nRF51822 UART not work
Hi all My hardware is nRF51822 PCA0000 and PCA0001, I just want to compile/load any UART example to test my UART workable or not. So I have tried example project button_radio_example、led_radio_example and uart_example, I got no signal on hypetrm with any example project. I set break point on Keil with any example project and got the same result, the processing hang on :
PCA0000 :
void simple_uart_put(uint8_t cr)
  NRF_UART0->TXD = (uint8_t)cr;
  while (NRF_UART0->EVENTS_TXDRDY!=1)   // HANG ON THIS LINE !!!!!!
    // Wait for TXD data to be sent
  NRF_UART0->EVENTS_TXDRDY=0;
PCA0001 :
uint8_t simple_uart_get(void)
  while (NRF_UART0->EVENTS_RXDRDY != 1)   // HANG ON THIS LINE !!!!!!
    // Wait for RXD data to be received
  NRF_UART0->EVENTS_RXDRDY = 0;
  return (uint8_t)NRF_UART0->RXD;
any idea ?
  • There shouldn't really be anything special needed to get this working. Which serial port are you connecting to, and which settings are you using? The examples use 38400 bps by default. Have you tried another terminal emulator?
    One thing I'd recommend you to verify is that the pinout is correct. This is easiest done by comparing the pinout given in the Evaluation Kit User Guide with the one actually used by your code. The different board revisions have the UART pins connected to different pins on the nRF51822, and if you use the wrong mapping, you will have trouble.
    Edit: Attached verified working hex for PCA10001. Please test it and see.
    uart_example_arm.hex
  • I ever use putty and hypertrm and they all not work. I am sure I test with correct port !
    Because I only have two UART ports. https://devzone.nordicsemi.com/?controller=attachment&task=displayFile&tmpl=component&id=208
    But I find the default bound rate of the two UART is 9600 not 38400, I fix them but still not work, but is this a correct default value ? https://devzone.nordicsemi.com/index.php/discussions?controller=attachment&task=displayFile&tmpl=component&id=209
    I just have PCA0000 and PCA0001 two boards,I did not buy the motherboard. So I can not test with pins right ? any other way ?
  • Still not work, I reply a new post as below.
  • I actually didn't mean the wrong serial port on the PC side, but the wrong pins for UART on the nRF51822 side. Can you please verify that as well? Also, the baud rate is usually set in the application you're using, i.e. putty or hyperterm, in addition to the port itself.
  • OK! The pin number of UART (print on back of the PCA0001 board) is : P0.08 RTS P0.09 TXD P0.10 CTS P0.11 RXD
    This is my pin define on PCA0001.h #define RX_PIN_NUMBER 11 #define TX_PIN_NUMBER 9 #define CTS_PIN_NUMBER 10 #define RTS_PIN_NUMBER 8
    Seems OK ?
