Reading ADC in nRF52840
I am new to development with Nordic chips. I am using nRF52840-DK (SES,nRF5_SDK_15.3.0_59ac345) to read analog input on ADC pin AIN0. I want to continuously read the adc after pairing is established and then broadcast the data over Bluetooth. In order to achieve my objective, I am trying to run ble_app_hrs example by combining the SAADC example with it. Is this approach correct.
When I compile my program using SES, I am getting the following error in nrfx_timer.h(line 74). I don't get this error if run the these examples individually.
'NRFX_TIMER0_INST_IDX' undeclared here (not in a function); did you mean 'NRFX_TIMER_INSTANCE'?
Jagbir
 * Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
 * All rights reserved.
/** @example examples/ble_peripheral/ble_app_hrs/main.c
 * @brief Heart Rate Service Sample Application main file.
 * This file contains the source code for a sample application using the Heart Rate service
 * (and also Battery and Device Information services). This application uses the
 * @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "nrf_sdm.h"
#include "app_error.h"
#include "ble.h"
#include "ble_err.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_bas.h"
#include "ble_hrs.h"
#include "ble_dis.h"
#include "ble_conn_params.h"
#include "sensorsim.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "app_timer.h"
#include "bsp_btn_ble.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "fds.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_lesc.h"
#include "nrf_ble_qwr.h"
#include "ble_conn_state.h"
#include "nrf_pwr_mgmt.h"
/*Addded suport for ADC files */
#include <stdbool.h>
#include <stdio.h>
#include "nrf_drv_saadc.h"
#include "nrf_drv_ppi.h"
#include "nrf_drv_timer.h"
#include "boards.h"
#include "nrf_delay.h"
// End of mixing
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define DEVICE_NAME                         "Nordic_HRM"                            /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME                   "NordicSemiconductor"                   /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_ADV_INTERVAL                    300                                     /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
#define APP_ADV_DURATION                    18000                                   /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define APP_BLE_CONN_CFG_TAG                1                                       /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_BLE_OBSERVER_PRIO               3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define BATTERY_LEVEL_MEAS_INTERVAL         APP_TIMER_TICKS(2000)                   /**< Battery level measurement interval (ticks). */
#define MIN_BATTERY_LEVEL                   81                                      /**< Minimum simulated battery level. */
#define MAX_BATTERY_LEVEL                   100                                     /**< Maximum simulated 7battery level. */
#define BATTERY_LEVEL_INCREMENT             1                                       /**< Increment between each simulated battery level measurement. */
#define HEART_RATE_MEAS_INTERVAL            APP_TIMER_TICKS(1000)                   /**< Heart rate measurement interval (ticks). */
#define MIN_HEART_RATE                      140                                     /**< Minimum heart rate as returned by the simulated measurement function. */
#define MAX_HEART_RATE                      300                                     /**< Maximum heart rate as returned by the simulated measurement function. */
#define HEART_RATE_INCREMENT                10                                      /**< Value by which the heart rate is incremented/decremented for each call to the simulated measurement function. */
#define RR_INTERVAL_INTERVAL                APP_TIMER_TICKS(300)                    /**< RR interval interval (ticks). */
#define MIN_RR_INTERVAL                     100                                     /**< Minimum RR interval as returned by the simulated measurement function. */
#define MAX_RR_INTERVAL                     500                                     /**< Maximum RR interval as returned by the simulated measurement function. */
#define RR_INTERVAL_INCREMENT               1                                       /**< Value by which the RR interval is incremented/decremented for each call to the simulated measurement function. */
#define SENSOR_CONTACT_DETECTED_INTERVAL    APP_TIMER_TICKS(5000)                   /**< Sensor Contact Detected toggle interval (ticks). */
#define MIN_CONN_INTERVAL                   MSEC_TO_UNITS(400, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.4 seconds). */
#define MAX_CONN_INTERVAL                   MSEC_TO_UNITS(650, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (0.65 second). */
#define SLAVE_LATENCY                       0                                       /**< Slave latency. */
#define CONN_SUP_TIMEOUT                    MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY      APP_TIMER_TICKS(5000)                   /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY       APP_TIMER_TICKS(30000)                  /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT        3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
#define LESC_DEBUG_MODE                     0                                       /**< Set to 1 to use LESC debug keys, allows you to use a sniffer to inspect traffic. */
#define SEC_PARAM_BOND                      1                                       /**< Perform bonding. */
#define SEC_PARAM_MITM                      0                                       /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                      1                                       /**< LE Secure Connections enabled. */
#define SEC_PARAM_KEYPRESS                  0                                       /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES           BLE_GAP_IO_CAPS_NONE                    /**< No I/O capabilities. */
#define SEC_PARAM_OOB                       0                                       /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE              7                                       /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE              16                                      /**< Maximum encryption key size. */
#define DEAD_BEEF                           0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
//Added ADC stuff by JS
#define SAMPLES_IN_BUFFER 5
volatile uint8_t state = 1;
static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(0);
static nrf_saadc_value_t     m_buffer_pool[2][SAMPLES_IN_BUFFER];
static nrf_ppi_channel_t     m_ppi_channel;
static uint32_t              m_adc_evt_counter;
void timer_handler(nrf_timer_event_t event_type, void * p_context)
    ret_code_t err_code;
    /* setup m_timer for compare event every 400ms */
    uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer, 400);
                                   NRF_TIMER_CC_CHANNEL0,
                                   ticks,
                                   NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
                                   false);
    uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer,
        NRF_TIMER_CC_CHANNEL0);
                                          timer_compare_event_addr,
                                          saadc_sample_task_addr);
        err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
        int i;
        NRF_LOG_INFO("ADC event number: %d", (int)m_adc_evt_counter);
        for (i = 0; i < SAMPLES_IN_BUFFER; i++)
            NRF_LOG_INFO("%d", p_event->data.done.p_buffer[i]);
        m_adc_evt_counter++;
void saadc_init(void)
    nrf_saadc_channel_config_t channel_config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN0);
    err_code = nrf_drv_saadc_init(NULL, saadc_callback);
    err_code = nrf_drv_saadc_channel_init(0, &channel_config);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER);
// End of ADC stuff.
BLE_HRS_DEF(m_hrs);                                                 /**< Heart rate service instance. */
BLE_BAS_DEF(m_bas);                                                 /**< Structure used to identify the battery service. */
NRF_BLE_GATT_DEF(m_gatt);                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                 /**< Advertising module instance. */
APP_TIMER_DEF(m_battery_timer_id);                                  /**< Battery timer. */
APP_TIMER_DEF(m_heart_rate_timer_id);                               /**< Heart rate measurement timer. */
APP_TIMER_DEF(m_rr_interval_timer_id);                              /**< RR interval timer. */
APP_TIMER_DEF(m_sensor_contact_timer_id);                           /**< Sensor contact detected timer. */
static uint16_t m_conn_handle         = BLE_CONN_HANDLE_INVALID;    /**< Handle of the current connection. */
static bool     m_rr_interval_enabled = true;                       /**< Flag for enabling and disabling the registration of new RR interval measurements (the purpose of disabling this is just to test sending HRM without RR interval data. */
static sensorsim_cfg_t   m_battery_sim_cfg;                         /**< Battery Level sensor simulator configuration. */
static sensorsim_state_t m_battery_sim_state;                       /**< Battery Level sensor simulator state. */
static sensorsim_cfg_t   m_heart_rate_sim_cfg;                      /**< Heart Rate sensor simulator configuration. */
static sensorsim_state_t m_heart_rate_sim_state;                    /**< Heart Rate sensor simulator state. */
static sensorsim_cfg_t   m_rr_interval_sim_cfg;                     /**< RR Interval sensor simulator configuration. */
static sensorsim_state_t m_rr_interval_sim_state;                   /**< RR Interval sensor simulator state. */
static ble_uuid_t m_adv_uuids[] =                                   /**< Universally unique service identifiers. */
    {BLE_UUID_HEART_RATE_SERVICE,           BLE_UUID_TYPE_BLE},
    {BLE_UUID_BATTERY_SERVICE,              BLE_UUID_TYPE_BLE},
    {BLE_UUID_DEVICE_INFORMATION_SERVICE,   BLE_UUID_TYPE_BLE}
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in] line_num   Line number of the failing ASSERT call.
 * @param[in] file_name  File name of the failing ASSERT call.
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
void advertising_start(bool erase_bonds)
    if (erase_bonds == true)
        delete_bonds();
        // Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
        err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
    pm_handler_on_pm_evt(p_evt);
    pm_handler_flash_clean(p_evt);
    switch (p_evt->evt_id)
            advertising_start(false);
/**@brief Function for performing battery measurement and updating the Battery Level characteristic
 *        in Battery Service.
static void battery_level_update(void)
    uint8_t  battery_level;
    battery_level = (uint8_t)sensorsim_measure(&m_battery_sim_state, &m_battery_sim_cfg);
    err_code = ble_bas_battery_level_update(&m_bas, battery_level, BLE_CONN_HANDLE_ALL);
    if ((err_code != NRF_SUCCESS) &&
        (err_code != NRF_ERROR_INVALID_STATE) &&
        (err_code != NRF_ERROR_BUSY) &&
        (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
        APP_ERROR_HANDLER(err_code);
/**@brief Function for handling the Battery measurement timer timeout.
 * @details This function will be called each time the battery level measurement timer expires.
 * @param[in] p_context  Pointer used for passing some arbitrary information (context) from the
 *                       app_start_timer() call to the timeout handler.
static void battery_level_meas_timeout_handler(void * p_context)
    UNUSED_PARAMETER(p_context);
    battery_level_update();
/**@brief Function for handling the Heart rate measurement timer timeout.
 * @details This function will be called each time the heart rate measurement timer expires.
 *          It will exclude RR Interval data from every third measurement.
static void heart_rate_meas_timeout_handler(void * p_context)
    static uint32_t cnt = 0;
    uint16_t        heart_rate;
    heart_rate = (uint16_t)sensorsim_measure(&m_heart_rate_sim_state, &m_heart_rate_sim_cfg);
    cnt++;
    err_code = ble_hrs_heart_rate_measurement_send(&m_hrs, heart_rate);
    // Disable RR Interval recording every third heart rate measurement.
    // NOTE: An application will normally not do this. It is done here just for testing generation
    // of messages without RR Interval measurements.
    m_rr_interval_enabled = ((cnt % 3) != 0);
/**@brief Function for handling the RR interval timer timeout.
 * @details This function will be called each time the RR interval timer expires.
static void rr_interval_timeout_handler(void * p_context)
    if (m_rr_interval_enabled)
        uint16_t rr_interval;
        rr_interval = (uint16_t)sensorsim_measure(&m_rr_interval_sim_state,
                                                  &m_rr_interval_sim_cfg);
        ble_hrs_rr_interval_add(&m_hrs, rr_interval);
/**@brief Function for handling the Sensor Contact Detected timer timeout.
 * @details This function will be called each time the Sensor Contact Detected timer expires.
static void sensor_contact_detected_timeout_handler(void * p_context)
    static bool sensor_contact_detected = false;
    sensor_contact_detected = !sensor_contact_detected;
    ble_hrs_sensor_contact_detected_update(&m_hrs, sensor_contact_detected);
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
    // Initialize timer module.
    err_code = app_timer_init();
    // Create timers.
    err_code = app_timer_create(&m_battery_timer_id,
                                APP_TIMER_MODE_REPEATED,
                                battery_level_meas_timeout_handler);
    err_code = app_timer_create(&m_heart_rate_timer_id,
                                heart_rate_meas_timeout_handler);
    err_code = app_timer_create(&m_rr_interval_timer_id,
                                rr_interval_timeout_handler);
    err_code = app_timer_create(&m_sensor_contact_timer_id,
                                sensor_contact_detected_timeout_handler);
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
    err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_HEART_RATE_SENSOR_HEART_RATE_BELT);
/**@brief GATT module event handler.
static void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
        NRF_LOG_INFO("GATT ATT MTU on connection 0x%x changed to %d.",
                     p_evt->conn_handle,
                     p_evt->params.att_mtu_effective);
    ble_hrs_on_gatt_evt(&m_hrs, p_evt);
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    APP_ERROR_HANDLER(nrf_error);
 * @details Initialize the Heart Rate, Battery and Device Information services.
    ble_hrs_init_t     hrs_init;
    ble_bas_init_t     bas_init;
    ble_dis_init_t     dis_init;
    uint8_t            body_sensor_location;
    // Initialize Heart Rate Service.
    body_sensor_location = BLE_HRS_BODY_SENSOR_LOCATION_FINGER;
    memset(&hrs_init, 0, sizeof(hrs_init));
    hrs_init.evt_handler                 = NULL;
    hrs_init.is_sensor_contact_supported = true;
    hrs_init.p_body_sensor_location      = &body_sensor_location;
    // Here the sec level for the Heart Rate Service can be changed/increased.
    hrs_init.hrm_cccd_wr_sec = SEC_OPEN;
    hrs_init.bsl_rd_sec      = SEC_OPEN;
    err_code = ble_hrs_init(&m_hrs, &hrs_init);
    // Initialize Battery Service.
    memset(&bas_init, 0, sizeof(bas_init));
    bas_init.evt_handler          = NULL;
    bas_init.support_notification = true;
    bas_init.p_report_ref         = NULL;
    bas_init.initial_batt_level   = 100;
    // Here the sec level for the Battery Service can be changed/increased.
    bas_init.bl_rd_sec        = SEC_OPEN;
    bas_init.bl_cccd_wr_sec   = SEC_OPEN;
    bas_init.bl_report_rd_sec = SEC_OPEN;
    err_code = ble_bas_init(&m_bas, &bas_init);
    // Initialize Device Information Service.
    memset(&dis_init, 0, sizeof(dis_init));
    ble_srv_ascii_to_utf8(&dis_init.manufact_name_str, (char *)MANUFACTURER_NAME);
    dis_init.dis_char_rd_sec = SEC_OPEN;
    err_code = ble_dis_init(&dis_init);
/**@brief Function for initializing the sensor simulators.
static void sensor_simulator_init(void)
    m_battery_sim_cfg.min          = MIN_BATTERY_LEVEL;
    m_battery_sim_cfg.max          = MAX_BATTERY_LEVEL;
    m_battery_sim_cfg.incr         = BATTERY_LEVEL_INCREMENT;
    m_battery_sim_cfg.start_at_max = true;
    sensorsim_init(&m_battery_sim_state, &m_battery_sim_cfg);
    m_heart_rate_sim_cfg.min          = MIN_HEART_RATE;
    m_heart_rate_sim_cfg.max          = MAX_HEART_RATE;
    m_heart_rate_sim_cfg.incr         = HEART_RATE_INCREMENT;
    m_heart_rate_sim_cfg.start_at_max = false;
    sensorsim_init(&m_heart_rate_sim_state, &m_heart_rate_sim_cfg);
    m_rr_interval_sim_cfg.min          = MIN_RR_INTERVAL;
    m_rr_interval_sim_cfg.max          = MAX_RR_INTERVAL;
    m_rr_interval_sim_cfg.incr         = RR_INTERVAL_INCREMENT;
    m_rr_interval_sim_cfg.start_at_max = false;
    sensorsim_init(&m_rr_interval_sim_state, &m_rr_interval_sim_cfg);
/**@brief Function for starting application timers.
static void application_timers_start(void)
    // Start application timers.
    err_code = app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
    err_code = app_timer_start(m_heart_rate_timer_id, HEART_RATE_MEAS_INTERVAL, NULL);
    err_code = app_timer_start(m_rr_interval_timer_id, RR_INTERVAL_INTERVAL, NULL);
    err_code = app_timer_start(m_sensor_contact_timer_id, SENSOR_CONTACT_DETECTED_INTERVAL, NULL);
/**@brief Function for handling the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module which
 *          are passed to the application.
 *          @note All this function does is to disconnect. This could have been done by simply
 *                setting the disconnect_on_fail config parameter, but instead we use the event
 *                handler mechanism to demonstrate its use.
/**@brief Function for handling a Connection Parameters error.
    cp_init.start_on_notify_cccd_handle    = m_hrs.hrm_handles.cccd_handle;
    // Prepare wakeup buttons.
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
            NRF_LOG_INFO("Fast advertising.");
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected.");
            NRF_LOG_INFO("Disconnected, reason %d.",
                          p_ble_evt->evt.gap_evt.params.disconnected.reason);
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
            NRF_LOG_DEBUG("BLE_GAP_EVT_SEC_PARAMS_REQUEST");
        case BLE_GAP_EVT_AUTH_KEY_REQUEST:
            NRF_LOG_INFO("BLE_GAP_EVT_AUTH_KEY_REQUEST");
        case BLE_GAP_EVT_LESC_DHKEY_REQUEST:
            NRF_LOG_INFO("BLE_GAP_EVT_LESC_DHKEY_REQUEST");
         case BLE_GAP_EVT_AUTH_STATUS:
             NRF_LOG_INFO("BLE_GAP_EVT_AUTH_STATUS: status=0x%x bond=0x%x lv4: %d kdist_own:0x%x kdist_peer:0x%x",
                          p_ble_evt->evt.gap_evt.params.auth_status.auth_status,
                          p_ble_evt->evt.gap_evt.params.auth_status.bonded,
                          p_ble_evt->evt.gap_evt.params.auth_status.sm1_levels.lv4,
                          *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_own),
                          *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_peer));
            // No implementation needed.
    uint32_t ram_start = 0;
    // Enable BLE stack.
 * @param[in]   event   Event generated by button press.
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
        case BSP_EVENT_WHITELIST_OFF:
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
    ble_advertising_init_t init;
    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance      = true;
    init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
    bsp_event_t startup_event;
    err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
    err_code = nrf_ble_lesc_request_handler();
        nrf_pwr_mgmt_run();
/**@brief Function for application main entry.
    bool erase_bonds;
    // Initialize.
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    advertising_init();
    services_init();
    sensor_simulator_init();
    conn_params_init();
    peer_manager_init();
 //ADC Capturing
     uint32_t err_code = NRF_LOG_INIT(NULL);
    ret_code_t ret_code = nrf_pwr_mgmt_init();
    APP_ERROR_CHECK(ret_code);
    saadc_init();
    saadc_sampling_event_init();
    NRF_LOG_INFO("SAADC HAL simple example started.");
  //End of ADC capturing
    // Start execution.
    NRF_LOG_INFO("Heart Rate Sensor example started.");
    application_timers_start();
    advertising_start(erase_bonds);
    // Enter main loop.
    for (;;)
        idle_state_handle();
        NRF_LOG_FLUSH(); //Added with ADC code
  • Hi
    Andreas has left Nordic unfortunately, and I will take over the case instead.
    The problem with your code is that you initialize the UART before you enable logging.
    Since the log module is configured to use the UART this means you are initializing it twice.
    If you comment out the call to uart_init() your code should run. It crashes again because the RAM settings are incorrect, but the UART log will inform you how to fix this.
    Best regards
    Torbjørn Øvrebekk
  • I am still getting the same error after disabling the uart_init().
    Couple of questions:
    1) In the source navigator window on SES, I do see an error message "unknown register name 'vfpcc' in asm" but this issue is not preventing me from building. I did search the devzone for this issue , in the Case ID: 208419 it's mentioned that this issue is just a visual distraction and doesn't impact building/code execution . I have confirmed that I use gcc instead of clang in my project but I am unsure why I am getting this error.
    2) How to access the UART log. How did you diagnose the RAM settings.
    Thanks.
  • Hi
    1) The reply from Johannes in the case you link to is describing the reason for this issue, no?
    Did you try his suggested fix, by making some modifications to the cmsis_gcc.h file?
    2) You have to connect to the CDC comport of your development kit, and set the baudrate to 115200. Then you should see the log output when you run your code, and the log will include the correct RAM settings for your project.
    Best regards
    Torbjørn
  • 1) Yes, I did change the cmsis_gcc but it did not fix the error. Can we the ignore errors displayed the source navigator window on SES,
    2) I have connected the dev kit to putty terminal with the desired setting but I don't see any output on putty screen.I have already attached the full project in the attachments here. Can you recreate the errors with nRf52840 DK with SES and debug it.
  • Hi
    1) Yes, this error does not affect the program itself, it is only a convenience issue.
    2) Yes, I get the following log output when I run your code (after commenting out the uart_init() call):
    <info> app_timer: RTC: initialized.
    <warning> nrf_sdh_ble: Insufficient RAM allocated for the SoftDevice.
    <warning> nrf_sdh_ble: Change the RAM start location from 0x20002AE8 to 0x20002BE0.
    <warning> nrf_sdh_ble: Maximum RAM size for application is 0x3D420.
    <error> nrf_sdh_ble: sd_ble_enable() returned NRF_ERROR_NO_MEM.
    <error> app: Fatal error
    <warning> app: System reset
    After fixing this issue I got another problem related to the initialization of the ble_nus service.
    The reason for this problem is that in order to use a proprietary service you need to set the NRF_SDH_BLE_VS_UUID_COUNT define in sdk_config.h equal to the number of unique 128-bit UUID's you are using in your application.
    The ble_nus service needs 1 128-bit UUID, so you have to set this value to 1 or more and once again change the RAM settings to make room for this:
    <warning> nrf_sdh_ble: Change the RAM start location from 0x20002BE8 to 0x20002BF0.
    <warning> nrf_sdh_ble: Maximum RAM size for application is 0x3D410.
    After fixing the RAM settings again I now got an error because you are trying to initialize timer 0 in the application. The TIMER0 module is used by the SoftDevice, and can not be used by the application when the SoftDevice is in use.
    To fix this problem I had to change this line (line 127 of main.c):
    to this:
    static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(1);
    Then I had to modify sdk_config.h to enable TIMER1 instead of TIMER0.
    With all this fixed the application appears to run nicely, and I can connect to the kit from my phone.
    I attached the modified project for your reference:
    ble_app_uart.zip
    The only project I updated was the one in this folder:
    \ble_app_uart\pca10056\s140\ses
    Best regards
    Torbjørn
