nRF9160 to Google Cloud Pub/Sub: Build errors
I followed this guide to send data to the GCP using the Thingy:91 : https://devzone.nordicsemi.com/nordic/nordic-blog/b/blog/posts/how-to-connect-nrf91-to-google-cloud
Im pretty sure I did it correct and followed all steps listed there.
But I can't get it to build. I tried it with the v0.4.0 tag and also master, cause this was recommended here in the forum.
This is my build error log:
Rebuilding ‘spm/zephyr/include/generated/driver-validation.h’ from solution ‘build’ in configuration ‘Common’
  Combining ‘spm/zephyr/include/generated/driver-validation.h’
Rebuilding ‘spm/zephyr/CMakeFiles/spm_driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘spm/zephyr/spm_driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘spm/zephyr/include/generated/kobj-types-enum.h’ from solution ‘build’ in configuration ‘Common’
  Combining ‘spm/zephyr/include/generated/kobj-types-enum.h’
Rebuilding ‘spm/zephyr/include/generated/otype-to-str.h’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘spm/zephyr/CMakeFiles/spm_kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘spm/zephyr/spm_kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘spm/zephyr/misc/generated/syscalls.json’ from solution ‘build’ in configuration ‘Common’
  Combining ‘spm/zephyr/misc/generated/syscalls.json’
Rebuilding ‘spm/zephyr/include/generated/syscall_list.h’ from solution ‘build’ in configuration ‘Common’
  Combining ‘spm/zephyr/include/generated/syscall_list.h’
Rebuilding ‘spm/zephyr/CMakeFiles/spm_syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘spm/zephyr/include/generated/syscall_dispatch.c’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘spm/zephyr/spm_syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘spm/zephyr/include/generated/syscall_macros.h’ from solution ‘build’ in configuration ‘Common’
  Combining ‘spm/zephyr/include/generated/syscall_macros.h’
Rebuilding ‘spm/zephyr/CMakeFiles/spm_syscall_macros_h_target’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘spm/zephyr/spm_syscall_macros_h_target’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘cmake_object_order_depends_target_spm_offsets’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘spm/zephyr/spm_offsets’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘offsets.c’
Rebuilding ‘spm/zephyr/include/generated/offsets.h’ from solution ‘build’ in configuration ‘Common’
  Combining ‘spm/zephyr/include/generated/offsets.h’
Rebuilding ‘spm/zephyr/CMakeFiles/spm_offsets_h’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘spm/zephyr/spm_offsets_h’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘cmake_object_order_depends_target_spm_app’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘cmake_object_order_depends_target_spm_arch__arm__core’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘cmake_object_order_depends_target_spm_arch__arm__core__cortex_m’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘cmake_object_order_depends_target_spm_arch__arm__core__cortex_m__mpu’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘cmake_object_order_depends_target_spm_drivers__serial’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘cmake_object_order_depends_target_spm_kernel’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘cmake_object_order_depends_target_spm_lib__libc__minimal’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘cmake_object_order_depends_target_spm_mbedcrypto_vanilla’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘cmake_object_order_depends_target_spm_mbeddrbg’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘cmake_object_order_depends_target_spm_zephyr’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘spm/zephyr/linker.cmd’ from solution ‘build’ in configuration ‘Common’
  Combining ‘spm/zephyr/linker.cmd’
Rebuilding ‘spm/zephyr/CMakeFiles/spm_linker_script_target’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘spm/zephyr/spm_linker_script_target’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘cmake_object_order_depends_target_spm_zephyr_prebuilt’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘spm/spm_app/libspm_app.a’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘main.c’
  Archiving ‘libspm_app.a’
Rebuilding ‘spm/zephyr/libspm_zephyr.a’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘isr_tables.c’
  Compiling ‘sw_isr_common.c’
  Compiling ‘arm_core_cmse.c’
  Compiling ‘arm_core_tz.c’
  Compiling ‘crc16_sw.c’
  Compiling ‘crc32_sw.c’
  Compiling ‘crc8_sw.c’
  Compiling ‘crc7_sw.c’
  Compiling ‘fdtable.c’
  Compiling ‘hex.c’
  Compiling ‘mempool.c’
  Compiling ‘rb.c’
  Compiling ‘sem.c’
  Compiling ‘thread_entry.c’
  Compiling ‘timeutil.c’
  Compiling ‘work_q.c’
  Compiling ‘printk.c’
  Compiling ‘configs.c’
  Compiling ‘soc.c’
  Compiling ‘mpu_regions.c’
  Compiling ‘system_nrf9160.c’
  Compiling ‘nrfx_glue.c’
  Compiling ‘power.c’
  Compiling ‘reboot.c’
  Compiling ‘policy_residency.c’
  Compiling ‘uart_console.c’
  Compiling ‘nrf_power_clock.c’
  Compiling ‘sys_clock_init.c’
  Compiling ‘nrf_rtc_timer.c’
  Compiling ‘spm.c’
  Compiling ‘secure_services.c’
  Archiving ‘libspm_zephyr.a’
Rebuilding ‘spm/zephyr/arch/arch/arm/core/libspm_arch__arm__core.a’ from solution ‘build’ in configuration ‘Common’
  Assembling ‘exc_exit.S’
  Assembling ‘swap_helper.S’
  Assembling ‘cpu_idle.S’
  Assembling ‘fault_s.S’
  Assembling ‘nmi_on_reset.S’
  Compiling ‘swap.c’
  Assembling ‘isr_wrapper.S’
  Compiling ‘irq_manage.c’
  Compiling ‘thread.c’
  Compiling ‘fatal.c’
  Compiling ‘nmi.c’
  Compiling ‘prep_c.c’
  Archiving ‘libspm_arch__arm__core.a’
Rebuilding ‘spm/zephyr/arch/arch/arm/core/cortex_m/libspm_arch__arm__core__cortex_m.a’ from solution ‘build’ in configuration ‘Common’
  Assembling ‘vector_table.S’
  Assembling ‘reset.S’
  Compiling ‘fault.c’
  Compiling ‘scb.c’
  Compiling ‘thread_abort.c’
  Compiling ‘irq_init.c’
  Archiving ‘libspm_arch__arm__core__cortex_m.a’
Rebuilding ‘spm/zephyr/arch/arch/arm/core/cortex_m/mpu/libspm_arch__arm__core__cortex_m__mpu.a’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘arm_core_mpu.c’
  Compiling ‘arm_mpu.c’
  Archiving ‘libspm_arch__arm__core__cortex_m__mpu.a’
Rebuilding ‘spm/zephyr/lib/libc/minimal/libspm_lib__libc__minimal.a’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘atoi.c’
  Compiling ‘strtol.c’
  Compiling ‘strtoul.c’
  Compiling ‘malloc.c’
  Compiling ‘exit.c’
  Compiling ‘bsearch.c’
  Compiling ‘strncasecmp.c’
  Compiling ‘strstr.c’
  Compiling ‘string.c’
  Compiling ‘strspn.c’
  Compiling ‘prf.c’
  Compiling ‘stdout_console.c’
  Compiling ‘sprintf.c’
  Compiling ‘fprintf.c’
  Compiling ‘gmtime.c’
  Archiving ‘libspm_lib__libc__minimal.a’
Rebuilding ‘spm/zephyr/drivers/serial/libspm_drivers__serial.a’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘uart_nrfx_uarte.c’
  Archiving ‘libspm_drivers__serial.a’
Rebuilding ‘spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/libspm_mbeddrbg.a’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘ctr_drbg.c’
  Compiling ‘entropy.c’
  Archiving ‘libspm_mbeddrbg.a’
Rebuilding ‘spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/libspm_mbedcrypto_vanilla.a’ from solution ‘build’ in configuration ‘Common’
  Compiling ‘aes.c’
    opening dependency file C:/Users/TimSahr/Documents/Nordic/sourcecode_root/ncs/nrf/samples/nrf9160/nRF9160DKtoGoogleCloud/build_nrf9160_pca10090ns/spm\zephyr\modules\nrfxlib\nrf_security\src\mbedtls\CMakeFiles\spm_mbedcrypto_vanilla.dir\C_\Users\TimSahr\Documents\Nordic\sourcecode_root\ncs\mbedtls\library\aes.c.obj.d: No such file or directory
  Compiling ‘aesni.c’
    opening dependency file C:/Users/TimSahr/Documents/Nordic/sourcecode_root/ncs/nrf/samples/nrf9160/nRF9160DKtoGoogleCloud/build_nrf9160_pca10090ns/spm\zephyr\modules\nrfxlib\nrf_security\src\mbedtls\CMakeFiles\spm_mbedcrypto_vanilla.dir\C_\Users\TimSahr\Documents\Nordic\sourcecode_root\ncs\mbedtls\library\aesni.c.obj.d: No such file or directory
  Compiling ‘arc4.c’
    opening dependency file C:/Users/TimSahr/Documents/Nordic/sourcecode_root/ncs/nrf/samples/nrf9160/nRF9160DKtoGoogleCloud/build_nrf9160_pca10090ns/spm\zephyr\modules\nrfxlib\nrf_security\src\mbedtls\CMakeFiles\spm_mbedcrypto_vanilla.dir\C_\Users\TimSahr\Documents\Nordic\sourcecode_root\ncs\mbedtls\library\arc4.c.obj.d: No such file or directory
  Compiling ‘aria.c’
    opening dependency file C:/Users/TimSahr/Documents/Nordic/sourcecode_root/ncs/nrf/samples/nrf9160/nRF9160DKtoGoogleCloud/build_nrf9160_pca10090ns/spm\zephyr\modules\nrfxlib\nrf_security\src\mbedtls\CMakeFiles\spm_mbedcrypto_vanilla.dir\C_\Users\TimSahr\Documents\Nordic\sourcecode_root\ncs\mbedtls\library\aria.c.obj.d: No such file or directory
  Compiling ‘asn1write.c’
    opening dependency file C:/Users/TimSahr/Documents/Nordic/sourcecode_root/ncs/nrf/samples/nrf9160/nRF9160DKtoGoogleCloud/build_nrf9160_pca10090ns/spm\zephyr\modules\nrfxlib\nrf_security\src\mbedtls\CMakeFiles\spm_mbedcrypto_vanilla.dir\C_\Users\TimSahr\Documents\Nordic\sourcecode_root\ncs\mbedtls\library\asn1write.c.obj.d: No such file or directory
  Compiling ‘asn1parse.c’
    opening dependency file C:/Users/TimSahr/Documents/Nordic/sourcecode_root/ncs/nrf/samples/nrf9160/nRF9160DKtoGoogleCloud/build_nrf9160_pca10090ns/spm\zephyr\modules\nrfxlib\nrf_security\src\mbedtls\CMakeFiles\spm_mbedcrypto_vanilla.dir\C_\Users\TimSahr\Documents\Nordic\sourcecode_root\ncs\mbedtls\library\asn1parse.c.obj.d: No such file or directory
  Compiling ‘base64.c’
    opening dependency file C:/Users/TimSahr/Documents/Nordic/sourcecode_root/ncs/nrf/samples/nrf9160/nRF9160DKtoGoogleCloud/build_nrf9160_pca10090ns/spm\zephyr\modules\nrfxlib\nrf_security\src\mbedtls\CMakeFiles\spm_mbedcrypto_vanilla.dir\C_\Users\TimSahr\Documents\Nordic\sourcecode_root\ncs\mbedtls\library\base64.c.obj.d: No such file or directory
  Compiling ‘bignum.c’
    opening dependency file C:/Users/TimSahr/Documents/Nordic/sourcecode_root/ncs/nrf/samples/nrf9160/nRF9160DKtoGoogleCloud/build_nrf9160_pca10090ns/spm\zephyr\modules\nrfxlib\nrf_security\src\mbedtls\CMakeFiles\spm_mbedcrypto_vanilla.dir\C_\Users\TimSahr\Documents\Nordic\sourcecode_root\ncs\mbedtls\library\bignum.c.obj.d: No such file or directory
Build failed
Any help is appreciated!
Tim
  • Hi ,
    I tried it again today and now I get error -13.
    I tried to find some information about the error number but can't find any.
    Provisioning complete
    Initializing modem
    Establishing LTE link (this may take some time) ...
    [00:00:04.352,233] <inf> lte_lc: Using legacy LTE PCO mode...
    Modem configured
    Connecting to Google Cloud
    [00:00:25.399,536] <inf> gcloud: Got CONNECT command
    [00:00:25.399,536] <dbg> gcloud.gcloud_thread: Initiating broker
    [00:00:25.771,453] <dbg> gcloud.broker_init: IPv4 Address found 0xce857d4a
    [00:00:25.771,484] <dbg> gcloud.gcloud_thread: Making JWT
    [00:00:26.301,574] <dbg> gcloud.make_jwt: timestamp: 1569312515
    [00:00:26.596,160] <dbg> gcloud.gcloud_thread: Initiating client
    [00:00:27.723,602] <dbg> gcloud.make_jwt: timestamp: 1569312517
    [00:00:28.018,188] <dbg> gcloud.client_init: JWT:
    eyJhbGciOiJFUzI1NiIsInR5cCI6IkpXVCJ9.eyJhdWQiOiJmbHV0ZWQtY2xvY2stMjQ5MzE1IiwiZXhwIjoxNTY5MzU1NzE3LCJpYXQiOjE1NjkzMTI1MTd9.6MoUK~
    [00:00:28.018,218] <dbg> gcloud.client_init: JWT length: 208
    [00:00:28.018,218] <dbg> gcloud.gcloud_thread: Starting input timer
    [00:00:28.018,249] <dbg> gcloud.gcloud_thread: Connecting mqtt
    Sending JSON data:
    "Message":22019
    [00:00:35.409,729] <wrn> gcloud: Cannot publish data while not connected to Google Cloud
    [00:00:39.603,912] <err> gcloud: mqtt_connect failed: -111 Connection refused
    GCLOUD THREAD LIVES
    [00:00:39.603,942] <inf> gcloud: Got INPUT_TIMEOUT command
    [00:00:39.603,973] <err> gcloud: mqtt_input failed: -13
    GCLOUD THREAD LIVES
    Sending JSON data:
    "Message":22019
    [00:00:45.419,952] <wrn> gcloud: Cannot publish data while not connected to Google Cloud
    [00:00:48.018,249] <inf> gcloud: Got INPUT_TIMEOUT command
    [00:00:48.018,280] <err> gcloud: mqtt_input failed: -13
    GCLOUD THREAD LIVES
    Thanks.
    Tim
  • Hi Tim,
    In order to find what error number -13 is, you can use strerror().
    printk("err: %d\n", strerror(-err));
    This will print what error number -13 corresponds to. You can add this where the following is in the code
    LOG_ERR("mqtt_input failed: %d", err);
    That is, line 635 in gcloud.c
    strerror() must take a positive error number, hence the minus in front of err in the code above.
    Hope this helps.
    Marte
  • Hi ,
    now it works. The problem was in the Google Cloud I guess. Something with the certificates. The error was "connection refused" so I added the device again to the cloud. Slight smile
  • Hi Tim,
    Yes, connection refused does sound like a problem with certificates or how the device was added on Google Cloud.
    Great that you managed to solve it!
  • Hi
    I am facing the same above issue while connecting my Thingy91 PCA20035 device to Google cloud uisng MQTT bridge.
    I have placed nRFDKtoGoogleCloud folder inside the ncs-folder, for example giving the path \ncs\nrf\samples\nrf9160\nRF9160DKtoGoogleCloud.
    I m pretty sure I did it correct and followed all steps listed there.
    After writing the hex file to the thingy:91 this is the serial output.
    This is my build error logs:
    ***** Booting Zephyr OS version 2.1.0-rc1 *****
    Provisioning
    GCLOUD_HOSTNAME:mqtt.googleapis.com
    GCLOUD THREAD LIVES
    [00:00:00.939,575] <err> gcloud: key delete err: 2 No such file or directory
    [00:00:01.519,470] <err> gcloud: key delete err: 2 No such file or directory
    [00:00:02.098,663] <err> gcloud: key delete err: 2 No such file or directory
    [00:00:02.678,314] <err> gcloud: key delete err: 2 No such file or directory
    [00:00:03.260,894] <err> gcloud: key delete err: 2 No such file or directory
    [00:00:03.386,901] <dbg> gcloud.gcloud_provision: CERT:
    -----BEGIN CERTIFICATE-----
    MIIBdTCCARugAwIBAgIJAOvj4PVfAgqjMAoGCCqGSM49BAMCMBYxFDASBgNVBAMM
    C25yZjkxLW1hcnRlMCAXDTE5MDQwNTExMTUxN1oYDzQ3NTcwMzAyMTExNTE3WjAW
    MRQwEgYDVQQDDAtucmY5MS1tYXJ0ZTBZMBMGByqGSM49AgEGCCqGSM49AwEHA0IA
    BAq8otkWGnocpdAxlnpJdVn6EBb1WbQnZXLFaYzsMeXWGFIIO02hWTvaSUPI1xNs
    0QB8c3IU9oBhDXkRNU2Nqi2jUDBOMB0GA1UdDgQWBBRLAhO335CAd280I/qVQmiM
    07nd8TAfBgNVHSMEGDAWgBRLAhO335CAd280I/qVQmiM07nd8TAMBgNVHRMEBTAD
    AQH/MAoGCCqGSM49BAMCA0gAMEUCIF2kQO7Cqn73ANmwBdgGA1y/KGOpOU4I/ywF
    LEu8trOUAiEA8//UWttMRkmaylghw3mgsYGGKk17rY+4j+4mGUwvDnw=
    -----END CERTIFICATE-----
    Initializing modem
    [00:00:06.564,483] <dbg> lte_lc.parse_nw_reg_status: Network registration status: 2
    [00:00:09.131,195] <dbg> lte_lc.parse_nw_reg_status: Network registration status: 5
    Modem configured
    [00:00:09.227,691] <inf> gcloud: Got CONNECT command
    [00:00:09.252,288] <dbg> gcloud.gcloud_thread: Initiating broker
    [00:00:09.676,086] <dbg> gcloud.broker_init: IPv4 Address found 0xce857d4a
    [00:00:09.702,667] <dbg> gcloud.gcloud_thread: Making JWT
    [00:00:10.487,609] <dbg> gcloud.make_jwt: timestamp: 1580855965
    Timestamp: 1580855965[00:00:10.830,932] <dbg> gcloud.gcloud_thread: Initiating client
    [00:00:11.204,559] <dbg> gcloud.make_jwt: timestamp: 1580855966
    Timestamp: 1580855966[00:00:11.547,485] <dbg> gcloud.client_init: JWT:
    eyJhbGciOiJFUzI1NiIsInR5cCI6IkpXVCJ9.eyJhdWQiOiJzcGFucGFya2luZyIsImV4cCI6MTU4MDg5OTE2NiwiaWF0IjoxNTgwODU1OTY2fQ.g1_nGrphjRQ5kFYHij3hlTmLZp81dy9615EoEtSxyNnyf92dlW3lMpzmRYifMqp_3C4ElG1TaGXLX3r4ImQvtA
    [00:00:11.589,355] <dbg> gcloud.client_init: JWT length: 198
    [00:00:11.667,724] <dbg> gcloud.gcloud_thread: Starting input timer
    [00:00:11.693,725] <dbg> gcloud.gcloud_thread: Connecting mqtt
    [00:00:11.739,135] <err> gcloud: mqtt_connect failed: -22 Invalid argument
    GCLOUD THREAD LIVES
    Sending JSON data:
    "Message": 22019
    [00:00:19.285,156] <wrn> gcloud: Cannot publish data while not connected to Google Cloud
    [00:00:21.693,817] <inf> gcloud: Got INPUT_TIMEOUT command
    GCLOUD THREAD LIVES
    Sending JSON data:
    "Message": 22019
    [00:00:19.285,256] <wrn> gcloud: Cannot publish data while not connected to Google Cloud
    [00:00:21.693,917] <inf> gcloud: Got INPUT_TIMEOUT command
    Please help me with the possible solution to fix the above issue.
    This is missing my final deadline for production.
    Thanks
