I am using UART1 to communicate with sensor. It is working fine. I can receive the data. Now I want to modify this data. When I use strcpy() function, it works properly. But when I use functions like strchr(), there is error. I will paste the code and error as well.
To modify the received data from sensor, I am modifying the UART callback function. So is this the reason for the error and what should I do to overcome this problem?
Code:
#include <zephyr.h> #include <misc/printk.h> #include <uart.h> #include <stdio.h> #include <string.h> #include <stdlib.h> static u8_t uart_buf[1024]; void uart_cb(struct device *x) { uart_irq_update(x); int data_length = 0; if (uart_irq_rx_ready(x)) { data_length = uart_fifo_read(x, uart_buf, sizeof(uart_buf)); uart_buf[data_length] = 0; } printk("%s", uart_buf); // k_sleep(1000); char dest[strlen(uart_buf)]; // strncpy(dest,uart_buf,strlen(uart_buf)); strcpy(dest, uart_buf); printk("%s", dest); const char ch = ','; char *ret; ret = strchr(uart_buf, ch); printk("%s", ret); } void main(void) { struct device *uart = device_get_binding("UART_1"); uart_irq_callback_set(uart, uart_cb); uart_irq_rx_enable(uart); printk("UART loopback start!\n"); while (1) { k_cpu_idle(); } }
Output:
UART loopback start! $Exception occurred in Secure State ***** HARD FAULT ***** Fault escalation (see below) ***** BUS FAULT ***** Precise data bus error BFAR Address: 0x50008120 ***** Hardware exception ***** Current thread ID = 0x200200b0 Faulting instruction address = 0xe608 Fatal fault in ISR! Spinning...
