The firrmware of the connected J-link doesnt support the following memory access: Read @ 0x02000004
Hello, im relatively new to this and not sure why im getting this error. According to previous such error clarifications, i read that the newest versions have to be used. Im using the most recent version of all softwares. But still getting the following error. Can someone kindly guide me.Below are comment error, target settings and version of software
JLink info:
DLL: V5.12f, compiled May 17 2016 16:03:35
Firmware: J-Link Lite-Cortex-M V9 compiled May 17 2019 09:50:01
Hardware: V9.00
S/N : 519001316
Feature(s) : GDB
* JLink Info: Found SWD-DP with ID 0x2BA01477
* JLink Info: SWD speed too high. Reduced from 4000 kHz to 2025 kHz
for stability
* JLink Info: Found Cortex-M4 r0p1, Little endian.
* JLink Info: FPUnit: 6 code (BP) slots and 2 literal slots
* JLink Info: CoreSight components:
* JLink Info: ROMTbl 0 @ E00FF000
* JLink Info: ROMTbl 0 [0]: FFF0F000, CID: B105E00D, PID: 000BB00C SCS
* JLink Info: ROMTbl 0 [1]: FFF02000, CID: B105E00D, PID: 003BB002 DWT
* JLink Info: ROMTbl 0 [2]: FFF03000, CID: B105E00D, PID: 002BB003 FPB
* JLink Info: ROMTbl 0 [3]: FFF01000, CID: B105E00D, PID: 003BB001 ITM
* JLink Info: ROMTbl 0 [4]: FFF41000, CID: B105900D, PID: 000BB9A1 TPIU
* JLink Info: ROMTbl 0 [5]: FFF42000, CID: B105900D, PID: 000BB925 ETM
ROMTableAddr = 0xE00FF000
Target info:
Device: nRF52832_xxAA
VTarget = 2.070V
State of Pins:
TCK: 0, TDI: 1, TDO: 1, TMS: 1, TRES: 1, TRST: 255
Hardware-Breakpoints: 6
Software-Breakpoints: 8192
Watchpoints:          4
JTAG speed: 2000 kHz
Error: Flash Download failed  -  Target DLL has been cancelled
Flash Load finished at 18:28:57
Load "C:\\Users\\kd_studies\\Desktop\\Arbeit
software\\installing\\nRF5_SDK_15.3.0_59ac345\\nRF5_SDK_15.3.0_59ac345\\examples\\ant\\ant_io_demo\\ant_io_tx\\d52_starterkit\\s212\\arm5_no_packs\\_build\\nrf52832_xxaa.axf"
Set JLink Project File to "C:\Users\kd_studies\Desktop\Arbeit
software\installing\nRF5_SDK_15.3.0_59ac345\nRF5_SDK_15.3.0_59ac345\examples\ant\ant_io_demo\ant_io_tx\d52_starterkit\s212\arm5_no_packs\JLinkSettings.ini"
* JLink Info: Device "NRF52832_XXAA" selected.
JLink info:
Hardware: V9.00
S/N : 519001316
Feature(s) : GDB
* JLink Info: SWD speed too high. Reduced from 4000 kHz to 1518 kHz
for stability
Target info:
VTarget = 1.998V
State of Pins:
Watchpoints:          4
JTAG speed: 1500 kHz
Flash Load finished at 18:32:27
JLink info:
Hardware: V9.00
S/N : 519001316
Feature(s) : GDB
for stability
Target info:
VTarget = 2.012V
State of Pins:
Watchpoints:          4
Flash Load finished at 18:32:35
JLink info:
Hardware: V9.00
S/N : 519001316
Feature(s) : GDB
* JLink Info: SWD speed too high. Reduced from 4000 kHz to 1138 kHz
for stability
Target info:
VTarget = 2.004V
State of Pins:
Watchpoints:          4
JTAG speed: 1130 kHz
Flash Load finished at 18:32:55
JLink info:
Hardware: V9.00
S/N : 519001316
Feature(s) : GDB
Target info:
VTarget = 2.058V
State of Pins:
Watchpoints:          4
JTAG speed: 942 kHz
Flash Load finished at 18:34:01
Target settigs are as below
Software version keil   --   5.28
nRgo Studio   --     1.21.2.10
SDK --    nRF5_SDK_15.3.0_59ac345
J-link   --  6.50b
ANT soft device     --     s332
  • It says succesful...   Sorry having trouble copying the log file, hence the photo
    And i tried reinstallling J-link, 6.50a and b....both are throwing error.... Im using Keil, J-link, nRFGo Studio.  Should i install anything else?
  • I see. I have had problems with Segger J-link not working correctly a few times, and though I never found out what actually caused it, uninstalling all Segger related and everything that depended on it, rebooting and installing again solved the problem. Please try that again first. Note that the reboot between uninstalling and installing is important in my experience, at least if you are using MS Windows.
  • is the compiler default or should i change that too in target settings?
    I think I am missing some context, but if you are asking about the example Keil projects, then no - you don't need to change anything. They are correctly set up when you extract the SDK and will build out of the box.
    i installed as you said , with a reboot(which i hadnt done before), Thank you.
    i uninstalled all softwares, shut down, installed, one after that other. im using S212 project and S212 soft device with below memory address,
    in the Softdevice version document, the ROM is 72kb and RAM is 2.94kb.
    WIth below error message
    Build started: Project: ant_io_tx_d52_starterkit_s212
    *** Using Compiler 'V5.06 update 6 (build 750)', folder: 'C:\Keil_v5\ARM\ARMCC\Bin'
    Build target 'nrf52832_xxaa'
    linking...
    Program Size: Code=12408 RO-data=3992 RW-data=304 ZI-data=10960
    FromELF: creating hex file...
    ".\_build\nrf52832_xxaa.axf" - 0 Error(s), 0 Warning(s).
    Build Time Elapsed:  00:00:03
    Load "C:\\Users\\bjnag\\Desktop\\Softwares\\Arbeit software\\nRF5_SDK_15.3.0_59ac345\\nRF5_SDK_15.3.0_59ac345\\examples\\ant\\ant_io_demo\\ant_io_tx\\d52_starterkit\\s212\\arm5_no_packs\\_build\\nrf52832_xxaa.axf"
    Set JLink Project File to "C:\Users\bjnag\Desktop\Softwares\Arbeit software\nRF5_SDK_15.3.0_59ac345\nRF5_SDK_15.3.0_59ac345\examples\ant\ant_io_demo\ant_io_tx\d52_starterkit\s212\arm5_no_packs\JLinkSettings.ini"
    JLink info:
    DLL: V6.50b, compiled Sep  6 2019 17:57:35
    Hardware: V9.00
    S/N : 519001316
    Feature(s) : GDB
    * JLink Info: Found SW-DP with ID 0x2BA01477
    * JLink Info: SWD speed too high. Reduced from 4000 kHz to 2025 kHz for stability
    * JLink Info: Scanning AP map to find all available APs
    * JLink Info: AP[2]: Stopped AP scan as end of AP map has been reached
    * JLink Info: AP[0]: AHB-AP (IDR: 0x24770011)
    * JLink Info: AP[1]: JTAG-AP (IDR: 0x02880000)
    * JLink Info: Iterating through AP map to find AHB-AP to use
    * JLink Info: AP[0]: Core found
    * JLink Info: AP[0]: AHB-AP ROM base: 0xE00FF000
    * JLink Info: CPUID register: 0x410FC241. Implementer code: 0x41 (ARM)
    * JLink Info: ROMTbl[0] @ E00FF000
    * JLink Info: ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7
    * JLink Info: ROMTbl[0][1]: E0001000, CID: B105E00D, PID: 003BB002 DWT
    * JLink Info: ROMTbl[0][2]: E0002000, CID: B105E00D, PID: 002BB003 FPB
    * JLink Info: ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM
    * JLink Info: ROMTbl[0][4]: E0040000, CID: B105900D, PID: 000BB9A1 TPIU
    * JLink Info: ROMTbl[0][5]: E0041000, CID: B105900D, PID: 000BB925 ETM
    * JLink Info: Reset: Halt core after reset via DEMCR.VC_CORERESET.
    * JLink Info: Reset: Reset device via AIRCR.SYSRESETREQ.
    Target info:
    VTarget = 2.767V
    State of Pins:
    Watchpoints:          4
    Erase Failed!
    Error: Flash Download failed  -  "Cortex-M4"
    Flash Load finished at 14:31:16
    JLink info:
    Hardware: V9.00
    S/N : 519001316
    Feature(s) : GDB
    Target info:
    VTarget = 2.767V
    State of Pins:
    Watchpoints:          4
    Erase Failed!
    Flash Load finished at 14:34:41
    JLink info:
    Hardware: V9.00
    S/N : 519001316
    Feature(s) : GDB
    Target info:
    VTarget = 2.767V
    State of Pins:
    Watchpoints:          4
    Erase Failed!
    Flash Load finished at 14:38:01
    NRFgo, I had uploaded the hex file of softdevice212
    In the nRF connect, I get as below when i read the memory,
    On this, I'm trying to load the Keil file.
    Is the procedure alright? and I'm still getting some error, I'm not able to solve it.
    ****When i upload soft device hexfile and application of blinky board directly from nRFstudio, the hardware works and the leds start to blink.
