Immutable bootloader private key in zephyr
In trying to use a private key file to sign the application image I'm running into an issue with the PEM file. I created a PEM file using the following command:
openssl ecparam -name prime256v1 -genkey -noout -out priv.pem
as documented here: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/samples/bootloader/README.html
Then I modified my application's prj.conf file by adding these lines:
# Bootloader
CONFIG_SECURE_BOOT=y
CONFIG_SB_SIGNING_KEY_FILE="priv.pem"
The build output generates this error:
-- Using application from 'C:/Users/me/Repos/myproject'
Zephyr version: 2.0.99
-- Found PythonInterp: C:/Python37/python.exe (found suitable version "3.7.3", minimum required is "3.4")
-- Selected BOARD nrf9160_pca10090ns
-- Found west: C:/Python37/Scripts/west.exe (found suitable version "0.6.3", minimum required is "0.6.0")
-- Cache files will be written to: C:\Users\me\AppData\Local/.cache/zephyr
-- Loading C:/Users/me/Repos/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090ns.dts as base
-- Overlaying C:/Users/me/Repos/ncs/zephyr/dts/common/common.dts
-- Overlaying C:/Users/me/Repos/myproject/nrf9160_pca10090ns.overlay
Devicetree configuration written to C:/Users/me/Repos/myproject/build/zephyr/include/generated/generated_dts_board.conf
warning: TEST_RANDOM_GENERATOR (defined at subsys/random/Kconfig:8) was assigned the value 'y' but
got the value 'n'. You can check symbol information (including dependencies) in the 'menuconfig'
interface (see the Application Development Primer section of the manual), or in the Kconfig
reference at
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_TEST_RANDOM_GENERATOR.html (which is
updated regularly from the master branch). See the 'Setting configuration values' section of the
Board Porting Guide as well.
Parsing Kconfig tree in C:/Users/me/Repos/myproject/Kconfig
Loaded configuration 'C:/Users/me/Repos/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090ns_defconfig'
Merged configuration 'C:/Users/me/Repos/myproject/prj.conf'
Configuration saved to 'C:/Users/me/Repos/myproject/build/zephyr/.config'
-- The C compiler identification is GNU 7.3.1
-- The CXX compiler identification is GNU 7.3.1
-- Found assembler: C:/gnuarmemb/bin/arm-none-eabi-gcc.exe
-- Using application from 'C:/Users/me/Repos/ncs/nrf/samples/nrf9160/spm'
Changed board to secure nrf9160_pca10090 (NOT NS)
USING OUT OF TREE BOARD
-- Loading C:/Users/me/Repos/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090.dts as base
-- Overlaying C:/Users/me/Repos/ncs/nrf/samples/nrf9160/spm/nrf9160_pca10090.overlay
Devicetree configuration written to C:/Users/me/Repos/myproject/build/spm/zephyr/include/generated/generated_dts_board.conf
Parsing Kconfig tree in C:/Users/me/Repos/ncs/zephyr/Kconfig
Loaded configuration 'C:/Users/me/Repos/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090_defconfig'
Merged configuration 'C:/Users/me/Repos/ncs/nrf/samples/nrf9160/spm/prj.conf'
Configuration saved to 'C:/Users/me/Repos/myproject/build/spm/zephyr/.config'
-- Using application from 'C:/Users/me/Repos/ncs/nrf/samples/bootloader'
Devicetree configuration written to C:/Users/me/Repos/myproject/build/b0/zephyr/include/generated/generated_dts_board.conf
Merged configuration 'C:/Users/me/Repos/ncs/nrf/samples/bootloader/prj.conf'
Configuration saved to 'C:/Users/me/Repos/myproject/build/b0/zephyr/.config'
CMake Error at C:/Users/me/Repos/ncs/nrf/subsys/bootloader/cmake/debug_keys.cmake:57 (message):
  Config points to non-existing PEM file 'priv.pem'
  C:/Users/me/Repos/ncs/nrf/subsys/bootloader/image/CMakeLists.txt:67 (include)
See also "C:/Users/me/Repos/myproject/build/CMakeFiles/CMakeOutput.log".
See also "C:/Users/me/Repos/myproject/build/CMakeFiles/CMakeError.log".
The priv.pem file is in the same directory as my prj.conf file. What am I doing wrong that the build tools can't find it?
  • Here is the CMakeError.log:
    Compiling the C compiler identification source file "CMakeCCompilerId.c" failed.
    Compiler: C:/gnuarmemb/bin/arm-none-eabi-gcc.exe
    Build flags:
    Id flags:
    The output was:
    1
    c:/gnuarmemb/bin/../lib/gcc/arm-none-eabi/7.3.1/../../../../arm-none-eabi/lib\libc.a(lib_a-exit.o): In function `exit':
    exit.c:(.text.exit+0x2c): undefined reference to `_exit'
    collect2.exe: error: ld returned 1 exit status
    Compiling the CXX compiler identification source file "CMakeCXXCompilerId.cpp" failed.
    Build flags:
    Id flags:
    The output was:
    1
    And here's the CMakeOutput.log:
    The target system is: Generic - 2.0.99 - arm
    The host system is: Windows - 10.0.17763 - AMD64
    Compiling the C compiler identification source file "CMakeCCompilerId.c" succeeded.
    Build flags:
    Id flags: -c
    The output was:
    0
    Compilation of the C compiler identification source "CMakeCCompilerId.c" produced "CMakeCCompilerId.o"
    The C compiler identification is GNU, found in "C:/Users/me/Repos/myproject/build/CMakeFiles/3.14.5/CompilerIdC/CMakeCCompilerId.o"
    Compiling the CXX compiler identification source file "CMakeCXXCompilerId.cpp" succeeded.
    Build flags:
    Id flags: -c
    The output was:
    0
    Compilation of the CXX compiler identification source "CMakeCXXCompilerId.cpp" produced "CMakeCXXCompilerId.o"
    The CXX compiler identification is GNU, found in "C:/Users/me/Repos/myproject/build/CMakeFiles/3.14.5/CompilerIdCXX/CMakeCXXCompilerId.o"
    Checking whether the ASM compiler is GNU using "--version" matched "(GNU assembler)|(GCC)|(Free Software Foundation)":
    arm-none-eabi-gcc.exe (GNU Tools for Arm Embedded Processors 7-2018-q2-update) 7.3.1 20180622 (release) [ARM/embedded-7-branch revision 261907]
    Copyright (C) 2017 Free Software Foundation, Inc.
    This is free software; see the source for copying conditions.  There is NO
    warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
    When setting the path to the PEM, which folder is it referencing? I put it in the same folder as my CMakeLists.txt but that isn't correct. Using an absolute path can't be the best way to do it, so
    1. Where should the PEM file be? Or
    2. How can I use a relative path?
    I'm not using the Segger IDE - just command line tools and text editors.
  • Thanks for providing this information. I have forwarded it to our R&D team and will get back to asap.
    Øyvind
  • I performed the following steps, and did not see any issue. Please let me know what you have done differently:
    1. Jump to latest master (you should be able to do this on older commits as well)
    2. West update <- The warning about the 'TEST_RANDOM_GENERATOR' might indicate that this step is not done properly
    3. Use BOARD nrf9160_pca10090ns
    4. Jump to zephyr/samples/hello_world
    5. Run your openssl command
    6. modify zephyr/samples/hello_world prj.conf by adding the two lines you mention above
    7. cmake -GNinja -DBOARD=nrf9160_pca10090ns && ninja flash
    8. Verify that hello world boots.
    Also, the help text for the 'SB_SIGNING_KEY_FILE' explicitly states that the path shall be absolute. Note that for this case, the relative path provided by you also worked for me.
    Try to follow those steps, and let me know if/when it fails.
    Edit: I see now that you are on windows. Please try to use the absolute path :)
  • Hi shibshab,
    I tried the above steps on nrf master, by specifying the private in absolute and relative path but the applicant failed to boot, with following error message.
    # Bootloader
    #CONFIG_SB_SIGNING_KEY_FILE="priv.pem"
    CONFIG_SB_SIGNING_KEY_FILE="C:/Data/GIT/ncs/master/zephyr/samples/hello_world/priv.pem"
    2020-10-12T13:50:30.809Z DEBUG modem << *** Booting Zephyr OS build v2.3.0-rc1-ncs1-3614-ga4ead9805140  ***
    2020-10-12T13:50:30.817Z DEBUG modem << Attempting to boot slot 0.
    2020-10-12T13:50:30.819Z DEBUG modem << Attempting to boot from address 0x8000.
    2020-10-12T13:50:30.820Z DEBUG modem << Firwmare has been invalidated: 0x91020000.
    2020-10-12T13:50:30.822Z DEBUG modem << Failed to validate, permanently invalidating!
    2020-10-12T13:50:30.825Z DEBUG modem << Attempting to boot slot 1.
    2020-10-12T13:50:30.827Z DEBUG modem << No fw_info struct found.
    2020-10-12T13:50:30.831Z DEBUG modem << No bootable image found. Aborting boot.
    thanks and regards
    KK
  • I think its nothing to do with the private key, even just enabling CONFIG_SECURE_BOOT=y doesn't work either
    regards
    KK
