error: #20: identifier "NRF_DRV_TWI_INSTANCE_0" is undefined but defined in SDK_config.h
At the following line
const static nrf_drv_twi_t m_twi_master = NRF_DRV_TWI_INSTANCE(MASTER_TWI_INST);
I get the error:
hal.c(35): error:  #20: identifier "NRF_DRV_TWI_INSTANCE_0" is undefined
When looking further it seems likein the following code from nrf_drv_twi.h is greyed out
#define NRF_DRV_TWI_INSTANCE(id)    NRF_DRV_TWI_INSTANCE_(id)
#define NRF_DRV_TWI_INSTANCE_(id)   NRF_DRV_TWI_INSTANCE_ ## id
#if NRFX_CHECK(NRFX_TWIM0_ENABLED)
    #define NRF_DRV_TWI_INSTANCE_0 \
        { 0, { .twim = NRFX_TWIM_INSTANCE(0) }, true }
#elif NRFX_CHECK(NRFX_TWI0_ENABLED)
        { 0, { .twi = NRFX_TWI_INSTANCE(0) }, false }
#if NRFX_CHECK(NRFX_TWIM1_ENABLED)
    #define NRF_DRV_TWI_INSTANCE_1 \
        { 1, { .twim = NRFX_TWIM_INSTANCE(1) }, true }
#elif NRFX_CHECK(NRFX_TWI1_ENABLED)
        { 1, { .twi = NRFX_TWI_INSTANCE(1) }, false }
When I go even further and look in my SDK_config.h I can clearly see that all TWI and TWIS and TWIM entries are set to 1 and the instances are also set to 1:
// <e> NRFX_TWI_ENABLED - nrfx_twi - TWI peripheral driver
#ifndef NRFX_TWI_ENABLED
#define NRFX_TWI_ENABLED 1
// <q> NRFX_TWI0_ENABLED  - Enable TWI0 instance
#ifndef NRFX_TWI0_ENABLED
#define NRFX_TWI0_ENABLED 1
What else can be the problem?
