Immutable bootloader private key in zephyr
In trying to use a private key file to sign the application image I'm running into an issue with the PEM file. I created a PEM file using the following command:
openssl ecparam -name prime256v1 -genkey -noout -out priv.pem
as documented here: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/samples/bootloader/README.html
Then I modified my application's prj.conf file by adding these lines:
# Bootloader
CONFIG_SECURE_BOOT=y
CONFIG_SB_SIGNING_KEY_FILE="priv.pem"
The build output generates this error:
-- Using application from 'C:/Users/me/Repos/myproject'
Zephyr version: 2.0.99
-- Found PythonInterp: C:/Python37/python.exe (found suitable version "3.7.3", minimum required is "3.4")
-- Selected BOARD nrf9160_pca10090ns
-- Found west: C:/Python37/Scripts/west.exe (found suitable version "0.6.3", minimum required is "0.6.0")
-- Cache files will be written to: C:\Users\me\AppData\Local/.cache/zephyr
-- Loading C:/Users/me/Repos/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090ns.dts as base
-- Overlaying C:/Users/me/Repos/ncs/zephyr/dts/common/common.dts
-- Overlaying C:/Users/me/Repos/myproject/nrf9160_pca10090ns.overlay
Devicetree configuration written to C:/Users/me/Repos/myproject/build/zephyr/include/generated/generated_dts_board.conf
warning: TEST_RANDOM_GENERATOR (defined at subsys/random/Kconfig:8) was assigned the value 'y' but
got the value 'n'. You can check symbol information (including dependencies) in the 'menuconfig'
interface (see the Application Development Primer section of the manual), or in the Kconfig
reference at
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_TEST_RANDOM_GENERATOR.html (which is
updated regularly from the master branch). See the 'Setting configuration values' section of the
Board Porting Guide as well.
Parsing Kconfig tree in C:/Users/me/Repos/myproject/Kconfig
Loaded configuration 'C:/Users/me/Repos/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090ns_defconfig'
Merged configuration 'C:/Users/me/Repos/myproject/prj.conf'
Configuration saved to 'C:/Users/me/Repos/myproject/build/zephyr/.config'
-- The C compiler identification is GNU 7.3.1
-- The CXX compiler identification is GNU 7.3.1
-- Found assembler: C:/gnuarmemb/bin/arm-none-eabi-gcc.exe
-- Using application from 'C:/Users/me/Repos/ncs/nrf/samples/nrf9160/spm'
Changed board to secure nrf9160_pca10090 (NOT NS)
USING OUT OF TREE BOARD
-- Loading C:/Users/me/Repos/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090.dts as base
-- Overlaying C:/Users/me/Repos/ncs/nrf/samples/nrf9160/spm/nrf9160_pca10090.overlay
Devicetree configuration written to C:/Users/me/Repos/myproject/build/spm/zephyr/include/generated/generated_dts_board.conf
Parsing Kconfig tree in C:/Users/me/Repos/ncs/zephyr/Kconfig
Loaded configuration 'C:/Users/me/Repos/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090_defconfig'
Merged configuration 'C:/Users/me/Repos/ncs/nrf/samples/nrf9160/spm/prj.conf'
Configuration saved to 'C:/Users/me/Repos/myproject/build/spm/zephyr/.config'
-- Using application from 'C:/Users/me/Repos/ncs/nrf/samples/bootloader'
Devicetree configuration written to C:/Users/me/Repos/myproject/build/b0/zephyr/include/generated/generated_dts_board.conf
Merged configuration 'C:/Users/me/Repos/ncs/nrf/samples/bootloader/prj.conf'
Configuration saved to 'C:/Users/me/Repos/myproject/build/b0/zephyr/.config'
CMake Error at C:/Users/me/Repos/ncs/nrf/subsys/bootloader/cmake/debug_keys.cmake:57 (message):
  Config points to non-existing PEM file 'priv.pem'
  C:/Users/me/Repos/ncs/nrf/subsys/bootloader/image/CMakeLists.txt:67 (include)
See also "C:/Users/me/Repos/myproject/build/CMakeFiles/CMakeOutput.log".
See also "C:/Users/me/Repos/myproject/build/CMakeFiles/CMakeError.log".
The priv.pem file is in the same directory as my prj.conf file. What am I doing wrong that the build tools can't find it?
  • You are correct, i haven't enabled MCUBoot boot, only secured boot was enabled
    # Bootloader
    the question is do we need mcuboot, can't b0+app(including spm) suffice? ya i do do agree the the application upgrade wont be possible if we dont have mcuboot.
    regards
    kk
  • That configuration is currently not supported. Is it so that you only want secure boot, no firmware upgrade functionality?
  • I do need firmware upgrade functionality, but if i start providing my self generated private key i end up in this booting issue.
    2020-10-13T11:26:59.824Z DEBUG modem << *** Booting Zephyr OS build v2.3.0-rc1-ncs1-3614-ga4ead9805140  ***
    2020-10-13T11:26:59.844Z DEBUG modem << Attempting to boot slot 0.
    2020-10-13T11:26:59.856Z DEBUG modem << Attempting to boot from address 0x8200.
    2020-10-13T11:26:59.860Z DEBUG modem << Firwmare has been invalidated: 0x91020000.
    2020-10-13T11:26:59.860Z DEBUG modem << Failed to validate, permanently invalidating!
    2020-10-13T11:26:59.860Z DEBUG modem << Attempting to boot slot 1.
    2020-10-13T11:26:59.861Z DEBUG modem << No fw_info struct found.
    2020-10-13T11:26:59.861Z DEBUG modem << No bootable image found. Aborting boot.
    Build log
    C:\Data\GIT\ncs\master\zephyr\samples\hello_world\build>ninja rom_report
    [0/1] Re-running CMake...
    Including boilerplate (Zephyr base (cached)): C:/Data/GIT/ncs/master/zephyr/cmake/app/boilerplate.cmake
    -- Application: C:/Data/GIT/ncs/master/zephyr/samples/hello_world
    -- Using NCS Toolchain 1.3.0 for building. (C:/Data/GIT/ncs/master/toolchain/cmake)
    -- Zephyr version: 2.4.0 (C:/Data/GIT/ncs/master/zephyr)
    -- Found west (found suitable version "0.7.3", minimum required is "0.7.1")
    -- Board: nrf9160dk_nrf9160ns
    -- Cache files will be written to: C:/Data/GIT/ncs/master/zephyr/.cache
    -- Found dtc: C:/Data/GIT/ncs/master/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found toolchain: gnuarmemb (C:/Data/GIT/ncs/master/toolchain/opt)
    -- Found BOARD.dts: C:/Data/GIT/ncs/master/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160ns.dts
    -- Generated zephyr.dts: C:/Data/GIT/ncs/master/zephyr/samples/hello_world/build/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: C:/Data/GIT/ncs/master/zephyr/samples/hello_world/build/zephyr/include/generated/devicetree_unfixed.h
    Parsing C:/Data/GIT/ncs/master/zephyr/Kconfig
    Loaded configuration 'C:/Data/GIT/ncs/master/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160ns_defconfig'
    Merged configuration 'C:/Data/GIT/ncs/master/zephyr/samples/hello_world/prj.conf'
    Configuration saved to 'C:/Data/GIT/ncs/master/zephyr/samples/hello_world/build/zephyr/.config'
    Kconfig header saved to 'C:/Data/GIT/ncs/master/zephyr/samples/hello_world/build/zephyr/include/generated/autoconf.h'
    Changed board to secure nrf9160dk_nrf9160 (NOT NS)
    === child image spm -  begin ===
    -- Application: C:/Data/GIT/ncs/master/nrf/samples/spm
    -- Found BOARD.dts: C:/Data/GIT/ncs/master/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160.dts
    -- Found devicetree overlay: C:/Data/GIT/ncs/master/nrf/samples/spm/nrf9160dk_nrf9160.overlay
    -- Generated zephyr.dts: C:/Data/GIT/ncs/master/zephyr/samples/hello_world/build/spm/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: C:/Data/GIT/ncs/master/zephyr/samples/hello_world/build/spm/zephyr/include/generated/devicetree_unfixed.h
    Loaded configuration 'C:/Data/GIT/ncs/master/zephyr/samples/hello_world/build/spm/zephyr/.config'
    No change to configuration in 'C:/Data/GIT/ncs/master/zephyr/samples/hello_world/build/spm/zephyr/.config'
    No change to Kconfig header in 'C:/Data/GIT/ncs/master/zephyr/samples/hello_world/build/spm/zephyr/include/generated/autoconf.h'
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/Data/GIT/ncs/master/zephyr/samples/hello_world/build/spm
    === child image spm -  end ===
    === child image b0 -  begin ===
    -- Application: C:/Data/GIT/ncs/master/nrf/samples/bootloader
    -- Generated zephyr.dts: C:/Data/GIT/ncs/master/zephyr/samples/hello_world/build/b0/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: C:/Data/GIT/ncs/master/zephyr/samples/hello_world/build/b0/zephyr/include/generated/devicetree_unfixed.h
    Loaded configuration 'C:/Data/GIT/ncs/master/zephyr/samples/hello_world/build/b0/zephyr/.config'
    No change to configuration in 'C:/Data/GIT/ncs/master/zephyr/samples/hello_world/build/b0/zephyr/.config'
    No change to Kconfig header in 'C:/Data/GIT/ncs/master/zephyr/samples/hello_world/build/b0/zephyr/include/generated/autoconf.h'
    CMake Warning at ../../subsys/bootloader/CMakeLists.txt:21 (message):
            --- WARNING: When using the immutable bootloader on  ---
            --- this SoC, the UICR must be erased when flashing. ---
            --- E.g. by calling 'west flash --erase'             ---
    CMake Warning at C:/Data/GIT/ncs/master/zephyr/kernel/CMakeLists.txt:54 (message):
      Single threaded mode (CONFIG_MULTITHREADING=n) is deprecated
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/Data/GIT/ncs/master/zephyr/samples/hello_world/build/b0
    === child image b0 -  end ===
    === child image mcuboot -  begin ===
    -- Application: C:/Data/GIT/ncs/master/bootloader/mcuboot/boot/zephyr
    -- Found devicetree overlay: C:/Data/GIT/ncs/master/bootloader/mcuboot/boot/zephyr/dts.overlay
    -- Generated zephyr.dts: C:/Data/GIT/ncs/master/zephyr/samples/hello_world/build/mcuboot/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: C:/Data/GIT/ncs/master/zephyr/samples/hello_world/build/mcuboot/zephyr/include/generated/devicetree_unfixed.h
    Parsing C:/Data/GIT/ncs/master/bootloader/mcuboot/boot/zephyr/Kconfig
    Loaded configuration 'C:/Data/GIT/ncs/master/zephyr/samples/hello_world/build/mcuboot/zephyr/.config'
    No change to configuration in 'C:/Data/GIT/ncs/master/zephyr/samples/hello_world/build/mcuboot/zephyr/.config'
    No change to Kconfig header in 'C:/Data/GIT/ncs/master/zephyr/samples/hello_world/build/mcuboot/zephyr/include/generated/autoconf.h'
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/Data/GIT/ncs/master/zephyr/samples/hello_world/build/mcuboot
    MCUBoot bootloader key file: C:/Data/GIT/ncs/master/bootloader/mcuboot/root-rsa-2048.pem
    === child image mcuboot -  end ===
    CMake Warning at C:/Data/GIT/ncs/master/nrf/cmake/mcuboot.cmake:115 (message):
            --- WARNING: Using default MCUBoot key, it should not ---
            --- be used for production.                           ---
      C:/Data/GIT/ncs/master/bootloader/mcuboot/zephyr/CMakeLists.txt:1 (include)
    -- Configuring done
    -- Generating done
    [0/157] Performing build step for 'spm_subimage'
    [149/153] Linking C executable zephyr\zephyr_prebuilt.elf
               FLASH:       32256 B        48 KB     65.63%
                SRAM:        5520 B        64 KB      8.42%
            IDT_LIST:          40 B         2 KB      1.95%
    [153/153] Linking C executable zephyr\zephyr.elf
    [2/153] Performing build step for 'b0_subimage'
    [105/109] Linking C executable zephyr\zephyr_prebuilt.elf
               FLASH:       26200 B        32 KB     79.96%
                SRAM:       38824 B        64 KB     59.24%
    [109/109] Linking C executable zephyr\zephyr.elf
    [129/153] Linking C executable zephyr\zephyr_prebuilt.elf
               FLASH:       15396 B     392704 B      3.92%
                SRAM:        4040 B       128 KB      3.08%
            IDT_LIST:          56 B         2 KB      2.73%
    [132/151] Creating public key from private key used for signing
    [139/151] Performing build step for 'mcuboot_subimage'
    [118/122] Linking C executable zephyr\zephyr_prebuilt.elf
               FLASH:       40588 B        48 KB     82.58%
                SRAM:       24724 B        64 KB     37.73%
            IDT_LIST:          88 B         2 KB      4.30%
    [122/122] Linking C executable zephyr\zephyr.elf
    [144/149] Creating signature of application
    [145/149] Creating validation for zephyr.hex, storing to
    [148/149] cmd.exe /C "cd /D C:\Data\GIT\ncs\master\zephyr\samples\hello_world\build\...t.py --input C:/Data/GIT/ncs/master/zephyr/samples/hello_world/build/partitions.yml"
     (0x100000 - 1024kB):
    +---0x0: b0 (0x8000)-----------------------+
    | 0x0: b0_image (0x8000)                   |
    +---0x8000: s0 (0xc200)--------------------+
    | 0x8000: s0_pad (0x200)                   |
    +---0x8200: s0_image (0xc000)--------------+
    | 0x8200: mcuboot (0xc000)                 |
    | 0x14200: EMPTY_0 (0xe00)                 |
    +---0x15000: s1 (0xc200)-------------------+
    | 0x15000: s1_pad (0x200)                  |
    | 0x15200: EMPTY_1 (0x6e00)                |
    | 0x1c000: s1_image (0xc000)               |
    +---0x28000: mcuboot_primary (0x6c000)-----+
    | 0x28000: mcuboot_pad (0x200)             |
    +---0x28200: mcuboot_primary_app (0x6be00)-+
    +---0x28200: spm_app (0x6be00)-------------+
    | 0x28200: spm (0xc000)                    |
    | 0x34200: app (0x5fe00)                   |
    | 0x94000: mcuboot_secondary (0x6c000)     |
    [148/149] cmd.exe /C "cd /D C:\Data\GIT\ncs\master\zephyr\samples\hello_world\build\...d/build --json C:/Data/GIT/ncs/master/zephyr/samples/hello_world/build/rom.json rom"
      File "C:/Data/GIT/ncs/master/zephyr/scripts/footprint/size_report", line 643, in <module>
        main()
      File "C:/Data/GIT/ncs/master/zephyr/scripts/footprint/size_report", line 605, in main
        print("WARN: Symbol '{0}' is not in RAM or ROM".format(sym['name']))
    TypeError: string indices must be integers
    FAILED: zephyr/cmake/reports/CMakeFiles/rom_report
    cmd.exe /C "cd /D C:\Data\GIT\ncs\master\zephyr\samples\hello_world\build\zephyr\cmake\reports && C:\Data\GIT\ncs\master\toolchain\opt\bin\python.exe C:/Data/GIT/ncs/master/zephyr/scripts/footprint/size_report -k C:/Data/GIT/ncs/master/zephyr/samples/hello_world/build/zephyr/zephyr.elf -z C:/Data/GIT/ncs/master/zephyr -o C:/Data/GIT/ncs/master/zephyr/samples/hello_world/build --json C:/Data/GIT/ncs/master/zephyr/samples/hello_world/build/rom.json rom"
    C:\Data\GIT\ncs\master\zephyr\samples\hello_world\build>west flash
    # b0 Bootloader
    CONFIG_SB_SIGNING_KEY_FILE="C:/Data/GIT/ncs/master/zephyr/samples/hello_world/priv.pem"
    # MCUboot as upgradable bootloader
    CONFIG_BOOTLOADER_MCUBOOT=y
