Just need a quick confirmation, in S140/SDK15.2, what is the correct to config hvn_tx_queue_size?
I found in some post said it can not be set directly, instead one should only change NRF_SDH_BLE_GAP_EVENT_LENGTH.
While in other posts said it can be direct set as in here
So which one exactly should be the right way? Will change NRF_SDH_BLE_GAP_EVENT_LENGTH only work in 15.2?
thanks.
Hi
You should follow Runar's advice and edit NRF_SDH_BLE_GAP_EVENT_LENGTH to change the queue size. You can set the queue size directly, but we generally don't recommend editing registers directly like that.
Simon
thank you Simonr
So does it mean that if I set a new NRF_SDH_BLE_GAP_EVENT_LENGTH, then value of ble_gatts_conn_cfg_t::hvn_tx_queue_size will be automatically updated, and how I can read the the new hvn_tx_queue_size value out ?
Depending on how much you want to change the queue size, you might have to increase NRF_SDH_BLE_GATT_MAX_MTU_SIZE as well to increase the static MTU size and NRF_SDH_BLE_GAP_DATA_LENGTH to increase the data length to be negotiated. So yes, hvn_tx_queue_size will be indirectly configured by the SoftDevice, based on what the EVENT_LENGTH and DATA_LENGTH is set to.
Simonr
Do you know any place to read the exact value.of hvn_tx_queue_size out that can be used in other place in program? there seems no api function to read it.
Correct, there is no API function for this.
