nrf52840 System Idle Current Too High
My firmware is working well and handling required functions, so I have begun trying to work on power management to reduce device power draw. I am using S140 and my BLE peripheral is sending a proprietary advertising packet every second. When not advertising, it is idle but checks counters within a 100 mSec timer handler.
I have introduced a 6.8 ohm resistor between the positive post on my battery and VDDSOC (positive power) on my custom board. Measured mV or uV across this resistor gives me current. When idle, I am measuring 1 mW (approx 160 uA). I am expecting < 5 uA when idle.
I have confirmed that BLE functions are not the culprit as this measurement is unchanged regardless of whether I measure it between advertising periods or when advertising is disabled.
I also use SPI to talk to an accelerometer, but I have confirmed that SPI is not the issue as current is unchanged if I don't enable SPI.
No other peripherals such as UART are used.
I have disabled NRF Logging (#define NRF_LOG_ENABLED 0 and #define NRF_LOG_DEFAULT_LEVEL  0 in sdk_config.h).
I am using Seggar_RTT logging, but I have unplugged my JLink interface when measuring power and I understand that Seggar_RTT logging is dormant and does not use power when there is no JLink connection to a target.
I am using LFXO with the following config.
#define NRF_SDH_CLOCK_LF_SRC NRF_CLOCK_LF_SRC_XTAL
#define NRF_SDH_CLOCK_LF_RC_CTIV 0
#define NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 0
#define NRF_SDH_CLOCK_LF_ACCURACY NRF_CLOCK_LF_ACCURACY_20_PPM
I have a single app timer set at 100 mSec. I have confirmed that it is not contributing to much draw as the current does not change when I disable the functions handled within it.
In previous projects (e.g. nrf52832) I was able to get the idle current down to a few uA by setting: sd_power_dcdc_mode_set(NRF_POWER_DCDC_ENABLE); and using preprocessor directive SWI_DISABLE0 ... but I am already using these and I am still over 150 uA.
I have spent a lot of time confirming that peripherals are not active and they should not be contributing to any significant draw (LED controller is disabled and my acc is being put to sleep via SPI).
My startup code is below.
  ret_code_t err_code;
  // Initialize logging through Nordic and terminal.
  SEGGER_RTT_Init();
  SEGGER_RTT_printf(0, "Logging started.\n");
  // As per egs, setup the clock driver to use the lfclk (before timers_init)
  APP_ERROR_CHECK(nrf_drv_clock_init());
  APP_SCHED_INIT(SCHED_MAX_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
  // Init the bmi160 connection (includes spi master).
  xtag_init_bmi160();
  // Ensure that it is powered down for now. Woken upon config.
  xtag_suspend_bmi160();
  // Init timers.
  timers_init();
  // Init buttons and LEDs.
  gpio_init();
  // Init power managment.
  APP_ERROR_CHECK( nrf_pwr_mgmt_init());
  // Init BLE elements.
  ble_stack_init();
  gap_params_init();
  gatt_init();
  xtag_adv_config(true);
  services_init();
  conn_params_init();
  //peer_manager_init();
  // Start advertising.
  xtag_adv_start();
  // Start the 100 msec timer.
  err_code = app_timer_start(m_100_msec_timer_id, APP_TIMER_TICKS(100), NULL);
  // Enable DCDC mode (low power support in idle mode).
  err_code = sd_power_dcdc_mode_set(NRF_POWER_DCDC_ENABLE);
  // Enter main loop.
  for (;;)
    nrf_pwr_mgmt_run();
    app_sched_execute();
Any other suggestions for changes would be appreciated.
Thanks in advance.
Mark J
