GPIO setup parameters for AoA Antenna switching
I have an issue with getting the I/Os correctly setup for antenna switching.
I am running the radio_test example code with the following modifications.
So far, I have the following code for the GPIO setup:
//Defines are at top of file
#define ANT1 NRF_GPIO_PIN_MAP(0,17)
#define ANT2 NRF_GPIO_PIN_MAP(1,8)
#define ANT3 NRF_GPIO_PIN_MAP(1,7)
#define ANT4 NRF_GPIO_PIN_MAP(1,6)
//other support code
//Pin config
nrf_gpio_pin_clear(ANT1);
nrf_gpio_cfg_output(ANT1);
nrf_gpio_pin_clear(ANT2);
nrf_gpio_cfg_output(ANT2);
nrf_gpio_pin_clear(ANT3);
nrf_gpio_cfg_output(ANT3);
nrf_gpio_pin_clear(ANT4);
nrf_gpio_cfg_output(ANT4);
//DFE pin config
NRF_RADIO->PSEL.DFEGPIO[0] = ANT1; //(P0.17)
NRF_RADIO->PSEL.DFEGPIO[1] = ANT2; //(P1.08)
NRF_RADIO->PSEL.DFEGPIO[2] = ANT3; //(P1.07)
NRF_RADIO->PSEL.DFEGPIO[4] = ANT4; //(P1.06)
NRF_RADIO->SWITCHPATTERN = 1; //Only P0.07 active
NRF_RADIO->SWITCHPATTERN = 2; //Only P1.08 active
NRF_RADIO->SWITCHPATTERN = 4; //Only P1.07 active
NRF_RADIO->SWITCHPATTERN = 8; //Only P1.06 active
NRF_RADIO->DFEMODE = RADIO_DFEMODE_DFEOPMODE_AoA;
NRF_RADIO->DFECTRL1 = 10 << RADIO_DFECTRL1_NUMBEROF8US_Pos |
                       1 << RADIO_DFECTRL1_DFEINEXTENSION_Pos;
Then in the radio_test.c file, I include in the function radio_rx( ...)
uint32_t g_iq_packet[RADIO_MAX_PAYLOAD_LEN];
void radio_rx(....)
//orig example code still exists here, only not shown
    NRF_RADIO->DFEPACKET.PTR = (uint32_t)g_iq_packet;
From a board running the radio_test example, I issue the 'start_tx_modulated_carrier' command the immediately issue the 'start_rx" command on a seperate DK also running the radio_test example with the above modifications.
I expected to see a short duration square wave on each of the antenna GPIO pins, so, 4 square waves cascading in time. However from my logic analyzer capture, you can clearly see that is not the case.
How should I be setting up the config registers to fire each of the pins.  Nothing else is connected to the board except the logic analyzer.
Also, how do I correlate the IQ data from the DFEPACKET.PTR to the specific antenna?
  • Hi
    Piotr is one of the firmware engineers here at Nordic, and has experience in this field, so what is said in this quote is reliable. Please note that the "first sample from switch-period would be taken in first sampling slot, so you would have a time delay of 4 samples". So no, you would not have 44 samples instead of 48, but you will have a delay of 1us before the samples are taken.
    Simon
    I know his wording is reliable  and same was written in White Paper "The hardware always aligns the first IQ sample in the first sample slot."
    But I am not getting that time delay understanding, can you clear my understanding?
    in 24 us even radio start sampling on first edge of sample slot duration maximum 45 samples can be taken.
    0.25us Guard Period
    0.5
    0.75
    1
    1.25
    1.5
    1.75
    2
    2.25
    2.5
    2.75
    3
    3.25
    3.5
    3.75
    4
    4.25 Reference Period Sample 1
    4.5 Sample 2
    4.75 Sample 3
    5 Sample 4
    5.25 Sample 5
    5.5 Sample 6
    5.75 Sample 7
    6 Sample 8
    6.25 Sample 9
    6.5 Sample 10
    6.75 Sample 11
    7 Sample 12
    7.25 Sample 13
    7.5 Sample 14
    7.75 Sample 15
    8 Sample 16
    8.25 Sample 17
    8.5 Sample 18
    8.75 Sample 19
    9 Sample 20
    9.25 Sample 21
    9.5 Sample 22
    9.75 Sample 23
    10 Sample 24
    10.25 Sample 25
    10.5 Sample 26
    10.75 Sample 27
    11 Sample 28
    11.25 Sample 29
    11.5 Sample 30
    11.75 Sample 31
    12 Sample 32
    12.25 Switch Slot 1
    12.5
    12.75
    13
    13.25 Sample Slot 1 Sample 33
    13.5 Sample 34
    13.75 Sample 35
    14 Sample 36
    14.25 Switch Slot 2 Sample 37
    14.5 Sample 38
    14.75 Sample 39
    15 Sample 40
    15.25 Sample Slot 2 Sample 41
    15.5 Sample 42
    15.75 Sample 43
    16 Sample 44
    16.25 Switch Slot 3 Sample 45
    16.5 Sample 46
    16.75 Sample 47
    17 Sample 48
    17.25 Sample Slot 3 Sample 49
    17.5 Sample 50
    17.75 Sample 51
    18 Sample 52
    18.25 Switch Slot 4 Sample 53
    18.5 Sample 54
    18.75 Sample 55
    19 Sample 56
    19.25 Sample Slot 4 Sample 57
    19.5 Sample 58
    19.75 Sample 59
    20 Sample 60
    20.25 Switch Slot 5 Sample 61
    20.5 Sample 62
    20.75 Sample 63
    21 Sample 64
    21.25 Sample Slot 5 Sample 65
    21.5 Sample 66
    21.75 Sample 67
    22 Sample 68
    22.25 Switch Slot 6 Sample 69
    22.5 Sample 70
    22.75 Sample 71
    23 Sample 72
    23.25 Sample Slot 6 Sample 73
    23.5 Sample 74
    23.75 Sample 75
    24 Sample 76
    Sample 77
  • I'm sorry, but I'm not sure I understand what you mean by this, or how to explain this delay any further than it being a delay before the sampling starts. As this ticket is rather old and long, please create a new ticket where you describe your question in detail (and link to this thread if relevant).
    SImon
