Immutable bootloader private key in zephyr
In trying to use a private key file to sign the application image I'm running into an issue with the PEM file. I created a PEM file using the following command:
openssl ecparam -name prime256v1 -genkey -noout -out priv.pem
as documented here: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/samples/bootloader/README.html
Then I modified my application's prj.conf file by adding these lines:
# Bootloader
CONFIG_SECURE_BOOT=y
CONFIG_SB_SIGNING_KEY_FILE="priv.pem"
The build output generates this error:
-- Using application from 'C:/Users/me/Repos/myproject'
Zephyr version: 2.0.99
-- Found PythonInterp: C:/Python37/python.exe (found suitable version "3.7.3", minimum required is "3.4")
-- Selected BOARD nrf9160_pca10090ns
-- Found west: C:/Python37/Scripts/west.exe (found suitable version "0.6.3", minimum required is "0.6.0")
-- Cache files will be written to: C:\Users\me\AppData\Local/.cache/zephyr
-- Loading C:/Users/me/Repos/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090ns.dts as base
-- Overlaying C:/Users/me/Repos/ncs/zephyr/dts/common/common.dts
-- Overlaying C:/Users/me/Repos/myproject/nrf9160_pca10090ns.overlay
Devicetree configuration written to C:/Users/me/Repos/myproject/build/zephyr/include/generated/generated_dts_board.conf
warning: TEST_RANDOM_GENERATOR (defined at subsys/random/Kconfig:8) was assigned the value 'y' but
got the value 'n'. You can check symbol information (including dependencies) in the 'menuconfig'
interface (see the Application Development Primer section of the manual), or in the Kconfig
reference at
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_TEST_RANDOM_GENERATOR.html (which is
updated regularly from the master branch). See the 'Setting configuration values' section of the
Board Porting Guide as well.
Parsing Kconfig tree in C:/Users/me/Repos/myproject/Kconfig
Loaded configuration 'C:/Users/me/Repos/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090ns_defconfig'
Merged configuration 'C:/Users/me/Repos/myproject/prj.conf'
Configuration saved to 'C:/Users/me/Repos/myproject/build/zephyr/.config'
-- The C compiler identification is GNU 7.3.1
-- The CXX compiler identification is GNU 7.3.1
-- Found assembler: C:/gnuarmemb/bin/arm-none-eabi-gcc.exe
-- Using application from 'C:/Users/me/Repos/ncs/nrf/samples/nrf9160/spm'
Changed board to secure nrf9160_pca10090 (NOT NS)
USING OUT OF TREE BOARD
-- Loading C:/Users/me/Repos/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090.dts as base
-- Overlaying C:/Users/me/Repos/ncs/nrf/samples/nrf9160/spm/nrf9160_pca10090.overlay
Devicetree configuration written to C:/Users/me/Repos/myproject/build/spm/zephyr/include/generated/generated_dts_board.conf
Parsing Kconfig tree in C:/Users/me/Repos/ncs/zephyr/Kconfig
Loaded configuration 'C:/Users/me/Repos/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090_defconfig'
Merged configuration 'C:/Users/me/Repos/ncs/nrf/samples/nrf9160/spm/prj.conf'
Configuration saved to 'C:/Users/me/Repos/myproject/build/spm/zephyr/.config'
-- Using application from 'C:/Users/me/Repos/ncs/nrf/samples/bootloader'
Devicetree configuration written to C:/Users/me/Repos/myproject/build/b0/zephyr/include/generated/generated_dts_board.conf
Merged configuration 'C:/Users/me/Repos/ncs/nrf/samples/bootloader/prj.conf'
Configuration saved to 'C:/Users/me/Repos/myproject/build/b0/zephyr/.config'
CMake Error at C:/Users/me/Repos/ncs/nrf/subsys/bootloader/cmake/debug_keys.cmake:57 (message):
  Config points to non-existing PEM file 'priv.pem'
  C:/Users/me/Repos/ncs/nrf/subsys/bootloader/image/CMakeLists.txt:67 (include)
See also "C:/Users/me/Repos/myproject/build/CMakeFiles/CMakeOutput.log".
See also "C:/Users/me/Repos/myproject/build/CMakeFiles/CMakeError.log".
The priv.pem file is in the same directory as my prj.conf file. What am I doing wrong that the build tools can't find it?
  • Have performed a chip erase before flashing b0? `nrfjprog -e`
  • Are you building for a non-secure board? If so you should use MCUBoot as the single stage bootloader instead. B0 does not support non-secure apps as the next step in the bootloader chain.
  • To my understanding when you build the application(with NS) with secure boot and mcuoot support the child images are build automatically with their respective secure or NS configuration, no need to specify explicitly.
    Lets us consider an application on which i am presently working on i.e ncs\master\nrf\applications\serial_lte_modem, by adding the following config lines to the my application builds the b0 and mcuboo(NS) automatically
    # b0 Bootloader
    # MCUboot as upgradable bootloader
    CONFIG_BOOTLOADER_MCUBOOT=y
    ROM map
    terminal o/p
    -------------------------------b0 -------------------------------------------------
    2020-10-13T06:54:51.280Z DEBUG modem << *** Booting Zephyr OS build v2.3.0-rc1-ncs1-3614-ga4ead9805140  ***
    2020-10-13T06:54:51.284Z DEBUG modem << Attempting to boot slot 0.
    2020-10-13T06:54:51.289Z DEBUG modem << Attempting to boot from address 0x8200.
    2020-10-13T06:54:51.291Z DEBUG modem << Verifying signature against key 0.
    2020-10-13T06:54:51.298Z DEBUG modem << Hash: 0x8e...d7
    2020-10-13T06:54:51.316Z DEBUG modem << Firmware signature verified.
    2020-10-13T06:54:51.318Z DEBUG modem << Firmware version 1
    2020-10-13T06:54:51.324Z DEBUG modem << Setting monotonic counter (version: 1, slot: 0)
    2020-10-13T06:54:51.325Z DEBUG modem << Booting (0x8200).
    -------------------------------mcuboot -------------------------------------------------
    2020-10-13T06:54:51.334Z DEBUG modem << *** Booting Zephyr OS build v2.3.0-rc1-ncs1-3614-ga4ead9805140  ***
    2020-10-13T06:54:51.337Z DEBUG modem << [00:00:00.006,042] [0m<inf> mcuboot: Starting bootloader[0m
    2020-10-13T06:54:51.350Z DEBUG modem << [00:00:00.012,359] [0m<inf> mcuboot: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3[0m
    2020-10-13T06:54:51.353Z DEBUG modem << [00:00:00.022,491] [0m<inf> mcuboot: Boot source: none[0m
    2020-10-13T06:54:51.357Z DEBUG modem << [00:00:00.028,015] [0m<inf> mcuboot: Swap type: none[0m
    2020-10-13T06:54:51.374Z DEBUG modem << [00:00:00.033,691] [0m<inf> mcuboot: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3[0m
    2020-10-13T06:54:51.376Z DEBUG modem << [00:00:00.043,792] [0m<inf> mcuboot: Boot source: none[0m
    2020-10-13T06:54:51.386Z DEBUG modem << [00:00:00.049,346] [0m<inf> mcuboot: Swap type: none[0m
    2020-10-13T06:54:51.652Z DEBUG modem << [00:00:00.319,702] [0m<inf> mcuboot: Bootloader chainload address offset: 0x28000[0m
    2020-10-13T06:54:51.664Z DEBUG modem << [00:00:00.327,514] [0m<inf> mcuboot: Jumping to the first image slot[0m
    -------------------------------app---------------------------------------------
    2020-10-13T06:54:52.037Z DEBUG modem << Ready
    2020-10-13T06:54:55.659Z DEBUG modem >> AT
    2020-10-13T06:54:55.675Z DEBUG modem << OK
    2020-10-13T06:54:56.153Z DEBUG modem >> AT
    2020-10-13T06:54:56.168Z DEBUG modem << OK
    regrads
    kk
  • You are correct in that the bootloaders (both b0 and mcuboot) are automatically built for the secure variant of the board. In the case of your issue, I'm wondering if you have enabled MCUBoot or not (when you saw the issue about missing validation info)
