I am getting several issues to install west, and samples look they don´t work without west... Any help ? Thanks
Here is the log from CMD.
It should be last version, I have installed some weeks ago for these tests...Can the issue be on the proxy side? I will check with our technical team if they can find something...
Ana
Hi, did you solve your issue?
I have the same issue but I am definitely connected to the internet. Would it be possible that my company's firewall is the one that's preventing a connection to west's servers? If so, would there be a way around this (i.e should I try installing it using my personal internet from home) ?
C:\windows\system32>pip3 install -v west
Created temporary directory: C:\Users\schmialf\AppData\Local\Temp\pip-ephem-wheel-cache-bstwm1ni
Created temporary directory: C:\Users\schmialf\AppData\Local\Temp\pip-req-tracker-oqo5g7o8
Created requirements tracker 'C:\\Users\\schmialf\\AppData\\Local\\Temp\\pip-req-tracker-oqo5g7o8'
Created temporary directory: C:\Users\schmialf\AppData\Local\Temp\pip-install-vbuth_ef
Collecting west
1 location(s) to search for versions of west:
* https://pypi.org/simple/west/
Getting page https://pypi.org/simple/west/
Found index url https://pypi.org/simple
Looking up "https://pypi.org/simple/west/" in the cache
Request header has "max_age" as 0, cache bypassed
Starting new HTTPS connection (1): pypi.org:443
Incremented Retry for (url='/simple/west/'): Retry(total=4, connect=None, read=None, redirect=None, status=None)
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x000001D155F56CD0>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed')': /simple/west/
Starting new HTTPS connection (2): pypi.org:443
Incremented Retry for (url='/simple/west/'): Retry(total=3, connect=None, read=None, redirect=None, status=None)
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x000001D155F56D30>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed')': /simple/west/
Starting new HTTPS connection (3): pypi.org:443
Incremented Retry for (url='/simple/west/'): Retry(total=2, connect=None, read=None, redirect=None, status=None)
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x000001D155F6C3D0>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed')': /simple/west/
Starting new HTTPS connection (4): pypi.org:443
Incremented Retry for (url='/simple/west/'): Retry(total=1, connect=None, read=None, redirect=None, status=None)
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x000001D155F6C820>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed')': /simple/west/
Starting new HTTPS connection (5): pypi.org:443
Incremented Retry for (url='/simple/west/'): Retry(total=0, connect=None, read=None, redirect=None, status=None)
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x000001D155F6C760>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed')': /simple/west/
Starting new HTTPS connection (6): pypi.org:443
Could not fetch URL https://pypi.org/simple/west/: connection error: HTTPSConnectionPool(host='pypi.org', port=443): Max retries exceeded with url: /simple/west/ (Caused by NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x000001D155F6C640>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed')) - skipping
Config variable 'Py_DEBUG' is unset, Python ABI tag may be incorrect
Given no hashes to check 0 links for project 'west': discarding no candidates
ERROR: Could not find a version that satisfies the requirement west (from versions: none)
Cleaning up...
Removed build tracker 'C:\\Users\\schmialf\\AppData\\Local\\Temp\\pip-req-tracker-oqo5g7o8'
ERROR: No matching distribution found for west
Exception information:
File "c:\python38\lib\site-packages\pip\_internal\cli\base_command.py", line 188, in main
status = self.run(options, args)
File "c:\python38\lib\site-packages\pip\_internal\commands\install.py", line 345, in run
resolver.resolve(requirement_set)
File "c:\python38\lib\site-packages\pip\_internal\legacy_resolve.py", line 196, in resolve
self._resolve_one(requirement_set, req)
File "c:\python38\lib\site-packages\pip\_internal\legacy_resolve.py", line 359, in _resolve_one
abstract_dist = self._get_abstract_dist_for(req_to_install)
File "c:\python38\lib\site-packages\pip\_internal\legacy_resolve.py", line 305, in _get_abstract_dist_for
abstract_dist = self.preparer.prepare_linked_requirement(
File "c:\python38\lib\site-packages\pip\_internal\operations\prepare.py", line 134, in prepare_linked_requirement
req.populate_link(finder, upgrade_allowed, require_hashes)
File "c:\python38\lib\site-packages\pip\_internal\req\req_install.py", line 211, in populate_link
self.link = finder.find_requirement(self, upgrade)
File "c:\python38\lib\site-packages\pip\_internal\index.py", line 1227, in find_requirement
raise DistributionNotFound(
pip._internal.exceptions.DistributionNotFound: No matching distribution found for west
1 location(s) to search for versions of pip:
* https://pypi.org/simple/pip/
Getting page https://pypi.org/simple/pip/
Looking up "https://pypi.org/simple/pip/" in the cache
Could not fetch URL https://pypi.org/simple/pip/: connection error: HTTPSConnectionPool(host='pypi.org', port=443): Max retries exceeded with url: /simple/pip/ (Caused by NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x000001D155F568E0>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed')) - skipping
Given no hashes to check 0 links for project 'pip': discarding no candidates
Greatly appreciate your help on this matter :))
Thank you in advanced!!
Hi, yes, it can very likely be your company's firewall preventing the connection. You could try installing using your personal internet and see if that solves the issue.
If it does, I suggest talking to your IT department about this limitation.
For more questions on this matter, please make a new ticket on DevZone and link it to this case.
Heidi
Thank you, this issue has been resolving using a personal internet.
