DFU_public_key.c won't compile.
I have create a new DFU_public_key.c file with nrf_util and replace the existing file in the dfu_req_handling folder (MacOSX).
I had to change the name of the nRF5_SDK_14.2-2.0_17b948a  to nRF5_SDK_14  because Terminal.app had problem with the name while navigating directories.
When I compile the program with the new key in place,  I have the following compiling error :
Compiling ‘dfu_public_key.c’
expected '}' before numeric constant
to match this '{'
The error point at the second 0x....  line (line 11).
Here is the file with the key hidden:
/* This file was automatically generated by nrfutil on 2019-12-13 (YY-MM-DD) at 15:42:07 */
#include "stdint.h"
#include "compiler_abstraction.h"
/** @brief Public key used to verify DFU images */
__ALIGN(4) const uint8_t pk[64] =
    0x....
    0x....
I don't see the problem with the file.
Help would be appreciate.   Thanks
    Sorry for the late reply. I have been out of office for the Christmas Holidays, and we have been short staffed, so we have not been able to answer all the cases.
    SL06 said:
    and have install the 4.9 - 2014 q4 version. although a version 5.4 was available
     That is good. I recommend you to use the same version that the SDK that you are using was written in and tested with.
    Edvin
