SEGGER EMBEDDED STUDIO, ERROR offsets.c.obj
Hi!
I'm currently setting up the nRF9160 dev kit for development and are having some trouble with "building" the asset tracking application.
Building ‘zephyr/include/generated/driver-validation.h’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/include/generated/driver-validation.h’
Building ‘zephyr/include/generated/kobj-types-enum.h’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/include/generated/kobj-types-enum.h’
Building ‘zephyr/include/generated/otype-to-str.h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls.json’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/misc/generated/syscalls.json’
Building ‘zephyr/include/generated/syscall_list.h’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/include/generated/syscall_list.h’
Building ‘zephyr/include/generated/syscall_dispatch.c’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/syscall_macros.h’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/include/generated/syscall_macros.h’
Building ‘zephyr/include/generated/offsets.h’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/include/generated/offsets.h’
1> Traceback (most recent call last):
1> File "C:/programvare/nrfsemi/ncs/zephyr/scripts/gen_offset_header.py", line 72, in <module>
1> input_file = open(args.input, 'rb')
1> FileNotFoundError: [Errno 2] No such file or directory: 'C:/programvare/nrfsemi/ncs/nrf/applications/asset_tracker/build/zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj'
Build failed
Any clues on what can cause this error message?
I'm using master branch.
David
  • No problem!
    From what I can see you only need to write:
    set GNUARMEMB_TOOLCHAIN_PATH=C:/gnuarmemb
  • C:\programvare\nrfsemi\ncs\nrf\applications\asset_tracker>SET ZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb
    C:\programvare\nrfsemi\ncs\nrf\applications\asset_tracker>set GNUARMEMB_TOOLCHAIN_PATH=C:/gnuarmemb
    C:\programvare\nrfsemi\ncs\nrf\applications\asset_tracker>west build -b nrf9160_pca10090
    -- west build: build configuration:
    source directory: C:\programvare\nrfsemi\ncs\nrf\applications\asset_tracker
    build directory: C:\programvare\nrfsemi\ncs\nrf\applications\asset_tracker\build
    BOARD: nrf9160_pca10090 (origin: command line)
    -- Using application from 'C:/programvare/nrfsemi/ncs/nrf/applications/asset_tracker'
    Zephyr version: 1.14.99
    -- Found PythonInterp: C:/Python37/python.exe (found suitable version "3.7.2", minimum required is "3.4")
    -- Selected BOARD nrf9160_pca10090
    -- Found west: C:/Python37/Scripts/west.exe (found suitable version "0.6.2", minimum required is "0.6.0")
    -- Cache files will be written to: C:\Users\Bruker\AppData\Local/.cache/zephyr
    -- Loading C:/programvare/nrfsemi/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090.dts as base
    -- Overlaying C:/programvare/nrfsemi/ncs/zephyr/dts/common/common.dts
    Device tree configuration written to C:/programvare/nrfsemi/ncs/nrf/applications/asset_tracker/build/zephyr/include/generated/generated_dts_board.conf
    Parsing Kconfig tree in C:/programvare/nrfsemi/ncs/nrf/applications/asset_tracker/Kconfig
    Loaded configuration 'C:/programvare/nrfsemi/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090_defconfig'
    Merged configuration 'C:/programvare/nrfsemi/ncs/nrf/applications/asset_tracker/prj.conf'
    Configuration saved to 'C:/programvare/nrfsemi/ncs/nrf/applications/asset_tracker/build/zephyr/.config'
    warning: BSD_LIBRARY (defined at C:/programvare/nrfsemi/ncs/nrf\lib\bsdlib/Kconfig:8) was assigned
    the value 'y' but got the value 'n'. You can check symbol information (including dependencies) in
    the 'menuconfig' interface (see the Application Development Primer section of the manual), or in the
    Kconfig reference at docs.zephyrproject.org/.../CONFIG_BSD_LIBRARY.html
    (which is updated regularly from the master branch). See the 'Setting configuration values' section
    of the Board Porting Guide as well.
    warning: NRF9160_GPS (defined at C:/programvare/nrfsemi/ncs/nrf\drivers\nrf9160_gps/Kconfig:8) has direct dependencies BSD_LIBRARY with value n, but is currently being y-selected by the following symbols:
    - GPS_CONTROL (defined at C:/programvare/nrfsemi/ncs/nrf/applications/asset_tracker\src/gps_controller/Kconfig:9), with value y, direct dependencies y (value: y)
    warning: AT_CMD (defined at C:/programvare/nrfsemi/ncs/nrf\drivers\at_cmd/Kconfig:9) has direct dependencies BSD_LIBRARY with value n, but is currently being y-selected by the following symbols:
    - AT_HOST_LIBRARY (defined at C:/programvare/nrfsemi/ncs/nrf\lib\at_host/Kconfig:9), with value y, direct dependencies y (value: y)
    - NRF9160_GPS_HANDLE_MODEM_CONFIGURATION (defined at C:/programvare/nrfsemi/ncs/nrf\drivers\nrf9160_gps/Kconfig:27), with value y, direct dependencies NRF9160_GPS (value: y), and select condition NRF9160_GPS (value: y)
    - LTE_LINK_CONTROL (defined at C:/programvare/nrfsemi/ncs/nrf\drivers\lte_link_control/Kconfig:7), with value y, direct dependencies y (value: y)
    -- The C compiler identification is GNU 8.3.1
    -- The CXX compiler identification is GNU 8.3.1
    -- Found assembler: C:/gnuarmemb/bin/arm-none-eabi-gcc.exe
    -- Performing Test toolchain_is_ok
    -- Performing Test toolchain_is_ok - Success
    Including module: nrf in path: C:\programvare\nrfsemi\ncs\nrf
    Including module: nffs in path: C:\programvare\nrfsemi\ncs\modules\fs\nffs
    Including module: segger in path: C:\programvare\nrfsemi\ncs\modules\debug\segger
    Including module: mbedtls in path: C:\programvare\nrfsemi\ncs\modules\crypto\mbedtls
    Including module: mcuboot in path: C:\programvare\nrfsemi\ncs\mcuboot\zephyr
    Including module: mcumgr in path: C:\programvare\nrfsemi\ncs\modules\lib\mcumgr
    Including module: tinycbor in path: C:\programvare\nrfsemi\ncs\modules\lib\tinycbor
    Including module: nrfxlib in path: C:\programvare\nrfsemi\ncs\nrfxlib
    CMake Warning at C:/programvare/nrfsemi/ncs/zephyr/CMakeLists.txt:1559 (message):
    --- WARNING: __ASSERT() statements are globally ENABLED ---
    --- The kernel will run more slowly and use more memory ---
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/programvare/nrfsemi/ncs/nrf/applications/asset_tracker/build
    [67/161] Building C object zephyr/modules/nrf/subsys/net/lib/nrf_cloud/CMakeFiles/..__nrf__subsys__net__lib__nrf_cloud.dir/src/nrf_cloud_transport.c.obj
    FAILED: zephyr/modules/nrf/subsys/net/lib/nrf_cloud/CMakeFiles/..__nrf__subsys__net__lib__nrf_cloud.dir/src/nrf_cloud_transport.c.obj
    C:\gnuarmemb\bin\arm-none-eabi-gcc.exe -DBUILD_VERSION=v1.14.99-ncs3-snapshot2-1276-g4493a423a645 -DKERNEL -DNRF9160_XXAA -DPROJECT_NAME=asset_tracker -DUSE_PARTITION_MANAGER=0 -D_FORTIFY_SOURCE=2 -D__LINUX_ERRNO_EXTENSIONS__ -D__ZEPHYR__=1 -IC:/programvare/nrfsemi/ncs/zephyr/kernel/include -IC:/programvare/nrfsemi/ncs/zephyr/arch/arm/include -IC:/programvare/nrfsemi/ncs/zephyr/include -IC:/programvare/nrfsemi/ncs/zephyr/include/drivers -Izephyr/include/generated -IC:/programvare/nrfsemi/ncs/zephyr/soc/arm/nordic_nrf/nrf91 -IC:/programvare/nrfsemi/ncs/zephyr/soc/arm/nordic_nrf/include -IC:/programvare/nrfsemi/ncs/zephyr/ext/hal/cmsis/Include -IC:/programvare/nrfsemi/ncs/zephyr/ext/hal/nordic/nrfx -IC:/programvare/nrfsemi/ncs/zephyr/ext/hal/nordic/nrfx/drivers/include -IC:/programvare/nrfsemi/ncs/zephyr/ext/hal/nordic/nrfx/hal -IC:/programvare/nrfsemi/ncs/zephyr/ext/hal/nordic/nrfx/mdk -IC:/programvare/nrfsemi/ncs/zephyr/ext/hal/nordic/. -IC:/programvare/nrfsemi/ncs/zephyr/subsys/net/lib/sockets/. -I../../../include -I../../../ext/cjson/. -I../../../lib/at_cmd_parser/include -I../../../subsys/net/lib/cloud/./include -I../../../subsys/net/lib/nrf_cloud/./include -I../src -I../src/orientation_detector/. -I../src/ui/include -I../src/cloud_codec/. -I../src/gps_controller/. -I../src/env_sensors/. -isystem C:/gnuarmemb/arm-none-eabi/include -Os -imacrosC:/programvare/nrfsemi/ncs/nrf/applications/asset_tracker/build/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -mthumb -mcpu=cortex-m33 -imacrosC:/programvare/nrfsemi/ncs/zephyr/include/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wno-unused-but-set-variable -Werror=implicit-int -fno-asynchronous-unwind-tables -fno-pie -fno-pic -fno-strict-overflow -fno-reorder-functions -fno-defer-pop -fmacro-prefix-map=C:/programvare/nrfsemi/ncs/nrf/applications/asset_tracker=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/programvare/nrfsemi/ncs/zephyr=ZEPHYR_BASE -ffunction-sections -fdata-sections -mabi=aapcs -march=armv8-m.main+dsp -std=c99 -MD -MT zephyr/modules/nrf/subsys/net/lib/nrf_cloud/CMakeFiles/..__nrf__subsys__net__lib__nrf_cloud.dir/src/nrf_cloud_transport.c.obj -MF zephyr\modules\nrf\subsys\net\lib\nrf_cloud\CMakeFiles\..__nrf__subsys__net__lib__nrf_cloud.dir\src\nrf_cloud_transport.c.obj.d -o zephyr/modules/nrf/subsys/net/lib/nrf_cloud/CMakeFiles/..__nrf__subsys__net__lib__nrf_cloud.dir/src/nrf_cloud_transport.c.obj -c C:/programvare/nrfsemi/ncs/nrf/subsys/net/lib/nrf_cloud/src/nrf_cloud_transport.c
    C:/programvare/nrfsemi/ncs/nrf/subsys/net/lib/nrf_cloud/src/nrf_cloud_transport.c: In function 'nct_client_id_get':
    C:/programvare/nrfsemi/ncs/nrf/subsys/net/lib/nrf_cloud/src/nrf_cloud_transport.c:272:3: error: #error Missing NRF_CLOUD_CLIENT_ID
    [72/161] Building C object zephyr/kernel/CMakeFiles/kernel.dir/poll.c.obj
    ERROR: command exited with status 1: 'C:\Program Files\CMake\bin\cmake.EXE' --build 'C:\programvare\nrfsemi\ncs\nrf\applications\asset_tracker\build'
  • I am still getting the same error when building inside SEGGER Embedded Studio,
    - David
  • Hmm. Seems like there may be an issue with your certificate file, at least from what I can see in the errors.
    Could you see if the certificates.h under asset_tracker/src matches this one?
  • This file is missing in my directory C:\programvare\nrfsemi\ncs\nrf\applications\asset_tracker\src
    I copied the files to my directory, but this did not help.
    -David
