Thingy 91 problems in nRF cloud and with connecting to network
I am sorry but this is totally BS. I just got the Thingy 91 and it does only problems...
I have no problem using a full day on getting stuff like that to work, but please don't put videos of some idiots getting this to work in 2 min, I feel like I am a totally moran not getting it to work. I strongly recommend removing all video guides that simply tell a lie about this dev board...
For my question:
1. I simply can get it to connect with the provided SIM card. I am in Denmark so it should work, it simply blinks all the color all the time and does not connect. (I have used other NBiot in my house, so I know it should work)
2. Even after doing all this *** with updating to the long AT command in order to put a new JSON certificate and so on I still get this shitty message on nRF cloud that the device can not be found! What to do? Do I have to get Thingy 91 to connect 1st?
I have worked with other NBiot modules, such as SIMcom from China and I was really hoping for some quality from Scandinavian when buying this module, but not only that it does not work, it is totally false advertised! I feel violated.
Please help.
  • Hi Noam,
    I am sorry to hear that you had a bad experience when getting started with the Thingy:91.
    However, that does not justify the profound language in your post, please try to avoid that in your answers.
    I can understand that you are having issues getting connected to the NB-IoT network, this is because the iBasis SIM card does not yet support this network in your region.
    I recommend that you acquire a local IoT SIM card from one of your major operators that supports LTE-M or NB-IoT.
    I recommend that you connect a USB to Thingy:91 and open the LTE Link Monitor in nRF Connect for Desktop to use it as a serial output terminal:
    (This will help you to see the different console outputs from the application. e.g. you may see why you cannot get a connection etc.)
    Please uncheck "Automatic requests" and "Auto device/port filter":
    Turn OFF the Thingy:91 and turn it ON.
    Then select the correct port:
    You should now be able to get out some log information from the application:
    e.g.
    You need to be connected to a network to be able to pair the Thingy:91 to nRF cloud as well.
    (That is the reason you get the error code on the website.)
    Martin L.
