SEGGER EMBEDDED STUDIO, ERROR offsets.c.obj
Hi!
I'm currently setting up the nRF9160 dev kit for development and are having some trouble with "building" the asset tracking application.
Building ‘zephyr/include/generated/driver-validation.h’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/include/generated/driver-validation.h’
Building ‘zephyr/include/generated/kobj-types-enum.h’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/include/generated/kobj-types-enum.h’
Building ‘zephyr/include/generated/otype-to-str.h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls.json’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/misc/generated/syscalls.json’
Building ‘zephyr/include/generated/syscall_list.h’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/include/generated/syscall_list.h’
Building ‘zephyr/include/generated/syscall_dispatch.c’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/syscall_macros.h’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/include/generated/syscall_macros.h’
Building ‘zephyr/include/generated/offsets.h’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/include/generated/offsets.h’
1> Traceback (most recent call last):
1> File "C:/programvare/nrfsemi/ncs/zephyr/scripts/gen_offset_header.py", line 72, in <module>
1> input_file = open(args.input, 'rb')
1> FileNotFoundError: [Errno 2] No such file or directory: 'C:/programvare/nrfsemi/ncs/nrf/applications/asset_tracker/build/zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj'
Build failed
Any clues on what can cause this error message?
I'm using master branch.
David
  • When I use the command : west build -b nrf9160_pca10090ns
    with "ns", I get a'little bit further, but still having a error.
    You know the difference bethween typing nrf9160_pca10090ns/nrf9160_pca10090 ?
    Running Partition Manager...
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/programvare/nrfsemi/ncs/nrf/applications/asset_tracker/build
    [99/344] Building C object spm/zephyr/CMakeFiles/spm_zephyr.dir/C_/programvare/nrfsemi/ncs/nrf/subsys/spm/spm.c.obj
    FAILED: spm/zephyr/CMakeFiles/spm_zephyr.dir/C_/programvare/nrfsemi/ncs/nrf/subsys/spm/spm.c.obj
    C:\gnuarmemb\bin\arm-none-eabi-gcc.exe -DBUILD_VERSION=v1.14.99-ncs3-snapshot2-1276-g4493a423a645 -DKERNEL -DMBEDTLS_CONFIG_FILE=\"nrf-config.h\" -DNRF9160_XXAA -DUSE_PARTITION_MANAGER=1 -D_FORTIFY_SOURCE=2 -D__ZEPHYR__=1 -IC:/programvare/nrfsemi/ncs/zephyr/kernel/include -IC:/programvare/nrfsemi/ncs/zephyr/arch/arm/include -IC:/programvare/nrfsemi/ncs/zephyr/include -IC:/programvare/nrfsemi/ncs/zephyr/include/drivers -Ispm/zephyr/include/generated -IC:/programvare/nrfsemi/ncs/zephyr/soc/arm/nordic_nrf/nrf91 -IC:/programvare/nrfsemi/ncs/zephyr/soc/arm/nordic_nrf/include -IC:/programvare/nrfsemi/ncs/zephyr/lib/libc/minimal/include -IC:/programvare/nrfsemi/ncs/zephyr/ext/hal/cmsis/Include -IC:/programvare/nrfsemi/ncs/zephyr/ext/hal/nordic/nrfx -IC:/programvare/nrfsemi/ncs/zephyr/ext/hal/nordic/nrfx/drivers/include -IC:/programvare/nrfsemi/ncs/zephyr/ext/hal/nordic/nrfx/hal -IC:/programvare/nrfsemi/ncs/zephyr/ext/hal/nordic/nrfx/mdk -IC:/programvare/nrfsemi/ncs/zephyr/ext/hal/nordic/. -IC:/programvare/nrfsemi/ncs/nrf/include -IC:/programvare/nrfsemi/ncs/nrfxlib/crypto/nrf_cc310_mbedcrypto/include/mbedtls -Ispm/zephyr/modules/nrfxlib/nrf_security/include -IC:/programvare/nrfsemi/ncs/mbedtls/include -IC:/programvare/nrfsemi/ncs/mbedtls/include/mbedtls -isystem c:/gnuarmemb/bin/../lib/gcc/arm-none-eabi/8.3.1/include -isystem c:/gnuarmemb/bin/../lib/gcc/arm-none-eabi/8.3.1/include-fixed -Os -nostdinc -imacrosC:/programvare/nrfsemi/ncs/nrf/applications/asset_tracker/build/spm/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -mthumb -mcpu=cortex-m33 -mfpu=fpv5-sp-d16 -mfloat-abi=hard -imacrosC:/programvare/nrfsemi/ncs/zephyr/include/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wno-unused-but-set-variable -Werror=implicit-int -fno-asynchronous-unwind-tables -fno-pie -fno-pic -fno-strict-overflow -fno-reorder-functions -fno-defer-pop -fmacro-prefix-map=C:/programvare/nrfsemi/ncs/nrf/applications/asset_tracker=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/programvare/nrfsemi/ncs/zephyr=ZEPHYR_BASE -ffunction-sections -fdata-sections -mabi=aapcs -march=armv8-m.main+dsp -mcmse -std=c99 -MD -MT spm/zephyr/CMakeFiles/spm_zephyr.dir/C_/programvare/nrfsemi/ncs/nrf/subsys/spm/spm.c.obj -MF spm\zephyr\CMakeFiles\spm_zephyr.dir\C_\programvare\nrfsemi\ncs\nrf\subsys\spm\spm.c.obj.d -o spm/zephyr/CMakeFiles/spm_zephyr.dir/C_/programvare/nrfsemi/ncs/nrf/subsys/spm/spm.c.obj -c C:/programvare/nrfsemi/ncs/nrf/subsys/spm/spm.c
    In file included from C:/programvare/nrfsemi/ncs/nrf/subsys/spm/spm.c:20:
    C:/programvare/nrfsemi/ncs/nrf/subsys/spm/spm.c: In function 'spm_jump':
    C:/programvare/nrfsemi/ncs/zephyr/arch/arm/include/cortex_m/tz.h:319:22: error: called object is not a function or function pointer
    ((tz_ns_func_ptr_t)(cmse_nsfptr_create(fptr)))
    C:/programvare/nrfsemi/ncs/nrf/subsys/spm/spm.c:429:13: note: in expansion of macro 'TZ_NONSECURE_FUNC_PTR_CREATE'
    reset_ns = TZ_NONSECURE_FUNC_PTR_CREATE(vtor_ns[1]);
    [104/344] Building C object spm/zephyr/arch/arm/core/CMakeFiles/spm_arch__arm__core.dir/irq_manage.c.obj
    ERROR: command exited with status 1: 'C:\Program Files\CMake\bin\cmake.EXE' --build 'C:\programvare\nrfsemi\ncs\nrf\applications\asset_tracker\build'
    C:\programvare\nrfsemi\ncs\nrf\applications\asset_tracker>
    -David
  • Hmm.
    nrf9160_pca10090ns targets the build for the "non secure partition" of the chip, nrf9160_pca10090 targets the secure part. I don't know the exact significance of this, but from what I know the asset_tracker is meant to be build with nrf9160_pca10090ns as you've already done.
    Did you delete the build folder between each time you ran west build now?
  • Ok, yes I did.
    -- Configuring done
    -- Generating done
    [92/344] Building C object spm/zephyr/CMakeFiles/spm_zephyr.dir/C_/programvare/nrfsemi/ncs/nrf/subsys/spm/spm.c.obj
    [97/344] Building C object spm/zephyr/CMakeFiles/spm_zephyr.dir/drivers/timer/nrf_rtc_timer.c.obj
    -David
  • Hi.
    Which GCC version are you using?
    You should be using the version listed in the Getting Started Assistant, 7-2018-q2-update.
    Didrik
  • Hey Didrik,
    I can confirm that when I change the GCC  version to 7-2018-q2-update, it works.
    But .. It only works with using cmd, with the following commands.
    1. SET ZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb
    2. SET GNUARMEMB_TOOLCHAIN_PATH="C:\gnuarmemb"
    3. west build -b nrf9160_pca10090ns
    An additional note to mention here is that men building with "ns" non-secure it says the following:
    "Changed board to secure nrf9160_pca10090 (NOT NS)"
    Why is that?, what is the difference between these two?
    When I use SEGGER Embedded Studio to "Build" the application I get following response.
    I believe it has to do with my missing "Directory" options, see picture below.
    Tools -> Options -> nRF Connect
    How do I add the directory here?
    GCC -> gnuarmemb
    Zephyr
    - David
