Error installing WEST "No matching distribution found for west"
I am getting several issues to install west, and samples look they don´t work without west... Any help ? Thanks
Here is the log from CMD.
  • Hi!
    Could you describe to me which steps you have done? Are you using the Getting Started Assistant in nRF Connect?
    Have you completed all of step one so that it is green in the menu to the left?
    Also, I will need the whole error message. The image you attached is cropped.
    Heidi
  • Hello Heidi,
    yes I am using nRF Connect,When I try to install west  (on the step 2) is when I got this error...
     here is the ERROR
      WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('
    bject at 0x00000000042EBDF0>: Failed to establish a new connection: [WinError 10061] Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte')': /simple/west
      WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('
    bject at 0x00000000042EB460>: Failed to establish a new connection: [WinError 10061] Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte')': /simple/west
      WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('
    bject at 0x00000000042EBDC0>: Failed to establish a new connection: [WinError 10061] Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte')': /simple/west
      WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('
    bject at 0x00000000042EB730>: Failed to establish a new connection: [WinError 10061] Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte')': /simple/west
      WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('
    bject at 0x00000000042EB400>: Failed to establish a new connection: [WinError 10061] Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte')': /simple/west
      ERROR: Could not find a version that satisfies the requirement west (from versions: none)
    ERROR: No matching distribution found for west
    same issue, here the info:
    $ pip3 install -v west
    Created temporary directory: C:\Users\alcala_an\AppData\Local\Temp\pip-ephem-wheel-cache-8g82hm5c
    Created temporary directory: C:\Users\alcala_an\AppData\Local\Temp\pip-req-tracker-8ta1gff2
    Created requirements tracker 'C:\\Users\\alcala_an\\AppData\\Local\\Temp\\pip-req-tracker-8ta1gff2'
    Created temporary directory: C:\Users\alcala_an\AppData\Local\Temp\pip-install-x8t1vk7c
    Collecting west
      1 location(s) to search for versions of west:
      * https://pypi.org/simple/west/
      Getting page https://pypi.org/simple/west/
      Found index url https://pypi.org/simple
      Looking up "">pypi.org/.../" in the cache
      Request header has "max_age" as 0, cache bypassed
      Starting new HTTPS connection (1): pypi.org:443
      Incremented Retry for (url='/simple/west/'): Retry(total=4, connect=None, read=None, redirect=None, status=None)
    pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x0000000003AEBFA0>: Failed to establish a new connection: [WinErro
    ] Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte')': /simple/west/
      Starting new HTTPS connection (2): pypi.org:443
    Cleaning up...
    Removed build tracker 'C:\\Users\\alcala_an\\AppData\\Local\\Temp\\pip-req-tracker-8ta1gff2'
    ERROR: Operation cancelled by user
    Exception information:
      File "c:\python38\lib\site-packages\pip\_vendor\urllib3\util\connection.py", line 70, in create_connection
        sock.connect(sa)
    ConnectionRefusedError: [WinError 10061] Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweiger
    During handling of the above exception, another exception occurred:
      File "c:\python38\lib\site-packages\pip\_internal\cli\base_command.py", line 188, in main
        status = self.run(options, args)
      File "c:\python38\lib\site-packages\pip\_internal\commands\install.py", line 345, in run
        resolver.resolve(requirement_set)
      File "c:\python38\lib\site-packages\pip\_internal\legacy_resolve.py", line 196, in resolve
        self._resolve_one(requirement_set, req)
      File "c:\python38\lib\site-packages\pip\_internal\legacy_resolve.py", line 359, in _resolve_one
        abstract_dist = self._get_abstract_dist_for(req_to_install)
      File "c:\python38\lib\site-packages\pip\_internal\legacy_resolve.py", line 305, in _get_abstract_dist_for
        abstract_dist = self.preparer.prepare_linked_requirement(
      File "c:\python38\lib\site-packages\pip\_internal\operations\prepare.py", line 134, in prepare_linked_requirement
        req.populate_link(finder, upgrade_allowed, require_hashes)
      File "c:\python38\lib\site-packages\pip\_internal\req\req_install.py", line 211, in populate_link
        self.link = finder.find_requirement(self, upgrade)
      File "c:\python38\lib\site-packages\pip\_internal\index.py", line 1200, in find_requirement
        candidates = self.find_candidates(
      File "c:\python38\lib\site-packages\pip\_internal\index.py", line 1183, in find_candidates
        candidates = self.find_all_candidates(project_name)
      File "c:\python38\lib\site-packages\pip\_internal\index.py", line 1128, in find_all_candidates
        for page in self._get_pages(url_locations, project_name):
      File "c:\python38\lib\site-packages\pip\_internal\index.py", line 1282, in _get_pages
        page = _get_html_page(location, session=self.session)
      File "c:\python38\lib\site-packages\pip\_internal\index.py", line 234, in _get_html_page
        resp = _get_html_response(url, session=session)
      File "c:\python38\lib\site-packages\pip\_internal\index.py", line 165, in _get_html_response
        resp = session.get(
      File "c:\python38\lib\site-packages\pip\_vendor\requests\sessions.py", line 546, in get
        return self.request('GET', url, **kwargs)
      File "c:\python38\lib\site-packages\pip\_internal\download.py", line 624, in request
        return super(PipSession, self).request(method, url, *args, **kwargs)
      File "c:\python38\lib\site-packages\pip\_vendor\requests\sessions.py", line 533, in request
        resp = self.send(prep, **send_kwargs)
      File "c:\python38\lib\site-packages\pip\_vendor\requests\sessions.py", line 646, in send
        r = adapter.send(request, **kwargs)
      File "c:\python38\lib\site-packages\pip\_vendor\cachecontrol\adapter.py", line 53, in send
        resp = super(CacheControlAdapter, self).send(request, **kw)
      File "c:\python38\lib\site-packages\pip\_vendor\requests\adapters.py", line 439, in send
        resp = conn.urlopen(
      File "c:\python38\lib\site-packages\pip\_vendor\urllib3\connectionpool.py", line 666, in urlopen
        return self.urlopen(method, url, body, headers, retries,
      File "c:\python38\lib\site-packages\pip\_vendor\urllib3\connectionpool.py", line 600, in urlopen
        httplib_response = self._make_request(conn, method, url,
      File "c:\python38\lib\site-packages\pip\_vendor\urllib3\connectionpool.py", line 344, in _make_request
        self._validate_conn(conn)
      File "c:\python38\lib\site-packages\pip\_vendor\urllib3\connectionpool.py", line 843, in _validate_conn
        conn.connect()
      File "c:\python38\lib\site-packages\pip\_vendor\urllib3\connection.py", line 316, in connect
        conn = self._new_conn()
      File "c:\python38\lib\site-packages\pip\_vendor\urllib3\connection.py", line 159, in _new_conn
        conn = connection.create_connection(
        sock.connect(sa)
    KeyboardInterrupt
    1 location(s) to search for versions of pip:
    * https://pypi.org/simple/pip/
    Getting page https://pypi.org/simple/pip/
    Could not fetch URL https://pypi.org/simple/pip/: connection error: HTTPSConnectionPool(host='pypi.org', port=443): Max retries exce
    th url: /simple/pip/ (Caused by NewConnectionError('
    rweigerte')) - skipping
    Config variable 'Py_DEBUG' is unset, Python ABI tag may be incorrect
    Given no hashes to check 0 links for project 'pip': discarding no candidates
  • From the log, it looks like you're not connected to the internet?
    Do you have the latest version of pip3?
