Mesh 3.2: LPN GET and receiving STATUS
Based on the experimental_lpn example if have ported at application (light switch) to work as a low power node.
Everything work fine on the lpn node where i use the generic_onoff_client to send button on/off to a server node.
I now want to 'request' the generic_onoff_server status issuing a GET from the client. This is also received on the server and a STATUS published.
Both server and client have been setup to use same app-key and group address on publish/subscribe.
To help me verifying what is send/received, i have added debug-print (__LOG) in app_mesh_core_event_cb()  on NRF_MESH_EVT_MESSAGE_RECEIVED and NRF_MESH_EVT_TX_COMPLETE.
I using the light_switch_server example as server and have verified that the light_switch_client example works fine receiving STATUS, but not the exprimental_lpn
Are there any restriction in the experimental_lpn that prevent me from receiving STATUS ?
  • I have also made these changes to the mesh-init and main loop .. allowing me to use APP_SCHED (Event Scheduler) .
    void mesh_init(void)
        mesh_stack_init_params_t init_params =
            /* Run application and mesh event handling in main loop using app_scheduler:
               When using the APP_SCHED to post event, the irq_priority must be changed from
               NRF_MESH_IRQ_PRIORITY_LOWEST to NRF_MESH_IRQ_PRIORITY_THREAD in order to avoid
               mesh app assert. */
            .core.irq_priority       = NRF_MESH_IRQ_PRIORITY_THREAD, //NRF_MESH_IRQ_PRIORITY_LOWEST,
            .core.lfclksrc           = DEV_BOARD_LF_CLK_CFG,
            .core.p_uuid             = NULL,
            .models.models_init_cb   = models_init_cb,
            .models.config_server_cb = NULL //config_server_evt_cb
        ERROR_CHECK(mesh_stack_init(&init_params, &m_device_provisioned));
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "m_device_provisioned:%d\n",m_device_provisioned);
        /* Register event handler to receive LPN and friendship events. */
        nrf_mesh_evt_handler_add(&m_mesh_core_event_handler);
        for (;;)
            app_sched_execute();
            bool done = nrf_mesh_process();
            if (done)
                sd_app_evt_wait();
  • Did I missed that at LPN can only received STATUS etc after establishing a friendship with a server ?
    In order for a node using the Low Power feature to consistently receive messages, it must establish a friendship with a node with the Friend feature, yes.
    Terje
