Hello, I am writing a Program where I use GPS and NBIoT.
Recently, I wanted to combine the default GPS example code with an NBIoT Code, that connects to a TCP Server and when I tested it, either the Server Connection or the GPS failed. So I looked up and find an answer: https://devzone.nordicsemi.com/f/nordic-q-a/48636/nrf9160-localization-lte-nb
NBIoT and GPS can only run seperately. I tried now to switch between the to modes, but it didn't really work: I tried to run some AT Command during the runtime to switch from
AT%XSYSTEMMODE=0,1,0,0
to
AT%XSYSTEMMODE=0,0,1,0
and back within the code:
* Copyright (c) 2018 Nordic Semiconductor ASA
* SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
#include <zephyr.h>
#include <stdio.h>
#include <uart.h>
#include <string.h>
#include <net/socket.h>
void ATCFUN4(){
static int at_command_socket;
int bytes_sent, bytes_read;
static u8_t at_command[256] = "AT+CFUN=4\r\n";
static char result[256];
at_command_socket = socket(AF_LTE, 0, NPROTO_AT);
int bytes_to_send = strlen(at_command);
bytes_sent = send(at_command_socket, at_command, bytes_to_send, 0);
bytes_read = recv(at_command_socket, result, sizeof(result), 0);
printk("RECEIVED FROM recv(): %s\n", result);
void ATCFUN1(){
static u8_t at_command[256] = "AT+CFUN=1\r\n";
void NBIoT_Mode(){
static u8_t at_command[256] = "AT%XSYSTEMMODE=0,0,1,0\r\n";
void GPS_Mode(){
static u8_t at_command[256] = "AT%XSYSTEMMODE=0,1,0,0\r\n";
void read_mode(){
static u8_t at_command[256] = "AT%XSYSTEMMODE?\r\n";
void main(void)
while (1)
ATCFUN4();
k_sleep(1000);
NBIoT_Mode();
k_sleep(1000);
ATCFUN1();
k_sleep(1000);
read_mode();
k_sleep(1000);
ATCFUN4();
k_sleep(1000);
GPS_Mode();
k_sleep(1000);
ATCFUN1();
k_sleep(1000);
read_mode();
k_sleep(1000);
I wrote this code as a test to see, if I can switch between the two modes properly.
And I get this result in the LTE Monitor:
It only jumps one time and then it don't jumps back.
Is this the write way to change the network mode? Or do you have any idea how this could work properly?
Thanks for your answers!
