"                               //** Hardware access layer for managing the GPIO peripheral.**//
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_rtc.h"                                //**To access registers like INTENSET and EVTEN of RTC**//
    #include "nrf_saadc.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_sdh_soc.h"
    #include "peer_manager.h"
    #include "peer_manager_handler.h"
    #include "rtc_service.h"                            //**rtc service related header file**//
    #include "sensorsim.h"
    #include <math.h>
    #include <stdbool.h>
    #include <stdint.h>
    #include <stdio.h>
    #include <string.h>
    #define SAMPLES_IN_BUFFER 5
    #define COMPARE_COUNTERTIME (3UL)                   //**< Get Compare event COMPARE_TIME seconds after the counter starts from 0. *//
    #define DEVICE_NAME "1Nordic_integration1"          /**< Name of device. Will be included in the advertising data. */
    #define MANUFACTURER_NAME "NordicSemiconductor"     /**< Manufacturer. Will be passed to Device Information Service. */
    #define APP_ADV_INTERVAL 300                        /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
    #define APP_ADV_DURATION 18000                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define APP_BLE_OBSERVER_PRIO 3                      /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_BLE_CONN_CFG_TAG 1                      /**< A tag identifying the SoftDevice BLE configuration. */
    #define MIN_CONN_INTERVAL MSEC_TO_UNITS(100, UNIT_1_25_MS) /**< Minimum acceptable connection interval (0.1 seconds). */
    #define MAX_CONN_INTERVAL MSEC_TO_UNITS(200, UNIT_1_25_MS) /**< Maximum acceptable connection interval (0.2 second). */
    #define SLAVE_LATENCY 0                                    /**< Slave latency. */
    #define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS)   /**< Connection supervisory timeout (4 seconds). */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT 3                       /**< Number of attempts before giving up the connection parameter negotiation. */
    #define SEC_PARAM_BOND 1                               /**< Perform bonding. */
    #define SEC_PARAM_MITM 0                               /**< Man In The Middle protection not required. */
    #define SEC_PARAM_LESC 0                               /**< LE Secure Connections not enabled. */
    #define SEC_PARAM_KEYPRESS 0                           /**< Keypress notifications not enabled. */
    #define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE /**< No I/O capabilities. */
    #define SEC_PARAM_OOB 0                                /**< Out Of Band data not available. */
    #define SEC_PARAM_MIN_KEY_SIZE 7                       /**< Minimum encryption key size. */
    #define SEC_PARAM_MAX_KEY_SIZE 16                      /**< Maximum encryption key size. */
    #define DEAD_BEEF 0xDEADBEEF      /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define BATT_MEAS_INTERVAL_MS 400 //**The interval between two measurements (to set up the application timer)**//
    #define mask 0XFFFFFF             //**Macro for wrapping value into 24bit**//
    //**Battery voltage measurement parameters and variables**//
    #define BATT_MAX_VOLTAGE_MV 1000                          //**The maximum battery voltage in mV (for percentage calculations)**//
    #define BATT_MIN_VOLTAGE_MV 432                           //**The minimum battery voltage in mV, used for % calculation and low battery action**//
    #define BATT_MEAS_AVG_FACTOR 3                            //**The inverse of the weight to use for the running average smoothing of the read value**//
    #define BATTERY_LEVEL_MEAS_INTERVAL APP_TIMER_TICKS(2000) //**< Battery level measurement interval (ticks). **//
    #define STRING_DISPLAY_INTERVAL APP_TIMER_TICKS(2000)     //**< string display interval (ticks). **//
    #define WRITE 25                                          //**Assigning GPIO Pin number to write pin of HT1632**//
    #define DATA 26                                           //*Assigning GPIO Pin number to Data pin of HT1632*//
    #define CS 27                                             //*Assigning GPIO Pin number to CS pin of HT1632*//
    #define chip_byte_address(x, y) ((x % 21) << 1);          //*Setting Address*//
    uint8_t cursorX = 0;                                      //*Cursor X position*//
    uint8_t cursorY = 0;                                      //*Cursor Y position*//
    char str[] = "ORDAN TECHNOLOGIES PVT LTD";                //*Welcome String*//
    char str1[] = "BATTERY LOW";                              //*String to be displayed on Battery Low Condition*//
    char str2[] = "BATTERY FULLY CHARGED";                    //*String to be displayed on Battery Critically Low Condition*//
    uint8_t deframe_arr[5];                                   //*Array to store string to serve scrolling functionality*//
    uint8_t i;                                                //**//
    bool HT1632_flag = false;
    uint32_t str_length, display_len = 4, loop, k, length; //**//
    uint32_t str_length = sizeof(str);                     //**//
    const nrf_drv_rtc_t rtc_instance = NRF_DRV_RTC_INSTANCE(2);
    float new_meas_value_in_mv = 0;
    uint16_t new_meas_value = 0;
    NRF_BLE_GATT_DEF(m_gatt);           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
    BLE_RTC_DEF(m_rtc);                 //**<RTC Module Instance**//
    BLE_BAS_DEF(m_bas);                 //**< Structure used to identify the battery service. **//
    APP_TIMER_DEF(m_battery_timer_id);  //**< Battery timer.**//
    APP_TIMER_DEF(m_adc_timer_id);      //**ADC Timer**//
    APP_TIMER_DEF(m_str_timer_id);
    static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
    static uint32_t m_adc_evt_counter, battery_critical;     //**variable to count no. of events**//
    static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifiers. */
            {BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE},
            {BLE_UUID_BATTERY_SERVICE, BLE_UUID_TYPE_BLE},
    static nrf_saadc_value_t m_buffer_pool[2][SAMPLES_IN_BUFFER];
    uint32_t m_batt_current_voltage_mv = 0;       //The current, smoothed out, battery voltage
    uint8_t m_batt_percentage, conn_handle_value; //The current battery percentage calculated from voltage
    static void advertising_start(bool erase_bonds);
    /**@brief Callback function for asserts in the SoftDevice.
     * @param[in] line_num   Line number of the failing ASSERT call.
     * @param[in] file_name  File name of the failing ASSERT call.
    void assert_nrf_callback(uint16_t line_num, const uint8_t *p_file_name)
    /**@brief Function for handling Peer Manager events.
     * @param[in] p_evt  Peer Manager event.
    static void pm_evt_handler(pm_evt_t const *p_evt)
      pm_handler_on_pm_evt(p_evt);
      pm_handler_flash_clean(p_evt);
      switch (p_evt->evt_id) {
        advertising_start(false);
    //**Function for writing 8 bit data on to RAM**//
    void senddata_8bit(uint8_t address, uint8_t data)
      nrf_gpio_pin_clear(CS);
      ht1632_command(HT1632_ID_WR, 0x04); //1<<2);  // send ID: WRITE to RAM
      ht1632_command(address, 0x40);      //1<<6); // Send address
      writedatabits(data, 8);
      nrf_gpio_pin_set(CS);
    /**function defining logic for sending command code**/
    void ht1632_command(uint8_t ID, uint8_t firstbit)
      while (firstbit) {
        nrf_gpio_pin_clear(WRITE);
        nrf_delay_us(1);
        if (ID & firstbit) {
          nrf_gpio_pin_set(DATA);
          nrf_delay_us(1);
        } else {
          nrf_gpio_pin_clear(DATA);
          nrf_delay_us(1);
        nrf_gpio_pin_set(WRITE);
        nrf_delay_us(1);
        firstbit >>= 1;
    //**Writing one byte data on to LED Driver**//
    void writedatabits(uint8_t data, uint8_t count)
      while (count) {
        nrf_delay_us(1);
        if (data & 1) {
        } else {
        nrf_delay_us(1);
        count--;
        data >>= 1;
    //**Function for clearing all leds on LED Driver**//
    void clearallbits(uint8_t data)
      uint8_t i, address_var;
      for (i = 0; i <= 20; i++) {
        address_var = i * 2;
        senddata_8bit(address_var, data);
    //**Function for sending command**//
    void ht1632_sendcmd(uint8_t command)
      nrf_delay_us(1);
      ht1632_command(HT1632_ID_CMD, 1 << 2); // send 3 bits of id: COMMMAND
      ht1632_command(command, 1 << 7);       // send the actual command
      ht1632_command(0, 1);
      nrf_gpio_pin_set(CS); /* one extra dont-care bit in commands. */
      nrf_delay_us(1);
    //**All LEDS on and OFF Functionality using commands**//
    void blinker()
      ht1632_sendcmd(HT1632_CMD_BLON);
      nrf_delay_ms(250);
      ht1632_sendcmd(HT1632_CMD_BLOFF);
    //** Gpio pins initializtion for ht1632 led driver**//
    void ht1632_gpio_init()
      nrf_gpio_cfg_output(CS);
      nrf_gpio_cfg_output(WRITE);
      nrf_gpio_cfg_output(DATA);
    //**HT1632 LED Driver Initialization in master mode **//
    void ht1632_Init()
      ht1632_sendcmd(HT1632_CMD_SYSON); // Enable system
      ht1632_sendcmd(HT1632_CMD_LEDON); // LEDs on
      ht1632_sendcmd(HT1632_CMD_MSTMD);   // MASTER MODE
      ht1632_sendcmd(HT1632_CMD_RCCLK);   // master mode
      ht1632_sendcmd(HT1632_CMD_COMS00);  // com8, NMOS drivers
      ht1632_command(HT1632_CMD_PWM1, 8); // PWM duty cycle 1/16
    //** Function for Sending single character**//
    int putChar(int x, int y, char c)
      uint8_t charIndex;
      uint8_t colData;
      uint8_t numCols;
      uint8_t addr;
      // uint8_t colsLeft = 0;
      uint8_t chipn0 = 1;
      if (c > 15) {
        // Regular characters
        // replace undisplayable characters with blank;
        if (c < 32 || c > 126) {
          charIndex = 0;
        } else {
          charIndex = c - 32;
        numCols = Font5x21[charIndex][4];
        // get the number of columns this character uses
        for (uint8_t col = 0; col < 3; col++) {
          colData = Font5x21[charIndex][col];
          addr = chip_byte_address(x, y);
          senddata_8bit(addr, colData);
          x++;
      cursorX = x;
      cursorY = y;
      //return colsLeft;
    //** Function for Sending string**//
    void putstring(uint8_t x, uint8_t y, char *str)
      cursorX = x;
      cursorY = y;
      while (*str) {
        putChar(cursorX, y, *str++);
        cursorX += 1;
    //**Function for sending string of length 27 onto HT1632 LED Driver**//
    void send_message(char *message)
      if (HT1632_flag == false) {
        HT1632_flag = true;
        if (str_length > 5) {
          for (loop = 0; loop < str_length - 5; loop++) {
            for (k = 0; k <= display_len; k++) {
              deframe_arr[k] = message[k + loop];
            k = 0;
            putstring(0, 0, deframe_arr);
            memset(deframe_arr, 0, 5);
            nrf_delay_ms(250);
      nrf_delay_ms(1000);
    //**Handler function for SAADC**//
    void saadc_callback(nrf_drv_saadc_evt_t const *p_event)
      uint32_t value = 0, res;
      float config_param_ratio, vp, num;
      if (p_event->type == NRF_DRV_SAADC_EVT_DONE) {
        ret_code_t err_code;
        err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
        int i;
        NRF_LOG_INFO("ADC event number: %d", (int)m_adc_evt_counter);
        for (i = 0; i < SAMPLES_IN_BUFFER; i++) {
          NRF_LOG_INFO("%d", p_event->data.done.p_buffer[i]);
          value = value + p_event->data.done.p_buffer[i];
          //The measurement has to be * (61/11) (voltage divider) and * 1200/1023 (ADC reference/resolution)
          new_meas_value = value / SAMPLES_IN_BUFFER;
        NRF_LOG_INFO("ADC avg output: %d", new_meas_value);
        //** if The measurement has to be * (61/11) (voltage divider) and * 1200/1023 (ADC reference/resolution)**//
        //    m_batt_percentage = (( new_meas_value_in_mv-BATT_MIN_VOLTAGE_MV)*100) / (BATT_MAX_VOLTAGE_MV-BATT_MIN_VOLTAGE_MV);
        ++m_adc_evt_counter;
    /**@brief Function for performing battery measurement and updating the Battery Level characteristic
     *        in Battery Service.
    static void battery_level_update(void)
      err_code = ble_bas_battery_level_update(&m_bas, m_batt_percentage, BLE_CONN_HANDLE_ALL);
      if ((err_code != NRF_SUCCESS) &&
          (err_code != NRF_ERROR_INVALID_STATE) &&
          (err_code != NRF_ERROR_BUSY) &&
          (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)) {
        APP_ERROR_HANDLER(err_code);
    /**@brief Function for handling the Battery measurement timer timeout.
     * @details This function will be called each time the battery level measurement timer expires.
     * @param[in] p_context  Pointer used for passing some arbitrary information (context) from the
     *                       app_start_timer() call to the timeout handler.
    static void battery_level_meas_timeout_handler(void *p_context)
      uint32_t err_code;
      UNUSED_PARAMETER(p_context);
      new_meas_value_in_mv = (new_meas_value * 3.6) / 1.024;
      m_batt_percentage = ((new_meas_value_in_mv - BATT_MIN_VOLTAGE_MV) * 100) / (BATT_MAX_VOLTAGE_MV - BATT_MIN_VOLTAGE_MV);
      if (m_batt_percentage <= 20) {
        send_message(str1);
      //function display message "battery low n battery level" on ht1632//
      else {
        send_message(str2);
      //function display message "battery fully charged n battery levl" on ht1632//
      battery_level_update();
    /**@brief Function for triggering an ADC reading
     * The result will be processed in the ADC IRQ handler
    static void adc_start(void *p_context)
      NRF_SAADC->TASKS_SAMPLE = 1;
    void stringdisplay()
      send_message(str);
    /**@brief Function for the Timer initialization.
     * @details Initializes the timer module. This creates and starts application timers.
    static void timers_init(void)
      // Initialize timer module.
      // Create timers.
      err_code = app_timer_create(&m_str_timer_id,
          APP_TIMER_MODE_REPEATED,
          stringdisplay);
      err_code = app_timer_create(&m_battery_timer_id,
          battery_level_meas_timeout_handler);
      err_code = app_timer_create(&m_adc_timer_id,
          adc_start);
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
     *          device including the device name, appearance, and the preferred connection parameters.
      ble_gap_conn_params_t gap_conn_params;
          (const uint8_t *)DEVICE_NAME,
          strlen(DEVICE_NAME));
      /* YOUR_JOB: Use an appearance value matching the application's use case.
           err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_);
           APP_ERROR_CHECK(err_code); */
      gap_conn_params.slave_latency = SLAVE_LATENCY;
      gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
    /**@brief Function for initializing the GATT module.
    static void gatt_init(void) {
      ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
      APP_ERROR_HANDLER(nrf_error);
    //**Function for raising notification**//
    uint32_t our_rtc_characteristic_update(ble_rtc_t *p_rtc_service, uint32_t evt_update)
      uint32_t err_code;
      if (p_rtc_service->conn_handle != BLE_CONN_HANDLE_INVALID) {
        uint8_t temp;
        uint16_t len = 4;
        ble_gatts_hvx_params_t hvx_params;
        uint8_t buffer[sizeof(evt_update)];
        memcpy(buffer, &evt_update, len);
        memset(&hvx_params, 0, sizeof(hvx_params));
        hvx_params.handle = p_rtc_service->rtc_char_handles.value_handle;
        hvx_params.type = BLE_GATT_HVX_NOTIFICATION;
        hvx_params.offset = 0;
        hvx_params.p_len = &len;
        hvx_params.p_data = buffer;
        err_code = sd_ble_gatts_hvx(p_rtc_service->conn_handle, &hvx_params);
      } else {
        err_code = NRF_ERROR_INVALID_STATE;
      return err_code;
    //**Function for handling cc write event**//
    static void rtc_cc_write_handler(uint16_t conn_handle, ble_rtc_t *p_rtc_service, uint32_t value)
      printf("cc value\r\n");
      uint32_t cc_set, capturedval_rtc2;
      uint32_t err_code;
      if (value > 0)
        value &= 0xffffffff;
        capturedval_rtc2 = NRF_RTC2->COUNTER;
        printf("counter value %d\n", capturedval_rtc2);
        cc_set = capturedval_rtc2 + value;
        printf("cc value  %d\n", cc_set);
        // Set compare channel to trigger interrupt after COMPARE_COUNTERTIME seconds
        err_code = nrf_drv_rtc_cc_set(&rtc_instance, 1, cc_set, true);
        //**Notification test**//
        our_rtc_characteristic_update(&m_rtc, value);
        nrf_gpio_pin_toggle(LED_2);
        //Power on RTC instance
        nrf_drv_rtc_enable(&rtc_instance);
      ble_rtc_init_t init_rtc = {0}; //Initializing rtc_write_handler with 0**//
      ble_bas_init_t bas_init;
      init_rtc.rtc_write_handler = rtc_cc_write_handler; //**assigning cc_write handler to the rtc_write_handler(member of ble_rtc_init_t)**//
      err_code = rtc_service_init(&m_rtc, &init_rtc);    //**RTC Service Initialization**//
      // Initialize Battery Service.
      memset(&bas_init, 0, sizeof(bas_init));
      bas_init.evt_handler = NULL;
      bas_init.support_notification = true;
      bas_init.p_report_ref = NULL;
      bas_init.initial_batt_level = 100;
      // Here the sec level for the Battery Service can be changed/increased.
      bas_init.bl_rd_sec = SEC_OPEN;
      bas_init.bl_cccd_wr_sec = SEC_OPEN;
      bas_init.bl_report_rd_sec = SEC_OPEN;
      err_code = ble_bas_init(&m_bas, &bas_init);
    /**@brief Function for handling the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module which
     *          are passed to the application.
     *          @note All this function does is to disconnect. This could have been done by simply
     *                setting the disconnect_on_fail config parameter, but instead we use the event
     *                handler mechanism to demonstrate its use.
    static void on_conn_params_evt(ble_conn_params_evt_t *p_evt)
      if (p_evt->evt_type == BLE_CONN_PARAMS_EVT_FAILED) {
    /**@brief Function for handling a Connection Parameters error.
      cp_init.p_conn_params = NULL;
      cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
      cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
      cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
      cp_init.disconnect_on_fail = false;
      cp_init.evt_handler = on_conn_params_evt;
      cp_init.error_handler = conn_params_error_handler;
    /**@brief Function for starting timers.
    static void application_timers_start(void)
      // Start application timers.
      err_code = app_timer_start(m_str_timer_id, STRING_DISPLAY_INTERVAL, NULL);
      err_code = app_timer_start(m_adc_timer_id, APP_TIMER_TICKS(BATT_MEAS_INTERVAL_MS), NULL);
      err_code = app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
    static void sleep_mode_enter(void) {
      switch (ble_adv_evt) {
      case BLE_ADV_EVT_FAST:
        NRF_LOG_INFO("Fast advertising.");
      case BLE_ADV_EVT_IDLE:
        sleep_mode_enter();
    static void ble_evt_handler(ble_evt_t const *p_ble_evt, void *p_context)
      ret_code_t err_code = NRF_SUCCESS;
      switch (p_ble_evt->header.evt_id) {
        NRF_LOG_INFO("Disconnected.");
      case BLE_GAP_EVT_CONNECTED:
        NRF_LOG_INFO("Connected.");
      case BLE_GAP_EVT_PHY_UPDATE_REQUEST: {
        ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
      } break;
      case BLE_GATTC_EVT_TIMEOUT:
      case BLE_GATTS_EVT_TIMEOUT:
        // No implementation needed.
      uint32_t ram_start = 0;
      // Enable BLE stack.
    /**@brief Function for the Peer Manager initialization.
    static void peer_manager_init(void)
      err_code = pm_init();
      sec_param.bond = SEC_PARAM_BOND;
      sec_param.mitm = SEC_PARAM_MITM;
      sec_param.lesc = SEC_PARAM_LESC;
      sec_param.keypress = SEC_PARAM_KEYPRESS;
      sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
      sec_param.oob = SEC_PARAM_OOB;
      sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
      sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
      sec_param.kdist_own.enc = 1;
      sec_param.kdist_own.id = 1;
      sec_param.kdist_peer.enc = 1;
      sec_param.kdist_peer.id = 1;
    /**@brief Clear bond information from persistent storage.
    static void delete_bonds(void)
      NRF_LOG_INFO("Erase bonds!");
      err_code = pm_peers_delete();
     * @param[in]   event   Event generated when button is pressed.
    static void bsp_event_handler(bsp_event_t event)
      switch (event) {
      case BSP_EVENT_SLEEP:
        sleep_mode_enter();
        break; // BSP_EVENT_SLEEP
      case BSP_EVENT_DISCONNECT:
        if (err_code != NRF_ERROR_INVALID_STATE) {
        break; // BSP_EVENT_DISCONNECT
      case BSP_EVENT_WHITELIST_OFF:
        if (m_conn_handle == BLE_CONN_HANDLE_INVALID) {
        break; // BSP_EVENT_KEY_0
      ble_advertising_init_t init;
      ble_uuid_t adv_uuids[] = {{BLE_UUID_RTC_SERVICE, BLE_UUID_TYPE_VENDOR_BEGIN}}; //**creating a array variable and add service UUID and it's TYPE to it.**//
      init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
      init.advdata.include_appearance = true;
      init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
      init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
      init.advdata.uuids_complete.p_uuids = m_adv_uuids;
      init.srdata.uuids_complete.uuid_cnt = sizeof(adv_uuids) / sizeof(adv_uuids[0]); //**Adding Service to the advertising packet**//
      init.srdata.uuids_complete.p_uuids = adv_uuids;
      init.config.ble_adv_fast_enabled = true;
      init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
    static void buttons_leds_init(bool *p_erase_bonds)
      bsp_event_t startup_event;
      err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
      if (NRF_LOG_PROCESS() == false) {
        nrf_pwr_mgmt_run();
      if (erase_bonds == true) {
        delete_bonds();
        // Advertising is started by PM_EVT_PEERS_DELETED_SUCEEDED event
      } else {
        ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
    /** @brief: Function for handling the RTC0 interrupts.
     * Triggered on TICK and COMPARE0 match.
    static void rtc_handler(nrf_drv_rtc_int_type_t int_type)
      if (int_type == NRF_DRV_RTC_INT_COMPARE1) {
        printf("compared\n");
        nrf_gpio_pin_toggle(20);
        printf("toggle occured\n");
      } else if (int_type == NRF_DRV_RTC_INT_TICK) {
        nrf_gpio_pin_toggle(17);
    //**RTC2 Initialization**//
    void rtc2_init()
      uint32_t err_code;
      nrf_drv_rtc_config_t config = NRF_DRV_RTC_DEFAULT_CONFIG;
      config.prescaler = 4095;
      err_code = nrf_drv_rtc_init(&rtc_instance, &config, rtc_handler);
    //**SAADC Initialization**//
    void saadc_init(void)
      nrf_saadc_channel_config_t channel_config =
          NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN0);
      err_code = nrf_drv_saadc_init(NULL, saadc_callback);
      err_code = nrf_drv_saadc_channel_init(0, &channel_config);
      err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);
      err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER);
    /**@brief Function for application main entry.
      uint32_t j;
      bool erase_bonds;
      // Initialize.
      log_init();
      ht1632_gpio_init();
      ht1632_Init();
      clearallbits(0x00);
      timers_init();
      power_management_init();
      ble_stack_init();
      gap_params_init();
      gatt_init();
      rtc2_init();
      services_init();
      advertising_init();
      saadc_init();
      conn_params_init();
      peer_manager_init();
      // Start execution.
      NRF_LOG_INFO("Template example started.");
      application_timers_start();
      advertising_start(erase_bonds);
      clearallbits(0x00);
      // Enter main loop.
      for (;;)
        idle_state_handle();
    Thank you for the response.And yes,From my description I tried to explain the issue concerned about connect and disconnect proccess.Above I have inserted source code of my application.I also gave a try using scheduler but if I just enable APP_TIMER_CONFIG_USE_SCHEDULER in sdk_config.h I coudn't find device advertising on nRFConnect for Mobile.
    NOTE: RTC2_Handler is also being used by the application.
    Thank you.
  • I'm not sure exactly how you measure that the connect/disconnect is delayed, but most likely the issues you are seeing is caused by your use of nrf_delay_ms() in function send_message(). From what I can see, the loop will loop over 20 times, blocking 250 ms for each loop, totalling over 5 seconds. At the end of the function, you also have another delay of 1 second. Since this function is called every time battery_level_meas_timeout_handler() is executed (every 2 seconds), you will get interrupt starvation in the application.
    sorry for late reply.Thank you so much your answer was helpful to me.And exactly after commenting out delays it is working fine.But if i need to have some manditory delay.How can i deal with it?
    Thank you once again!
  • Normally if you want something to happen at a specific point of time in the future, you setup a timer. When the timer timeouts, a callback handler will be called where you can perform the desired task. Please have a look at the application timer tutorial.
