nRF5 SDK16.0.0 bootloader issue
I am trying to upload the firmware with secure DFU using following method:
  1. generated the dfu_public_key.c and private.pem pair
  2. copied the "dfu_public_key.c" into "\examples\dfu" folder
  3. Ran "build_all.bat" to create "micro_ecc_lib_nrf52.a" at "\nRF5_SDK_16.0.0_98a08e2\external\micro-ecc\nrf52hf_armgcc\armgcc"
  4. Compiled "secure_bootloader_ble_s140_pca10056.emProject" and copied "secure_bootloader_ble_s140_pca10056.hex" to the package folder as "bootloader.hex"
  5. Ran "02_flash_SD_and_bootloader.bat" to upload the bootloader
  6. FW.zip was created using "03_create_fw_zip_package.bat"
I can see DFUTarg when I search the devices but when try to upload the FW.zip, it prompts error: "When writing 'EXECUTE' command to Control Point Characteristic of DFU Target: Operation code 4 (EXECUTE) failed on DFU Target. Result code 5 (INVALID_OBJECT)". Please see the attached image of error.
I have been doing this for SDK15.0.0 and nRF52832 for several months. The only difference now is that the SDK is v16.0.0 and chip is nRF52840. I have paid attention when copied the bootloader (which is s140 for nRF52840). Also the DFU example is also for S140 and nRF840. The FW.zip compiled project is also for nRF52840 which, otherwise, works fine on chip.
Please let me know why this error is happening.
  • Hello ,
    I have copied exact script in the SDK16.0.0\examples\dfu\secure_bootloader\pca10056_s140_ble\armgcc
    make -j9
    nrfjprog -e
    nrfjprog --program ..\..\..\..\..\components\softdevice\s140\hex\s140_nrf52_7.0.1_softdevice.hex --verify
    nrfjprog --program _build\nrf52840_xxaa_s140.hex --verify
    nrfjprog --reset
    del files\bootloader.hex
    del files\buttonless.hex
    del files\private.key
    copy ..\..\..\..\ble_peripheral\ble_app_buttonless_dfu\pca10056\s140\armgcc\_build\nrf52840_xxaa.hex files\buttonless.hex
    copy _build\nrf52840_xxaa_s140.hex files\bootloader.hex
    copy ..\..\..\private.key files\private.key
    nrfutil pkg generate --application files\buttonless.hex --application-version 1 --hw-version 52 --sd-req 0xCA --key-file files\private.key files\my_image.zip
    Here is the result of the script when executed:
    DONE nrf52840_xxaa_s140
    Erasing user available code and UICR flash areas.
    Applying system reset.
    Parsing hex file.
    Reading flash area to program to guarantee it is erased.
    Checking that the area to write is not protected.
    Programming device.
    Verifying programming.
    Verified OK.
    Parsing hex file.
    Programming device.
    Verified OK.
    Run.
            1 file(s) copied.
            1 file(s) copied.
            1 file(s) copied.
    Zip created at files\my_image.zip
    Press any key to continue . . .
    Before this, I had to compile the "nRF5_SDK_16.0.0_98a08e2\examples\ble_peripheral\ble_app_buttonless_dfu" project using following script:
    @ECHO OFF
    :: This script will use git (must be in %PATH%) and arm-none-eabi tools in combination with GNU Make
    :: to both fetch and compile all variants of micro-ecc for the nRF5 families
    WHERE >nul 2>nul git
    IF %ERRORLEVEL% NEQ 0 (
        ECHO "git is not installed. Please install and append to PATH."
    IF NOT EXIST micro-ecc/uECC.c (
        ECHO "micro-ecc not found! Let's pull it from HEAD."
        git clone https://github.com/kmackay/micro-ecc.git
    make -C pca10056/s140/armgcc
    ::make -C nrf51_iar/armgcc
    pause
    The "my_image.zip" was created in the "files folder".
    But when I try to upload the "my_image.zip" via DFU, exact same error is prompted as noted in the very first post of this ticket:
    When writing 'EXECUTE' command to Control Point Characteristic of DFU Target: Operation code 4 (EXECUTE) failed on DFU Target. Result code 5 (INVALID_OBJECT).
    About the following line in your script:
    Are you sure it is ble_app_buttonless_dfu and not \examples\dfu\secure_bootloader\pca10056_s140_ble\armgcc\_build folder from where dfu file needs to be copied?
  • I used the buttonless example as an example of the application that I wanted to update to via DFU.
    What HW are you running on? A normal DK?
    Can you please try to unzip an unmodified version of the SDK and:
    1: generate private.key and dfu_public_key.c in SDK\examples\dfu.
    2: compile the bootloader, ble_app_buttonless_dfu.
    3: run the build_all.bat from SDK\external\micro-ecc, and run the script again?
    It should work out of the box like that, if you are running on a DK. What DK version do you have?
    BR,
    Edvin
  • It's a 3rd party DK with nRF52840 module. So the pca10056 and S140 should work on it.
  • Does it have an external LFXTAL, or only RC Oscillator? And what are the specs on the LFXTAL?
    Did you try the unmodified SDK?
  • Yes, I tried unmodified SDK and it miraculously worked.
    Thanks for the help.
