hi,
i want to implement zigbee protocol. our requirement is 50 nodes with mesh topology.please suggest us the example code.
jagadeesh
hi,
jagadeesh
hi,
i have taken three boards. in one board i have dumped light coordinator code. and other two boards i have dumped light switch code.i am using internal clock.there is no network connection.
// <e> NRFX_CLOCK_ENABLED - nrfx_clock - CLOCK peripheral driver
#ifndef NRFX_CLOCK_ENABLED
#define NRFX_CLOCK_ENABLED 1
// <o> NRFX_CLOCK_CONFIG_LF_SRC - LF Clock Source
// <0=> RC
// <1=> XTAL
// <2=> Synth
// <131073=> External Low Swing
// <196609=> External Full Swing
#ifndef NRFX_CLOCK_CONFIG_LF_SRC
#define NRFX_CLOCK_CONFIG_LF_SRC 0
// <o> NRFX_CLOCK_CONFIG_IRQ_PRIORITY - Interrupt priority
#ifndef NRFX_CLOCK_CONFIG_IRQ_PRIORITY
#define NRFX_CLOCK_CONFIG_IRQ_PRIORITY 6
NRF_LOG_INFO("Joined network successfully");
bsp_board_led_on(ZIGBEE_NETWORK_STATE_LED);
nrf_gpio_pin_set(PAIR_LED);
/* Check the light device address */
if (m_device_ctx.bulb_params.short_addr == 0xFFFF)
zb_err_code = ZB_SCHEDULE_ALARM(find_light_bulb, param, MATCH_DESC_REQ_START_DELAY);
ZB_ERROR_CHECK(zb_err_code);
zb_err_code = ZB_SCHEDULE_ALARM(find_light_bulb_timeout, 0, MATCH_DESC_REQ_TIMEOUT);
param = 0; // Do not free buffer - it will be reused by find_light_bulb callback
NRF_LOG_ERROR("Failed to join network. Status: %d", status);
bsp_board_led_off(ZIGBEE_NETWORK_STATE_LED);
nrf_gpio_pin_clear(PAIR_LED);
zb_err_code = ZB_SCHEDULE_ALARM(light_switch_leave_and_join, 0, ZB_TIME_ONE_SECOND);
jagadeesh
three boards
What boards, exactly?
Are you getting any log messages?
What debugging have you done?
connection is established between coordinator and router and end device. please suggest me a example, to send 30 bytes of data from end device to coordinator.i am a beginner.
Regards jagadeesh
