Reading ADC in nRF52840
I am new to development with Nordic chips. I am using nRF52840-DK (SES,nRF5_SDK_15.3.0_59ac345) to read analog input on ADC pin AIN0. I want to continuously read the adc after pairing is established and then broadcast the data over Bluetooth. In order to achieve my objective, I am trying to run ble_app_hrs example by combining the SAADC example with it. Is this approach correct.
When I compile my program using SES, I am getting the following error in nrfx_timer.h(line 74). I don't get this error if run the these examples individually.
'NRFX_TIMER0_INST_IDX' undeclared here (not in a function); did you mean 'NRFX_TIMER_INSTANCE'?
Jagbir
 * Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
 * All rights reserved.
/** @example examples/ble_peripheral/ble_app_hrs/main.c
 * @brief Heart Rate Service Sample Application main file.
 * This file contains the source code for a sample application using the Heart Rate service
 * (and also Battery and Device Information services). This application uses the
 * @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "nrf_sdm.h"
#include "app_error.h"
#include "ble.h"
#include "ble_err.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_bas.h"
#include "ble_hrs.h"
#include "ble_dis.h"
#include "ble_conn_params.h"
#include "sensorsim.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "app_timer.h"
#include "bsp_btn_ble.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "fds.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_lesc.h"
#include "nrf_ble_qwr.h"
#include "ble_conn_state.h"
#include "nrf_pwr_mgmt.h"
/*Addded suport for ADC files */
#include <stdbool.h>
#include <stdio.h>
#include "nrf_drv_saadc.h"
#include "nrf_drv_ppi.h"
#include "nrf_drv_timer.h"
#include "boards.h"
#include "nrf_delay.h"
// End of mixing
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define DEVICE_NAME                         "Nordic_HRM"                            /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME                   "NordicSemiconductor"                   /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_ADV_INTERVAL                    300                                     /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
#define APP_ADV_DURATION                    18000                                   /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define APP_BLE_CONN_CFG_TAG                1                                       /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_BLE_OBSERVER_PRIO               3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define BATTERY_LEVEL_MEAS_INTERVAL         APP_TIMER_TICKS(2000)                   /**< Battery level measurement interval (ticks). */
#define MIN_BATTERY_LEVEL                   81                                      /**< Minimum simulated battery level. */
#define MAX_BATTERY_LEVEL                   100                                     /**< Maximum simulated 7battery level. */
#define BATTERY_LEVEL_INCREMENT             1                                       /**< Increment between each simulated battery level measurement. */
#define HEART_RATE_MEAS_INTERVAL            APP_TIMER_TICKS(1000)                   /**< Heart rate measurement interval (ticks). */
#define MIN_HEART_RATE                      140                                     /**< Minimum heart rate as returned by the simulated measurement function. */
#define MAX_HEART_RATE                      300                                     /**< Maximum heart rate as returned by the simulated measurement function. */
#define HEART_RATE_INCREMENT                10                                      /**< Value by which the heart rate is incremented/decremented for each call to the simulated measurement function. */
#define RR_INTERVAL_INTERVAL                APP_TIMER_TICKS(300)                    /**< RR interval interval (ticks). */
#define MIN_RR_INTERVAL                     100                                     /**< Minimum RR interval as returned by the simulated measurement function. */
#define MAX_RR_INTERVAL                     500                                     /**< Maximum RR interval as returned by the simulated measurement function. */
#define RR_INTERVAL_INCREMENT               1                                       /**< Value by which the RR interval is incremented/decremented for each call to the simulated measurement function. */
#define SENSOR_CONTACT_DETECTED_INTERVAL    APP_TIMER_TICKS(5000)                   /**< Sensor Contact Detected toggle interval (ticks). */
#define MIN_CONN_INTERVAL                   MSEC_TO_UNITS(400, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.4 seconds). */
#define MAX_CONN_INTERVAL                   MSEC_TO_UNITS(650, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (0.65 second). */
#define SLAVE_LATENCY                       0                                       /**< Slave latency. */
#define CONN_SUP_TIMEOUT                    MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY      APP_TIMER_TICKS(5000)                   /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY       APP_TIMER_TICKS(30000)                  /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT        3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
#define LESC_DEBUG_MODE                     0                                       /**< Set to 1 to use LESC debug keys, allows you to use a sniffer to inspect traffic. */
#define SEC_PARAM_BOND                      1                                       /**< Perform bonding. */
#define SEC_PARAM_MITM                      0                                       /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                      1                                       /**< LE Secure Connections enabled. */
#define SEC_PARAM_KEYPRESS                  0                                       /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES           BLE_GAP_IO_CAPS_NONE                    /**< No I/O capabilities. */
#define SEC_PARAM_OOB                       0                                       /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE              7                                       /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE              16                                      /**< Maximum encryption key size. */
#define DEAD_BEEF                           0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
//Added ADC stuff by JS
#define SAMPLES_IN_BUFFER 5
volatile uint8_t state = 1;
static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(0);
static nrf_saadc_value_t     m_buffer_pool[2][SAMPLES_IN_BUFFER];
static nrf_ppi_channel_t     m_ppi_channel;
static uint32_t              m_adc_evt_counter;
void timer_handler(nrf_timer_event_t event_type, void * p_context)
    ret_code_t err_code;
    /* setup m_timer for compare event every 400ms */
    uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer, 400);
                                   NRF_TIMER_CC_CHANNEL0,
                                   ticks,
                                   NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
                                   false);
    uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer,
        NRF_TIMER_CC_CHANNEL0);
                                          timer_compare_event_addr,
                                          saadc_sample_task_addr);
        err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
        int i;
        NRF_LOG_INFO("ADC event number: %d", (int)m_adc_evt_counter);
        for (i = 0; i < SAMPLES_IN_BUFFER; i++)
            NRF_LOG_INFO("%d", p_event->data.done.p_buffer[i]);
        m_adc_evt_counter++;
void saadc_init(void)
    nrf_saadc_channel_config_t channel_config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN0);
    err_code = nrf_drv_saadc_init(NULL, saadc_callback);
    err_code = nrf_drv_saadc_channel_init(0, &channel_config);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER);
// End of ADC stuff.
BLE_HRS_DEF(m_hrs);                                                 /**< Heart rate service instance. */
BLE_BAS_DEF(m_bas);                                                 /**< Structure used to identify the battery service. */
NRF_BLE_GATT_DEF(m_gatt);                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                 /**< Advertising module instance. */
APP_TIMER_DEF(m_battery_timer_id);                                  /**< Battery timer. */
APP_TIMER_DEF(m_heart_rate_timer_id);                               /**< Heart rate measurement timer. */
APP_TIMER_DEF(m_rr_interval_timer_id);                              /**< RR interval timer. */
APP_TIMER_DEF(m_sensor_contact_timer_id);                           /**< Sensor contact detected timer. */
static uint16_t m_conn_handle         = BLE_CONN_HANDLE_INVALID;    /**< Handle of the current connection. */
static bool     m_rr_interval_enabled = true;                       /**< Flag for enabling and disabling the registration of new RR interval measurements (the purpose of disabling this is just to test sending HRM without RR interval data. */
static sensorsim_cfg_t   m_battery_sim_cfg;                         /**< Battery Level sensor simulator configuration. */
static sensorsim_state_t m_battery_sim_state;                       /**< Battery Level sensor simulator state. */
static sensorsim_cfg_t   m_heart_rate_sim_cfg;                      /**< Heart Rate sensor simulator configuration. */
static sensorsim_state_t m_heart_rate_sim_state;                    /**< Heart Rate sensor simulator state. */
static sensorsim_cfg_t   m_rr_interval_sim_cfg;                     /**< RR Interval sensor simulator configuration. */
static sensorsim_state_t m_rr_interval_sim_state;                   /**< RR Interval sensor simulator state. */
static ble_uuid_t m_adv_uuids[] =                                   /**< Universally unique service identifiers. */
    {BLE_UUID_HEART_RATE_SERVICE,           BLE_UUID_TYPE_BLE},
    {BLE_UUID_BATTERY_SERVICE,              BLE_UUID_TYPE_BLE},
    {BLE_UUID_DEVICE_INFORMATION_SERVICE,   BLE_UUID_TYPE_BLE}
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in] line_num   Line number of the failing ASSERT call.
 * @param[in] file_name  File name of the failing ASSERT call.
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
void advertising_start(bool erase_bonds)
    if (erase_bonds == true)
        delete_bonds();
        // Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
        err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
    pm_handler_on_pm_evt(p_evt);
    pm_handler_flash_clean(p_evt);
    switch (p_evt->evt_id)
            advertising_start(false);
/**@brief Function for performing battery measurement and updating the Battery Level characteristic
 *        in Battery Service.
static void battery_level_update(void)
    uint8_t  battery_level;
    battery_level = (uint8_t)sensorsim_measure(&m_battery_sim_state, &m_battery_sim_cfg);
    err_code = ble_bas_battery_level_update(&m_bas, battery_level, BLE_CONN_HANDLE_ALL);
    if ((err_code != NRF_SUCCESS) &&
        (err_code != NRF_ERROR_INVALID_STATE) &&
        (err_code != NRF_ERROR_BUSY) &&
        (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
        APP_ERROR_HANDLER(err_code);
/**@brief Function for handling the Battery measurement timer timeout.
 * @details This function will be called each time the battery level measurement timer expires.
 * @param[in] p_context  Pointer used for passing some arbitrary information (context) from the
 *                       app_start_timer() call to the timeout handler.
static void battery_level_meas_timeout_handler(void * p_context)
    UNUSED_PARAMETER(p_context);
    battery_level_update();
/**@brief Function for handling the Heart rate measurement timer timeout.
 * @details This function will be called each time the heart rate measurement timer expires.
 *          It will exclude RR Interval data from every third measurement.
static void heart_rate_meas_timeout_handler(void * p_context)
    static uint32_t cnt = 0;
    uint16_t        heart_rate;
    heart_rate = (uint16_t)sensorsim_measure(&m_heart_rate_sim_state, &m_heart_rate_sim_cfg);
    cnt++;
    err_code = ble_hrs_heart_rate_measurement_send(&m_hrs, heart_rate);
    // Disable RR Interval recording every third heart rate measurement.
    // NOTE: An application will normally not do this. It is done here just for testing generation
    // of messages without RR Interval measurements.
    m_rr_interval_enabled = ((cnt % 3) != 0);
/**@brief Function for handling the RR interval timer timeout.
 * @details This function will be called each time the RR interval timer expires.
static void rr_interval_timeout_handler(void * p_context)
    if (m_rr_interval_enabled)
        uint16_t rr_interval;
        rr_interval = (uint16_t)sensorsim_measure(&m_rr_interval_sim_state,
                                                  &m_rr_interval_sim_cfg);
        ble_hrs_rr_interval_add(&m_hrs, rr_interval);
/**@brief Function for handling the Sensor Contact Detected timer timeout.
 * @details This function will be called each time the Sensor Contact Detected timer expires.
static void sensor_contact_detected_timeout_handler(void * p_context)
    static bool sensor_contact_detected = false;
    sensor_contact_detected = !sensor_contact_detected;
    ble_hrs_sensor_contact_detected_update(&m_hrs, sensor_contact_detected);
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
    // Initialize timer module.
    err_code = app_timer_init();
    // Create timers.
    err_code = app_timer_create(&m_battery_timer_id,
                                APP_TIMER_MODE_REPEATED,
                                battery_level_meas_timeout_handler);
    err_code = app_timer_create(&m_heart_rate_timer_id,
                                heart_rate_meas_timeout_handler);
    err_code = app_timer_create(&m_rr_interval_timer_id,
                                rr_interval_timeout_handler);
    err_code = app_timer_create(&m_sensor_contact_timer_id,
                                sensor_contact_detected_timeout_handler);
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
    err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_HEART_RATE_SENSOR_HEART_RATE_BELT);
/**@brief GATT module event handler.
static void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
        NRF_LOG_INFO("GATT ATT MTU on connection 0x%x changed to %d.",
                     p_evt->conn_handle,
                     p_evt->params.att_mtu_effective);
    ble_hrs_on_gatt_evt(&m_hrs, p_evt);
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    APP_ERROR_HANDLER(nrf_error);
 * @details Initialize the Heart Rate, Battery and Device Information services.
    ble_hrs_init_t     hrs_init;
    ble_bas_init_t     bas_init;
    ble_dis_init_t     dis_init;
    uint8_t            body_sensor_location;
    // Initialize Heart Rate Service.
    body_sensor_location = BLE_HRS_BODY_SENSOR_LOCATION_FINGER;
    memset(&hrs_init, 0, sizeof(hrs_init));
    hrs_init.evt_handler                 = NULL;
    hrs_init.is_sensor_contact_supported = true;
    hrs_init.p_body_sensor_location      = &body_sensor_location;
    // Here the sec level for the Heart Rate Service can be changed/increased.
    hrs_init.hrm_cccd_wr_sec = SEC_OPEN;
    hrs_init.bsl_rd_sec      = SEC_OPEN;
    err_code = ble_hrs_init(&m_hrs, &hrs_init);
    // Initialize Battery Service.
    memset(&bas_init, 0, sizeof(bas_init));
    bas_init.evt_handler          = NULL;
    bas_init.support_notification = true;
    bas_init.p_report_ref         = NULL;
    bas_init.initial_batt_level   = 100;
    // Here the sec level for the Battery Service can be changed/increased.
    bas_init.bl_rd_sec        = SEC_OPEN;
    bas_init.bl_cccd_wr_sec   = SEC_OPEN;
    bas_init.bl_report_rd_sec = SEC_OPEN;
    err_code = ble_bas_init(&m_bas, &bas_init);
    // Initialize Device Information Service.
    memset(&dis_init, 0, sizeof(dis_init));
    ble_srv_ascii_to_utf8(&dis_init.manufact_name_str, (char *)MANUFACTURER_NAME);
    dis_init.dis_char_rd_sec = SEC_OPEN;
    err_code = ble_dis_init(&dis_init);
/**@brief Function for initializing the sensor simulators.
static void sensor_simulator_init(void)
    m_battery_sim_cfg.min          = MIN_BATTERY_LEVEL;
    m_battery_sim_cfg.max          = MAX_BATTERY_LEVEL;
    m_battery_sim_cfg.incr         = BATTERY_LEVEL_INCREMENT;
    m_battery_sim_cfg.start_at_max = true;
    sensorsim_init(&m_battery_sim_state, &m_battery_sim_cfg);
    m_heart_rate_sim_cfg.min          = MIN_HEART_RATE;
    m_heart_rate_sim_cfg.max          = MAX_HEART_RATE;
    m_heart_rate_sim_cfg.incr         = HEART_RATE_INCREMENT;
    m_heart_rate_sim_cfg.start_at_max = false;
    sensorsim_init(&m_heart_rate_sim_state, &m_heart_rate_sim_cfg);
    m_rr_interval_sim_cfg.min          = MIN_RR_INTERVAL;
    m_rr_interval_sim_cfg.max          = MAX_RR_INTERVAL;
    m_rr_interval_sim_cfg.incr         = RR_INTERVAL_INCREMENT;
    m_rr_interval_sim_cfg.start_at_max = false;
    sensorsim_init(&m_rr_interval_sim_state, &m_rr_interval_sim_cfg);
/**@brief Function for starting application timers.
static void application_timers_start(void)
    // Start application timers.
    err_code = app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
    err_code = app_timer_start(m_heart_rate_timer_id, HEART_RATE_MEAS_INTERVAL, NULL);
    err_code = app_timer_start(m_rr_interval_timer_id, RR_INTERVAL_INTERVAL, NULL);
    err_code = app_timer_start(m_sensor_contact_timer_id, SENSOR_CONTACT_DETECTED_INTERVAL, NULL);
/**@brief Function for handling the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module which
 *          are passed to the application.
 *          @note All this function does is to disconnect. This could have been done by simply
 *                setting the disconnect_on_fail config parameter, but instead we use the event
 *                handler mechanism to demonstrate its use.
/**@brief Function for handling a Connection Parameters error.
    cp_init.start_on_notify_cccd_handle    = m_hrs.hrm_handles.cccd_handle;
    // Prepare wakeup buttons.
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
            NRF_LOG_INFO("Fast advertising.");
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected.");
            NRF_LOG_INFO("Disconnected, reason %d.",
                          p_ble_evt->evt.gap_evt.params.disconnected.reason);
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
            NRF_LOG_DEBUG("BLE_GAP_EVT_SEC_PARAMS_REQUEST");
        case BLE_GAP_EVT_AUTH_KEY_REQUEST:
            NRF_LOG_INFO("BLE_GAP_EVT_AUTH_KEY_REQUEST");
        case BLE_GAP_EVT_LESC_DHKEY_REQUEST:
            NRF_LOG_INFO("BLE_GAP_EVT_LESC_DHKEY_REQUEST");
         case BLE_GAP_EVT_AUTH_STATUS:
             NRF_LOG_INFO("BLE_GAP_EVT_AUTH_STATUS: status=0x%x bond=0x%x lv4: %d kdist_own:0x%x kdist_peer:0x%x",
                          p_ble_evt->evt.gap_evt.params.auth_status.auth_status,
                          p_ble_evt->evt.gap_evt.params.auth_status.bonded,
                          p_ble_evt->evt.gap_evt.params.auth_status.sm1_levels.lv4,
                          *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_own),
                          *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_peer));
            // No implementation needed.
    uint32_t ram_start = 0;
    // Enable BLE stack.
 * @param[in]   event   Event generated by button press.
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
        case BSP_EVENT_WHITELIST_OFF:
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
    ble_advertising_init_t init;
    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance      = true;
    init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
    bsp_event_t startup_event;
    err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
    err_code = nrf_ble_lesc_request_handler();
        nrf_pwr_mgmt_run();
/**@brief Function for application main entry.
    bool erase_bonds;
    // Initialize.
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    advertising_init();
    services_init();
    sensor_simulator_init();
    conn_params_init();
    peer_manager_init();
 //ADC Capturing
     uint32_t err_code = NRF_LOG_INIT(NULL);
    ret_code_t ret_code = nrf_pwr_mgmt_init();
    APP_ERROR_CHECK(ret_code);
    saadc_init();
    saadc_sampling_event_init();
    NRF_LOG_INFO("SAADC HAL simple example started.");
  //End of ADC capturing
    // Start execution.
    NRF_LOG_INFO("Heart Rate Sensor example started.");
    application_timers_start();
    advertising_start(erase_bonds);
    // Enter main loop.
    for (;;)
        idle_state_handle();
        NRF_LOG_FLUSH(); //Added with ADC code
  • Hi.
    The first issue you have is that you try to initialize logging twice.
    Please remove:
         //uint32_t err_code = NRF_LOG_INIT(NULL);
        //APP_ERROR_CHECK(err_code);
        //NRF_LOG_DEFAULT_BACKENDS_INIT();
    from main(void).
    Second problem i spotted is in saadc_sampling_event_init() -> nrf_drv_timer_init();
    This assert triggers:
    Andreas
  • Thanks Andreas. I was thinking that using the ble_app_uart example with saadc will suit my application more.
    The function used in my code “err_code = ble_nus_string_send(&m_nus, my_data_array, BLE_NUS_MAX_DATA_LEN); “ is replaced by following function in latest sdk.
     uint32_t ble_nus_data_send(ble_nus_t * p_nus, uint8_t   * p_data, uint16_t  * p_length, uint16_t    conn_handle)
    How can I use the new function without sacrificing the original functionality.
    		static uint8_t my_data_array[BLE_NUS_MAX_DATA_LEN];
    		uint8_t index;
    		char	out_str[256];
    		int total = 0;
    		int average = 0;
            int i;
            NRF_LOG_INFO("ADC event number: %d\r\n", (int)m_adc_evt_counter);
                NRF_LOG_INFO("%d\r\n", p_event->data.done.p_buffer[i]);
    						total += p_event->data.done.p_buffer[i];
    				average = total / SAMPLES_IN_BUFFER;
    				// display adc average once every 5 samples
    				memset(my_data_array, 0x0, BLE_NUS_MAX_DATA_LEN);
    				sprintf(out_str,"ADC val = %d",average);
    				for (i=0;i<strlen(out_str);i++)
    					my_data_array[i] = (uint8_t)out_str[i];
            NRF_LOG_INFO("ADC val sent: %d\r\n", (int)m_adc_evt_counter);
    				// get button status and display
    				for (index=0;index<=3;index++)
    						if (app_button_is_pushed(index))
    							sprintf(out_str,"Button %1d = 0",index);
    						NRF_LOG_INFO("Button val sent: %d\r\n", index);
    							sprintf(out_str,"Button %1d = 1",index);
    /** @file
     * @defgroup ble_sdk_uart_over_ble_main main.c
     * @ingroup  ble_sdk_app_nus_eval
     * @brief    UART over BLE application main file.
     * This file contains the source code for a sample application that uses the Nordic UART service.
     * This application uses the @ref srvlib_conn_params module.
    #include <stdint.h>
    #include <string.h>
    #include "nrf.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    // Includes for ADC
    #include <stdio.h>
    #include <string.h>
    #include "nrf.h"
    #include "boards.h"
    //  End of ADC includes
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    //Start of defines for ADC
    static ble_nus_t             m_nus;                                      /**< Structure to identify the Nordic UART Service. */
    static nrf_ble_gatt_t        m_gatt;                                     /**< GATT module instance. */
    static ble_uuid_t            m_adv_uuids[] = {{BLE_UUID_NUS_SERVICE, NUS_SERVICE_UUID_TYPE}};  /**< Universally unique service identifier. */
    static uint16_t              m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;  /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    //End of defines for ADC
    //Prototype of function for ADC support
    }//End of timer handler
                                       ticks,
                                       false);
    		uint8_t index;
    		char	out_str[256];
    		int total = 0;
    		int average = 0;
            int i;
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    //static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    //static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    //static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    //   {BLE_UUID_NUS_SERVICE, NUS_SERVICE_UUID_TYPE}
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] p_file_name File name of the failing ASSERT call.
    /**@brief Function for initializing the timer module.
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
            uint32_t err_code;
            for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
                do
                    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
            if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
                while (app_uart_put('\n') == NRF_ERROR_BUSY);
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        // Initialize NUS.
    /**@brief Function for handling an event from the Connection Parameters Module.
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        uint32_t err_code;
                sleep_mode_enter();
        uint32_t err_code;
                NRF_LOG_INFO("Connected");
                NRF_LOG_INFO("Disconnected");
            } break;
                // Pairing not supported
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
    /**@brief Function for handling events from the GATT library. */
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
        uint32_t err_code;
        switch (event)
                sleep_mode_enter();
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') ||
                    (data_array[index - 1] == '\r') ||
                    (index >= m_ble_nus_max_data_len))
                    if (index > 1)
                        do
                        } while (err_code == NRF_ERROR_RESOURCES);
                    index = 0;
            case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate    = NRF_UARTE_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
        uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
            nrf_pwr_mgmt_run();
    /**@brief Application main function.
        bool erase_bonds;
        // Initialize.
        uart_init();
        log_init();
        timers_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        // Start execution.
        saadc_init();
        NRF_LOG_INFO("UART SAADC HAL simple example started.");
        advertising_start();
        // Enter main loop.
        for (;;)
            nrf_pwr_mgmt_run();
            NRF_LOG_FLUSH();    }
  • Hi.
    Have you taken a look at the API description?
    They are basically the same, only difference is that ble_nus_data_send requires the connection handle to the destination of the message as input.
    Andreas
  • I was able to use the new function but I my program always ends up in a break point condition after log_init(). Am I initializing something multiple times ?
     nRF5_SDK_16.0.0_98a08e2_ble_app_uart_saadc_10_31.zip
  • Andreas,
    I was able to use the new function but I my program always ends up in a break point condition after log_init(). Am I initializing something multiple times ? See the following link.
    devzone.nordicsemi.com/.../nRF5_5F00_SDK_5F00_16.0.0_5F00_98a08e2_5F00_ble_5F00_app_5F00_uart_5F00_saadc_5F00_10_5F00_31.zip
