Button interrupt , gpiote
HEllo;
I'm working with nrf52832 and sdk15 , and for interrupt button i chose to work with the example "/nRF5_SDK_15.0.0_a53641a/examples/peripheral/pin_change_int/"
, so my question is how we can know its pushed button(push the button two time)  and long press.
and how we can add : three configuration nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_HITOLO(true);/and LOTOHI and toggle , all together. thank you for your help .
and what about consume of the energy is it better to work wirh nrf_gpio_pin_read(30) or this methode of interupt.
  • A huge portion of the support team is currently on Christmas vacation and you may experience delayed answers. Most of the staff will be back 6 of January 2020 and you can be sure to get an answer shortly after that.
    Simon
  • Okey no probleme ; I'll be waiting for the reply , happy vacation for all
  • so my question is how we can know its pushed button(push the button two time)
     In the pin change int example, you know that button 1 is pushed (a transition happens) when a GPIOTE event is triggered. In the pin_change_int example, the function in_pin_handler() will run in response to this event.
    and long press
     Check out this ticket.
     I am not sure if I understand what you are asking about here, can you explain it in more details?
     It depends on how you use nrf_gpio_pin_read(). If you put it in a while(1) it will definitely use more power than the method using GPIOTE events and interrupt.
    However, if you create a timer that will trigger an interrupt handler periodically and run nrf_gpio_pin_read() in the handler, then the current consumption will be low. The drawback of this method is that it will most definitely loose some pin transitions. I think the initial method is the best one.
    Simon
  • Hello Simon thank you for your answer.
    I contiue working with the example (examples/peripheral/pin_change_int), and I made this code :
    #include <stdbool.h>
    #include "nrf.h"
    #include "nrf_drv_gpiote.h"
    #include "app_error.h"
    #include "boards.h"
    #include "nrf_delay.h"
    #define PIN_IN 30
    #define PIN_OUT 26
    bool HL_state;
    bool LH_state;
    bool First_state;
    bool up_state;
    int HL_counter=0;
    int LH_counter=0;
    int count ;
    int push_counter;
    int up_counter;
    void in_pin_handlerHL(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
        //nrf_drv_gpiote_out_toggle(PIN_OUT);
        NRF_GPIOTE->EVENTS_IN[0] = 0;
            if (nrf_gpio_pin_read(30)==0)
                HL_counter ++;
                HL_state=true;
                LH_state=false;
                LH_counter=0;
            }else{
                LH_counter ++;
                LH_state=true;
                HL_state=false;
                HL_counter=0;
    // void in_pin_handlerLH(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
    //     //nrf_drv_gpiote_out_toggle(PIN_OUT);
    //     NRF_GPIOTE->EVENTS_IN[0] = 0;
    //     LH_counter ++;
    //         if (nrf_gpio_pin_read(30)==1)
    //             LH_state=true;
    //             HL_state=false;
    //             HL_counter=0;
    //         }else{
    //             LH_state=false;
     * @brief Function for configuring: PIN_IN pin for input, PIN_OUT pin for output,
     * and configures GPIOTE to give an interrupt on pin change.
    static void gpio_init(void)
        ret_code_t err_code;
        if (!nrf_drv_gpiote_is_init())
        nrf_drv_gpiote_out_config_t out_config = GPIOTE_CONFIG_OUT_SIMPLE(false);
        // err_code = nrf_drv_gpiote_out_init(PIN_OUT, &out_config);
        // APP_ERROR_CHECK(err_code);
        nrf_drv_gpiote_in_config_t in_configHL = GPIOTE_CONFIG_IN_SENSE_TOGGLE(false);
        // nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_TOGGLE(true);
        in_configHL.pull = NRF_GPIO_PIN_PULLUP;
        nrf_drv_gpiote_in_config_t in_configLH = GPIOTE_CONFIG_IN_SENSE_LOTOHI(true);
        in_configLH.pull = NRF_GPIO_PIN_PULLUP;
        err_code = nrf_drv_gpiote_in_init(PIN_IN, &in_configHL, in_pin_handlerHL);
        // err_code = nrf_drv_gpiote_in_init(PIN_IN, &in_configLH, in_pin_handlerLH);
        nrf_drv_gpiote_in_event_enable(PIN_IN, true);
     * @brief Function for application main entry.
        gpio_init();
        //printf("HL_state%d\n", HL_state );
        //printf("LH_state%d\n", LH_state );
           // printf("start");
        while (true)
            if (HL_state==true)
                //printf("yes\n");
                First_state=true;
                count=0;
                push_counter ++;
            }else
                count ++;
                //printf("counter : %d\n", count);
                push_counter=0;
                up_counter ++;
            if (1<count && count <5 && First_state==true )
                printf("UP\n");
                up_state=true;
                First_state=false;
                up_counter=0;
            }else{
                up_state==false;
            if (HL_state==true && up_state==true && up_counter < 10)
                printf("double\n");
                up_state=false;
                First_state=false;
                count=0;
                up_counter=0;
            }else{
            if(20<push_counter && push_counter<50 && HL_state==true){
                printf("hold_press\n");
                up_state=false;
                First_state=false;
            }else if(push_counter>50 && HL_state==true){
                printf("long_press\n");
                up_state=false;
                First_state=false;
                push_counter=0;
            }else{
            nrf_delay_ms(100);
    is it right ? , my question is can we do the high to lo and lo to high configuration as i commented in my code , cause it dosnt work for me , but for the moment i made it , I think it's right, please give me your feed back about my code. and i hope it will not consume a lot of energy
  • Before continuing, I would like to ask why you don't use the solution already provided in this thread? That solution is based on a timer, which makes it more accurate and energy-efficient.
    Simon
